2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-05-02mkimage: fix argument parsing on BSD systemsAndreas Bießmann
The getopt(3) optstring '-' is a GNU extension which is not available on BSD systems like OS X. Remove this dependency by implementing argument parsing in another way. This will also change the lately introduced '-b' switch behaviour. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-02arch/arm/imx-common/Makefile: Update u-boot.uim MKIMAGEFLAGSTom Rini
We need to be passing -T firmware here and aren't. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-02fs: ext4: fix symlink read functionRonald Zachariah
The function ext4fs_read_symlink was unable to handle a symlink which had target name of exactly 60 characters. Signed-off-by: Ronald Zachariah <rozachar@cisco.com> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Rini <trini@konsulko.com>
2016-05-02Revert "rockchip: rk3288: correct sdram setting"Vagrant Cascadian
This reverts commit b5788dc0dd9570e98552833767f4373db965985d. Ram size is incorrectly reported as 512MB on a firefly-rk3288 board with 2GB of ram. Reverting this patch displays the full amount of ram. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-02Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-05-02Revert "omap3: Use raw SPL by default for mmc1"Tom Rini
Unfortunately with this change we now are unable to do FS mode boots from MMC1 as with the way the code works today we will always load and assume that the hard-coded raw location contains U-Boot. Further, we cannot fix this by just changing other logic to try FS-then-RAW as it would also make us have to ignore what order the ROM is telling us to try. This reverts commit 22d90d560a2b01c47f180e196e6c6485eb8e65db. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-02Revert "ti_armv7_common.h: Fix U-Boot location on eMMC"Tom Rini
We cannot change the long standing hard-coded offset for raw boot mode for everyone to accommodate how Android expects things to be done here. This reverts commit ef5ebe951bec72631cdbc7cef9079e6c684e5d0b. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-01ARM: uniphier: move pin-mux code into pin_init functionMasahiro Yamada
The code in uniphier_sld3_sbc_init() is pin-muxing, so it would be a better fit in uniphier_sld3_early_pin_init(). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-01ARM: uniphier: allow to use System Bus for ROM boot mode of PH1-LD20Masahiro Yamada
The System Bus is not available by default on the ROM boot mode of PH1-LD20. To use devices connected to the System Bus, such as the Micro Support Card, it is necessary to set up pin-muxing and some System Bus Controller register. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-01ARM: uniphier: enable Peripherl clock to use UART in SPLMasahiro Yamada
This is needed to use UART on SPL. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-01ARM: uniphier: fix boot mode table of PH1-LD20Masahiro Yamada
PH1-LD20 does not have the dedicated boot swap select latch. Instead, it is controlled from the boot mode select. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-28Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2016-04-28Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-04-28drivers/video/am335x-fb: Properly point framebuffer behind paletteMartin Pietryka
The DMA was outputting the palette on the screen because the base for the DMA was not after the palette. In addition to that, the ceiling was also too high, this led that the output on the screen was shifted. NOTE: According to the TRM, even in 16/24bit mode a palette is required in the first 32 bytes of the framebuffer. See also: https://e2e.ti.com/support/arm/sitara_arm/f/791/p/234967/834483#834483 "In this mode, the LCDC will assume all information is data and thus you need to ensure that the DMA points to the first pixel of data and not the first entry in the frame buffer which is the beginning of the 512 byte palette." Signed-off-by: Martin Pietryka <martin.pietryka@chello.at> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2016-04-28drivers/video/am335x-fb: Add support for 16bpp formatMartin Pietryka
To support 16bpp we just need to change the raster_ctrl register accordingly. Also 32bpp mode should work as well, but was not tested. According to the TRM the uppermost byte will be ignored when LCD_TFT_24BPP_UNPACK is set. The switch logic is based on the Linux kernel tilcdc driver: drivers/gpu/drm/tilcdc/tilcdc_crtc.c: lines 407 through 419 (kernel was checked out at commit: bcc981e9ed8) Signed-off-by: Martin Pietryka <martin.pietryka@chello.at> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2016-04-27omap3: Reduce logic/overo SPL max image sizeTom Rini
While the OMAP3 has 64KiB of SRAM, per the TRM the download area is only from 0x40200000 to 0x4020F000 and exceeding that will cause failure to boot. Further, we need to make sure that we don't run into SRAM_SCRATCH_SPACE_ADDR as once SPL is running we will write values there and would corrupt our running image. Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-27sunxi: Enable LDO3 at 3.3V on A13-OLinuXino boardHans de Goede
LDO3 is used for the VGA output, this fixes a regression where the VGA output on these boards would no longer work. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-27sunxi: mctl_mem_matches: Add missing memory barrierHans de Goede
We are running with the caches disabled when mctl_mem_matches gets called, but the cpu's write buffer is still there and can still get in the way, add a memory barrier to fix this. This avoids mctl_mem_matches always returning false in some cases, which was resulting in: U-Boot SPL 2015.07 (Apr 14 2016 - 18:47:26) DRAM: 1024 MiB U-Boot 2015.07 (Apr 14 2016 - 18:47:26 +0200) Allwinner Technology CPU: Allwinner A23 (SUN8I) DRAM: 512 MiB Where 512 MiB is the right amount, but the DRAM controller would be initialized for 1024 MiB. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-26ARM64: zynqmp: Cleanup config file after CMD moveMichal Simek
The patch: "configs: Re-sync almost all of cmd/Kconfig" (sha1: 78d1e1d0a157c8b48ea19be6170b992745d30f38) doesn't remove empty if-endif. This patch is fixing it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-26ARM: uniphier: revive some commands lost by Kconfig re-syncMasahiro Yamada
The recently added uniphier_ld20_defconfig missed the tree-wide re-sync by commit 89cb2b5f8be4 ("configs: Re-sync with cmd/Kconfig"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-26Merge branch 'master' of git://git.denx.de/u-boot-samsungTom Rini
2016-04-25Prepare v2016.05-rc3Tom Rini
2016-04-25pico-imx6ul: Update the defconfigTom Rini
The defconfig/config.h file were merged but were already out of sync with mainline. This brings them further into line now. Cc: Richard Hu <richard.hu@technexion.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2016-04-25drivers/video/am335x-fb: Fix bits for LCD_PALMODE_RAWDATA definitionMartin Pietryka
According to the TRM you have to set bits [21:20] to 0b10 for RAW mode, so (0x10 << 20) is obviously wrong here. Signed-off-by: Martin Pietryka <martin.pietryka@chello.at>
2016-04-25pci: Device scanning range fixYoshinori Sato
The terminal condition in the area where a PCI device is scanned is wrong, and 1f.7 isn't scanned. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-04-25mmc: sdhci: add const qualifier to the name of struct sdhci_hostMasahiro Yamada
This allows to drop annoying (char *) casts when setting the host name of struct sdhci_host. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-25ARM: DRA7: Add ABB setup for all domainsNishanth Menon
ABB should be initialized for all required domains voltage domain for DRA7: IVA, GPU, EVE in addition to the existing MPU domain. If we do not do this, kernel configuring just the frequency using the default boot loader configured voltage can fail on many corner lot units and has been hard to debug. This specifically is a concern with DRA7 generation of SoCs since other than VDD_MPU, all other domains are only permitted to setup the voltages to required OPP only at boot. Reported-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-25ARM: OMAP5: Enable ABB configuration for MM voltage domainNishanth Menon
Since we setup the voltage and frequency for the MM domain, we *must* setup the ABB configuration needed for the domain as well. If we do not do this, kernel configuring just the frequency using the default boot loader configured voltage can fail on many corner lot units. Reported-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-25ARM: OMAP5/DRA7: Move ABB TXDONE mask to voltage structureNishanth Menon
ABB TX_DONE mask will vary depending on ABB module. For example, 3630 never had ABB on IVA domain, while OMAP5 does use ABB on MM domain, DRA7 has it on all domains with the exception of CORE, RTC. Hence, move the txdone mask definition over to structure describing voltage domain. Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-25ARM: OMAP5/DRA7: Get rid of control_std_fuse_opp_vdd_mpu_2Nishanth Menon
This information is already available under vcores->volts.efuse.reg. There is no reason for duplicating the information since AVS Class 0 definitions are common for OMAP5 and DRA7 and defined with STD_FUSE_OPP_* macros. This allows a central location of defining the ABB and voltage definitions especially since they are reused. This also makes it simpler to prevent mistakes involved when changing the boot OPP for the device. Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-25common/dlmalloc.c: Delete content that was moved to malloc.hRobert P. J. Day
Remove several hundred lines of content surrounded by: #if 0 /* Moved to malloc.h */ ... moved stuff ... #endif /* 0 */ /* Moved to malloc.h */ Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25spl: spl_mmc: Disambiguate error messageFabio Estevam
The error message "spl: mmc block read error" may come from two different functions, so we should better annotate the function name where the error comes from to help debugging. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hikey: Simplify README instructions.Peter Griffin
This patch updates and simplifies the hikey README. The old instructions were hard to follow, and convoluted. This patch also updates the link to the mcuimage.bin which was outdated. Using an outdated mcuimage.bin results in the additional a53 cores not coming online when the kernel issues PSCI requests to arm trusted firmware (ATF). Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: Align memory node with upstream kernelPeter Griffin
The memory node gets automatically generated by U-Boot in arch_fixup_fdt(), before passing control to the kernel using U-Boots representation of the dram banks. However the upstream kernel uses the memory node to carve-out regions of RAM for various purposes. To make this work without changing arch_fixup_fdt() which will effect many platforms we replicate the upstream memory node layout using the dram banks. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: dts: Add pl011 additional clock binding.Peter Griffin
This is a binding which only exists in U-Boot, but is required to get working serial in U-Boot. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: Implement reset_cpu() for hikey.Peter Griffin
This allows the reset command to reset the board from u-boot. => reset resetting ... INFO: BL1: 0xf9810000 - 0xf9818000 [size = 32768] NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.1(debug):7fb9b0e NOTICE: BL1: Built : 17:06:41, Apr 19 2016 Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: Enable OF_CONTROL for hikey board.Peter Griffin
Currently only the serial pl01x driver is using DT, and the other drivers still use platform data but as more DT lands in the upstream kernel the aim is to migrate the other drivers over to DT as well to have a fully DT configured hikey u-boot. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25MAINTAINERS: Add myself as maintainer for hikeyPeter Griffin
This patch adds myself as maintainer for the hikey U-Boot port. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: Add hikey & hi6220 dts from v4.6-rc3.Peter Griffin
Import the upstream kernel dts into U-Boot. Currently only serial is supported, but a lot more DT changes are queued for v4.7. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25sf: fix timebase data type in _wait_ready()Stephen Warren
get_timer() returns an unsigned 64-bit value, but is currently assigned to a signed 32-bit variable. Due to sign extension and data truncation, this causes the timeout loop in spi_flash_cmd_wait_ready() to immediately (and incorrectly) fire for about 50% of all time values, based on whether bit 31 is set. In sandbox at least, this causes the test to pass or fail based on system uptime, as opposed to time since the U-Boot binary was started. Fixes: 4efad20a1751 ("sf: Update status reg check in spi_flash_cmd_wait_ready") Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-25ti_armv7_common.h: Fix U-Boot location on eMMCSemen Protsenko
According to common eMMC partition table for Android boot (see PARTS_DEFAULT definition in include/configs/dra7xx_evm.h), "bootloader" partition (where u-boot.img is stored) starts at 256 KiB. Which is equal to 512 sectors (as 1 MMC sector size is 512 bytes). This patch fixes CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR constant so that it points to correct address of "bootloader" partition and SPL is able to read, parse and run u-boot.img correctly. This change was originally done as part of patch [1] in omapzoom u-boot. Without this patch, SPL fails to parse U-Boot header with next error: mkimage signature not found - ih_magic = 4814325a While at it, also fix U-Boot partition size, which is 384 KiB (as stated in include/configs/dra7xx_evm.h). [1] http://omapzoom.org/?p=repo/u-boot.git;a=commit;h=742b82d0c0aa0ed8096c2225a00e9f350212efa9 Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25cmd: Kconfig: Add a Kconfig options for a few CMDDinh Nguyen
Add the following CMD options to Kconfig: CMD_BOOTZ CMD_ASKENV CMD_GREPENV CMD_USB_MASS_STORAGE CMD_FAT CMD_MII CMD_CACHE CMD_DFU CMD_EXT2 CMD_EXT4 CMD_EXT4_WRITE CMD_FS_GENERIC CMD_MMC Signed-off-by: Dinh Nguyen <dinguyen@kernel.org> [trini: Don't make CMD_USB_MASS_STORAGE nor CMD_DFU depend on CMD_USB] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25configs: Re-sync CONFIG_USB_MUSB_HOSTTom Rini
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to the defconfig files. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-uniphierTom Rini
