HOSTCFLAGS_autoconf.mk.dep was added by commit 422322f
but it has never been used.
Cc: Vadim Bendebury <vbendeb@chromium.org>
are passed
Lack of this check resulted in a data abort when CPU tried to execute the
following command (without further mandatory input): 'pmic MAX77686_PMIC'.
Only the 'pmic list' command requires one passed parameter.
Other require at least two valid parameters for correct operation.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Commit 6825a95 (kbuild: use Linux Kernel build scripts)
changed the behavior of linkage when USE_PRIAVATE_LIBGCC
is defined as "yes".
(It dropped arch/arm/lib/eabi_compat.o from the
target library.)
Affected boards are all Tegra boards.
This commit gets back the same behavior as before Kbuild series.
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
The calloc() call was allocating space for the sizeof the struct
pointer rather than for the struct contents.
Besides, since this buffer is passed to mmc for writing and some
platforms may use cache, the legacy_mbr struct should be cache-aligned.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Fix the following checkpatch warning:-
WARNING: externs should be avoided in .c files
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
compare two U-Boot Environment variables with itest.s, example:
=> print tmp ver
tmp=U-Boot 2013.10-g75e
ver=U-Boot 2013.10-g75eb4bc (Jan 21 2014 - 10:35:39)MPC83XX
=> print check_ub_ver
check_ub_ver=if itest.s \${tmp} == \${ver}; then echo equal; else echo diff ;fi
=> run check_ub_ver
diff
=> setenv tmp U-Boot 2013.10-g75eb4bc (Jan 21 2014 - 10:35:39)MPC83XX
=> print tmp ver
tmp=U-Boot 2013.10-g75eb4bc (Jan 21 2014 - 10:35:39)MPC83XX
=> run check_ub_ver
equal
check with this ubi command, if a UBI volume with "volumename"
exists in current ubi device.
There are some entries which produce the same binaries:
- ep8248E is equivalent to ep8248
- MPC8360ERDK_66 is equivalent to MPC8360ERDK
- Adder87x/AdderUSB is equivalent to Adder
- EVB64260_750CX is equivalent to EVB64260
I also notice
- Lite5200 is equivalent to icecube_5200
- Lite5200_LOWBOOT is equivalent to icecube_5200_LOWBOOT
- Lite5200_LOWBOOT08 is equivalent to icecube_5200_LOWBOOT08
But I am keeping them.
(Wolfgang suggested to do so because Lite5200* are referenced
in misc documents.)
The 8th field of boards.cfg takes the form:
<board config name>[:comma separated config options]
We should describe explicitely the 8th field only when it is necessary
to do so.
Specify "-" in the 8th field if it is the same as 7th field.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
In an ext4 filesystem, the inode corresponding to a file has a 60-byte
area which contains an extent header structure and up to 4 extent
structures (5 x 12 bytes).
For files that need more than 4 extents to be represented (either files
larger than 4 x 128MB = 512MB or smaller files but very fragmented),
ext4 creates extent index structures. Each extent index points to a 4KB
physical block where one extent header and additional 340 extents could
be stored.
The current u-boot ext4 code is very inefficient when it tries to load a
file which has extent indexes. For each logical file block the code will
read over and over again the same blocks of 4096 bytes from the disk.
Since the extent tree in a file is always the same, we can cache the
extent structures in memory before actually starting to read the file.
This patch creates a simple linked list of structures holding information
about all the extents used to represent a file. The list is sorted by
the logical block number (ee_block) so that we can easily find the
proper extent information for any file block.
Without this patch, a 69MB file which had just one extent index pointing
to a block with another 6 extents was read in approximately 3 minutes.
With this patch applied the same file can be read in almost 20 seconds.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
This patch fixes the following warning messages coming out of
'drivers/net/smc91111.h' when compiled for 'vexpress_aemv8a':
warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Currently this issue seems to surface when SMSC is compiled for 64-bit
ARMv8 platforms, so the change is protected under CONFIG_ARM64, so that
it doesn't break other existing platforms.
In addition this patch tries to fix some checkpatch errors and warnings
(others related to camel-casing and volatile usage will be addressed
by a later patch).
This fix has been tested on both ARMv8 foundation model v1 and v2.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Reported-by: Nishanth Menon <nm@ti.com>
The pattern rule "MLO*" can delete both MLO and MLO.byteswap.
U-Boot supports various boot images for various SoCs.
It is annoying to modify .gitignore file every time
we add/delete boot images.
Fortunately, there is a simple rule:
Those with file name prefix "u-boot" at the top directory
are all generated files.
For aarch64, unsigned long is 64-bit data. Memory commands should be fixed
with u32 for 32-bit address access. To be clear, ushort is replace with
u16, u_char is replaced with u8.
Signed-off-by: York Sun <yorksun@freescale.com>
Acked-by: Wolfgang Denk <wd@denx.de>
The directory name from an fdtdir directive in a PXE config file should
always be pre-pended to the DTB filename; it shouldn't matter whether
the DTB filename came from the $fdtfile environment variable, or whether
it was constructed dynamically from ${soc}-${board}.dtb. Fix the code to
always prepend the directory name.
Reported-by: Dennis Gilmore <dennis@ausil.us>
Fixes: c61d94d86035 ("pxe: implement fdtdir extlinux.conf tag")
Reviewed-by: Dennis Gilmore <dennis@ausil.us>
Tested-by: Dennis Gilmore <dennis@ausil.us>
This patch deal with error message of mtest command.
When test failed, the mtest command will output error information
that include memory address and value. But the address field is
not correct or misleading.
Signed-off-by: David Feng <fenghua@phytium.com.cn>
This function has been around for powerpc. It is used for systems with
memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory,
this feature can limit U-boot to one block without going over the limit.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Freescale LayerScape SoCs support controller interleaving on 256 byte size.
This interleaving is mandoratory.
DDR base address has been the same from the view of core and DDR
controllers. This has changed for Freescale ARM-based SoCs. Controllers
setup DDR memory in a contiguous space and cores view it at separated
locations.
endian
Initially it was believed the DDR controller on Freescale ARM would have
big endian. But some platform will have little endian.
do_bootm_standanlone() calls ntohl(images->ep) which is wrong because
endianess conversion has already been done:
do_bootm()
\-do_bootm_states()
+-bootm_find_os()
| \-images.ep = image_get_ep();
| \-uimage_to_cpu(hdr->ih_ep);
\-boot_selected_os()
\-do_bootm_standanlone()
Without this conversion the code works correctly at least on AT91SAM9G45.
On big endian systems there should be no difference after applying this
patch because uimage_to_cpu(x) and ntohl(x) both expand to 'x'.
Signed-off-by: Christian Eggers <ceggers@gmx.de>
Use default_serial_puts() instead of duplicating the implementation.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
We have an unused FAT implementation in fs/fdos, remove.
In case of little-endian ARC700 instructions (which may include target
address) are encoded as middle-endian. That's why it's required to swap
bytes after read and ten right before write back.
But in case of big-endian ARC700 instructions are encoded as a plain
big-endian. Thus no need for byte swapping.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Francois Bedard <fbedard@synopsys.com>
cc: Noam Camus <noamc@ezchip.com>
Proper spelling of the boad marketing name is with upper case.
So changing it from lower case to upper case here.
With accepted change to DW GMAC driver -
92a190aaab3536d695c51e0739f925910eb49889 (net/designware - switch driver
to phylib usage) we need to update this board because
"designware_initialize" now accepts only 2 parameters instead of 4.
Cc: Vineet Gupta <vgupta@synopsys.com>
This is required for proper functionality on big-endian targets.
Memory-mapped registres of ARC UART are not 32-bit words but 8-bit bytes
so on little-endian target either acessor (_l or _b) works fine.
On big-endian only _b accessors works as expected.
Cc: Noam Camus <noamc@ezchip.com>
Explanation is in in-lined comment.
With d6a320d we moved some clock externs out of blackfin_local.h and
into clock.h but now need to include <asm/clock.h> in more drivers to
avoid warnings.
Cc: Sonic Zhang <sonic.zhang@analog.com>
The commit:
"EXT4: Fix number base handling of "ext4write" command"
SHA1: f7740f7712b8638f08b83a7e5d00bc1d6bb086a9
Cleaned up the ext4write command format.
This commit shall be regarded as a follow up, since the DFU subsystem is
using those commands for its normal operation.
Commit 5ab502cb gathered all device tree sources
to arch/$(ARCH)/dts/.
So tegra124-venice2.dts also must go to arch/arm/dts directory
to build venice2 board.
(Commit 5ab502cb had been posted before venice2 board support
was merged. So an unvisible conflict happened.)
Makefile
drivers/net/npe/Makefile
These two conflicts arise from commit 0b2d3f20
("ARM: NET: Remove the IXP NPE ethernet driver") and are
resolved by deleting the drivers/net/npe/Makefile file
and removing the CONFIG_IXP4XX_NPE line from Makefile.
This file was only required for compilation of designware_i2c driver.
Since explicit inclusion of "hardware.h" is now removed from the driver
we may safely remove this empty header as well.
Cc: Stefan Roese <sr@denx.de>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Armando Visconti <armando.visconti@st.com>
As soon as all boards have their CONFIG_SYS_I2C_BASE defined in
configuration files instead of "asm/arch/hardware.h" it's safe to remove
the inclusion in question and make driver platform-independent.
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include
<arch/hardware.h> which other platforms may not have at all.
It's always good to have a driver platform-independent.
Adds support for set-speed on the OMAP24xx I2C Adapter.
Changes to omap24_i2c_write(...) for polling ARDY Bit from IRQ-Status.
Otherwise on a subsequent call the transfer of last byte from the
predecessor is aborted and therefore lost. For exmaple when
i2c_write(...) is followed by a i2c_setspeed(...) (which has to
deactivate and activate master for changing psc,...).
Minor cosmetical changes.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Make sure the I2C write queue is empty before leaving the mxs_i2c_write().
If we start and I2C write and only wait for ACK, the MXS I2C IP block may
enter next operation while still processing the write aftermath internally.
This will in turn disrupt one or more subsequent transfer(s).
A testcase for this issue is as such. This testcase is also interesting because
the first I2C_WRITE which becomes disruptive happens in the 'i2c read' command.
The 'i2c read' command first uses I2C_WRITE to send I2C address of the chip and
then uses I2C_READ to read data from the chip. After this command completes, the
'i2c probe' will use sequence of I2C_WRITE commands to probe the I2C bus. The
problem is that the first I2C_WRITE disrupted the I2C IP block operation and
this sideeffect propagates all the way to this next I2C_WRITE used by the 'i2c
probe' call. The result is the 'i2c probe' receives an ACK on I2C address 0x00,
even if this ACK was owned by the previous I2C_WRITE operation. Note that the
'i2c read' command must read from a valid I2C chip address.
Wrong:
> i2c probe
Valid chip addresses: 50 51
> i2c read 0x50 0x0.2 0x10 0x42000000
> i2c probe
Valid chip addresses: 00 50 51
With this patch
> i2c probe
> i2c probe
Cc: Fabio Estevam <festevam@gmail.com>
Enhance the DesignWare I2C driver to support address length more
than 1 byte. This enhancement is required as some I2C slave
device such as EEPROM chip might have 16 bit address byte.
Signed-off-by: Chin Liang See <clsee@altera.com>
Acked-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
cc: Armando Visconti <armando.visconti@st.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
add support for bootcounter on an i2c device. And add a
README for all bootcounter options.
The ADI twi peripheral is not binding to Blackfin processor only.
Access i2c registers by standard io functions.
Fix coding style.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Change to a generic name.
Initialize the second i2c controller.
Signed-off-by: Michael Burr <michael.burr@logicpd.com>
Fixed bug with alen == 0 in 'i2c_write', 'i2c_read'
Further minor corrections:
- Write 'address' register before 'data' register.
- Write 'transfer_size' register before 'address' register.
In Kbuild, every makefile must have non-empty obj- or obj-y.
Otherwise, built-in.o will not be created and the link stage
will fail.
