2005-08-10 | Add configuration for IFM SPI eval board | Wolfgang Denk | |
2005-08-10 | Fix CompactFlash problem on HMI1001 board | Wolfgang Denk | |
2005-08-09 | Make new "mtdparts" code build with older compilers | Wolfgang Denk | |
Patch by Andrea Scian, 09 Aug 2005 | |||
2005-08-09 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-09 | Fix compiler warnings with older GCC versions | Wolfgang Denk | |
2005-08-08 | Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux) | Stefan Roese | |
Patch by Stefan Roese, 08 Aug 2005 | |||
2005-08-08 | Add common (with Linux) MTD partition scheme and "mtdparts" command | Wolfgang Denk | |
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning. | |||
2005-08-08 | Fix build problems for PM856 Board | Wolfgang Denk | |
2005-08-08 | Fix sign extension bug in 'fpga loadb' command; | Wolfgang Denk | |
make 'fpga loadb' always print the file header info Patch by Andrew Dyer, 11 Jan 2005 | |||
2005-08-07 | Fix errors that occur when accessing SystemACE CF | Wolfgang Denk | |
Patch by Jeff Angielski, 09 Jan 2005 | |||
2005-08-06 | Document switching between U-Boot and PlanetCore on RPXlite | Wolfgang Denk | |
by Sam Song, 24 Dec 2004 | |||
2005-08-06 | Fix PowerQUICC II mask detection. | Wolfgang Denk | |
Patch by Eugene Surovegin, 20 Dec 2004 | |||
2005-08-06 | Add support for Altera NIOS DK1C20 board | Wolfgang Denk | |
Patch by Shlomo Kut, 13 Dec 2004 | |||
2005-08-06 | Add support for ep8248 board | Wolfgang Denk | |
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup. | |||
2005-08-06 | Fix baudrate setting for KGDB on MPC8260 | Wolfgang Denk | |
Patch by HoJin, 11 Dec 2004 | |||
2005-08-06 | Fix 'mii help' text formatting | Wolfgang Denk | |
Patch by Cory Tusar, 10 Dec 2004 | |||
2005-08-06 | Fix return code of NFS command | Wolfgang Denk | |
Patch by Hiroshi Ito, 11 Dec 2004 | |||
2005-08-06 | Fix typo | Wolfgang Denk | |
2005-08-06 | Fix compiler warnings in cpu/ppc4xx/usbdev.c | Wolfgang Denk | |
Patch by Steven Blakeslee, 04 Aug 2005 | |||
2005-08-05 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/jon_loeliger | Wolfgang Denk | |
2005-08-05 | Fix compiler warnings | Wolfgang Denk | |
2005-08-05 | Add support for MicroSys PM856 board | Wolfgang Denk | |
Patch by Josef Wagner, 03 Aug 2005 | |||
2005-08-05 | Minor fixes to PM854 board | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-05 | Fix compile problem in cmd_flash.c | Wolfgang Denk | |
Patch by Teun Grinwis, 05 Aug 2005 | |||
2005-08-04 | Default 8349ADS CONFIG_PCI off for now. | Jon Loeliger | |
Real support for PCI comes in a follow-up patch. | |||
2005-08-04 | Adjust configuration of XENIAX board | Wolfgang Denk | |
(chip select and GPIO required for USB operation) | |||
2005-08-04 | Add support for AMCC Bamboo PPC440EP eval board | Stefan Roese | |
Patch by Stefan Roese, 04 Aug 2005 | |||
2005-08-04 | Fix typos in cpu/85xx/start.S which caused DataTLB exception to be | Wolfgang Denk | |
routed to the Watchdog handler Patch by Eugene Surovegin, 18 Jun 2005 | |||
2005-08-04 | (re)enabled scsi commands do_scsi() and do_scsiboot() | Wolfgang Denk | |
Patch by Denis Peter, 06 Dec 2004 | |||
2005-08-04 | Fix endianess problem in TFTP / NFS default filenames | Wolfgang Denk | |
Patch by Hiroshi Ito, 06 Dec 2004 | |||
2005-08-03 | Ignore broadcast status bit in received frames in 8260 FCC ethernet | Wolfgang Denk | |
loopback test code Patch by Murray Jensen, 18 Jul 2005 | |||
2005-08-03 | Fix typo in mkconfig script (used == instead of =) | Wolfgang Denk | |
2005-08-03 | Cleanup build problems (on Fedora Core x86_64 build host) | Wolfgang Denk | |
2005-08-03 | Update MAINTAINERS file | Wolfgang Denk | |
2005-08-02 | Merge with rsync://git-user@source.denx.net/git/u-boot.git | Jon Loeliger | |
2005-08-02 | Changed maintainer for all AMCC eval boards to Stefan Roese <sr@denx.de>. | Stefan Roese | |
Patch by Stefan Roese, 2 Aug 2005 | |||
2005-08-02 | Coding style cleanup | Wolfgang Denk | |
2005-08-02 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-02 | Remove unnecessary defines from usb_defs.h again. | Stefan Roese | |
2005-08-02 | Fix low-level OHCI transfers for PPC440EP (same as ARM920t and MPC5xxx). | Stefan Roese | |
2005-08-01 | Fix style issues primarily in 85xx and 83xx boards. | Jon Loeliger | |
- C++ comments - Trailing white space - Indentation not by TAB - Excessive amount of empty lines - Trailing empty lines | |||
2005-08-01 | Major cleanup for AMCC PPC4xx eval boards. | Stefan Roese | |
Patch by Stefan Roese, 01 Aug 2005 | |||
2005-08-01 | Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone. | Stefan Roese | |
Patch by Steven Blakeslee, 27 Jul 2005 | |||
2005-07-31 | Minor fixes for PPChameleon Board: | Wolfgang Denk | |
* fix alignment of NAND size * make code do what the comment says | |||
2005-07-30 | Add missing CHANGELOG entry | Wolfgang Denk | |
2005-07-30 | Implement h/w sector protection status synchronization at boot. | Wolfgang Denk | |
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip. | |||
2005-07-29 | * Patch by Ron Alder, 11 July 2005 | Lunsheng Wang | |
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board. |
