2018-02-04mx6memcal: launder through savedefconfigEric Nelson
This patch just changes the order of configuration items in mx6memcal_defconfig to match the Kconfig layout, making it easier to track changes made using menuconfig. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04arm: imx: mx53loco: remove usage of mx53_dram_sizePatrick Bruenn
Static variables are not available during board_init_f(). 'static uint32_t mx53_dram_size[2];' was used in board specific dram_init(), dram_init_banksize() and get_effective_memsize() to avoid multiple calls to get_ram_size(). Reused dram initialization functions from arch/arm/mach-imx/mx5/mx53_dram.c Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2018-02-04arm: imx: m53evk: remove usage of mx53_dram_sizePatrick Bruenn
2018-02-04arm: imx: cx9020: move dram init into common placePatrick Bruenn
Move dram_init(), dram_init_banksize() and get_effective_memsize() to arch/arm/mach-imx/mx5/mx53_dram.c, where it can be reused by m53evk and mx53loco. Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2018-02-04arm: imx: cx9020: remove usage of mx53_dram_sizePatrick Bruenn
Static variables are not available during board_init_f(). 'static uint32_t mx53_dram_size[2];' was used in board specific dram_init(), dram_init_banksize() and get_effective_memsize() to avoid multiple calls to get_ram_size(). However multiple calls are better than undefined behavior... This fixes: https://lists.denx.de/pipermail/u-boot/2017-November/313214.html https://lists.denx.de/pipermail/u-boot/2017-December/314480.html Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2018-02-04board,ge,bx50v3 - rtc time validationNandor Han
Validate the time at startup: - in case rtc error add to kernel command line RTC_ERROR - clamp date to 1-Jan-2036 Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04configs: ge_bx50v3: automatic partition selection and video output failure ↵Ian Ray
message The exact definition of a successful boot is defined by user-space. Determine the boot partition automatically. A partition is selected if file `/boot/bootcause/firstboot' exists (meaning that the partition has freshly installed software) OR if file `/boot/fitImage' exists. When userspace determines that new software was successfully installed, it must (1) delete `/boot/fitImage' on the _inactive_ partition and (2) remove `/boot/bootcause/firstboot'. Enable video, but do not display logos or other version information. Silence kernel console logging by default. Print a message to VGA screen in case of boot failure and reset bootcount to allow the user to attempt boot again. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: mount rootfs read-onlyHannu Lounento
Change the kernel command line to mount the root filesystem read-only in order to be able to run filesystem check on it on boot. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04configs: ge_bx50v3: enable bootcountIan Ray
Enable bootcount using an EXT file. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04config: ge_bx50v3: read boot scriptIan Ray
Read boot script from shared partition, if available. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Support FIT and select configuration based on VPDIan Ray
Modify configuration to support FIT. Set variable `confidx' from VPD, in order to load the correct device tree. Modify/simplify U-Boot environment to support loading FIT image. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Enable hardware watchdogMartyn Welch
Enable the hardware watchdog on bx50v3 to cause it to reset in the event the board hangs. Configure GPIO_9 pin as WDOG1_B so that a watchdog timeout results in a full system reset. The watchdog is used and reconfigured by systemd approximately 1.7 seconds into boot. Adding a few seconds for U-Boot and a few more seconds as a safety margin. Note that the PCIe controller is _not_ put back into a safe state prior to board reset. This is a problem if board reset is implemented as CPU reset. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: program MAC address to I210Hannu Lounento
There are two I210s on the b850v3 and one on the b450v3 and b650v3. One is connected to Marvell 88e6240 which is already programmed. Follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order. The environment variables are removed after programming the hardware because the variables seem to influence MAC addresses also after U-Boot. Specifically the MAC address of FEC (MC interface) would be incorrectly set: 'ethaddr', which maps to the first I210 chip and is set to I210's default address read from the driver by eth_write_hwaddr in eth_legacy.c because the variable is undefined (not set even by bx50v3.c), would result in the eth0 interface's MAC address to be set to I210's default address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: move FEC MAC address programming to driverMartyn Welch
Instead of programming the hardware directly in the board implementation, follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. This avoids duplicating the implementation as it already exists in the driver (drivers/net/fec_mxc.c: fec_set_hwaddr). The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order, i.e. FEC always has the index 2. The FEC driver does *not* set the flag Set MAC Address on Transmit (bit set_eth0_mac_address used to do but this is unnecessary as the Linux networking stack fills in the MAC address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04configs: Add network device support for bx50v3 productsIan Ray
Modify b450v3, b650v3 and b850v3 defconfigs to enable the network devices found in these products. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: Enable access to i2c bus 1 and 2Martyn Welch
The change in i2c configuration added to support access to the VPD has inadvertantly caused access to i2c buses 1 & 2 to be lost. This has resulted in the configuration for the PMIC to be attempted on the wrong bus and thus isn't taking effect. Add the required configuration to return access to buses 1 & 2. In order to ensure that any users of the bus numbering prior to addition in VPD patches work, add buses before configuration related to mux on bus 0 and tweak VPD bus usage to fit new numbering scheme. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04rtc: adding RX8010SJ rtc driverNandor Han
Add a new driver for RX8010SJ rtc chip. The driver implements both formats of U-Boot driver model. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04net: e1000: implement eth_write_hwaddrHannu Lounento
Implement programming MAC address to the hardware, i.e. external flash seen as EEPROM. MAC address is only written if it differs from what is already stored in flash or if reading the current MAC address fails. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> CC: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04net: e1000: split e1000_read_mac_addrHannu Lounento
Split the implementation of e1000_read_mac_addr into eeprom and register versions called by e1000_read_mac_addr. This allows for calling e1000_read_mac_addr when MAC address is needed with no constraints where it is read from, and for calling the register and, especially, the eeprom version directly in order to specify where to read the address from. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> CC: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04net: e1000: add support for writing to EEPROMHannu Lounento
Port functions for writing to EEPROM, updating the checksum and committing data to flash from the Linux kernel igb driver. Functions were ported from Linux 4.8-rc2 (694d0d0bb20). Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> CC: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04imx: mx8m: add ddr controller memory mapPeng Fan
Add ddrc memory map and enum types used in ddr initialization. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2018-02-04power: pmic/regulator allow dm be omitted by SPLPeng Fan
Allow the dm driver be omitted by SPL. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-02-04imx: imx8mq: add dtsi filePeng Fan
Add dtsi file for i.MX8MQ. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2018-02-04net: fec: fix build warnings for 64bits supportYe Li
When building for 64bits system, we get some warnings about type cast between pointer and integer. This patch eliminates the warnings by using ulong/long type which is 32bits on 32bits system or 64bits on 64bits system. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04net: fec: do not access reserved register for i.MX8MPeng Fan
The MIB RAM and FIFO receive start register does not exist on i.MX8M. Accessing these register will cause system hang. Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04gpio: mxc: add i.MX8M supportPeng Fan
Add i.MX8M GPIO support. There are 4 GPIO banks on i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: lcdif: include i.MX8MPeng Fan
Include i.MX8M in lcdif register layout map. Also included i.MX7ULP in this patch, since share same with i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04mmc: fsl_esdhc: support i.MX8MPeng Fan
Support i.MX8M in fsl esdhc driver. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04misc: ocotp: add i.MX8M supportPeng Fan
i.MX8M OCOTP follow same flow as i.MX6Q, but it has 64 banks and each bank 4 words. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04imx: makefile: compile files for i.MX8MPeng Fan
Compile files for i.MX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2018-02-04imx: mx8m: add soc related settings and filesPeng Fan
Add SoC level initialization code - arch_cpu_init - mmu table - detect cpu revision - reset cpu and wdog settings - timer init - wdog settings - lowlevel init to save/restore registers - a few dummy header file to avoid build failure - ft_system_setup Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04imx: mx7: move mmc env code to mmc_env.cPeng Fan
The mx7 mmc env code is shared by i.MX8M, so move it to mmc_env.c. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-02-04imx: cpu: support get_boot_device for i.MX8MPeng Fan
Enable get_boot_device for i.MX8M, it supports boot type USB. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: mx7: move get_boot_device to cpu.cPeng Fan
Move get_boot_device to cpu.c to prepare adding i.MX8M support, because i.MX8M share same code with i.MX7. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: bootaux: support i.MX8MPeng Fan
Add i.MX8M support. Because i.MX8M use SiP call trap to Arm Trusted Firmware to handle M4, so use #ifdef to avoid build error on i.MX6/7. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-02-04imx: cleanup bootauxPeng Fan
Move i.MX6/7 bootaux code to imx_bootaux.c. The i.MX6/7 has different src layout, so define M4 reg offset to ease the cleanup. Redefine the M4 related BIT for share common code. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04imx: refactor imx_get_mac_from_fusePeng Fan
Move imx_get_mac_from_fuse to a new mac.c for i.MX6/7. Since fuse regs structure are different for i.MX6/7, use mac address offset in code and define a new local struture imx_mac_fuse. Also sort the config order. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: cpu: add cpu speed/grade for i.MX8MPeng Fan
Use more general enum types for speed grade. Refine get_cpu_speed_grade_hz to support i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: cpu: move speed/temp to common cpuPeng Fan
The i.MX7 cpu speed/temp code could be reused on i.MX8M, so move them to common cpu code. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: add pad settings bit definition for i.MX8MPeng Fan
Add pad settings bit definition for i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: add i.MX8MQ SoC Revision and is_mx8m helperPeng Fan
Add i.MX8MQ SoC Revision Add is_mx8m helper The 7ULP is a dummy number, so use 0xEx. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: spl: implement spl_boot_device for i.MX8MPeng Fan
Implement spl_boot_device for i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: cpu: update cpu file to support i.MX8MPeng Fan
Update get_reset_cause to reflect i.MX8M Compile out get_ahb_clk and set_chipselect_size for i.MX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: boot_mode: add USB_BOOT entryPeng Fan
Add USB_BOOT entry. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-04imx: add sip functionPeng Fan
Add SiP (Silicon Provider) services function to issue SMC call to Arm Trusted Firmware. More SiP information could be found in https://github.com/ARM-software/arm-trusted-firmware/blob/master/ docs/arm-sip-service.rst Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2018-02-04imx: mx8m: add clock driverPeng Fan
Add clock driver to support i.MX8M. There are two kind PLLs, FRAC pll and SSCG pll. ROM already configured SYS PLL1/2, we only need to configure the output. ocotp/i2c/pll decoding and configuration/usdhc/lcdif/dram pll/ enet clock are configured in the code. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2018-02-04imx: mx8m: add pin header filePeng Fan
Add pin header file for i.MX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: mx8m: add register definition header filePeng Fan
Add register definition header file for i.MX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04imx: add i.MX8M into KconfigPeng Fan
Add i.MX8M into Kconfig, create a new folder mx8m dedicated for i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-04configs: icore: enable nand on mmc defconfigJagan Teki
Enable nand on mmc defconfig, so-that preparing nand for writing/updating bootimage, Linux becomes easy. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
