drivers/net/Makefile
(trivial merge)
Without this patch SPARC/LEON does not build.
Reported-by: Tom Rini <trini@ti.com>
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Before it was hardcoded to 1000 ticks per second.
's/zynq_serial_initalize/zynq_serial_initialize/g'
serial_initialize is used by all serial drivers.
Warnings:
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_init' was not declared. Should it be static?
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_setbrg' was not declared. Should it be static?
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_getc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_tstc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_putc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:181:1: warning: symbol 'uart_zynq0_puts' was not declared. Should it be static?
drivers/serial/serial_zynq.c:182:22: warning: symbol 'uart_zynq_serial0_device' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_init' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_setbrg' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_getc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_tstc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_putc' was not declared. Should it be static?
drivers/serial/serial_zynq.c:184:1: warning: symbol 'uart_zynq1_puts' was not declared. Should it be static?
drivers/serial/serial_zynq.c:185:22: warning: symbol 'uart_zynq_serial1_device' was not declared. Should it be static?
Signed-off-by: Jesper B. Christensen <jesper.christensen@cobham.com>
Warnings:
Add missing header.
Warnings:
drivers/net/zynq_gem.c:491:5: warning: symbol 'zynq_gem_initialize' was not declared. Should it be static?
drivers/net/zynq_gem.c:542:5: warning: symbol 'zynq_gem_of_init' was not declared. Should it be static?
MII is used by this driver.
- expand the condition with CONFIG_OF_CONTROL
Signed-off-by: Stephan Linz <linz@li-pro.net>
Last argument shouldn't be there.
Signed-off-by: Mateusz Zalega <m.zalega@samsung.com>
Cc: Tom Rini <trini@ti.com>
g_dnl_register() currently first attempts to register a composite
driver by name, and then saves the driver name once it's registered.
Internally to the registration code, g_dnl_do_config() is called and
attempts to compare the composite device's name with the list of known
device names. This fails since the composite device's name has not yet
been stored. This means that the first time "ums 0 0" is run, it fails,
but subsequent attempts succeed.
Re-order the name-saving and registration code to solve this.
Fixes: e5b834e07f51 ("USB: gadget: added a saner gadget downloader registration API")
Preprocessor definitions and hardcoded implementation selection in
g_dnl core were replaced by a linker list made of (usb_function_name,
bind_callback) pairs.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Future patches will make DFU too large to fit in this board's SPL build.
Acked-by: Tom Rini <trini@ti.com>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
In cases when MMC hadn't been initialized before, ie. by the user or other
subsystem, it was still uninitialized while UMS media capacity check,
leading to broken ums command.
UMS has to initialize resources it uses.
Tested on Samsung Goni.
Tested-by: Mateusz Zalega <m.zalega@samsung.com>
Previously offsets handled by dfu_fill_entity_mmc(), defined in boards'
CONFIG_DFU_ALT were treated as hexadecimal regardless of their prefix,
which sometimes led to confusion. This patch forces usage of explicit
numerical base prefixes.
When user attempted to perform a raw write using DFU (vide
dfu_fill_entity_mmc) with MMC interface not initialized before,
get_mmc_blk_size() reported invalid (zero) block size - it wasn't
possible to write ie. a new u-boot image.
This commit fixes that by initializing MMC device before use in
dfu_fill_entity_mmc().
While fixing initialization sequence, I had to change about half of
dfu_fill_entity_mmc's body, so I refactored it on the way to make it,
IMHO, considerably more comprehensible.
Being left as dead code, get_mmc_blk_size() was removed.
Former usb_cable_connected() patch broke compilation of boards which do
not support this feature.
I've renamed usb_cable_connected() to g_dnl_usb_cable_connected() and added
its default implementation to gadget downloader driver code. There's
only one driver of this kind and it's unlikely there'll be another, so
there's no point in keeping it in /common.
Previously this function was declared in usb.h. I've moved it, since
it's more appropriate to keep it in g_dnl.h - usb.h seems to be intended
for USB host implementation.
Existing code, confronted with default -EOPNOTSUPP return value,
continues as if the cable was connected.
CONFIG_USB_CABLE_CHECK was removed.
Change-Id: Ib9198621adee2811b391c64512f14646cefd0369
Implementation made use of types defined in common.h, even though it
wasn't #included. It worked in circumstances when .c files included
every needed header (all).
Structure definition used type block_dev_desc_t, defined in part.h, which
wasn't included in mmc.h. It worked only in circumstances when common.h,
or another header using part.h was incuded in implementation files.
Change-Id: I5b203928b689887e3e78beb00a378955e0553eb7
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Since highbank is actually shared between Highbank and Midway platforms,
remove the Highbank name from the prompt and use the default.
Signed-off-by: Rob Herring <robh@kernel.org>
Adapt highbank to use config_distro_defaults.h and remove the redundant
defines.
Allow ci_udc.o to be built when using the new(?) USB gadget framework,
as enabled by CONFIG_USB_GADGET.
Note that this duplicates the Makefile entry for ci_udc.o, since it's
also included inside #ifdef CONFIG_USB_ETHER. I'm not sure what that
define means; perhaps an old style of Ethernet-specific USB gadget
implementation?
I wonder if the line that this patch adds shouldn't be outside all of
the ifdefs, so it stands on its own, similar to how e.g. epautoconf.o
is shared between the two?
ci_udc.c allocates only a single buffer for each endpoint, which
ci_ep_alloc_request() returns as a hard-coded value rather than
dynamically allocating. Consequently, storage_common.c must limit
itself to using a single buffer at a time. Add a special case
to the definition of FSG_NUM_BUFFERS for this.
Another option would be to fix ci_ep_alloc_request() to dynamically
allocate the buffers like some/all(?) other device mode drivers do.
However, I don't think that ci_ep_queue() supports queueing up
multiple buffers either yet, and I'm not familiar enough with the
controller yet to implement that. As such, any attempt to use multiple
buffers simply results in data corruption and other errors.
Tegra's USB controller appears to be a variant of the ChipIdea
controller; perhaps derived from it, or simply a different version of
the IP core to what U-Boot supports today.
In this variant, at least the following difference are present:
- Some registers are moved about.
- Setup transaction completion is reported in a separate 'epsetupstat'
register, rather than in 'epstat' (which still exists, perhaps for
other transaction types).
- USB connection speed is reported in a separate 'hostpc1_devlc'
register, rather than 'portsc'.
- The registers used by ci_udc.c begin at offset 0x130 from the USB
register base, rather than offset 0x140. However, this is handled
by the associated EHCI controller driver, since the register address
is stored in controller.ctrl->hcor.
Introduce define CONFIG_CI_UDC_HAS_HOSTPC to indicate which variant of
the controller should be supported. The "HAS_HOSTPC" part of this name
mirrors the similar "has_hostpc" field used by the Linux EHCI controller
core to represent the presence/absence of the hostpc1_devlc register.
usb_gadget_register_driver() currently unconditionally programs PORTSC
to select a ULPI PHY. This is incorrect on at least the Tegra boards I
am testing with, which use a UTMI PHY for the OTG ports. Make the PHY
selection code conditional upon the specific EHCI controller that is in
use.
Ideally, I believe that the PHY initialization code should be part of
ehci_hcd_init() in the relevant EHCI controller driver, or some board-
specific function that ehci_hcd_init() calls.
For MX6, I'm not sure this PHY initialization code is correct even before
this patch, since ehci-mx6's ehci_hcd_init() already configures PORTSC to
a board-specific value, and it seems likely that the code in ci_udc.c is
incorrectly undoing this. Perhaps this is not an issue if the PHY
selection register bits aren't implemented on this instance of the MX6
USB controller?
ehci-mxs.c doens't appear to touch PORTSC, so this code is likely still
required there.
At least drivers/usb/gadget/storage_common.c expects that ep->req.actual
contain the number of bytes actually transferred. (At least in practice,
I observed it failing to work correctly unless this was the case).
However, ci_udc.c modifies ep->req.length instead. I assume that .length
is supposed to represent the allocated buffer size, whereas .actual is
supposed to represent the actual number of bytes transferred. In the OUT
transaction case, this may happen simply because the host sends a smaller
packet than the max possible size, which is quite legal. In the IN case,
transferring fewer bytes than requested could presumably happen as an
error.
Modify handle_ep_complete() to write to .actual rather than modifying
.length.
ci_ep_queue() currently only fills in the page0/page1 fields in the
queue item. If the buffer is larger than 4KiB (unaligned) or 8KiB
(page-aligned), then this prevents the HW from knowing where to write
the balance of the data.
Fix this by initializing all 5 pageN pointers, which allows up to
16KiB (potentially non-page-aligned) buffers.
This patch remove always false (since we tested ret = 0) ternary operator
with ret value returned.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Commit 4a271cb1b4ff doesn't take into account that fdtdec_setup_gpio()
returns success when the gpio passed to it is FDT_GPIO_NONE (no
gpio node found in the fdtdec_decode_gpio() call). This results in
calling gpio_direction_output() on invalid gpio. For this reason
executing "usb start" command on Arndale causes data abort in the
ehci-exynos driver.
Add the fdt_gpio_isvalid() check to fix that problem.
Signed-off-by: Andrey Konovalov <andrey.konovalov@linaro.org>
Cc: Julius Werner <jwerner@chromium.org>
Add missing missing disconnect and unbind calls to the musb gadget driver's
usb_gadget_unregister_driver function. Otherwise, any gadget drivers fail
to uninitialize and run a 2nd time.
Allow a NULL table to be passed to usb_gadget_get_string for cases
when a string table may not be populated.
Reviewed-by: Tom Rini <trini@ti.com>
Since dfu read/write operations needs to be flushed manually,
writing to filesystem on MMC by thor was broken. MMC raw write
actually is working fine because current dfu_flush() function
writes filesystem only. This commit adds dfu_flush() to f_thor
and now filesystem write is working.
This change was tested on Trats2 board.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
In thor's download_tail() function, dfu_get_entity() is called
before each dfu_write() call and the returned entity pointers
are the same. So dfu_get_entity() can be called just once and
this patch changes this.
USB keyboard polling failed for some keyboards on PowerPC 5020.
This was caused by requesting only 4 bytes of data from keyboards that
produce an 8 byte HID report.
Signed-off-by: Adrian Cox <adrian@humboldt.co.uk>
Update the EHCI driver to support interrupt transfers on PowerPC.
The rmobile SoC has usb host controller.
This supports USB controllers listed in the R8A7790, R8A7791 and R8A7740.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Most of the I2C slaves support accesses in the typical style
that is : read/write series of bytes at particular address offset.
These transactions look like:"
(1) START:Address:Tx:Offset:RESTART:Address[0..4]:Tx/Rx:data[0..n]:STOP"
However there are certain devices which support accesses in
terms of the transactions as follows:
(2) "START:Address:Tx:Txdata[0..n1]:Clock_stretching:
RESTART:Address:Rx:data[0..n2]"
Here Txdata is typically a command and some associated data,
similarly Rxdata could be command status plus some data received
as a response to the command sent.
Type (1) transactions are currently supportd in the
i2c driver using i2c_read and i2c_write APIs. I2C EEPROMs,
RTC, etc fall in this category.
To handle type (2) along with type (1) transactions,
i2c_read() function has been modified.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
This driver needs a data structure in SRAM before SDRAM is available.
This is not alway the case using .data section. Moving this data
structure to global_data guarantees it is writable.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
