When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
<common.h> pulls in a lot of headers. Including it from every .c
file is a bad idea. We need to remove contents until it contains
nothing.
Move printf() and friends to <stdio.h>.
For better test coverage, enable btrfs.
We specifically say that the last arg is u32, so use %lu.
Convert the sandbox architecture to make use of the new asm-generic/io.h
to provide address mapping functions. As sandbox actually performs
non-identity mapping between physical & virtual addresses we can't
simply make use of the generic mapping functions, but are able to
implement phys_to_virt() & make use of it from map_physmem().
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Convert the powerpc architecture to make use of the new asm-generic/io.h
to provide address mapping functions. As powerpc can actually perform
simply make use of the generic phys_to_virt() & virt_to_phys()
functions. However since map_physmem() already effectively implemented
the same thing as virt_to_phys() we can simply implement virt_to_phys()
instead of map_physmem() & use the generic map_physmem(). We also drop
the no-op unmap_physmem().
This has only been build-tested, feedback from architecture maintainers
is welcome.
Convert the nios2 architecture to make use of the new asm-generic/io.h to
provide address mapping functions. As nios2 actually performs
simply make use of the generic functions, with the exception of being
able to drop our no-op unmap_physmem() and definitions of unused map
flags.
Feedback from architecture maintainers is welcome.
Cc: Thomas Chou <thomas@wytron.com.tw>
Convert the mips architecture to make use of the new asm-generic/io.h to
provide address mapping functions. As mips actually performs
flags.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Convert the xtensa architecture to make use of the new asm-generic/io.h
to provide address mapping functions. As the generic implementations are
suitable for xtensa this is primarily a matter of moving code.
is welcome.
Cc: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Convert the x86 architecture to make use of the new asm-generic/io.h to
suitable for x86 this is primarily a matter of moving code.
is welcome.
Convert the sh architecture to make use of the new asm-generic/io.h to
suitable for sh this is primarily a matter of moving code.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Convert the nds32 architecture to make use of the new asm-generic/io.h
suitable for nds32 this is primarily a matter of removing code.
Cc: Macpaul Lin <macpaul@andestech.com>
Convert the microblaze architecture to make use of the new
asm-generic/io.h to provide address mapping functions. As the generic
implementations are suitable for microblaze this is primarily a matter
of removing code.
Convert the m68k architecture to make use of the new asm-generic/io.h to
suitable for m68k this is primarily a matter of emoving code.
Cc: Huan Wang <alison.wang@freescale.com>
Cc: Angelo Dureghello <angelo@sysam.it>
Acked-by: Angelo Dureghello <angelo@sysam.it>
Tested-by: Angelo Dureghello <angelo@sysam.it>
Convert the arm architecture to make use of the new asm-generic/io.h to
suitable for arm this is primarily a matter of removing code.
is welcome.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Convert the arc architecture to make use of the new asm-generic/io.h to
suitable for arc this is primarily a matter of removing code.
Cc: Alexey Brodkin <alexey.brodkin@synopsys.com>
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Most architectures currently supported by U-Boot use trivial
implementations of map_to_physmem & virt_to_phys which simply cast a
physical address to a pointer for use a virtual address & vice-versa.
This results in a lot of duplicate implementations of these mapping
functions.
The set of functions provided by different architectures also differs,
with some having implementations of phys_to_virt & others not. A later
patch will make use of phys_to_virt in architecture-neutral code, and so
requires that it be provided for all architectures.
This patch introduces an asm-generic/io.h which provides generic
implementations of address mapping functions, allowing the duplication
of them between architectures to be removed. Once architectures are
converted to make use of this generic header it will also ensure that
all of phys_to_virt, virt_to_phys, map_physmem & unmap_physmem are
provided. The 2 families of functions differ in that map_physmem may
create dynamic mappings whilst phys_to_virt may not & therefore is more
limited in scope but doesn't require information such as a length &
flags.
This patch doesn't convert any architectures to make use of this generic
header - later patches in the series will do so.
Cc: Bin Meng <bmeng.cn@gmail.com>
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 cmd/btrfs.c
create mode 100644 fs/btrfs/Kconfig
create mode 100644 fs/btrfs/Makefile
create mode 100644 fs/btrfs/btrfs.c
create mode 100644 include/btrfs.h
This adds the proper implementation for the BTRFS filesystem.
The implementation currently supports only read-only mode and
the filesystem can be only on a single device.
Checksums of data chunks is unimplemented.
Compression is implemented (ZLIB + LZO).
create mode 100644 fs/btrfs/btrfs.h
create mode 100644 fs/btrfs/chunk-map.c
create mode 100644 fs/btrfs/compression.c
create mode 100644 fs/btrfs/ctree.c
create mode 100644 fs/btrfs/dev.c
create mode 100644 fs/btrfs/dir-item.c
create mode 100644 fs/btrfs/extent-io.c
create mode 100644 fs/btrfs/hash.c
create mode 100644 fs/btrfs/inode.c
create mode 100644 fs/btrfs/root.c
create mode 100644 fs/btrfs/subvolume.c
create mode 100644 fs/btrfs/super.c
BTRFS on disk structures are stored in Little Endian. Add functions
to convert this structures to cpu and to disk format.
On Little Endian hosts, these functions do nothing.
On Big Endian the CALL_MACRO_FROM_EACH from variadic-macro.h is used
to define all the members for each structure on which cpu_to_le* or
le*_to_cpu is to be called.
create mode 100644 fs/btrfs/conv-funcs.h
Add btrfs_tree.h and ctree.h from Linux which contains constants
and structures for the BTRFS filesystem.
create mode 100644 fs/btrfs/btrfs_tree.h
create mode 100644 fs/btrfs/ctree.h
Add a header variadic-macro.h which defines the CALL_MACRO_FOR_EACH marco.
This macro can be used as follows:
#define TEST(x)
CALL_MACRO_FOR_EACH(TEST, a, b, c, d)
This will expand to
TEST(a) TEST(b) TEST(c) TEST(d)
The nice thing is that CALL_MACRO_FOR_EACH is a variadic macro, thus the
number of arguments can vary (although it has an upper limit - in this
implementation 32 arguments).
create mode 100644 include/u-boot/variadic-macro.h
The ext4, reiserfs and zfs filesystems all have their own implementation
of the same function, *_devread. Generalize this function into fs_devread
and put the code into fs/fs_internal.c.
[trini: Move fs/fs_internal.o hunk to the end of fs/Makefile as all
cases need it]
This is needed for BTRFS.
create mode 100644 lib/crc32c.c
Ignore these generated files during the build of dtc.
Add UniPhier platform specific glue layer to support USB3 Host mode
on Synopsys DWC3 IP.
The stored 'blk' value is overwritten to 'size / 512' before it can
be used in usb_stor_set_max_xfer_blk(). This is not what we want.
In fact, when 'size' exceeds the upper limit (USHRT_MAX * 512), we
should simply assign 'size' to the upper limit.
Reported-by: Coverity (CID: 167250)
Update the codes to conform with xHCI spec chapter 6.2.3.
Per xHCI spec, 'Error Count' should be set to 0 for isoch endpoints.
The 'Max Burst Size' indicates to the xHC the maximum number of
consecutive USB transactions that should be executed per scheduling
opportunity. This is a “zero-based” value, where 0 to 15 represents
burst sizes of 1 to 16, but at present this is always set to zero.
Let's program the required value according to real needs.
USB endpoint reports the period between consecutive requests to send
or receive data as bInverval in its endpoint descriptor. So far this
is ignored by xHCI driver and the 'Interval' field in xHC's endpoint
context is always programmed to zero which means 1ms for low speed
or full speed , or 125us for high speed or super speed. We should
honor the interval by getting it from endpoint descriptor.
USB 3.0 hubs report bit[5] in the port status change response as BH
reset. The hub shall set the C_BH_PORT_RESET field for this port.
During usb_hub_port_connect_change(), a port reset set feature
request is issued to the port, and later a port reset clear feature
is done to the same port before the function returns. However at
the end of usb_scan_port(), we attempt to clear port reset again
on a cached port status change variable, which should not be done.
Adjust the call to clear port reset to right before the call to
usb_hub_port_connect_change().
In xhci_check_maxpacket(), the control endpoint 0 max packet size
is wrongly taken from the interface's endpoint descriptor. However
the default endpoint 0 does not come with an endpoint descriptor
hence is not included in the interface structure. Change to use
epmaxpacketin[0] instead.
The other bug in this routine is that when setting max packet size
to the xHC endpoint 0 context, it does not clear its previous value
at all before programming a new one.
For xHCI it is not possible to read a device descriptor before it
has been assigned an address. That's why usb_setup_descriptor()
was called with 'do_read' being false. But we really need try to
read the device descriptor before starting any real communication
with the default control endpoint.
Full speed device endpoint 0 can have 8/16/32/64 bMaxPacketSize0.
Other speed devices report fixed value per USB spec. So it only
makes sense if we send a get device descriptor with 64 bytes to
full speed devices.
While we are here, update the comment block to be within 80 cols.
xHCI uses normal TRBs for both bulk and interrupt. This adds the
missing interrupt transfer support to xHCI so that devices like
USB keyboard that uses interrupt transfer can work.
Normal endpoint descriptor size is 7, but for audio extension it is
9. Handle that correctly when parsing endpoint descriptor.
At present xHCI driver assumes LS/FS devices are attached directly
to a HS hub. If they are connected to a LS/FS hub, the driver will
fail to perform the USB enumeration process on such devices.
This is fixed by looking from the device itself all the way up to
the HS hub where the TT that serves the device is located.
Now that we have changed to remove all devices under the root hub in
usb_stop(), and corrected the USB emulator select logic, it makes no
sense to do various tests based on 'usb tree' output since the order
of devices is no longer fixed. Remove these USB test cases related
to 'usb tree'.
For the USB remove test, ideally we should remove an emulator device
node from the device tree, but this is so far not working. Change to
test the 'usb stop' only.
With the root hub unbinding in usb_stop(), there is no need to do
a Sandbox-specific reset operation. usb_emul_reset() is no longer
used anywhere, drop it.
a blk uclass specific unbind operation.
At present we only do device_remove() during usb stop. The DM API
device_remove() only marks the device state as inactivated, but
still keeps its USB topology (eg: parent, children, etc) in the DM
device structure. There is no issue if we only start USB subsystem
once and never stop it. But a big issue occurs when we do 'usb stop'
and 'usb start' multiple times.
Strange things may be observed with current implementation, like:
- the enumeration may report only 1 mass storage device is detected,
but the total number of USB devices is correct.
- USB keyboard does not work anymore after a bunch of 'usb reset'
even if 'usb tree' shows it is correctly identified.
- read/write flash drive via 'fatload usb' may complain "Bad device"
In fact, every time when USB host controller starts the enumeration
process, it takes random time for each USB port to show up online,
hence each USB device may appear in a different order from previous
enumeration, and gets assigned to a totally different USB address.
As a result, we end up using a stale USB topology in the DM device
structure which still reflects the previous enumeration result, and
it may create an exact same DM device name like generic_bus_0_dev_7
that is already in the DM device structure. And since the DM device
structure is there, there is no device_bind() call to bind driver to
the device during current enumeration process, eventually creating
an inconsistent software representation of the hardware topology, a
non-working USB subsystem.
The fix is to clear the unused USB topology in the usb_stop(), by
calling device_unbind() on each controller's root hub device, and
the unbinding will unbind all of its children automatically.
For Sandbox, we need scan the device tree each time when we start
the USB stack, in order to re-create the emulated USB devices and
bind drivers for them before we actually do the driver probe.
At present the usb hub emulator always reports its downstream port
speed as full speed. Actually it is high speed for sandbox-flash,
and low speed for sandbox-keyb. We can determine the device speed
by checking its device descriptor bcdUSB field, and do the proper
hub port status report based on that.
This can be useful outside of the sandbox usb emulation uclass
driver. Expose it as a public API with a proper prefix (usb_emul_).
