Fix annoying config redefines in SoC/board level Kconfig.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
For the consistent location of SoC-level Kconfig.
Because DE2 driver is enabled by default, it is nice to disable it on
all boards which don't have any video output. List of such boards is
also much shorter.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This commit adds support for HDMI output.
This commits enable DM I2C support for A64/H3/H5 SoCs.
It is not enabled globaly for all sunxi SoCs, because some boards use
PMICs which are connected through I2C. In order to keep same
functionality, PMIC drivers needs to be ported to DM too.
This commit adds support for DM I2C on sunxi platform. It can coexist
with old style sunxi I2C driver, because it is still used in SPL and
by some SoCs.
Because sunxi platform doesn't yet support DM clk, reset and pinctrl
driver, workaround is needed to enable clocks and set resets and
pinctrls. This is done by calling i2c_init_board() in board_init().
This means that CONFIG_I2Cx_ENABLE options needs to be correctly set
in order to use needed I2C controller.
Commit is based on the previous patch made by Philipp Tomsich
This commit only moves i2c_init_board() function almost to the top and
doesn't have any functional changes.
This is needed for a temporary workaround in next commit when support
for DM I2C will be introduced.
Driver for that regulator is used only in SPL and it uses old I2C
interface. If we want to use DM I2C in U-Boot proper, compilation of
this driver has to be limited only to SPL.
Only A23/A33 in SUN8I want a default value of CONS_INDEX of 5, for other
chips the default value is 1 like other Allwinner SoCs.
Fix this default value.
The original wrong value has lead to wrong console on H3 Orange Pi
boards.
Fixes: 7095f8641863 ("sunxi: Convert CONS_INDEX to Kconfig")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Currently $fdtfile is constructed from CONFIG_DEFAULT_TREE, containing
the filename. However on arm64 that file is located in an allwinner
subdirectory.
To avoid the need for users/distros symlinking the .dtb files, prepend
the vendor directory for ARM64.
This aligns Pine64 with other boards such as Raspberry Pi 3.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Lichee Pi Zero is a development board with a V3s SoC, which features
64MiB DRAM co-packaged within the SoC, a TF slot, a SPI NOR slot (not
soldered in production batch), a 40-pin RGB LCD connector and some extra
pins available as 2.54mm pins or stamp holes.
Add support for it.
As we have now V3s support in board code, the V3s DTSI file should also
be added.
Add also some CCU include headers to satisfy the DTSI file.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
Basic U-Boot support is now present for V3s.
Some memory addresses are changed specially for V3s, as the original
address map cannot fit into a so small DRAM.
As the DRAM controller code needs a big refactor, the SPL support is
disabled in this version.
This is needed for HDMI, which will be added later.
Video driver for older Allwinner SoCs uses cfb console framework which
in turn uses struct ctfb_res_modes to hold timing informations. However,
DM video framework uses different structure - struct display_timing.
It makes more sense to convert lcdc to use new timing structure because
all new drivers should use DM video framework and older drivers might be
rewritten to use new framework too.
TCON unit has similar layout and functionality also on newer SoCs. This
commit splits out TCON code for easier reuse later.
The Bananapi M2 Ultra is the first publicly available development board
featuring the R40 SoC.
This patch add barebone dtsi/dts files for the R40 and Bananapi M2 Ultra,
as well as a defconfig for it.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The R40's CPU controls are a combination of sun6i and sun7i.
All controls are in the CPUCFG block, and it seems the R40 does not
have a PRCM block. The core reset, power gating and clamp controls
are grouped like sun6i.
Last, the R40 does not have a secure SRAM block.
This patch adds a PSCI implementation for CPU bring-up and hotplug
for the R40.
The R40 has the CPUCFG block at the same address as the A20.
Fix it.
Now that we can do DRAM initialization for the R40, we can enable
SPL support for it.
The R40 seems to have a variant of the memory controller found in
the H3 and A64 SoCs. Adapt the code for use on the R40. The changes
are based on released DRAM code and comparing register dumps from
boot0.
The PIO on the R40 SoC is mostly compatible with the A20.
Only a few pin functions for mmc2 were added to the PC
pingroup, to support 8 bit eMMCs.
These values were taken from the Banana Pi M2 Ultra fex file
found in the released vendor BSP. This is the only publicly
available R40 device at the time of this writing.
According to the BSP released by Banana Pi, the R40 (sun8iw11p1) has
an extra "PLL lock control" register in the CCU, which controls whether
the individual PLL lock status bits in each PLL's control register work
or not.
This patch enables it for all the PLLs.
The PIO is generally compatible with the A20, except that it routes the
full 8 bits and eMMC reset pins for mmc2.
The watchdog found on the R40 SoC is the older variant found on the A20.
Add the proper "#if defines" to make it work.
The R40 SoC uses the AXP221s in I2C mode to supply power.
Some regulator's common usages have changed, and also the recommended
voltage for existing usages have changed. Update the defaults to match.
The R40 is the successor to the A20. It is a hybrid of the A20, A33
and the H3.
The R40's PIO controller is compatible with the A20,
Reuse the A20 UART and I2C muxing code by adding the R40's macro.
The display pipeline is the newer DE 2.0 variant.
Block enabling video on R40 for now.
Currently we have some lines in board/sunxi/Kconfig that are very long.
These line either provide default values for a set of SoCs, or limit
some option to a subset of sunxi SoCs.
Fortunately Kconfig makes it easy to split them. The Kconfig language
document states
If multiple dependencies are defined, they are connected with '&&'.
This means we can split existing dependencies at "&&" symbols. This
applies to both the "depends on" lines and "if" expressions.
This patch splits them up to one symbol per line. This will make it
easier to add, remove, or modify one item at a time.
Convert the CONS_INDEX configuration to Kconfig.
Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not
needed anymore.
Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
[Maxime: Added a depends on ARCH_SUNXI to avoid build breakages]
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs
that used it in SYS_EXTRA_OPTIONS.
Convert the CONFIG_SATAPWR into kconfig.
Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some
defconfigs.
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to
update defconfig files of SYS_EXTRA_OPTIONS accordingly and
remove it when it is possible.
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS
from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it
with SUN8I_EMAC.
The USB_EHCI configuration is already set in this defconfig
using kconfig's config. This configuration in SYS_EXTRA_OPTIONS
must be removed and so the SYS_EXTRA_OPTIONS.
This configuration is not necessary in a defconfig file so
it is removed from the SYS_EXTRA_OPTIONS.
Remove the AXP209_POWER option from SYS_EXTRA_OPTIONS.
As this configuration already exists on Kconfig, we just need
to remove it from defconfig.
Move the SUNXI_GMAC config option to Kconfig, remove it
from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC.
Add myself as maintainer of the NanoPi NEO Air board.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
The RK3399-Q7 ("Puma") SoM exposes UART0 as the Qseven UART (i.e. the
serial line available via standardised pins on the edge connector and
available on a RS232 connector).
To support boards (such as the RK3399-Q7) that require UART0 as a
debug console, we match CONFIG_DEBUG_UART_BASE and add the appropriate
iomux setup to the rk3399 SPL code.
As we are already touching this code, we also move the board-specific
UART setup (i.e. iomux setup) into board_debug_uart_init(). This will
be called from the debug UART init when CONFIG_DEBUG_UART_BOARD_INIT
is set.
As the RK3399 needs to use its board_debug_uart_init() function, we
have Kconfig enable it by default for RK3399 builds.
With everything set up to define CONFIG_BAUDRATE via defconfig and
with to have the SPL debug UART either on UART0 or UART2, the configs
for the RK3399 EVB are then update (the change for the RK3399-Q7 is
left for later to not cause issues on applying the change).
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
For using mipi display, we need to enable lcd3v3
which supplied by rk808,so enable rk808 first.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
To enable mipi display, we need to enable pmic
rk808 first for lcd3v3 power,which use i2c0 to
communicate with soc. So enable i2c0.
when enable PMIC rk808,the system will halt at very
early stage,log is shown as bellow.
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: BL31: Initializing runtime services
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
time 44561b, 0 (<<----Just stop here)
It's caused by the absence of "{ }" in syscon_rk3399.c
,which will lead to memory overflow like below.According
to Sysmap file ,we can find the function buck_get_value
of rk808 is just follow the compatible struct,the pointer
"of_match" point to "buck_get_value",but it is not a
struct and don't have member of compatible, In this case,
system crash. So,on the face, it looks like that rk808 is
guilty.but he is really innocent.
while (of_match->compatible) { <<----------
if (!strcmp(of_match->compatible, compat)) {
*of_idp = of_match;
return 0;
of_match++;
Tested-by: Kever Yang <kever.yang@rock-chips.com>
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230
connector) system-on-module from Theobroma Systems, featuring the
Rockchip RK3399.
It provides the following feature set:
* up to 4GB DDR3
* on-module SPI-NOR flash
* on-module eMMC (with 8-bit interace)
* SD card (on a baseboad) via edge connector
* Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY
* HDMI/eDP/MIPI displays
* 2x MIPI-CSI
* USB
- 1x USB 3.0 dual-role (direct connection)
- 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub)
* on-module STM32 Cortex-M0 companion controller, implementing:
- low-power RTC functionality (ISL1208 emulation)
- fan controller (AMC6821 emulation)
- USB<->CAN bridge controller
Note that we use a multi-payload FIT image for booting and have
Cortex-M0 payload in a separate subimage: we thus rely on the FIT
image loader to put it into the SRAM region that ATF expects it in.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Fixed build warning on puma-rk3399:
The RK3399-Q7 (Puma) DTS should (of course) be dual-licensed.
This updates the licensing info in the rk3399-puma.dts.
The warm-reset of rk3188 socs keeps the remap setting as it was, so if
it was enabled, the cpu would start from address 0x0 of the sram instead
of address 0x0 of the bootrom, thus making the reset hang.
Therefore make sure the remap is disabled before attempting a warm reset.
Cold reset is not affected by this at all.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The lower address is reserved for ATF, do not use it.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
