platforms wishing to display RAM diagnostics in addition to size,
can do so, on one line, in their own board_add_ram_info()
implementation.
this consequently eliminates CONFIG_ADD_RAM_INFO.
Thanks to Stefan for the hint.
This patch has been sent on:
- 6 Jun 2007
Many users of PCI config read routines tend to ignore the function
ret value, and are only concerned about the contents of *val. Based
on this, pci_hose_read_config_{byte,word}_via_dword should initialize
the *val on dword read error.
Without this fix, for example, we'll go on scanning bus with vendor or
header_type uninitialized. This brings many unnecessary config trials.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Minor cleanups to confirm to the u-boot coding style.
Some german expressions -> english.
HCU5 enforces a unique IP adress for a given slot in the rack.
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Make ecc initialisation robust, as DDR2-ECC errors may be generated
while zeroing the RAM.
Return 16 bytes (a cacheline) less than the available memory, as the
board and/or PPC440EPx might have problems accessing the last bytes.
Forgot to cast of_flat_tree to ulong.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The TSEC driver's PHY code waits a long time for autonegotiation to
complete, even if the link is down. The PHY knows the link is
down or up before autonegotiation completes, so we can short-circuit
the process if the link is down.
Actually, fixed a large bug in the UEC for *all* platforms.
How did this ever work?
uec_init() did not follow the spec for eth_init(), and returned
0 on success. Switch it to return the link like tsec_init()
(and 0 on error)
The immap for the 8568 was defined based on MPC8568, rather than
CONFIG_MPC8568
CONFIG_QE was off
CONFIG_ETHPRIME was set to "Freescale GETH". Now is "FSL UEC0"
Fixed a comment about the ranges for CONFIG_ETHPRIME if TSEC_ENET is
enabled
The tsec_info structure and array has a "flags" field for each
ethernet controller. This field is the only reason there are
settings. Switch to defining TSECn_FLAGS for each controller
in the config header, and we can greatly simplify the array, and
also simplify the addition of future boards.
Changes to the TSEC driver affect almost all 83xx, 85xx, and 86xx boards.
Now we can do a MAKEALL test on all of them!
The fix, "Fix where the #ifdef CFG_BOOTMAPSZ is placed"
neglected to *also* put the code inside the similar #ifdef
for CONFIG_OF_FLAT_TREE.
bzip2 requires a significant chunk of malloc space, and there isn't
enough room on mpc885ads (with only 8MB RAM) for both bzip2's malloc area
and a downloaded image at 0x400000.
microblaze CPU have problem with bios_emulator code.
Microblaze toolchain doesn't support PRAGMA PACK.
This small CPCI750 update extends the board specific command
"show_config" to display the Marvell strapping registers and
extends the PCI IDE controller.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
As suggested by David Mitchell, here an update for the Sequoia/Rainier
bootstrap command.
Remove a leftover in net/tftp.c while we're at it.
Minor path corrections needed to ensure buildability.
Commit 073e1b509980cefe6f53c2d7fbbcd135df1e3924 "Fix initrd/dtb
interaction" put the new code outside of the #if defined(CONFIG_OF_LIBFDT)
when it should have gone inside of the conditional. As a result, it
broke non-LIBFDT board builds.
Also added a missing "not." to the comment.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Typically this causes scsi init to corrupt the
devlist and break the coninfo command.
Fix a compiler size warning.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
The original code would wrongly relocate the blob to be right before
the initrd if it existed. The blob *must* be within CFG_BOOTMAPSZ,
if it is defined. So we make two changes:
1) flag the blob for relocation whenever its address is above BOOTMAPSZ
2) If the blob is being relocated, relocate it before kbd, not initrd
When CFG_POST_ETHER_EXT_LOOPBACK is defined, the ethernet POST
is not done using an internal loopback connection, but by assuming
that an external loopback connector is plugged into the board.
