By Cleanup out-or-tree building for some boards (.depend)
(commit:c8a3b109f07f02342d097b30908965f7261d9f15)
because filse ware changed, some SH-boards have compile error.
I revised this problem.
New NOR Flash board support and remove old type flash board config.
And Remove network setting from config file.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
New NOR Flash board support and remove network setting from config file.
update mvBL-M7 config file to use UBOOT_VERSION and define
CONFIG_HIGH_BATS.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This change helps with better handling with others
Xilinx based platform.
board/amirix/ap1000/serial.c
board/exbitgen/exbitgen.c
board/exbitgen/flash.c
board/ml2/serial.c
board/xilinx/ml300/serial.c
Fix NAND FLASH timings for at91sam9x evaluation kits.
New timings are based on application note
"NAND Flash Support on AT91SAM9 Microcontrollers" available at
http://atmel.com/dyn/resources/prod_documents/doc6255.pdf
Signed-off-by: Patrice Vilchez <patice.vilchez@atmel.com>
Acked-by: Stelian Pop <stelian@popies.net>
AT91 RSTC registers are battery-backuped, so their values
are not reset across power cycles. One of those registers,
the AT91_RSTC_MR register, is being modified by U-Boot, in
the ethernet initialisation routine, to generate a 500ms
user reset.
Unfortunately, this value is not being restored afterwards,
causing subsequent resets to also last for 500ms.
This long reset sequence causes problems (at least) in the
boot sequence from NOR: by the time the CPU tries to load
a program from the NOR flash, the latter is still in reset
and not yet available.
Additionaly, this patch fixes a bug in the original code which
caused the reset delay to last for 2s instead of 500ms.
Signed-off-by: Stelian Pop <stelian@popies.net>
update mvBL-M7 config file to use UBOOT_VERSION.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Gary Jennejohn <garyj@denx.de>
Add support for updating mac-address and local-mac-address in fdt for
all MPC8260 targets.
Signed-off-by: Esben Haabendal <eha@doredevelopment.dk>
My text-editor (vim) has a bit of trouble syntax-highlighting the
cmd_nvedit.c file, because it apparently does not parse C
ifdef/else/endif. The following patch does not change the behavior of
the code at all, but does allow the editor to properly
syntax-highlight the file.
Signed-off-by: Steve Falco <sfalco@harris.com>
Currently, the setenv function does not return an error code.
This patch allows to test for errors.
fls64, __ilog2_u64, ffs64 are variants that work on an u64,
and fls is used to implement them.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
The Register URXD contains status information in bits [15..8].
With status bit 15 set, CTRL-C was reported as 0x8003 instead
of 0x03. Therefore CTRL-C was not detected.
To solve this, bits [15..8] were masked out now.
Signed-off-by: Juergen Kilb <J.Kilb@gmx.de>
Acked-by: Felix Radensky <felix@embedded-sol.com>
Signed-off-by: Francesco Albanese <Francesco.Albanese@swisscom.com>
Global FIT image operations like format check cannot be performed on
a first sector data, defer them to the point when whole FIT image was
uploaded to a system RAM.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Partial ('cmd_nand' case) Acked-by: Grant Erickson <gerickson@nuovations.com>
NAND and DOC bits Acked-by: Scott Wood <scottwood@freescale.com>
The driver need wait for the device updating signature to host.
If we don't wait for it, the driver can not detect the device(disk)
when the system powers up.
Signed-off-by: Dave Liu <daveliu@freescale.com>
