Add an interface for calling secure ROM APIs across a range of OMAP and
OMAP compatible high-security (HS) device variants. While at it, also
perform minor cleanup/alignment without any change in functionality.
Signed-off-by: Daniel Allred <d-allred@ti.com>
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Adds missing flush_dcache_range and invalidate_dcache_range dummy
(empty) placeholder functions to the #else portion of the #ifndef
CONFIG_SYS_DCACHE_OFF, where full implementations of these functions
are defined.
There are two enable methods supported by ARM64 Linux; psci and
spin-table. The latter is simpler and helpful for quick SoC bring
up. My main motivation for this patch is to improve the spin-table
support, which allows us to boot an ARMv8 system without the ARM
Trusted Firmware.
Currently, we have multi-entry code in arch/arm/cpu/armv8/start.S
and the spin-table is supported in a really ad-hoc way, and I see
some problems:
- We must hard-code CPU_RELEASE_ADDR so that it matches the
"cpu-release-addr" property in the DT that comes from the
kernel tree.
- The Documentation/arm64/booting.txt in Linux requires that
the release address must be zero-initialized, but it is not
cared by the common code in U-Boot. We must do it in a board
function.
- There is no systematic way to protect the spin-table code from
the kernel. We are supposed to do it in a board specific manner,
but it is difficult to predict where the spin-table code will be
located after the relocation. So, it also makes difficult to
hard-code /memreserve/ in the DT of the kernel.
So, here is a patch to solve those problems; the DT is run-time
modified to reserve the spin-table code (+ cpu-release-addr).
Also, the "cpu-release-addr" property is set to an appropriate
address after the relocation, which means we no longer need the
hard-coded CPU_RELEASE_ADDR.
Upon further review this breaks most other platforms as we need to check
what core we're running on before touching it at all.
This reverts commit d73718f3236c520a92efa401084c658e6cc067f3.
With the change to set up pinctrl after relocation, link fails to boot. Add
a special case in the link code to handle this.
Fixes: d8906c1f (x86: Probe pinctrl driver in cpu_init_r())
Add support for Advantech SOM-DB5800 with the SOM-6867 installed.
This is very similar to conga-qeval20-qa3-e3845 in that there is a
reference carrier board (SOM-DB5800) with a Baytrail based SoM (SOM-6867)
installed.
Currently supported:
- 2x UART (From ITE EC on SOM-6867) routed to COM3/4 connectors on
SOM-DB5800.
- 4x USB 2.0 (EHCI)
- Video
- SATA
- Ethernet
- PCIe
- Realtek ALC892 HD Audio
Pad configuration for HDA_RSTB, HDA_SYNC, HDA_CLK, HDA_SDO
HDA_SDI0 is set in DT to enable HD Audio codec.
Pin defaults for codec pin complexs are not changed.
Not supported:
- Winbond Super I/O (Must be disabled with jumpers on SOM-DB8500)
- USB 3.0 (XHCI)
- TPM
Signed-off-by: George McCollister <george.mccollister@gmail.com>
If global NVS says internal UART is not enabled, hide it in the ASL
code so that OS won't see it.
Reviewed-by: George McCollister <george.mccollister@gmail.com>
Tested-by: George McCollister <george.mccollister@gmail.com>
Now that platform-specific ACPI global NVS is added, pack it into
ACPI table and get its address fixed up.
This introduces quark-specific ACPI global NVS structure, defined in
both C header file and ASL file.
This introduces baytrail-specific ACPI global NVS structure, defined in
This patch adds support to enable and use the internal BayTrail UART
instead of the one integrated in the Super IO Winbond chip. For this,
a 2nd defconfig file is added.
This is useful for tests done for the congatec SoM used on baseboards
without such a Super IO chip.
Cc: Bin Meng <bmeng.cn@gmail.com>
For any FSP-enabled boards that want to enable debug UART support,
setup_internal_uart() will be called, but this API is only available
on BayTrail platform. Change to wrap it with CONFIG_INTERNAL_UART.
There are quite a number of BayTrail boards that uses an external
SuperIO chipset to provide the legacy UART. For such cases, it's
better to have a Kconfig option to enable the internal UART.
So far BayleyBay and MinnowMax boards are using internal UART as
the U-Boot console, enable this on these two boards.
For consistency with board_should_run_oprom(), do the same to
should_load_oprom(). Board support codes can provide this one
to override the default weak one.
At present should_load_oprom() calls board_should_run_oprom() to
determine whether oprom should be loaded. But sometimes we just
want to load oprom without running. Make them independent.
This option is defined at nowhere. Remove it.
The following python error:
Traceback (most recent call last):
File "./tools/patman/patman", line 144, in <module>
series = patchstream.FixPatches(series, args)
File "./tools/patman/patchstream.py", line 477, in FixPatches
commit = series.commits[count]
IndexError: list index out of range
is seen when:
- 'END' is missing in those tags
- those tags are put in the last part in a commit message
- the commit is not the last commit of the series
Add testing logic to see if a new commit starts.
'Series-changes' uses blank line to indicate its end. If that is
missing, series internal state variable 'in_change' may be wrong.
Correct its state.
If 'END' is missing in a 'Cover-letter' section, and that section
happens to show up at the very end of the commit message, and the
commit is the last commit of the series, patman fails to generate
cover letter for us. Handle this in CloseCommit of patchstream.
'Cover-letter', 'Series-notes' and 'Commit-notes' tags require an
'END' to be put at the end of its section. If we forget to put an
'END' in those sections, and these sections are followed by another
patman tag, patman generates incorrect patches. This adds codes to
handle such scenario.
Like other patman tags, use a new variable cover_match to indicate
a match for 'Cover-letter'.
Some uclass ids are out of order. Per the comments, sort them
in alphabetical order.
The cros-ec keyboard is always a child of the cros-ec node. Rather than
searching the device tree, looking at the children. Remove the compat string
which is now unused.
The 'COMPAT_' part should appear only once so drop the duplicate part. It is
ignored anyway, but let's keep things consistent.
The list is shrinking and we should avoid adding new things. Instead, a
proper driver should be created with driver model.
A few drivers have moved to driver model, so we can drop these strings.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
We have drivers for several more devices now, so drop the strings which are
no-longer used.
This fixes the following compiler error:
common/fb_mmc.c: In function ‘fb_mmc_erase’:
common/fb_mmc.c:209:17: error: ‘struct blk_desc’ has no member named
‘block_erase’
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Define a platform data structure for the MPC85XX GPIO driver to allow
use of the driver without device tree. Users should define the GPIO
blocks for their platform like this:
struct mpc85xx_gpio_plat gpio_blocks[] = {
.addr = 0x130000,
.ngpios = 32,
.addr = 0x131000,
.ngpios = 32,
U_BOOT_DEVICES(my_platform_gpios) = {
{ "gpio_mpc85xx", &gpio_blocks[0] },
{ "gpio_mpc85xx", &gpio_blocks[1] },
This is intended to build upon the recent submission of the base
MPC85XX driver from Mario Six. We need to use that new driver
without dts support and this patch gives us that flexibility.
This has been tested on a Freescale T2080 CPU, although only the first
GPIO block.
Signed-off-by: Hamish Martin <hamish.martin@alliedtelesis.co.nz>
Reviewed-by: Mario Six <mario.six@gdsys.cc>
Tested-by: Mario Six <mario.six@gdsys.cc>
Update the method of accessing the block device so that it works with
CONFIG_BLK enabled.
CONFIG_BLK enabled.
Now that we have fully moved to driver model, drop the old code.
Update this board to use driver model for block devices and MMC operations.
Add support for using driver model for block devices and MMC operations in
this driver.
this driver.
Move the configuration setting into a separate function which can be used by
the driver-model code.
Update the sandbox MMC emulation to use driver model for MMC operations.
These boards should have maintainer entries. Add them.
Enable this option to move rockchip over to use driver model for MMC
operations.
Add support to dwmmc for using driver model for MMC operations.
The driver model conversion for MMC has moved in small steps. The first step
was to have an MMC device (CONFIG_DM_MMC). The second was to use a child
block device (CONFIG_BLK). The final one is to use driver model for MMC
operations (CONFIG_DM_MMC_OP). Add support for this.
The immediate priority is to make all boards that use DM_MMC also use those
other two options. This will allow them to be removed.
This option is not actually needed for rockchip boards. Drop it, since it
will not support driver-model MMC operation support.
Move this code into separate functions so that it can be used from the uclass
also. Add static inline versions for when the option is disabled.
Since all Rockchip boards use CONFIG_BLK, we can remove this old code.
Rather than having an #ifdef in the main mmc.c file, control this feature
from the Makefile by moving the code into its own file.
Rather than having #ifdef in mmc.c, move this code into the legacy file.
Rather than having #ifdef in mmc.c, move this code into the uclass file.
These private functions are used both in the driver-model implementation and
in the legacy code. Add them to the header.
