2017-05-22Kconfig: Drop CONFIG_CMD_LOADYSimon Glass
This is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_KGDB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_KGDB Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22fs: Kconfig: Add a separate option for FS_JFFS2Simon Glass
Rather than using CMD_JFFS2 for both the filesystem and its command, we should have a separate option for each. This allows us to enable JFFS2 support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IOTRACE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOTRACE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IOLOOP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOLOOP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IO to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IO Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_IMX_FUSESimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_IMXOTPSimon Glass
2017-05-22Convert CONFIG_CMD_IMMAP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IMMAP Also move this command out of the cmd/ directory since it is PowerPC-specific. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_HDMIDETECT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HDMIDETECT Note that we cannot do 'default y if VIDEO' because this option is only enabled for a small subset of mx6 boards. Also this command is is not a great implementation (it doesn't use driver model). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_HD44760 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HD44760 Also drop CONFIG_CMD_HD44780 which appears to be a typo. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Add CONFIG_HASH to enable hashing APISimon Glass
At present CONFIG_CMD_HASH enables the 'hash' command which also brings in the hashing API. Some boards may wish to enable the API without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_GSC to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_GSC Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_GETTIME to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_GETTIME Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_FUSE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FUSE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGAD Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_FDT_MAX_DUMPSimon Glass
This option is not used by any board. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FDC to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FDC Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ETHSW to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ETHSW Also enable it for sandbox to increase build coverage. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ESBC_VALIDATE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ESBC_VALIDATE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_CALLBACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_CALLBACK Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
2017-05-22Convert CONFIG_CMD_ENTERRCM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENTERRCM Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EECONFIG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EECONFIG Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ECCTEST to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ECCTEST Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_SYS_I2C_DS4510_ADDRSimon Glass
This is only used by one board and always set to 0x51. Drop this option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_SYS_I2C_DS1621_ADDRSimon Glass
Now that dtt is gone, this is not used. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Drop digital thermometer and thermostat (DTT) driversSimon Glass
This subsystem is quite old. It has been replaced with a driver-model version (UCLASS_THERMAL). Boards are free to convert to that if required, but here is a removal patch that could be applied in the meantime. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Drop three-wire serial (TWS) supportSimon Glass
This subsystem has not been converted to driver model, there is only one driver and only one board that uses it. Drop it and its CONFIG option. Also drop the rtc4543 RTC driver since it uses TWS. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Kconfig: Drop CONFIG_SYS_I2C_DTT_ADDRSimon Glass
This option is only defined to a non-default value by canyonlands, which needs conversion to driver model (where the I2C address would be defined by the device tree). Drop this option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Convert CONFIG_DS4510 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_DS4510 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510Simon Glass
This option enables a command in the driver. But the functions defined by the driver are not called anywhere else in U-Boot. So it does not seem useful to have this driver without its commands. Drop this option, move the header file out of the common include/ directory and make all the function static. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_RSTSimon Glass
This option is only used in one driver and is not enabled by any board. It does not seem worth having the ability to remove this part of the support. Drop the option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_MEMSimon Glass
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_INFOSimon Glass
This option is only used in one driver and two boards. It does not seem worth having the ability to remove this part of the support. Drop the option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22FIT: Rename FIT_DISABLE_SHA256 to FIT_ENABLE_SHA256_SUPPORTTom Rini
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which is enabled by default and now a positive option. Convert the handful of boards that were disabling it before to save space. Cc: Dirk Eibach <eibach@gdsys.de> Cc: Lukasz Dalek <luk0104@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22test: py: Add cmd_echo dependencyMichal Simek
There is missing dependency on echo command. Mark tests which requires echo. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-05-18Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
