UART hardware on i.MX27 is the same as on the i.MX31 so we just
need to provide the driver with correct address of the registers.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch adds generic code to support Freescale's i.MX27 SoCs.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
This patch adds the NAND SPL framework needed to boot i.MX31 boards
from NAND.
It has been tested on a i.MX31 PDK board with large page NAND. Small
page NANDs should work as well, but this has not been tested.
Note: The i.MX31 NFC uses a non-standard layout for large page NANDs,
whether this is compatible with a particular setup depends on how
the NAND device is programmed by the flash programmer (e.g. JTAG
debugger).
The patch is based on the work by Maxim Artamonov.
Signed-off-by: Maxim Artamonov <scn1874@yandex.ru>
Currently CONFIG_ONENAND_IPL is used in a number of #ifdef's
in start.S. In preparation for adding support for NAND SPL
the macro CONFIG_PRELOADER is introducted and replaces the
CONFIG_ONENAND_IPL in start.S.
the lowlevel init sequence is the same so unify it
this will allow you to store use it for the env and to boot directly U-Boot from
The PM9261 board is based on the AT91SAM9261-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9261.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
optimize a few the RAM init
move PSRAM init to pm9263.c
this will allow us after to make the nor lowlevel_init generic
The way the ALL variable is used allows for config.mk's to add more
targets themselves without having to clutter up the top level Makefile.
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not
CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards.
Building the compression code in lib_generic/ with -O2 rather than -Os
gives a nice speed boost without too much code size increase.
The latest version of U-Boot got a bit fatter in the BSS section which
caused overflows in the RAM region, so increase the monitor size.
The SPI flash layer is much stricter about sector usage than the eeprom
layer we used to use, so update the env settings to better match the
sector alignment of the flashes we use.
Signed-off-by: Vivi Li <vivi.li@analog.com>
The debug tools that interface with the other side of the JTAG console
got much slower when generalizing things, so bump up the default timeout
value on the U-Boot side to cope. Hopefully at some point we can improve
the debug tools to speed things back up.
This script is similar to the netconsole script, but instead works with
the JTAG console device driver that exists on Blackfin parts.
All drivers need to be converted to CONFIG_NET_MULTI.
This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds a egiga driver for the Marvell Kirkwood SoC's.
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit <rshitrit@marvell.com>
Acked-by: Stefan Rose <sr@denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Different flavours of DaVinci SOC's have differences in their EMAC IP
This patch does the following
1) Updates base addresses for DM365
2) Updates MDIO frequencies for DM365 and DM646x
3) Update EMAC wrapper registers for DM365 and DM646x
Patch applies to u-boot-net git. the EMAC driver itself
will be updated shortly to add support for DM365 and DM646x
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
udelay(1) loop counter.
From 584b5fbd4abfc43f920cc1c329633e03816e28be Mon Sep 17 00:00:00 2001
From: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Date: Wed, 20 May 2009 18:26:01 -0400
Subject: [PATCH] Standardize the use of MCFFEC_TOUT_LOOP as a udelay(1) loop counter.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
The problem is that BOOTP_SIZE uses ETHER_HDR_SIZE which is 14 bytes.
If sending a VLAN tagged frame (when env variable vlan is set) this
should be VLAN_ETHER_HDR_SIZE=18 which is what NetSetEther returns.
Signed-off-by: Norbert van Bolhuis <nvbolhuis@aimvalley.nl>
Added CONFIG_NET_MULTI to all Davinci boards
Removed all calls to Davinci network driver from board code
Added cpu_eth_init() to cpu/arm926ejs/cpu.c
Removed pointless #ifdefs
Moved functions around in file in preparation for switch to newer API
This driver has been renamed davinci_emac.c
Chips supported:-
1. 88E6161 6 port gbe swtich with 5 integrated PHYs
2. 88E6165 6 port gbe swtich with 5 integrated PHYs
2. 88E6132 3 port gbe swtich with 2 integrated PHYs
Platform specific configuration supported for:-
default or router port vlan configuration
led_init configuration
mdip/n polarity reversal configuration
Note: This driver is supported and tested against
kirkwood egiga interface
Contributors:
Reviewed by: Ronen Shitrit <rshitrit@marvell.com>
Signed-off-by: Zach LeRoy <zleroy@xes-inc.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
All the Blackfin linker scripts were duplicated across the board dirs with
no difference save from the semi-often used ENV_IS_EMBEDDED option. So
unify all of them in the lib_blackfin/ dir and for the few boards that
need to embedded the environment directly, add a LDS_BOARD_TEXT define for
them to customize via their board config file. This is much simpler than
forcing them to duplicate the rest of the linker script.
The BF51xF parts have an internal SST SPI flash, so make sure the driver is
enabled by default so we can access it.
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup
common Blackfin board defines. The common method now is to use config.h,
so convert blackfin-config-post.h to that. Rename the still Blackfin
specific blackfin-config-pre.h to config-pre.h so the naming conventions
at least line up.
Allow boards to easily override the root= and default bootcmd, allow
people to tweak the file used in default bootcmds at runtime via one env
var, and add a stock nandboot command.
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com>
Newer Blackfin parts can an on-chip ROM that can boot LDRs over SPI flashes,
so add a new 'spibootldr' command to take advantage of it.
For the most part, the Blackfin processor boots files in the LDR format
rather than binary/ELF files. So we want to export the environment as a
raw blob to the LDR utility so it can embed it at the right location.
The Linux kernel has some helper rules which allow you to quickly produce
some of the intermediary files from C source. Specifically, you can
create .i files which is the preprocessed output and you can create .s
files which is the assembler output. This is useful when you are trying
to track down header/macro expansion errors or inline assembly errors.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
