Fix typo in AT91 memory setup.
- add support for "STK52xx" board (including PS/2 multiplexer)
- add hardware detection for TQM5200
* Update MAINTAINERS file
* Fix bug in MPC823 LCD driver
* Enable long help on CMC PU2 board;
fix reset issue;
increase CPU speed from 179 to 207 MHz.
unaligned tail part specially).
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
kernel on xaeniax board.
* Patch by Thomas Lange 07 Oct 2004:
Updated README for DBAu1x00 boards to match current status
Fix Flash support for Versatile.
* Patch by Roger Blofeld, 16 Sep 2004:
Fix timeout for DHCP command retry
Fix early serial hang when CONFIG_SERIAL_MULTI is defined.
* Patch by Pantelis Antoniou, 14 Sep 2004:
Kick watchdog when bz-decompressing
[Remember: CFG_HZ should be 1000 on ALL systems!]
- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- Improve platform.S code for omap1510inn that detects whether code
is running from SDRAM or not. Patch allows SDRAM to be configured
if code is running out of SRAM at 0x20000000.
* Patch by Frederick Klatt, 30 Aug 2004:
Add support for the Wind River SBC8540/SBC8560 boards
* Patches by Michael Bendzick, 30 Aug 2004:
- Configure omap1510inn board to use drivers/cfi_flash.c
- Make drivers/cfi_flash.c protect environment and redundant
environment.
* Patch by Steven Scholz, 23 Jun 2004:
- Add script (tools/img2brec.sh) to programm U-Boot into
(Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
- Enable ramdisk/initrd tagged param support for omap1610h2_config
- Remove static network setup defaults from mx1ads_config
- update ARM boards to use constants from mach-types.h
Patch by Gary Jennejohn, 04 Oct 2004:
- fix I2C on at91rm9200
- add support for Ricoh RS5C372A RTC
- add support for CMC PU2 board
- add support for I2C on at91rm9200
* Patch by Gary Jennejohn, 28 Sep 2004:
fix baudrate handling on at91rm9200
- remove ZPC.1900 board-specific flash driver;
switch the port to generic CFI driver;
- port clean-up
Add calc_fbsize() function used with VIDEOLFB_TAG on TRAB
* Patch by Hinko Kocevar, 21 Aug 2004:
- Group common framebuffer functions in common/lcd.c
- Group common framebuffer macros and #defines in include/lcd.h
- Provide calc_fbsize() for video ATAG
- Fix a typo in README
- Align "(RO)" output for "flinfo" after "protect on"
- Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency
ratio 1:1 when core frequency less than 50MHz
- fix some "use of label at end of compound statement" warnings
- Define type of LCD panel on lubbock board if CONFIG_LCD is used
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)"
- creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0
- moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/
- moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/
parameter type cleanup for NetSetTimeout()
- Added support for both 8 and 16 bit mode access to System ACE CF
through MPU.
- Fixed missing System ACE CF device during get FAT partition info
in fat_register_device function.
- Enabled System ACE CF support on ML300.
* Patch by Sean Chang, 09 Aug 2004:
Synch defines for saveenv and do_saveenv functions so they get
compiled under the same statement.
- Added I2C support for ML300.
- Added support for ML300 to read out its environment information
stored on the EEPROM.
- Added support to use board specific parameters as part of
U-Boot's environment information.
- Updated MLD files to support configuration for new features
above.
* Patches by Travis Sawyer, 5 Aug 2004:
- Remove incorrect bridge settings for eth group 6
- Add call to setup bridge in ppc_440x_eth_initialize
- Fix ppc_440x_eth_init to reset the phy only if its the
first time through, otherwise, just check the phy for the
autonegotiated speed/duplex. This allows the use of netconsole
- only print the speed/duplex the first time the phy is reset.
Add support for MKS Instruments "Quantum" board
* Fix build problem with Cogent boards;
avoid using <asm/byteorder.h> when using the host compiler
Fix NFS timeout issue
- Fix host tools building in Cygwin environment
- Fix header files search order for host tools
* Patch by Tom Armistead, 19 Jul 2004:
Fix kgdb.S support for 74xx_75x cpu
Fix MPC85xx I2C driver
Set the PCI class code for JSE board as part of PCI interface setup
* Patch by Michael Bendzick, 15 Jul 2004:
Fix problem with writes with odd sizes in drivers/cfi_flash.c when
CFG_FLASH_USE_BUFFER_WRITE is set
Allow clock setting on MPC866/MPC885 series chips according to
environment variable `cpuclk'
* Patch by Yuli Barcohen, 20 Apr 2004:
Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
Add support for xaeniax board
