In the upcoming release of axs103 v1.1 CPU will
run @100MHz which we support with that change.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Memory barriers are proven to be a requirement for both compiler and
real hardware to properly serialize access to critical data.
For example if CPU or data bus it uses may do reordering of data
accesses absence of memory barriers might easily lead to very subtle and
hard to debug data corruptions.
This implementation was heavily borrowed from up to date Linux kernel.
Now when we have support of IOC (IO-Coherency block) cahce operations
on regions are tuned to not be dummy stubs if IOC was found and enabled
in the core. That makes flush_dcache_range() useless for our purposes
here. And since we do need to flush modified reset vector to at least L2
cache (AKA SLC) so other cores will see it via its L1 instruction cache
we're using always functional flush_dcache_all() here.
According to ARC HS databook it is required to flush and disable
caches prior programming IOC registers. Otherwise ongoing coherent
memory operations may not observe the coherency protocols as
expected.
But since in ARC HS v2.1 there's no way to disable SLC (AKA L2 cache)
we're doing our best flushing and invalidating it.
invalidate_dcache_all() could be used in different use-cases
and what is especially important most of those cases won't be
related to DMAed data to or from peripherals, i.e. we'll be doing
invalidation of data used purely by CPU cores.
Given that IOC engine only snoops data that goes through DMA
we need to care ourselves about data used only by CPU cores
and so remove dependency on IOC from invalidate_dcache_all()
and always do real invalidation.
In case we have restarted u-boot there is a chance that environment
buffer contains old environment (from the previous boot). If UBI volume
is zero size, ubi_volume_read() doesn't modify the buffer and exits
successfully.
We need to clear buffer manually before reading it from UBI, so the
invalid CRC will cause setting default environment in case that the UBI
volume is zero size.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Tidy up garbage left by commit bb597c0eeb7e ("common: bootdelay: move
CONFIG_BOOTDELAY into a Kconfig option").
At this point, this is not referenced from anywhere, so remove it
(but it will be re-added later for a different meaning).
The sed script, tools/scripts/define2mk.sed, converts config defines
from C headers into include/autoconf.mk for the use in Makefiles.
I found the tool adds quotes around negative integer values.
For example, at the point of the v2016.07-rc1 tag,
include/configs/microblaze-generic.h defines
#define CONFIG_BOOTDELAY -1 /* -1 disables auto-boot */
Because it is an integer option, it should be converted to:
CONFIG_BOOTDELAY=-1
But, the script actually converts it to:
CONFIG_BOOTDELAY="-1"
This is a fatal problem for the tools/moveconfig.py because it parses
include/autoconf.mk for the config defines from the board headers.
CONFIG_BOOTDELAY="-1" is considered as a string type option and it
is dropped due to the type mismatch from the entry in Kconfig.
This commit fixes the script so that the tools/moveconfig.py can
correctly convert integer options with a negative value.
This option allows the 'make autoconf.mk' step to run against a former
repo state, while the savedefconfig step runs against the current repo
state. This is convenient for the case where something in the Kconfig
has changed such that the defconfig is no longer complete with the new
Kconfigs. This feature allows the .config to be built assuming those old
Kconfigs, but then savedefconfig based on the new state of the Kconfigs.
If in doubt, always specify this switch. It will always do the right
thing even if not required, but if it was required and you don't use it,
the moved configs will be incorrect. When not using this switch, you
must very carefully evaluate that all moved configs are correct.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The old color blends in with similar messages and makes them not stand
out.
The Slot.poll() method is already complicated and a new feature
we are going to add will make it more difficult to understand
the execution flow.
Refactor it with helper methods, .handle_error(), .do_defconfig(),
.do_autoconf(), .do_savedefconfig, and .update_defconfig().
I found "tools/moveconfig -s" might be useful for defconfig re-sync.
I could optimize it for re-sync if I wanted, but I do not want to
make the code complex for this feature.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Now, this tools invokes "make savedefconfig" only when it needs to
do so, but there might be cases where a user wants the tool to do
savedefconfig forcibly, for example, some defconfigs were already
out of sync and the user wants to fix it as well.
There are various factors that determine if the given defconfig is
updated, and it is probably what users are more interested in.
Show the log when the defconfig is updated. Also, copy the file
only when the file content was really updated to avoid changing
the time stamp needlessly.
This is a rare case, but there is still possibility that some CONFIG
is moved to the .config, but it is removed by "make savedefconfig".
(For example, it happens when the specified CONFIG has no prompt in
the Kconfig entry, i.e. it is not user-configurable.)
It might be an unexpected case. So, display the log in this case
(in yellow color to gain user's attention if --color option is given).
Now, "make savedefconfig" does not always happen. Display the log
when it happens.
If no CONFIG option is moved to the .config, no need to sync the
defconfig file. This accelerates the processing by skipping
needless "make savedefconfig".
Move similar code to finish() function.
Before this commit, the log was displayed in the format:
<defconfig_name> : <action1>
<defconfig_name> : <action2>
<defconfig_name> : <action3>
When we move multiple CONFIGs at the same time, we see as many
<defconfig_name> strings as actions for every defconfig, which is
redundant information.
Moreover, since normal log and error log are displayed separately,
Messages from different threads could be mixed, like this:
<foo> : <action1>
<foo> : <action2>
<bar> : <action1>
<bar> : <action2>
<foo> : <error_log>
This commit makes sure to call "print" once a defconfig, which
enables atomic logging for each defconfig. It also makes it
possible to refactor the log format as follows:
<foo_defconfig>
<action1>
<action2>
<error_log>
<bar_defconfig>
<action1>
<action2>
This will help further improvement/clean-up.
The paths to .config, include/autoconf.mk, include/config/auto.conf
are not changed during the defconfig walk. Compute them only once
when a new class instance is created.
We still pass the input file with CONFIG name, type, default value
in each line, but the last two fields are just ignored by the tool.
So, let's deprecate the input file and allow users to give CONFIG
names directly from the command line. The types and default values
are automatically detected and handled nicely by the tool.
Going forward, we can use this tool more easily like:
tools/moveconfig.py CONFIG_FOO CONFIG_BAR
Update the documentation and fix some typos I noticed while I was
working on.
Now types and defalut values given by the input file are just
ignored. Delete unnecessary code.
Commit 96464badc794 ("moveconfig: Always run savedefconfig on the
moved config") changed the work flow of this tool a lot from the
original intention when this tool was designed first.
Since then, before running this tool, users must edit the Kconfig to
add the menu entries for the configs they are moving. It means users
had already specified the type and the default value for each CONFIG
via its Kconfig entry. Nevertheless, users are still required to
dictate the same type and the default value in the input file. This
is tedious to use. So, my idea here is to deprecate the latter.
Before moving forward with it, there is one issue worth mentioning;
since the savedefconfig re-sync was introduced, this tool has not
been able to move bool options with "default y". Joe sent a patch
to solve this problem about a year ago, but it was not applied for
some reasons. Now, he came back with an updated patch, so this
problem will be fixed soon.
For other use cases, I see no reason to require redundant dictation
in the input file. Instead, the tool can know the types and default
values by parsing the .config file.
This commit changes the tool to use the CONFIG names, but ignore the
types and default values given by the input file.
This commit also fixes one bug. Prior to this commit, it could not
move an integer-typed CONFIG with value 1.
For example, assume we are moving CONFIG_CONS_INDEX. Please note
this is an integer type option.
Many board headers define this CONFIG as 1.
#define CONFIG_CONS_INDEX 1
It will be converted to
CONFIG_CONS_INDEX=y
and moved to include/autoconf.mk, by the tools/scripts/define2mk.sed.
It will cause "make savedefconfig" to fail due to the type conflict.
This commit takes care of it by detecting the type and converting the
CONFIG value correctly.
Currently, the progress " * defconfigs out of 1133" does not increase
monotonically.
Moreover, the number of processed defconfigs does not match the total
number of defconfigs when this tool finishes, like:
1132 defconfigs out of 1133
Clean up headers? [y/n]:
It looks like the task was not completed, and some users might feel
upset about it.
When the source tree is not clean, this tool raises an exception
with a message like follows:
Traceback (most recent call last):
File "tools/moveconfig.py", line 939, in <module>
main()
File "tools/moveconfig.py", line 934, in main
move_config(config_attrs, options)
File "tools/moveconfig.py", line 808, in move_config
while not slots.available():
File "tools/moveconfig.py", line 733, in available
if slot.poll():
File "tools/moveconfig.py", line 645, in poll
self.parser.update_dotconfig(self.defconfig)
File "tools/moveconfig.py", line 503, in update_dotconfig
with open(autoconf_path) as f:
IOError: [Errno 2] No such file or directory: '/tmp/tmpDtzCgl/include/autoconf.mk'
This does not explain what is wrong. Show an appropriate error
message "source tree is not clean, please run 'make mrproper'"
in such a situation.
Since commit 25400090b1e2 ("moveconfig: Print a message for
missing compiler"), this tool parses an error message every time an
error occurs during the process in order to detect missing compiler.
Instead of that, we can look for compilers in the PATH environment
only once before starting the defconfig walk. If a desired compiler
is missing, "make include/config/auto.conf" will apparently fail for
that architecture. So, the tool can just skip those board, showing
"Compiler is missing. Do nothing.".
We must ensure this tool is run from the top of source directory
before calling update_cross_compile(). Otherwise, the following
exception is thrown:
File "./moveconfig.py", line 918, in <module>
main()
File "./moveconfig.py", line 908, in main
File "./moveconfig.py", line 292, in update_cross_compile
for arch in os.listdir('arch'):
OSError: [Errno 2] No such file or directory: 'arch'
Nesting by "else:" is not generally useful after such statements
as return, break, sys.exit(), etc.
moved config") changed how defconfig files were updated.
Since then, the function update_defconfig() does not modify defconfig
files at all (instead, they are updated by "make savedefconfig"), so
update_dotconfig() is a better fit for this function. Also, update
the comment block to match the actual behavior.
Since commit 96464badc794 ("moveconfig: Always run savedefconfig on
the moved config"), --dry-run option is broken.
The --dry-run option prevents the .config from being modified,
but defconfig files might be updated by "make savedefconfig"
regardless of the --dry-run option.
Move the "if not self.options.dry_run" conditional to the correct
place.
Fixes 96464badc794 ("moveconfig: Always run savedefconfig on the moved config")
Add device tree support.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Add missing parenthesis around the variable into the macro.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Extend the boot device autodetection from SAMA5D2 only to the entire
SAMA5Dx family of microcontrollers.
Cc: Wenyou Yang <wenyou.yang@atmel.com>
[minor compile fix for SAMA5D2]
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
This board is based on Snapper 9G45 which has an Atmel AT91SAM9G45 chip and
128MB of SDRAM. It includes a small LCD, 2xUSB host, SD card, Ethernet and
two UARTs.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
[apply CONFIG_BOOTDELAY transition]
This should return a non-zero value if there is a missing property. Update
the return value accordingly. The only expected error is -FDT_ERR_NOTFOUND.
Add driver-model support to this driver. Most features can be controlled
from the device tree.
Adjust the driver to use struct display_timing for its display timing.
This is what is used by driver-model and allows the LCD init code to be
common.
In order to prevent build errors for copied code from linux introduce
dev_warn().
Suggested-by: Scott Wood <oss@buserror.net>
Add these definitions so that GPIOs can be used with driver model.
Tested-on: smartweb, corvus, taurus, axm
Tested-by: Heiko Schocher <hs@denx.de>
This needs to be set to avoid a fatal error when ECC is used.
This uses the wrote base register value. Fix it.
Add register definitions for the AT91 RTC so that this can potentially be
used in U-Boot.
Add this file from Linux v4.5.
