2004-01-06Fix comment.U-Boot-1_0_1wdenk
2004-01-06Set default clock for INCA-IP to 150 MHzwdenk
Prepare for 1.0.1 release
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2004-01-03* Patch by Robert Schwebel, 15 Dec 2003:wdenk
add support for cramfs (uses JFFS2 command interface)
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
2004-01-02* Patch by Denis Peter, 8 Dec 2003wdenk
- add support for the PATI board (MPC555) - add SPI support for the MPC5xx * Patch by Anders Larsen, 08 Dec 2003: add configuration options CONFIG_SERIAL_TAG and CONFIG_REVISION_TAG to pass ATAG_SERIAL and ATAG_REVISION, resp., to the ARM target; cleanup some redundand #defines
2004-01-02* Patch by André Schwarz, 8 Dec 2003:wdenk
fixes for Davicom DM9102A Ethernet Chip (#define CONFIG_TULIP_FIX_DAVICOM): - TX and RX deskriptors must be quad-word aligned - does not work with only one TX deskriptor - standard reset method does not work * Patch by Masami Komiya, 08 Dec 2003: add RTL8139 ethernet driver * Patches by Ed Okerson, 07 Dec 2003: - fix ethernet for the AU1x00 processors in little-endian mode. - extend memsetup.S for the AU1x00 processors in BE and LE modes
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-28Patch by Reinhard Meyer, 28 Dec 2003:wdenk
Add initial support for TOP5200 board
2003-12-27Cleanupwdenk
2003-12-27* Make CPU clock on ICA-IP board controllable by a "cpuclk"wdenk
environment variable which can set to "100", "133", or "150". The CPU clock will be configured accordingly upon next reboot. Other values are ignored. In case of an invalid or undefined "cpuclk" value, the compile-time default CPU clock speed will be used. * Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory window that is used to access the UART registers by the Linux driver) * Patch by Reinhard Meyer, 20 Dec 2003: Fix clock calculation for the MPC5200 for higher clock frequencies (above 2**32 / 10 = 429.5 MHz).
2003-12-20* Fix IceCube CLKIN configuration (it's 33.000000MHz)wdenk
* Add new configuration for IceCube board with DDR memory * Update TRAB memory configurations
2003-12-12Add JFFS2 support for INCA-IP boardwdenk
2003-12-09Minor reformattingwdenk
2003-12-09Patch by Bill Hargen, 09 Dec 2003.stroese
2003-12-09BUBINGA405EP added.stroese
2003-12-09Updated for PPC405EP boards.stroese
2003-12-09Fix output for "Unprotecting".stroese
2003-12-09Debug printf's removed.stroese
2003-12-09Updated for PPC405EP boards (2 banks only).stroese
2003-12-09BUBINGA405EP port fixed.stroese
2003-12-08* Patch by Bernhard Kuhn, 28 Nov 2003:wdenk
add support for Coldfire CPU add support for Motorola M5272C3 and M5282EVB boards
2003-12-07* Patch by Pierre Aubert, 24 Nov 2003:wdenk
- add a return value for the fpga command - add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT is defined. If ide_preinit fails, ide_init is aborted. - fix an endianess problem in fat.h
2003-12-07Patch by Wolter Kamphuis, 05 Dec 2003:wdenk
Add support for SNMC's QS850/QS823/QS860T boards
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-12-07* Patch by Andre Schwarz, 24 Nov 2003:wdenk
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards * Patch by Pavel Bartusek, 21 Nov 2003: set ZMII bridge speed on 440 * Patch by Anders Larsen, 17 Nov 2003: Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-12-07* Patch by Xue Ligong (Joe), 13 Nov 2003:wdenk
add Realtek 8019 ethernet driver * Patch by Yuli Barcohen, 13 Nov 2003: MPC826xADS/PQ2FADS cleanup * Patch by Anders Larsen, 12 Nov 2003: Update README to mark the PORTIO commands non-standard
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
2003-12-06* Patches by Stephan Linz, 3 Nov 2003:wdenk
- more endianess fixes for LAN91C111 driver - CFG_HZ configuration patch for NIOS Cyclone board * Patch by Stephan Linz, 28 Oct 2003: fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c * Patch by Steven Scholz, 20 Oct 2003: - make "mii info <addr>" show infor for PHY at "addr" only - Endian fix for miiphy_info()
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-12-06Accelerate booting on TRAB board: read and check autoupdate imageLABEL_2003_12_06_1550wdenk
headers first instead of always reading the whole images.
2003-12-05Fix typo in MPC5XXX code (pointed out by Victor Wren)wdenk
2003-12-03* Enabled password check on RMU boardwdenk
* Fix configuration problem with IceCube in LOWBOOT configuration: environment got embedded, corrupting the image layout.
2003-11-25Add support for BMS2003 boardwdenk
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display). Fix NEC display names (it's 6440 [for 640x480], not 6640).
2003-11-17Fix flash driver for TRAB board (must use Unlock Bypass Reset commandLABEL_2003_11_26_MKRwdenk
to exit Unlock Bypass Mode); adjust timings for flash, SRAM and CPLD
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-11-07* Patch by Bernhard Kuhn, 28 Oct 2003:wdenk
Add low boot support for MPC5200 * Fix problem with dual PCMCIA support (NSCU) * Fix MPC5200 I2C initialization function
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-10-28* Patch by Stephan Linz, 28 Oct 2003:wdenk
fix init sequence error for NIOS port * Allow lowercase spelling for IceCube_5200; support MPC5200LITE name * Add CONFIG_VERSION_VARIABLE to TRAB configuration
2003-10-26* Patch by Xiao Xianghua, 23 Oct 2003:wdenk
small patch for mpc85xx * Fix small problem in MPC5200 I2C driver * Fix FCC3 support on ATC board
2003-10-24* Correct header printing for multi-image files in do_bootm()dzu
* Make CONFIG_SILENT_CONSOLE work with CONFIG_AUTOBOOT_KEYED
2003-10-22Fix PCI problems on PPChameleon boardwdenk
2003-10-19* Patch by Steven Scholz, 18 Oct 2003:wdenk
Fix AT91RM9200 ethernet driver * Patch by Nye Liu, 17 Oct 2003: Fix typo in include/mpc8xx.h * Patch by Richard Woodruff, 16 Oct 03: Fixes for cpu/arm925/interrupt.c - Initialize timestamp & lastdec vars. - fix timestamp overflows. - fix lastdec overflow. - smarter normalization to allow udelay() below 1ms to work. * Patch by Scott McNutt, 16 Oct add networking support for the Altera Nios Development Kit, Cyclone Edition (DK-1C20) * Patch by Jon Diekema, 14 Oct 2003: add hint about doc/README.silent to README file
2003-10-19* Fix PCI problems on PPChameleonEVBLABEL_2003_10_20_0025wdenk
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
2003-10-19Add CompactFlash support for NSCUdzu
