2014-11-24Revert "hush: fix segfault on syntax error"Rabin Vincent
128059b92 ("hush: fix segfault on syntax error") attempted to fix a segfault on syntax errors, but it broke Ctrl-C handling, and the assumption that it made, that rcode could not be -1, is incorrect. Revert this change. Reported-by: Stephen Warren <swarren@wwwdotorg.org> Reported-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Rabin Vincent <rabin@rab.in>
2014-11-24Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24mx6boards: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Benard <eric@eukrea.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24nitrogen6x: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24ot1200: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24arm: imx: stop sata on bootNikita Kiryanov
Ideally, the Linux kernel should get the hardware in its most untouched state. For the most part, U-Boot does not reset the various subsystems it touches before boot, and usually Linux deals with it, but on some boards (cm_fx6) the Linux kernel fails to detect the ssd correctly if sata is used by U-Boot. Power off sata on OS boot so that Linux will have a clean state to work with. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-24arm: mx6: cm_fx6: implement board specific sata stopNikita Kiryanov
Provide board specific implementation for sata stop command for cm_fx6. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-24cmd_sata: implement sata stop commandNikita Kiryanov
Implement sata stop command. This introduces the __sata_stop() weak function, which mirrors the weak __sata_initialize() function, giving users the option of undoing the custom steps performed in overrides of sata_initialize(). Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-11-24sata: implement reset_sata for dwc_ahsataNikita Kiryanov
Add reset_sata() to the sata driver interface and implement it for dwc_ahsata. This function cleans up after sata_init(), and therefore accepts a device number like sata_init() does. A dummy implementation is provided for the rest of the drivers. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de>
2014-11-24arm: mx6: introduce disable_sata_clockNikita Kiryanov
Implement disable_sata_clock for mx6 SoCs. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-24gw_ventana: Use the generic spl_sd.cfgFabio Estevam
gw_ventana can boot from SPI or NAND and both of these interfaces boot from the same 0x400 offset. This means that we could simplify the code and replace the custom gw_ventana.cfg with the generic spl_sd.cfg, as it provides the same boot offset of 0x400. Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-23sandbox: script for testing sandbox/ext4/fat/fs commandsSuriyan Ramasami
Test size/read/write commands in a sandbox environment. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23ext4: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal EXT4 functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update common/spl/spl_ext.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23board/esd/common/auto_update.c: Use <flash.h>Tom Rini
A number of prototypes here are now found in <flash.h>. use. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Use md5sum and fatwrite to enable testing of fs commandsSuriyan Ramasami
Enable md5sum to obtain the MD5 of the read and written files to check their contents for validity. Use map_sysmem() to map buffer in a sandbox environment. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: fix gcc warning on MIPS64Daniel Schwierzeck
This fixes following warning when compiled with MIPS64 common/board_f.c: In function 'display_text_info': common/board_f.c:150:2: warning: format '%X' expects argument i of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat=] debug("U-Boot code: %08X -> %08lX BSS: -> %08lX\n", Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: add setup of initial stack frame for MIPSDaniel Schwierzeck
The MIPS specific setup of the initial stack frame was not ported to generic board_f. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-23spl: fix descending condition to drivers/mtd/nand/Masahiro Yamada
SPL should not reference CONFIG_CMD_NAND to decide whether or not it should build drivers/mtd/nand. CONFIG_CMD_NAND should be only used to select the NAND utility command on the command parser. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23commands: add more command entries in KconfigMasahiro Yamada
This commit adds some of command entries (CONFIG_CMD_*) to cover include/config_cmd_default.h and a little extra. Because U-Boot supports lots of commands, they should be categorized according to their usage. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23hush: add CONFIG_HUSH_PARSER to KconfigMasahiro Yamada
The README file states that the macros beginning with "CONFIG_SYS_" depend on the hardware etc. and should not be meddled with if you do not what you're doing. We have already screwed up with this policy; we have given the prefix "CONFIG_SYS_" to many user-selectable configurations. Here, "CONFIG_SYS_HUSH_PARSER" is one of them. Users can enable it if they want to use a more powerful command line parser, or disable it if they only need a simple one. This commit attempts to rename CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSER and move it to Kconfig. Every board maintainer is expected to enable CONFIG_HUSH_PARSER (= add "CONFIG_HUSH_PARSER=y" to his defconfig file) and remove "#define CONFIG_SYS_HUSH_PARSER" from his header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23FIT: add some FIT configurations to KconfigMasahiro Yamada
2014-11-23config: remove redundant CONFIG_SYS_PROMPT definesMasahiro Yamada
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT), each board header does not need to define CONFIG_SYS_PROMPT as long as it uses the default prompt "=> ". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23tegra: do not descend into empty directoriesMasahiro Yamada
Some tegra makefiles only contain a dummy line to generate a built-in.o. Let's do not descend into such directories. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23kbuild: use SoC-specific CONFIG to descend into SoC directoryMasahiro Yamada
Use "obj-$(CONFIG_FOO) += foo/" where it is possible. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23x86: use CONFIG_SYS_COREBOOT to descend into coreboot/ directoryMasahiro Yamada
The references of CONFIG_SYS_COREBOOT in arch/x86/cpu/coreboot/Makefile are redundant because the build system descends into the directory only when CONFIG_SYS_COREBOOT is defined. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23Add pr_fmt() macroThierry Reding
This macro can be overridden in source files (before including common.h) and can be used to specify a prefix for debug and error messages. An example of how to use this is shown below: #define pr_fmt(fmt) "foo: " fmt #include <common.h> ... debug("bar"); The resulting message will read: foo: bar Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23pci: Honour pci_skip_dev()Thierry Reding
When enumerating devices, honour the pci_skip_dev() function. This can be used by PCI controller drivers to restrict which devices will be probed. This is required by the NVIDIA Tegra PCIe controller driver, which will fail with a data abort exception if an access is attempted to a device number larger than 0 outside of bus 0. pci_skip_dev() is therefore implemented to prevent any such accesses. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23pci: Abort early if bus does not existThierry Reding
When listing the devices on a PCI bus, the current code will blindly try to access all devices. Internally this causes pci_bus_to_hose() to be repeatedly called and output an error message every time. Prevent this by calling pci_bus_to_hose() once and abort early if no bus was found. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23vsprintf: Add modifier for phys_addr_tThierry Reding
Provide a new modifier to vsprintf() to print phys_addr_t variables to avoid having to cast or #ifdef when printing them out. The %pa modifier is used for this purpose, so phys_addr_t variables need to be passed by reference, like so: phys_addr_t start = 0; printf("start: %pa\n", &start); Depending on the size of phys_addr_t this will print out the address with 8 or 16 hexadecimal digits following a 0x prefix. Signed-off-by: Thierry Reding <treding@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23fs: make it possible to read the filesystem UUIDChristian Gmeiner
Some filesystems have a UUID stored in its superblock. To allow using root=UUID=... for the kernel command line we need a way to read-out the filesystem UUID. changes rfc -> v1: - make the environment variable an option parameter. If not given, the UUID is printed out. If given, it is stored in the env variable. - corrected typos - return error codes changes v1 -> v2: - fix return code of do_fs_uuid(..) - document do_fs_uuid(..) - implement fs_uuid_unsuported(..) be more consistent with the way other optional functionality works changes v2 -> v3: - change ext4fs_uuid(..) to make use of #if .. #else .. #endif construct to get rid of unreachable code Hit any key to stop autoboot: 0 => fsuuid fsuuid - Look up a filesystem UUID Usage: fsuuid <interface> <dev>:<part> - print filesystem UUID fsuuid <interface> <dev>:<part> <varname> - set environment variable to filesystem UUID => fsuuid mmc 0:1 d9f9fc05-45ae-4a36-a616-fccce0e4f887 => fsuuid mmc 0:2 eb3db83c-7b28-499f-95ce-9e0bb21cda81 => fsuuid mmc 0:1 uuid1 => fsuuid mmc 0:2 uuid2 => printenv uuid1 uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887 => printenv uuid2 uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81 => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-11-23sata: fix a bug in init_sata() for pci-sata cardli pengbo
Except the first loop, init_sata() should return 0 instead of 1 in the others. This patch fix the issue of the 2nd sata port not workable on pci-sata card. Signed-off-by: Pengbo Li <Pengbo.Li@freescale.com>
2014-11-23ARM: bcm: Enable bcm11130 boardsSteve Rae
bcm11130 bcm11130_nand Signed-off-by: Steve Rae <srae@broadcom.com>
2014-11-23ARM: bcm: Enable five Cygnus boardsSteve Rae
bcm911360_entphn bcm911360_entphn-ns bcm911360k bcm958300k-ns bcm958305k - updates to support Cygnus and NSP board families better - add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards Signed-off-by: Steve Rae <srae@broadcom.com>
2014-11-23spl: Change debug to printf for "Unsupported boot-device"Stefan Roese
We had the problem on an AM33xx platform, that SPL detected an unsupported boot-device. But since this message is a debug message it took a bit of time to really know, where the hangup in SPL resulted from. So let's change this debug message to a printf and also print the detected boot-device that is not supported. This makes debugging of such cases much easier. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-22dm: core: remove unnecessary return condition in uclass lookupMasahiro Yamada
These conditions never happen. - There is no real uclass with UCLASS_INVALID id. - uclass never becomes NULL because ll_entry_start() always returns a valid pointer. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-22dm: core: remove unnecessary return condition in driver lookupMasahiro Yamada
The variable "drv" never becomes NULL because ll_entry_start() always returns a valid pointer even if there are no entries. The case "n_ents == 0" is covered by the following "for" loop. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-22dm: core: remove meaningless if conditionalMasahiro Yamada
If the variable "ret" is equal to "-ENOENT", it is trapped at [1] and never reaches [2]. At [3], the condition "ret != -ENOENT" is always true. if (ret == -ENOENT) { <------------------ [1] continue; } else if (ret == -ENODEV) { dm_dbg("Device '%s' has no compatible string\n", name); break; } else if (ret) { <------------------ [2] dm_warn("Device tree error at offset %d\n", offset); if (!result || ret != -ENOENT) <------------------ [3] result = ret; break; } Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-22dm: core: a trivial clean upMasahiro Yamada
2014-11-22cros_ec: Fix uninitialised variable in cros_ec.cSimon Glass
This fixes this cppcheck report: [drivers/misc/cros_ec.c:704]: (error) Uninitialized variable: req Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Wolfgang Denk <wd@denx.de>
2014-11-22dm: spi: Use device_bind_driver() instead of our own functionSimon Glass
The SPI function does the same thing, so we may as well just use the new generic function. The 'cs' parameter was not actually used, so can be dropped. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-22dm: spi: Correct handling of SPI chip selects in sandboxSimon Glass
This code was not updated when the chip select handling was adjusted. Fix it to call the correct function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-22dm: Add a function to bind a device by driver nameSimon Glass
In some cases we need to manually bind a device to a particular driver. Add a function to do this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-22dm: fdt: Correct handling of aliases with embedded digitsSimon Glass
Since we scan from left to right looking for the first digit, "i2c0" returns 2 instead of 0 for the alias number. Adjust the code to scan from right to left instead. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
