Signed-off-by: Robin Getz <robin.getz@analog.com>
We need signal.h for Blackfin/KGDB, so import the asm-generic/signal.h
for people to leverage.
cramfsls and cramfsload are added to the command list.
A cramfs placed at 'cramfs_addr' can the be listed with 'cramfsls' and files
can be loaded with 'cramfsload'. 'cramfs_addr' is an environment variable
specifying the address the cramfs is located.
This works for powerpc and for ARM.
Use CONFIG_CMD_CRAMFS.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
- malloc size 4 MB for all keymile boards
- use generic FDT code for fixing up the DTS
- enable unit-led at startup for keymile boards
- remove some dts updates for keymile boards
- ppc_83xx, kmeter1: take FE/GbE PHYs out of reset
- ppc_83xx, kmeter1: change from Intel Strata to Spansion 64MB flash
changed from Intel Strata to Spansion 64MB flash and changed flash layout.
| name | size | range | description |
| u-boot | 768 KB | 0xf0000000-0xf00bffff | for u-boot |
| env | 128 KB | 0xf00c0000-0xf00dffff | for environment |
| envred | 128 KB | 0xf00e0000-0xf00fffff | for environment (redundant) |
| ubi0 | 64512 KB | 0xf0100000-0xf3ffffff | ubi0 for ubi volumes |
Add redundant environment support for environment lying on a EEPROM.
Tested on uppcoming suen3 support
- CONFIG_ENV_EEPROM_IS_ON_I2C
define this, if you have I2C and SPI activated, and your
EEPROM, which holds the environment, is on the I2C bus.
- CONFIG_I2C_ENV_EEPROM_BUS
if you have an Environment on an EEPROM reached over
I2C muxes, you can now define, how to reach this
EEPROM.
the macros likely and unlikely were defined in include/linux/mtd/compat.h,
but used in code not related to MTD. moved the macro definitions to compiler.h
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Current code uses the second argument to bootm for standalone images to
override the load address specified in the image instead of passing all
parameters as is to the application. This behaviour is not documented
and not in line with how the go command works for standalone applications,
so we simply drop it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
In case we boot an image marked as 'standalone' and 'linux', the current
code erroneously tried to load a ramdisk.
Convert the funcs to do the conversion inline so that we can do the copy
all at once with memcpy. This let's us push out an weird arch-specific
issue with accessing different regions of memory to the memcpy function
like the MMRs on Blackfin systems, and it should be a bit faster.
The debugger_exception_handler definition is the same for everyone, so use
the common one now.
The default kgdb functions can be implemented with common U-Boot functions,
so rather than force everyone to copy & paste these things, create a set of
weak stubs.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
There are a bunch of features in U-Boot that we want to enable by default,
and it's best if we centralize them in one place rather than updating all
the board files out there.
When referring to PCIe and USB 'endpoint' is the standard naming
convention.
Acked-by: Remy Bohmer <linux@bohmer.net>
There are boards out there that do not have network support in
U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This
makes it desirable to be able to port network configuration (like
the IP address) to the Linux kernel.
We should not make the passing of the IP configuration to Linux
dependent on U-Boot features / settings.
For this, make getenv_IPaddr() global. This fixes build error
u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr'
on various architectures.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Nothing in U-Boot uses runtime C++ exceptions/unwinding, so there is no
need to list this section.
This is just Blackfin catching up with every one else.
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
The addition of KGDB overflowed the current linker section.
Need to reload the loop counters to keep from corrupting hardware loops.
Crashes rarely happen in the CPLB miss handler compared to the rest of
U-Boot code, so disable hardware tracing when processing misses. This
way a crash due to other functions will be shown properly.
The new board revision has a different LCD.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
If the requested clock cannot be exactly obtained, round it up so that we
err on the side of slightly slower rather than slightly faster.
Some common code uses more of the io.h funcs than we currently provide, so
pull in all of the ones from the linux kernel.
These need to be rethought, but until that happens, isolate the hack so
that we can extend the common code without breaking things.
Give the CF/IDE code its own file to keep things cleanly separated. While
we're here, clean up the code to use common functions.
Some SPI devices like to see high idle values rather than low.
The single initcode function was growing unwieldy, so split it up the
distinct steps into their own function. This should making digesting the
result much easier on people.
We need the definition of bd_t in this header, so pull in asm/u-boot.h.
While the initdram() function makes sense on some arches, it doesn't for
Blackfin systems as it's always implemented the same way.
The length of the sections is fixed at link time, so let the linker do the
calculation rather than doing it ourselves at runtime.
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru>
Very little additional code overhead, and only works when the user sets an
env var ahead of time, so default to on makes sense.
