Add header files for blackfin new processor bf60x.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Add support for per architecture CROSS_COMPILE toolchain definitions
via CROSS_COMPILE_ARCH where "ARCH" is any of the supported u-boot
architectures. This allows building every supported u-boot board in a
single pass of MAKEALL.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
Currently, in gpt command, partion size is converted from string
to unsigned long type using 'ustrtol' function. That type limits
the partition size to 4GB.
This patch changes the conversion function to 'ustrtoll' to return
unsigned long long type.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
The issue got introduced in a cleanup by Manjunath Hadli in commit
826e99136e2bce61f3f6572e32d7aa724c116e6d. The eth_getenv_enetaddr_by_index
method will validate the MAC addr and if none is set in the environment
0 will be returned. Set the MAC from the eeprom if no valid address
is found in environment.
Signed-off-by: Holger Hans Peter Freyther <holger@freyther.de>
u-boot is not consistent if state should be 0|1 or of the enum, the
GPIO driver expects this to be one of the enum values. Update the
caller.
The differences include the number of GPIOs and that one is
not required to set the pinmux on request.
Fix broken bootvx command.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
Fix a comment in the fw_env.config file, no functional change.
Add 'ustrtoull' function to convert size from string (ex: 1GiB)
to unsigned long long type
On architectures where manual relocation
is needed, the 'malloc_bin_reloc' function
must be called after 'mem_malloc_init'.
Make the 'malloc_bin_reloc' function static
and call it directly from 'mem_malloc_init'
instead of calling that from board_init_{r,f}
functions of the affected architectures.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
This saved 640 bytes on MPC8536DS (a board with two of the six
ports defined).
This is available on other architectures, and nds32 will start to break
without it as code starts to use error numbers more.
There is no need for a environment variable to configure the dtt bus.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Remove it from the processor specific headers. This is
already defined in the common header km83xx.h.
This board is similar to TUXX1 but it has a different sized second
FPGA. Therefore the configuration for the third chipselect is different.
This is a preparation for the upcoming kmopti2 board. This board has
also a second fpga on board which is different to the tuxx1 target. But we
want to use the same header file. So remove the config option
KM_DISABLE_APP2 and simply use the board names to distinguish the features.
If CONFIG_NAND_ECC_BCH is chosen from in the board configuration we add
an ecc mode to the kernel commandline.
Switch from 1-bit ecc to 4-bit ecc.
If CONFIG_NAND_ECC_BCH is set we use 4-bit error corretion code
instead of the 1-bit error correction code on the NAND device
within this driver.
Acked-by: Scott Wood <scottwood@freescale.com>
Replace uImage with ${uimage}.
If uimage is not set, default it to uImage.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
Replace the hardcoded string with a variable. If CONFIG_NAND_ECC_BCH is
set we use a specific name for the uImage (ecc_bch_uImage).
On this board we are using hard floating point, so select the correct
toolchain.
kmvect1 has a UEC2 connection to the piggy board and a UEC0 connection
to the switch MV88E6122. This switch has a connection to a frontport
ethernet interface. The ethernet port used for network booting is
automatically selected by u-boot. If a Piggy is plugged, the Piggy
port is selected (UEC2, eth1). If the Piggy isn't present, the
Frontport is selected (UEC0, eth0).
The switch reset is connected to a GPIO on the PRIO3 board FPGA (GPIO28)
and released at startup.
Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com>
For the the kmvect1 board we will also need a functionality to add an
offset to the IVMs MAC address, because these board will have two valid
ethernet ports for debugging purpose. So move the code to an own
function.
For kmvect1 we need a special solution and for km_arm boards we already
have. So move the common code to the architectur specific file.
This define isn't set within our setup files. So we can safely remove
the affected code.
EEprom_ivm_addr isn't set in our environment, so remove the usage of
this.
All boards from this serie use i2c. There is no need to #ifdef the
header.
Remove the manual relocation of env_name_spec. This has been missed
in the previous patch series for introducing dynamic relocation
on MIPS.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This code is pretty old and we want to support only 32-bit systems now.
Acked-by: Graeme Russ <graeme.russ@gmail.com>
Invert the polarity of this option to simplify the Makefile logic.
Acked-by: Gabe Black <gabeblack@chromium.org>
These lines are dealt with in the x86 Makefile and link script, so punt
them.
This x86 CPU variant is no longer required as the boards that use it have
been removed.
These are no longer used and should be removed.
The code handles relocation entries with the
following relocation types only:
mips32: R_MIPS_REL32
mips64: R_MIPS_REL+R_MIPS_64
xburst: R_MIPS_REL32
Other relocation entries are skipped without
processing. The code must be extended if other
relocation types must be supported.
Add -pie to LDFLAGS_FINAL to generate the .rel.dyn
fixup table, which will be applied to the relocated
image before transferring control to it.
The CONFIG_NEEDS_MANUAL_RELOC is not needed
after the patch, so remove that as well.
This section contain the table needed for dynamic
relocation. Also provide symbols for the relocation
code to access the table.
Discard all sections which are not needed in the final
ELF binary and U-Boot image. Section .dynsym cannot be
discarded or GNU ld crashes otherwise. This section
will be stripped by GNU objcpy in a later patch.
Use the newly introduced symbol __image_copy_end as end address for
relocation of U-Boot image. This is needed for dynamic relocation added
in later patches. This patch obsoletes the symbols uboot_end and
uboot_end_data which are removed.
Get the start and end address for clearing BSS from the newly
introduced symbols __bss_start and __bss_end. After GOT is
relocated, those symbols are already pointing to the correct
addresses.
Also optimize the loop by moving the address incrementation
to the delay slot to avoid the initial sub instruction.
Use the newly introduced symbols __image_copy_end and __bss_end
for setting up the memory area for the relocated U-Boot.
This symbol is used in later patches as end address
for relocation of the U-Boot image into RAM.
These symbols are used in later patches for as addresses for
clearing the BSS area in the relocated U-Boot image.
The '__got_start' and '__got_end' symbols are used
only in the linker script to compute the value of
the 'num_got_entries' symbol.
Remove the symbols and use the SIZEOF(.got) command
to get the size of the .got section.
Adopt reset vector handling from Yamon.
