- change gpio pin settings:
- gpio pin 6[13] (PLC reset) default value low
- gpio pin 6[0] (TPM reset) default value low
- 4 new GPIO pins
pin i/o name
- 3[9] input Board Type
- 2[7] input HW-ID0
- 2[6] input HW-ID1
- 2[3] input HW-ID2
- read board type and hw id from gpio pins on the enbw_cmc board,
and use board type for setting up different gpio pin settings.
- do not pass "davinci_mmc.use_dma=0" to linux, as MMC now
works with DMA.
- update logbuf support:
store post word in RTC scratch register
- add support for configuring KSZ8864RMN switch through
a config file on u-boot startup. For more infos see:
doc/README.switch_config
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
We do not need to call init_timer both in SPL and U-Boot itself, just
SPL needs to initialize the timer.
Signed-off-by: Thomas Weber <thomas@tomweber.eu>
Fix the .dts file USB unit addresses not to duplicate each-other.
Fix the board name string to indicate the vendor is Compulab not NVIDIA.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Walk the BIT and BCT to find the ODMDATA word in the
CustomerData field and put it into Scratch20 reg for
use by kernel, etc.
Built all Tegra builds OK; Booted on Seaboard and saw
ODMDATA in PMC scratch20 was the same as the value in my
burn-u-boot.sh file (0x300D8011). NOTE: All flash utilities
will have to specify the odmdata (nvflash --odmdata n) on
the command line or via a cfg file, or built in to their
BCT.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The SPI hardware on Seaboard is too broken to use; it is muxed with the
console UART and requires evil interactions between the SPI and UART
drivers to work even partially. The current code in U-Boot is not
sufficient to make this work correctly; auto boot is aborted due to
corruption in the UART RX channel interrupting it.
Instead, move the environment to eMMC, at the end of the second boot
sector. This should not conflict with any other eMMC usage, irrespective
of whether the board boots from SPI, NAND, or eMMC: if U-Boot is stored
in eMMC, it will be stored well below this location. The kernel only
uses the general area of the eMMC once booted, not the boot sectors.
Boards that are derivatives of Seaboard don't have the muxing issue,
and should/could have a separate U-Boot configuration file that does
enable SPI if desired.
Alternatively, the environment could be stored in NAND flash, but we
currently have no driver for that controller.
Store the environment in eMMC, at the end of the second boot sector.
This should not conflict with any other eMMC usage: U-Boot is stored
well below this location, and the kernel only uses the general area
The chosen flash offset matches Compulab's downstream U-Boot.
In anticipation of Tegra3 support, continue removing/renaming
Tegra2-specific files. No functional changes (yet).
Updated copyrights to 2012.
In anticipation of Tegra3 support, start removing/renaming
Also updated copyright to 2012.
Note: This assumes the user plugged the standard 8MB MoviNAND card into
J29/HSMMC/POP. If they didn't, the boot sector layout may be different.
However, use of that particular card is standard practice as far as I
know.
This chip is present on the Compulab TrimSlice.
This allows MMC drivers to perform cache flusing on the bufffers
without issue.
Cc: Andy Fleming <afleming@gmail.com>
Add a device tree for Ventana; the Seaboard file no longer represents
the HW present on Ventana.
Enable USB on Ventana.
The SMSC95xx series may exist either directly on a main board, or as a USB
to Ethernet dongle. However, dongles containing these chips are very rare.
Hence, remove this config option, except on Harmony where such a chip is
actually present on the board.
The asix option remains, since it's a popular chip, and I actively use a
dongle containing this.
Override -march setting for tegra to -march=armv4t for files that are
necessary for low level init on tegra.
The recent change to use -march=armv7-a for armv7 caused a regression
on tegra because tegra starts boot on a arm7tdmi processor before
transferring control to the cortex-a9. While still executing on the
arm7tdmi there are calls to getenv_ulong() and memset() that cause an
illegal instruction exception if compiled for armv7.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Correct this warning seen by Albert:
ap20.c:44:18: warning: array subscript is above array bounds
There is a subtle bug here which currently causes no errors, but might
in future if people use PCI or the 32KHz clock. So take the opportunity
to correct the logic now.
... to enable USB host support, which enables Ethernet support.
This will be used on TrimSlice.
This is based on top of:
tegra: add alternate UART1 funcmux entry
tegra: add UART1 on GPU funcmux entry
v2: remove enum change
Signed-off-by: Lucas Stach <dev@lynxeye.de>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Tom Warren <twarren@nvidia.com>
CC: Marek Vasut <marex@denx.de>
TrimSlice uses UART1 on the GPU pingroup.
CONFIG_CMD_PING/NFS aren't required for Whistler to boot.
Add some comments.
This implements a useful bootcmd for Tegra. The boot order is:
* If USB enabled, USB storage
* Internal MMC (SD card or eMMC)
* If networking is enabled, BOOTP/TFTP
When booting from USB or MMC, the boot script is assumed to be in
partition 1 (although this may be overridden via the rootpart variable),
both ext2 and FAT filesystems are supported, the boot script may exist
in either / or /boot, and the boot script may be named boot.scr.uimg or
boot.scr.
When booting over the network, it is assumed that boot.scr.uimg exists
on the TFTP server. There is less flexibility here since those setting
up network booting are expected to need less hand-holding.
In all cases, it is expected that the initial file loaded is a U-Boot
image containing a script that will load the kernel, load any required
initrd, load any required DTB, and finally bootm the kernel.
console isn't used by anything, and the kernel should be set appropriately
by whatever script is booting the kernel, not imposed by the bootloader.
mem might be useful, but the current value is pretty bogus, since it
includes nvmem options that make no sense for an upstream kernel, and
equally should not be required for any downstream kernel. Either way, this
is also best left to the kernel boot script.
smpflag isn't used by anything, and again was probably intended to be a
kernel command-line option better set by the kernel boot script.
Whistler is a highly configurable Tegra evaluation and development board.
This change adds support for the following specific configuration:
E1120 motherboard
E1108 CPU board
E1116 PMU board
The motherboard configuration switches are set as follows:
SW1=0 SW2=0 SW3=5
S1/S2/S3/S4 all on, except S3 7/8 are off.
Other combinations of daugher boards may work to varying degrees, but will
likely require some SW adjustment.
(In at least some configurations) Whistler uses UART1 on pingroups
UAA, UAB.
Simon Glass's proposal to fix this on Seaboard was NAK'd, so I
removed his NS16550 references and added a small delay before
SPI/UART muxing. Tested on my Seaboard with large SPI reads/writes
and saw no corruption (crc's matched) and no spurious comm chars.
Tested-by: Jimmy Zhang <jimmzhang@nvidia.com>
Use the POSIX variant of basename due to BSD systems (e.g. OS X) do not provide
GNU version of basename(3). It is save to use the POSIX variant here cause we do
never use argv[0] later on which may be modified by the basename(3) POSIX
variant.
On systems providing GNU variant the GNU variant should be used since string.h
is included before libgen.h. Therefore let the _GNU_SOURCE as is.
This patch fixes following warning (on OS X):
---8<---
mkenvimage.c: In function ‘main’:
mkenvimage.c:105: warning: implicit declaration of function ‘basename’
mkenvimage.c:105: warning: assignment makes pointer from integer without a cast
--->8---
cc: Keith Mok <ek9852@gmail.com>
The value of ET0_ERXD6 and GPSR1_INIT was wrong.
This fixes them.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This patch dramatically drops the amount of time u-boot needs to read a
file from an ext2 partition. On a typical 2 to 5 MB file (kernels and
initrds) it goes from tens of seconds to a couple seconds.
All we are doing here is grouping contiguous blocks into one read.
Boot tested on Globalscale Technologies Dreamplug (Kirkwood ARM SoC)
with three different files. sha1sums were calculated in Linux
userspace, and then confirmed after ext2load.
Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Add a new command "sysboot" which parses syslinux menu files and boots
using kernel and initrd specified by menu files. The operation is similar
to "pxe boot" except local files on ext2 or fat filesystem are parsed.
For syslinux, the initrd can be set in the append string as
"initrd=<file>", so try to find it there if we haven't already set the
initrd.
If the file path starts with a '/', then don't pre-pend the bootfile path.
This fixes a problem with running 'pxe boot' multiple times where the
bootfile path gets pre-pended to itself each time.
Kernels can be specified using "linux" or "kernel" entry. The difference
is kernel is supposed to detect the type of file, but for u-boot both are
treated the same.
Use a menu string if present, otherwise use the kernel string.
Include files outside of a menu were not getting included and parsed.
Make the menu timeout apply only when prompt flag is set and after the
menu is displayed. This allows auto boot to work no matter whether prompt
is set or cleared. Use the default selection if the menu times out.
This also fixes the timeout value given to readline_into_buffer to be
seconds instead of 10th of seconds.
Old behavior:
if prompt
display menu and wait for choice
else
wait for timeout
if key pressed
else
exit command
New behavior:
if prompt
display menu
if key pressed
wait for choice
else
boot default entry on timeout
else
boot default entry
This tests for a bad habits of mine like this:
return 0 ;
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
This driver is unused and obsolete.
Cc: unsik Kim <donari75@gmail.com>
Signed-off-by: Loïc Minier <lool@debian.org>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
