index
u-boot-toradex.git
2011.12-colibri_vf
2014.04-toradex
2014.10-toradex
2014.10-toradex-next
2015.04-imx7-1.1.0_ga-toradex-next
2015.04-toradex
2015.04-toradex-next
2016.11-toradex
2016.11-toradex-next
colibri
colibri-next
colibri_vf
toradex_2019.07
toradex_2019.07-next
toradex_2020.07
toradex_imx6
toradex_imx_lf_v2022.04
toradex_imx_lf_v2024.04
toradex_imx_v2017.03_4.9.123_imx8mm_ga-bring_up
toradex_imx_v2017.03_4.9.51_imx8_beta1-bring_up
toradex_imx_v2017.03_4.9.51_imx8_beta2-bring_up
toradex_imx_v2018.03_4.14.62_1.0.0_beta-bringup
toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup
toradex_imx_v2018.03_4.14.98_2.3.0_bringup
toradex_imx_v2020.04_5.4.24_2.1.0
toradex_imx_v2020.04_5.4.70_2.3.0
toradex_ti-u-boot-2021.01_bringup
toradex_ti-u-boot-2023.04
toradex_ti-u-boot-2024.04
U-Boot bootloader for Apalis and Colibri modules
Toradex
summary
refs
log
tree
commit
diff
log msg
author
committer
range
Age
Commit message (
Collapse
Author
2004-12-16
Code cleanup.
wdenk
2004-12-16
PCI405 board update
stroese
2004-12-16
AR405 board update
stroese
2004-12-16
Patch by Stefan Roese, 16 Dez 2004
stroese
2004-12-16
CONFIG_MX_CYCLIC description added
stroese
2004-12-16
some new esd boards added
stroese
2004-12-16
esd common update
stroese
2004-12-16
VOH405 board update
stroese
2004-12-16
PMC405 board update
stroese
2004-12-16
PLU405 board update
stroese
2004-12-16
PCI405 board update
stroese
2004-12-16
OCRTC board update
stroese
2004-12-16
HUB405 board update
stroese
2004-12-16
DU405 board update
stroese
2004-12-16
DP405 board update
stroese
2004-12-16
CPCIISER4 board update
stroese
2004-12-16
CPCI440 board update
stroese
2004-12-16
CANBT board update
stroese
2004-12-16
ASH405 board update
stroese
2004-12-16
AR405 board update
stroese
2004-12-16
ADCIOP board update
stroese
2004-12-16
CPCI405 board update
stroese
2004-12-16
WUH405 board support added
stroese
2004-12-16
VOM405 board support added
stroese
2004-12-16
TASREG board support added
stroese
2004-12-16
HH405 board support added
stroese
2004-12-16
CPCI750 board support added
stroese
2004-12-16
APC405 board support added
stroese
2004-12-16
G2000 board support added
stroese
2004-12-16
PMC405 board support added
stroese
2004-12-16
CPU speed calculation updated (fixed a rounding problem)
stroese
2004-12-16
stroese
2004-12-16
Coldfire MCF5249 support added
stroese
2004-12-16
esd config files updated
stroese
2004-12-16
new 405ep defines added
stroese
2004-12-16
new SST and EXCEL devices add
stroese
2004-12-16
- ext2fs support added
stroese
- Tundra universe support added
2004-12-16
"static" from "do_fat_read" removed
stroese
2004-12-16
stroese
2004-12-16
I2C added
stroese
2004-12-16
use same spacing for "NAND:" puts
stroese
2004-12-16
stroese
2004-12-16
added CONFIG_PCI_CONFIG_HOST_BRIDGE to enable host bridge configuration
stroese
2004-12-16
added ".i" same as ".jffs2s" for compatibility with older units ↵
stroese
(CFG_NAND_SKIP_BAD_DOT_I)
2004-12-16
memory commands "mdc" and "mwc" added for cyclic read/write
stroese
2004-12-16
remove "static" from "ide_dev_desc" to use it from external code
stroese
2004-12-16
code cleanup: use CFG_VXWORKS_MAC_PTR instead of multiple board defines
stroese
2004-12-16
stroese
2004-12-16
stroese
2004-12-16
stroese
[next]
