2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
2016-10-01bootm: fix passing argc to standalone appsZubair Lutfullah Kakakhel
This bug appears in b6396403 which makes u-boot unable to pass arguments via bootm to a standalone application without this patch. Steps to reproduce. Compile a u-boot. Use mkimage to package the standalone hello_world.bin file. e.g. For the MIPS Boston platform mkimage -n "hello" -A mips -O u-boot -C none -T standalone \ -a 0xffffffff80200000 -d hello_world.bin \ -ep 0xffffffff80200000 hello_out Then tftp hello_out and run it using boston # dhcp 192.168.154.45:hello_out ... boston # bootm $loadaddr 123 321 Without the patch the following output is observed. boston # bootm $loadaddr 123 321 Image Name: hello Image Type: MIPS U-Boot Standalone Program (uncompressed) Data Size: 1240 Bytes = 1.2 KiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK Loading Standalone Program ... OK Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 0 argv[0] = "0xffffffff88000000" With the patch, you see the following. boston # bootm $loadaddr 123 321 Image Name: hello Image Type: MIPS U-Boot Standalone Program (uncompressed) Data Size: 1240 Bytes = 1.2 KiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK Loading Standalone Program ... OK Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 3 argv[0] = "0xffffffff88000000" argv[1] = "123" argv[2] = "321" argv[3] = "<NULL>" Without the patch, the go command at the entry point seems to work. boston # go 0xffffffff80200000 123 321 Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 3 argv[0] = "0xffffffff80200000" argv[1] = "123" argv[2] = "321" argv[3] = "<NULL>" Hit any key to exit ... Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01input: specify the default of I8042_KEYB in more correct mannerMasahiro Yamada
Creating multiple entries of "config FOO" often gives us bad experiences. In this case, we should specify "default X86" as platforms that want this keyboard by default. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01sandbox, x86: select DM_KEYBOARD instead of default y entryMasahiro Yamada
Once we migrate to DM-based drivers, we cannot go back to legacy ones, i.e. config options like DM_* are not user-configurable. Make SANDBOX and X86 select DM_KEYBOARD like other platforms do. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-30Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2016-09-30Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/dra7xx_evm.h
2016-09-29nds32: Support relocation.rick
Enable pie option for relocation. Signed-off-by: rick <rick@andestech.com> Cc: Andes <uboot@andestech.com>
2016-09-28mpc85xx: powerpc: usb: Update the list of Socs afftected by erratum A006261Sriram Dash
Apply the erratum A006261 for the following Socs: P2041 rev 2.0, P2040 rev 2.0, P5040 rev 2.0, 2.1 Do not apply erratum A006261 for the following Socs: T4160, T4080, T1040, T1042, T1020, T1022, T2080, T2081 Erratum A006261 is applicable for the following Socs: P1010(1.0, 2.0), P2041(1.0, 1.1, 2.0, 2.1), P2040(1.0, 1.1, 2.0, 2.1), P3041(1.0, 1.1, 2.0, 2.1), P5010(1.0, 2.0), P5020(1.0, 2.0), P5021(1.0, 2.0), T4240(1.0, 2.0), P5040(1.0,2.0,2.1). Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-28mpc85xx: powerpc: usb: Enable Usb phy initialisation settings for P1010Sriram Dash
CONFIG_SYS_FSL_USB1_PHY_ENABLE is set and the USB Phy offset are set to enable the initial setting of Usb Phy for P1010. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-28mpc85xx: powerpc: usb: Modified the erratum A006261 according to endiannessSriram Dash
Modifies erratum implementation due to the fact that P3041, P5020, and P5040 are all big endian for the USB PHY registers, but they were specified little endian. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-27drivers: usb: xhci-fsl: Implement Erratum A-010151 for FSL USB3 controllerSriram Dash
Currently the controller by default enables the Receive Detect feature in P3 mode in USB 3.0 PHY. However, USB 3.0 PHY does not reliably support receive detection in P3 mode. Enabling the USB3 controller to configure USB in P2 mode whenever the Receive Detect feature is required. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-09-27usb: fsl: Renaming fdt_fixup_erratum and fdt_fixup_usb_erratumSriram Dash
The functions fdt_fixup_erratum and fdt_fixup_usb_erratum are fsl/nxp specific. So, make them explicit by renaming them fsl_fdt_fixup_erratum and fsl_fdt_fixup_usb_erratum Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-09-27apalis_t30: colibri_imx7: colibri_t30: fix ethernet functionalityMarcel Ziswiler
Since commit aa7a648747d8c704a9a81c9e493d386930724e9d ("net: Stop including NFS overhead in defragment max") the following has been reproducibly observed while trying to transfer data over TFTP: Load address: 0x80408000 Loading: EHCI timed out on TD - token=0x8008d80 T EHCI timed out on TD - token=0x88008d80 Rx: failed to receive: -5 This patch fixes this by lowering our TFTP block size to be within the standard maximal de-fragmentation aka IP packet size again. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-27configs: colibri_vf_defconfig: Enable USB driver model for Colibri VybridSanchayan Maity
Enable USB driver model for Toradex Colibri Vybrid modules. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2016-09-27ARM: dts: vf-colibri: Enable USB device tree node for Colibri VybridSanchayan Maity
Enable USB device tree node for Toradex Colibri Vybrid module. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2016-09-27ARM: dts: vf: Add device tree node for USB on VybridSanchayan Maity
Add device tree node for USB peripheral on Vybrid. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2016-09-27usb: host: ehci-vf: Migrate Vybrid USB to driver modelSanchayan Maity
Add driver model support for Vybrid USB driver. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2016-09-27cmd: dfu: Add error handling for failed registrationSanchayan Maity
Without this, if g_dnl_register() fails, DFU code continues on blindly and crashes. This fix makes it simply print an error message instead. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> [l.majewski@samsung.com - some manual tweaks needed]
2016-09-27dra7x: configs: enable SPL-DFU supportB, Ravi
This patch enables the SPL-DFU support for dra7x platform. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27dra7x: boot: add dfu bootmode supportB, Ravi
This patch enables the DFU boot mode support for dra7x platform. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27spl: dfu: adding dfu support functions for SPL-DFUB, Ravi
Adding support functions to run dfu spl commands. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27common: dfu: saperate the dfu common functionalityB, Ravi
The cmd_dfu functionality is been used by both SPL and u-boot, saperating the core dfu functionality moving it to common/dfu.c. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27spl: dfu: add dfu support in SPLB, Ravi
Traditionally the DFU support is available only as part 2nd stage boot loader(u-boot) and DFU is not supported in SPL. The SPL-DFU feature is useful for boards which does not have MMC/SD, ethernet boot mechanism to boot the board and only has USB inteface. This patch add DFU support in SPL with RAM memory device support to load and execute u-boot. And then leverage full functionality DFU in u-boot to flash boot inital binary images to factory or bare-metal boards to memory devices like SPI, eMMC, MMC/SD card using USB interface. This SPL-DFU support can be enabled through Menuconfig->Boot Images->Enable SPL-DFU support Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27drivers: usb: xhci-fsl: Change burst beat and outstanding pipelined ↵Sriram Dash
transfers requests This is required for better performance, and performs below tuning: 1. Enable burst length set, and define it as 4/8/16. 2. Set burst request limit to 16 requests. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-09-27colibri_t30: fix usb ethernet functionalityMarcel Ziswiler
Since commit aa7a648747d8c704a9a81c9e493d386930724e9d ("net: Stop including NFS overhead in defragment max") the following has been reproducibly observed while trying to transfer data over TFTP: Load address: 0x80408000 Loading: EHCI timed out on TD - token=0x8008d80 T EHCI timed out on TD - token=0x88008d80 Rx: failed to receive: -5 This patch fixes this by upping our maximal de-fragmentation aka IP packet size again. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-27net: asix: Fix ASIX 88772B with driver modelAlban Bedel
Commit 147271209a9d ("net: asix: fix operation without eeprom") added a special handling for ASIX 88772B that enable another type of header. This break the driver in DM mode as the extra handling needed in the receive path is missing. However this new header mode is not required and only seems to increase the code complexity, so this patch revert this part of commit 147271209a9d. This also reverts commit 41d1258aceb45b45f9e68f67a9c40f0afbc09dc9 ("net: asix: Fix AX88772B when used with DriverModel") of late. Fixes: 147271209a9d ("net: asix: fix operation without eeprom") Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-27Merge git://www.denx.de/git/u-boot-ppc4xxTom Rini
2016-09-27Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2016-09-27CPCI4052: Remove CONFIG_AUTO_COMPLETE and custom baud rate tableTom Rini
This board is getting close to or exceeding the size limit again, remove CONFIG_AUTO_COMPLETE to save space and while in here switch to the default and slightly less complete default baudrate table. Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-09-27ARM: tegra: flush caches via SMC callStephen Warren
On Tegra186, it is necessary to perform an SMC to fully flush all caches; flushing/cleaning by set/way is not enough. Implement the required hook to make this happen. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: fix ULPI PHY on Ventana and SeaboardStephen Warren
Commit ce02a71c2374 "tegra: dts: Sync tegra20 device tree files with Linux" enabled the ULPI USB port on Ventana, but made no attempt to ensure that U-Boot code could handle this. In practice, various code is missing, and various configuration options are not enabled, which causes U-Boot to hang when attempting to initialize this USB port. This patch enables ULPI PHY support on Ventana, and adds the required pinmux setup for the port to operate. Note that Ventana is so similar to Seaboard that this change is made in the Seaboard board file, which is shared with Ventana. Seaboard also has the ULPI USB port wired up in hardware, although to an internal port that often doesn't have anything attached to it. However, the DT nodes for the USB controller and PHY had different status property values, so the port was not initialized by U-Boot. Fix this inconsistency, and enable the ULPI port, just like in the Linux kernel DT. This likewise requires enabling ULPI support in the Seaboard defconfig. Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: fix USB controller aliasesStephen Warren
Some boards have a different set of USB controllers enabled in DT than the set referenced by /alias entries. This patch fixes that. For example, this avoids the following message while booting on Ventana, which is caused by the fact that the USB0 controller had no alias, and defaulted to wanting a sequence number of 0, which was later explicitly requested by the alias for USB controller 2. USB2: Device 'usb@c5008000': seq 0 is in use by 'usb@c5000000' This didn't affect USB operation in any way though. Related, there's no need for the USB controller aliases to have an order that's different from the HW order, so re-order any aliases to match the HW ordering. This has the benefit that since USB controller 0 is the only one that supports device-mode in HW, and U-Boot only supports enabling device move on controller 0, there's now good synergy in the ordering! For Tegra20, that's not relevant at present since USB device mode doesn't work correctly on that SoC, but it will save some head-scratching later. This patch doesn't fix the colibri_t20 board, even though it has the same issue, since Marcel already sent a patch for that. Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Harmony and Ventana
2016-09-27ARM: tegra: fix USB ULPI PHY reset signal inversion confusionStephen Warren
USB ULPI PHY reset signals are typically active low. Consequently, they should be marked as GPIO_ACTIVE_LOW in device tree, and indeed they are in the Linux kernel DTs, and in DT properties that U-Boot doesn't yet use. However, in DT properties that U-Boot does use, the value has been set to 0 (== GPIO_ACTIVE_HIGH) to work around a bug in U-Boot. This change fixes the DT to correctly represent the HW, and fixes the Tegra USB driver to cope with the fact that dm_gpio_set_value() internally handles any inversions implied by the DT value GPIO_ACTIVE_LOW. Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27i2c: tegra: only use new clock/reset APIsStephen Warren
Now that the standard clock/reset APIs are available for all Tegra SoCs, convert the I2C driver to use them exclusively, and remove any references to the custom Tegra-specific APIs. Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27mmc: tegra: only use new clock/reset APIsStephen Warren
Now that the standard clock/reset APIs are available for all Tegra SoCs, convert the MMC driver to use them exclusively, and remove any references to the custom Tegra-specific APIs. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: enable standard clock/reset APIs everywhereStephen Warren
Implementations of the standard clock and reset APIs are available on all Tegra SoCs now, so enable compilation of those uclasses. Enable the Tegra CAR drivers for all SoCs prior to the BPMP being available. This provides an implementation of those APIs everywhere. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: fix clock_get_periph_rate() for UART clocksStephen Warren
Make clock_get_periph_rate() return the correct value for UART clocks. This change needs to be applied before the patches that enable CONFIG_CLK for Tegra SoCs before Tegra186, since enabling that option causes ns16550_serial_ofdata_to_platdata() to rely on clk_get_rate() for UART clocks, and clk_get_rate() eventually calls clock_get_periph_rate(). This change is a rather horrible hack, as explained in the comment added to the clock driver. I've tried fixing this correctly for all clocks as described in that comment, but there's too much fallout elsewhere. I believe the clock driver has a number of bugs which all cancel each-other out, and unravelling that chain is too complex at present. This change is the smallest change that fixes clock_get_periph_rate() for UART clocks while guaranteeing no change in behaviour for any other clock, which avoids other regressions. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27clock: implement a driver for the Tegra CARStephen Warren
Implement a clock uclass driver for the Tegra CAR. This allows clients to use standard clock APIs on Tegra. This device is intended to be instantiated by the core Tegra CAR driver, rather than being instantiated directly from DT. The implementation uses the existing custom Tegra- specific clock APIs to avoid coupling the series with significant refactoring of the existing Tegra clock/clock code. The driver currently only supports peripheral clocks, and avoids support for other clocks such as PLLs and external clocks. This should be sufficient to convert over all Tegra peripheral drivers, and avoids a complex implementation which calls different Tegra-specific clock APIs based on the type of clock being manipulated. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27reset: implement a driver for the Tegra CARStephen Warren
Implement a reset uclass driver for the Tegra CAR. This allows clients to use standard reset APIs on Tegra. This device is intended to be instantiated by the core Tegra CAR driver, rather than being instantiated directly from DT. The implementation uses the existing custom Tegra- specific reset APIs to avoid coupling the series with significant refactoring of the existing Tegra clock/reset code. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27misc: implement Tegra CAR core driverStephen Warren
The Tegra CAR (Clock And Reset) module provides control of most clocks and reset signals within the Tegra SoC. This change implements a driver for this module. However, since the module implements multiple kinds of services (clocks, resets, perhaps more), all this driver does is bind various sub-devices, which in turn provide the real services. This driver is essentially an "MFD" (Multi-Function Device) in Linux kernel speak. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: add APIs the clock uclass driver will needStephen Warren
A future patch will implement a clock uclass driver for Tegra. That driver will call into Tegra's existing clock code to simplify the transition; this avoids tieing the clock uclass patches into significant refactoring of the existing custom clock API implementation. Some of the Tegra clock APIs that manipulate peripheral clocks require both the peripheral clock ID and parent clock ID to be passed in together. However, the clock uclass API does not require any such "parent" parameter, so the clock driver must determine this information itself. This patch implements new Tegra- specific clock API clock_get_periph_parent() for this purpose. The new API is implemented in the core Tegra clock code rather than SoC- specific clock code. The implementation uses various SoC-/clock-specific data. That data is only available in SoC-specific clock code. Consequently, two new internal APIs are added that enable the core clock code to retrieve this information from the SoC-specific clock code. Due to the structure of the Tegra clock code, this leads to some unfortunate code duplication. However, this situation predates this patch. Ideally, future work will de-duplicate the Tegra clock code, and migrate it into drivers/clk/tegra. However, such refactoring is kept separate from this series. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: add peripheral clock init tableStephen Warren
Currently, Tegra peripheral drivers control two aspects of their HW module clock(s): 1) The clock enable/rate for the peripheral clock itself. 2) The system-level clock tree setup, i.e. the clock parent. Aspect 1 is reasonable, but aspect 2 is a system-level decision, not something that an individual peripheral driver should in general know about or influence. Such system-level knowledge ties the driver to a specific SoC implementation, even when they use generic APIs for clock manipulation, since they must have SoC-specific knowledge such as parent clock IDs. Limited exceptions exist, such as where peripheral HW is expected to dynamically switch between clock sources at run-time, such as CPU clock scaling or display clock conflict management in a multi-head scenario. This patch enhances the Tegra core code to perform system-level clock tree setup, in a similar fashion to the Linux kernel Tegra clock driver. This will allow future patches to simplify peripheral drivers by removing the clock parent setup logic. This change is required prior to converting peripheral drivers to use the standard clock APIs, since: 1) The clock uclass doesn't currently support a set_parent() operation. Adding one is possible, but not necessary at the moment. 2) The clock APIs retrieve all clock IDs from device tree, and the DT bindings for almost all peripherals only includes information about the relevant peripheral clocks, and not any potential parent clocks. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: pull Tegra210 SoC DT from Linux v4.7Stephen Warren
The primary benefit of this change is that it adds all missing clocks and resets properties to peripherals. This will allow peripheral drivers to migrate to the standard clock and reset APIs in the future. Main changes: * Brought in the correct Tegra210 CAR binding; the old file in U-Boot appears to be a renamed version of the Tegra124 bindings rather than the real Tegra210 version. * Conversion of SPI and UART nodes to standard DMA bindings. U-Boot doesn't use DMA so isn't affected. * Split of EHCI and USB PHY nodes. The EHCI nodes continue to contain all information required by U-Boot, so U-Boot is not affected. * Conversion of many magic numbers to named defines. * Addition of many nodes not used by U-Boot, including separation of the Tegra LIC (Legacy IRQ controller) and GIC. * Node sort order fixes. Remaining deltas relative to the Linux DT: * U-Boot has enabled PCIe for Tegra210, but the kernel hasn't yet. * The GPIO node compatible value in the kernel explicitly includes Tegra124 values whereas U-Boot does not. I'll send a kernel patch to correct this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: pull Tegra124 SoC DT from Linux v4.7Stephen Warren
The primary benefit of this change is that it adds all missing clocks and resets properties to peripherals. This will allow peripheral drivers to migrate to the standard clock and reset APIs in the future. Main changes: * USB phy_type property is aligned with the kernel, so board files are updated so the final DT content doesn't change. I'm not convinved that Nyan uses HSIC phy_type. However, I'd rather this change be a no-op, and any DT bug-fixes be separate. * Sync misc changes from the kernel: missing DT content, minor compatible value fixes, typos. Remaining deltas relative to the Linux DT: * U-Boot uses #address-cells/#size-cells of 1 whereas the kernel uses 2. I believe U-Boot's DT parsing currently assumes that these values match the physical address size, so I didn't synchronize this part of the DT. * U-Boot uses the original XUSB PHY DT binding, wherease the kernel DT has moved to a newer version. Thus, XUSB client nodes include properties names phys and phy-names that do not appear in the kernel, and don't include pad definitions in the padctl node. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: pull Tegra114 SoC DT from Linux v4.7Stephen Warren
The primary benefit of this change is that it adds all missing clocks and resets properties to peripherals. This will allow peripheral drivers to migrate to the standard clock and reset APIs in the future. Main changes: * Conversion of SPI nodes to standard DMA bindings. U-Boot doesn't use DMA so isn't affected. * Split of EHCI and USB PHY nodes. The EHCI nodes continue to contain all information required by U-Boot, so U-Boot is not affected. * Boards need to define the clk32k_in clock that feeds the Tegra PMC. * Addition of tegra114-mc.h since tegra114.dtsi now includes it. * Conversion of many magic numbers to named defines. * Addition of many nodes not used by U-Boot. * Node sort order fixes. Remaining deltas relative to the Linux DT: * USB node compatible values in U-Boot explicitly list Tegra114 values whereas the kernel does not. I'll send a kernel patch to correct this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: pull Tegra30 SoC DT from Linux v4.7Stephen Warren
The primary benefit of this change is that it adds all missing clocks and resets properties to peripherals. This will allow peripheral drivers to migrate to the standard clock and reset APIs in the future. Main changes: * Modification of PCIe memory region addresses. The HW memory layout is programmable, so this should work fine, and Beaver PCIe was tested without issue. * Removal of pcie_xclk from the PCIe node and clock binding header. This clock doesn't exist and isn't used; only a reset with this ID exists. * Conversion of SPI nodes to standard DMA bindings. U-Boot doesn't use DMA so isn't affected. * Split of EHCI and USB PHY nodes. The EHCI nodes continue to contain all information required by U-Boot, so U-Boot is not affected. * Changed the phy_type value for the second USB port. This required board DTs to be updated to keep the same configuration. * Boards need to define the clk32k_in clock that feeds the Tegra PMC. * Addition of tegra30-mc.h since tegra30.dtsi now includes it. * Conversion of many magic numbers to named defines. * Addition of many nodes not used by U-Boot. * Node sort order fixes. Remaining deltas relative to the Linux DT: * None. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: pull Tegra20 SoC DT from Linux v4.7Stephen Warren
This brings in a few minor fixes since the last sync. The largest change is the removal of the definition for TEGRA20_CLK_PCIE_XCLK. This clock doesn't actually exist. Remaining deltas: * Addition of u-boot,dm-pre-reloc property to a couple of nodes. * Addition of the NAND controller, which Linux doesn't yet support. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
