Add Nios GDB/JTAG Console support:
- Add stubs to support gdb via JTAG.
- Add support for console over JTAG.
- Minor cleanup.
Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
(at least "usb reset" now passes successfully and "usb info" displays
correct information)
on-chip interfaces before external cards.
* Fix SL811 USB controller when attached to a USB hub
* Fix PHY discovery problem in cpu/mpc8xx/fec.c (introduced by
patches by Pantelis Antoniou, 30 Mar 2004)
* Fixes for SL811 USB controller:
- implement workaround for broken memory stick
- improve error handling
* Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better
cope with congested networks.
(JFFS2 speed enhancements) because of using non-public
data (PHYS_FLASH_SECT_SIZE)
* Patch by Travis Sawyer, 23 Apr 2004:
Fix VSC/CIS 8201 phy descrambler interoperability timing due to
errata from Vitesse Semiconductor.
JFFS2 speed enhancements:
- repair header CRC calculation in jffs2_1pass.c
- add eraseblock size to the partition information to skip empty
eraseblocks if we find more then 4k of free space.
- The JFFS2 scanner is now fast enough to remove the spinning wheel
so #ifdef-ed out.
- add watchdog calls in long running loops
* Patch by Philippe Robin, 22 Apr 2004:
Fix ethernet configuration for "versatile" board
* Patch by Kshitij Gupta, 21 Apr 2004:
Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards
* Patch by Steven Scholz, 24 Feb 2004:
Fix a bug in AT91RM9200 ethernet driver:
The MII interface is now initialized before accessing the PHY.
* Cleanup PCI ID's
Use U-boot's miiphy.h for PHY register names, rather than
introducing a new header file.
* Update pci_ids.h from linux-2.4.26
* Patch by Masami Komiya, 19 Apr 2004:
Fix problem cause by VLAN function on little endian architecture
without VLAN environment
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
sticks (including FAT / VFAT filesystem support)
* Add SL811 Host Controller Interface driver for USB
* Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README
* Patch by Pantelis Antoniou, 19 Apr 2004:
Allow to use shell style syntax (i. e. ${var} ) with standard parser.
Minor patches for Intracom boards.
* Patch by Christian Pell, 19 Apr 2004:
cleanup support for CF/IDE on PCMCIA for PXA25X
"miivals.h" is missing
* Patches by Mark Jonas, 13 Apr 2004:
- Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S
- Add sync instructions to IceCube SDRAM init code
- Move SDRAM chip constants into seperate include files
- Unify DDR and SDR initialization code
- Unify all IceCube (Lite5xxx) target names
Enable ranges in mii command, e.g. mii read 0-1f 0 or
mii read 4-7 18-1a. Also add mii dump subcommand for
pretty-printing standard regs 0-5.
* Patch by Stephen Williams, 16 April 2004:
fix typo in JSE.h; update MAINTAINERS
fix initdram function for utx8245 board
* Patch by Markus Pietrek, 14 Apr 2004:
use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag
* Patch by Reinhard Meyer, 18 Apr 2004:
provide the IDE Reset Function for EMK 5200 boards
* Patch by Masami Komiya, 12 Apr 2004:
fix pci_hose_write_config_{byte,word}_via_dword problems
Update max RAM size for debris board
* Patch by Travis Sawyer, 08 Apr 2004:
Add TLB entry for second DIMM slot on ocotea
* Patch by Masami Komiya, 08 Apr 2004:
add RTL8169 network driver
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
* Patch by Rune Torgersen, 06 Apr 2004:
- Fix some PCI problems on the MPC8266ADS board
- Fix the location of some PCI entries in the immap structure
- add support for microblaze processors
- add support for AtmarkTechno "suzaku" board
* Configure PPChameleon board to use JFFS2 NAND support.
* Added support for JFFS2 filesystem (read-only) on top of NAND flash
* Patch by Rune Torgersen, 16 Apr 2004:
LBA48 fixes
* Patches by Pantelis Antoniou, 16 Apr 2004:
- Fix some compile problems;
add "once" functionality for the netretry variable
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
add support for Intel Assabet board
Add support for Picture Elements JSE board
* Patch by Christian Pell, 01 Apr 2004:
Add CompactFlash support for PXA systems.
- some minor patches / cleanup
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
Improve and fix various things in the MPC8xx FEC driver:
1. The new 87x and 88x series of processors have two FECs,
and the new driver supports them both.
2. Another change in the 87x/88x series is support for
the RMII (Reduced MII) interface. However numerous
changes are needed to make it work since the PHYs
are connected to the same lines. That means that
you have to address them correctly over the MII
interface.
- add support for the Epson 156x series of graphical displays
(These displays are serial and not suitable for using a normal
framebuffer console on them)
- add infrastructure needed in order to POST any DSPs in a board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Add support for KUP4X Board
Add Reiserfs support
* Patch by Hinko Kocevar, 20 Mar 2004
- Add auto-release for SMSC LAN91c111 driver
- Add save/restore of PTR and PNR regs as suggested in datasheet
Increase speed of sector reads from SystemACE,
shorten poll timeout and remove a useless reset
* Patch by Tolunay Orkun, 19 Mar 2004:
Make GigE PHY 1000Mbps Speed/Duplex detection conditional
(CONFIG_PHY_GIGE)
* Patch by Brad Kemp, 18 Mar 2004:
prevent machine checks during a PCI scan
* Patch by Pierre Aubert, 18 Mar 2004:
Fix string cleaning in IDE identification
- Unify video mode handling for Chips & Technologies 69000 Video
chip and Silicon Motion SMI 712/710/810 Video chip
- Add selection of the video output (CRT or LCD) via 'videoout'
environment variable for the Silicon Motion
- README update
include/common.h typo fix
* Patches by Tolunay Orkun, 17 Mar 2004:
- Add support for bd->bi_iic_fast[] initialization via environment
variable "i2cfast" (CONFIG_I2CFAST)
- Add "i2cfast" u-boot environment variable support for csb272
Ignore '\0' characters in console input for use with telnet and
telco pads.
* Patch by Leon Kukovec, 17 Mar 2004:
typo fix for strswab prototype #ifdef
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
avoid dereferencing NULL pointer in lib_arm/armlinux.c
* Patch by Stephen Williams, 15 Mar 2004:
Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation
* Patch by Tolunay Orkun, 15 Mar 2004:
Initialize bi_opbfreq to real OPB frequency via get_OPB_freq()
* Patch by Travis Sawyer, 15 Mar 2004:
Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
attempting to switch on USB on SX1 board.
* Patch by Josef Wagner, 18 Mar 2004:
- Add support for MicroSys XM250 board (PXA255)
- Add support for MicroSys PM828 board (MPC8280)
- Add support for 32 MB Flash on PM825/826
- new SDRAM refresh rate for PM825/PM826
- added support for MicroSys PM520 (MPC5200)
- replaced Query by Identify command in CPU86/flash.c
to support 28F160F3B
* Fix wrap around problem with udelay() on ARM920T
* Add support for Macronix flash on TRAB board
Fix buffer overflow in IDE identification
- Adding get_ticks() and get_tbclk() for AT91RM9200
- Many white space fixes in cpu/at91rm9200/interrupts.c
* Patches by Steven Scholz, 20 Feb 2004:
some cleanup in AT91RM9200 related code
