add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
- add a return value for the fpga command
- add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT
is defined. If ide_preinit fails, ide_init is aborted.
- fix an endianess problem in fat.h
Add support for SNMC's QS850/QS823/QS860T boards
"revive" U-Boot support for old Motorola MPC860ADS board
* Patch by Cam(ilo?), 03 Dec 2003:
make examples build even with broken Montavista objcopy
* Patch by Pavel Bartusek, 27 Nov 2003:
fix conversion problem with "bootretry" evironment variable
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards
* Patch by Pavel Bartusek, 21 Nov 2003:
set ZMII bridge speed on 440
* Patch by Anders Larsen, 17 Nov 2003:
Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
- board/mpl/common/common_util.c
* implement support for BZIP2 compressed images
* various cleanups (printf -> puts, ...)
- board/mpl/common/flash.c
* report correct errors to upper layers
* check the erase fail and VPP low bits in status reg
- board/mpl/vcma9/cmd_vcma9.c
- board/mpl/vcma9/flash.c
- common/cmd_usb.c
* fix typo in comment
- cpu/arm920t/usb_ohci.c
* support for S3C2410 is missing in #if line
- drivers/cs8900.c
* reinit some registers in case of error (cable missing, ...)
- fs/fat/fat.c
* support for USB/MMC devices is missing in #if line
- include/configs/MIP405.h
- include/configs/PIP405.h
* enable BZIP2 support
* enlarge malloc space to 1MiB because of BZIP2 support
- include/configs/VCMA9.h
* enable USB support
- lib_arm/armlinux.c
* change calling convention of ARM Linux kernel as
described on http://www.arm.linux.org.uk/developer/booting.php
* Patch by Thomas Lange, 14 Nov 2003:
Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to
support all these AMD boards.
Workaround for mips au1x00 physical memory accesses (the au1x00
uses a 36 bit bus internally and cannot access physical memory
directly. Use the uncached SDRAM address instead of the physical
one.)
add Realtek 8019 ethernet driver
* Patch by Yuli Barcohen, 13 Nov 2003:
MPC826xADS/PQ2FADS cleanup
* Patch by Anders Larsen, 12 Nov 2003:
Update README to mark the PORTIO commands non-standard
update for for Atmel AT91RM9200DK development kit:
- support for environment variables in DataFlash
- Atmel DataFlash AT45DB1282 support
* Patch by Jeff Carr, 11 Nov 2003:
add support for new version of 8270 processors
* Patches by George G. Davis, 05 Nov 2003:
- only pass the ARM linux initrd tag to the kernel when an initrd
is actually present
- update omap1510inn configuration file
- more endianess fixes for LAN91C111 driver
- CFG_HZ configuration patch for NIOS Cyclone board
* Patch by Stephan Linz, 28 Oct 2003:
fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c
* Patch by Steven Scholz, 20 Oct 2003:
- make "mii info <addr>" show infor for PHY at "addr" only
- Endian fix for miiphy_info()
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
headers first instead of always reading the whole images.
* Fix configuration problem with IceCube in LOWBOOT configuration:
environment got embedded, corrupting the image layout.
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display).
Fix NEC display names (it's 6440 [for 640x480], not 6640).
to exit Unlock Bypass Mode); adjust timings for flash, SRAM and CPLD
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
Add low boot support for MPC5200
* Fix problem with dual PCMCIA support (NSCU)
* Fix MPC5200 I2C initialization function
* Patch by Kyle Harris, 30 Oct 2003:
Fix build errors for ixdp425 board
* Patch by David M. Horn, 29 Oct 2003:
Fixes to build under CYGWIN
* Get IceCube MGT5100 working (again)
* Fix problems in memory test on some boards (which was not
non-destructive as intended)
* Patch by Gary Jennejohn, 28 Oct 2003:
Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack
to prevent stack overflow on ARM systems
fix init sequence error for NIOS port
* Allow lowercase spelling for IceCube_5200; support MPC5200LITE name
* Add CONFIG_VERSION_VARIABLE to TRAB configuration
small patch for mpc85xx
* Fix small problem in MPC5200 I2C driver
* Fix FCC3 support on ATC board
* Make CONFIG_SILENT_CONSOLE work with CONFIG_AUTOBOOT_KEYED
Fix AT91RM9200 ethernet driver
* Patch by Nye Liu, 17 Oct 2003:
Fix typo in include/mpc8xx.h
* Patch by Richard Woodruff, 16 Oct 03:
Fixes for cpu/arm925/interrupt.c
- Initialize timestamp & lastdec vars.
- fix timestamp overflows.
- fix lastdec overflow.
- smarter normalization to allow udelay() below 1ms to work.
* Patch by Scott McNutt, 16 Oct
add networking support for the Altera Nios Development Kit,
Cyclone Edition (DK-1C20)
* Patch by Jon Diekema, 14 Oct 2003:
add hint about doc/README.silent to README file
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
header on image type as encoded in the header
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
for more information
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
- fix cmd_ide.c for non ppc boards (read/write functions did not
add ATA base address)
- fix for shannon board
- #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code
* Patch by Sangmoon Kim, 07 Oct 2003:
add support for debris board
Fixes for TRAB board
- /board/trab/rs485.c: correct baudrate
- /board/trab/cmd_trab.c: bug fix for problem with timer overflow in
udelay(); fix some timing problems with adc controller
- /board/trab/trab_fkt.c: add new commands: gain, eeprom and power;
modify commands: touch and buzzer
* Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE
(quick & dirty workaround for rogue pointer problem in get_vfatname());
Use direct function calls for auto_update instead of hush commands
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
fix pll_pci_to_mem_multiplier table for MPC8245
* Patch by Anders Larsen, 22 Sep 2003:
enable timed autoboot on PXA
* Patch by David Müller, 22 Sep 2003:
- add $(CFLAGS) to "-print-libgcc-filename" so compiler driver
returns correct libgcc file path
- "latency" reduction of busy-loop waiting to improve "U-Boot" boot
time on s3c24x0 systems
* Patch by Jon Diekema, 19 Sep 2003:
- Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet
link state to the fault LED.
- In NetLoop, make the Fault LED reflect the link status. The link
status gets updated on entry, and on timeouts.
allow mkimage to build and run on Cygwin-hosted systems
* Patch by Frank Müller, 18 Sep 2003:
use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in
cpu/mpc8xx/fec.c
* Patch by Pantelis Antoniou, 16 Sep 2003:
add tool to compute fileds in the PLPRCR register for MPC86x
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
is set
is set
