We should return a negative error number (-EINVAL) on error.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Series-to: trini, uboot
Allow a larger kernel binary to be decompressed - the default 8MB can
become limiting on a Malta.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Whilst U-boot does not require this itself, Linux currently relies upon
it having been muxed and enabled by the bootloader. Thus in order to
preserve compatibility with current kernels before a fix is merged in
Linux we will enable the SERIRQ interrupt and mux it to its pin.
Without doing this current kernels will never receive serial port
interrupts and the end result is typically that userland appears to
hang.
CONFIG_SYS_NS16550_CLK specifies the rate of the clock 16x the baud
rate. The SMSC FDC37M81x datasheet states that a divider of 1 results in
a UART at 115200 baud, thus the x16 clock rate is 115200 * 16.
Previously the divider was left at 0 which led to a rate of 38400 baud
regardless of CONFIG_BAUDRATE or the baudrate environment variable.
The baudrate passed to Linux in the environment was hardcoded at 38400.
Instead pass the correct baudrate from global data, allowing Linux to
correctly inherit the baudrate used by U-boot when console setup is not
explicitly specified.
Add the default RCW(SerDes 0x66_0x16) and PBI configure file for
T2080QDS board, so we can use PBL tool to generate the ramboot
image to support boot from NAND/SPI/SD.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
The T2080QDS is a high-performance computing evaluation, development and
test platform supporting the T2080 QorIQ Power Architecture processor.
T2080QDS feature overview
Processor:
- T2080 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
Memory:
- Single memory controller capable of supporting DDR3 and DDR3-LV devices
- Two DDR3 DIMMs up to 4GB, Dual rank @ 2133MT/s and ECC support
Ethernet interfaces:
- Two 1Gbps RGMII on-board ports
- Four 10Gbps XFI on-board cages
- 1Gbps/2.5Gbps SGMII Riser card
- 10Gbps XAUI Riser card
Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
SerDes:
- 16 lanes up to 10.3125GHz
- Supports Aurora debug, PEX, SATA, SGMII, sRIO, HiGig, XFI and XAUI
IFC:
- 128MB NOR Flash, 512MB NAND Flash, PromJet debug port and FPGA
eSPI:
- Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040)
USB:
- Two USB2.0 ports with internal PHY (one Type-A + one micro Type-AB)
PCIE:
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV)
SATA:
- Two SATA 2.0 ports on-board
SRIO:
- Two Serial RapidIO 2.0 ports up to 5 GHz
eSDHC:
- Supports SD/SDHC/SDXC/eMMC Card
I2C:
- Four I2C controllers.
UART:
- Dual 4-pins UART serial ports
System Logic:
- QIXIS-II FPGA system controll
Debug Features:
- Support Legacy, COP/JTAG, Aurora, Event and EVT
[York Sun: removed Makefile blank line at EOF,
fix conflicts with moving DDR driver]
Acked-by: York Sun <yorksun@freescale.com>
Add support for Freescale T2080/T2081 SoC.
T2080 includes the following functions and features:
- Four dual-threads 64-bit Power architecture e6500 cores, up to 1.8GHz
- 2MB L2 cache and 512KB CoreNet platform cache (CPC)
- Hierarchical interconnect fabric
- One 32-/64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving
- Data Path Acceleration Architecture (DPAA) incorporating acceleration
- 16 SerDes lanes up to 10.3125 GHz
- 8 mEMACs for network interfaces (four 1Gbps MACs and four 10Gbps/1Gbps MACs)
- High-speed peripheral interfaces
- Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz
- Additional peripheral interfaces
- Two serial ATA (SATA 2.0) controllers
- Two high-speed USB 2.0 controllers with integrated PHY
- Enhanced secure digital host controller (SD/SDHC/SDXC/eMMC)
- Enhanced serial peripheral interface (eSPI)
- Four 2-pin UARTs or two 4-pin UARTs
- Integrated Flash Controller supporting NAND and NOR flash
- Three eight-channel DMA engines
- Support for hardware virtualization and partitioning enforcement
- QorIQ Platform's Trust Architecture 2.0
Differences between T2080 and T2081:
Feature T2080 T2081
1G Ethernet numbers: 8 6
10G Ethernet numbers: 4 2
SerDes lanes: 16 8
Serial RapidIO,RMan: 2 no
SATA Controller: 2 no
Aurora: yes no
SoC Package: 896-pins 780-pins
There are more than two 10GEC in single FMAN in some SoCs(e.g. T2080).
This patch adds support for 10GEC3 and 10GEC4.
Freescale IFC controller has been used for mpc8xxx. It will be used
for ARM-based SoC as well. This patch moves the driver to driver/misc
and fix the header file includes.
Signed-off-by: York Sun <yorksun@freescale.com>
The DRAM base has been zero for Power SoCs. It could be non-zero
for ARM SoCs. Use a macro instead of hard-coding to zero.
Some DDR registers' fields have expanded to accommodate larger values.
These changes are backward compatible. Some fields are removed for newer
DDR controllers. Writing to those fields are safely ignored.
TIMING_CFG_2 register is fixed. Additive latency is added to RD_TO_PRE
automatically. It was a misunderstanding in commit c360ceac.
Make PowerPC specific code conditional so ARM SoCs can reuse
this driver. Add DDR3 driver for ARM.
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3
structure for 83xx, 85xx and 86xx.
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
The default partition table matches the .dts files for these boards in
Linux. This allows these partitions to be used by name with U-Boot's
"nand" command.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
The offset of register address within GPIO module is just
CONFIG_SYS_MPC85xx_GPIO_ADDR. So, fix it. The following platforms
are confirmed: MPC8572, P1023, P1020, P1022, P2020, P4080,
P5020, P5040, T4240, B4860.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Update T1040QDS naem to Poonam Aggrwal.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
The SPDX tag conversion ate part of this file, put things back to the
way they should be.
The use of 'bool' data types in globally used header files cases build
errors like this:
In file included from arch/blackfin/include/asm/blackfin.h:13:0,
from include/common.h:92,
from cmd_test.c:17:
arch/blackfin/include/asm/blackfin_local.h:54:1: error: unknown type name 'bool'
Use plain 'int' instead to avoid such kind of trouble.
Some board have multiple configurations.
For example, the board "m54455evb" has many configurations:
M54455EVB, M54455EVB_a66, M54455EVB_i66, M54455EVB_intel, ...
When we modify board-related files, we need to test
all configurations based on such a board.
In such a case, the new option -b is useful.
-I$(TOPDIR)/include is defined in the top config.mk.
All objects under api/ and examples/api/ directories are selected
by CONFIG_API.
So we can move CONFIG_API switch to the top Makefile.
In order to use CONFIG_API, the definition of SUBDIR_EXAMPLES-y
must be moved after "sinlude $(obj)include/autoconf.mk".
The directory tools/ is always built before common/.
So when envcrc tool is necessary in common/Makefile,
it already exists.
HOSTCFLAGS is meaningless because no host programs
are compiled there.
by CONFIG_API.
Commit 69434e4c deleted spieval board support
but it missed to clean up include/configs/spieval.h file.
We have a generic rule to generate .o file from *.S
in $(TOPDIR)/config.mk.
tools/updater needs board/MAI/AmigaOneG3SE board
for compiling.
But AmigaOneG3SE board was already deleted
by Commit 953b7e6.
It looks like tools/imls/Makefile is invoked from nowhere.
And also it is broken.
Some GPIO connected LEDs have inverted polarity.
Introduce new config option: CONFIG_GPIO_LED_INVERTED_TABLE for the
specifying the inverted GPIO LEDs list and add support for this in the
gpio_led driver.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Ilya Ledvich <ilya@compulab.co.il>
Add a check for the gpio_request() function return value and do not try
to configure the GPIO if the gpio_request() call fails.
Also, print an error message indicating the gpio_request() has failed.
The CONFIG_GPIO_LED symbol does not have any documentation in the README
file. Document the CONFIG_GPIO_LED symbol.
In the case of not having CONFIG_CMD_HASH but having CONFIG_CMD_CRC32
enabled (and not CONFIG_CRC32_VERIFY), we end up in this part of the
code path on hash_command(). However, we will only have exactly 3 args
here, and 3 > 3 is false, and we will not try and store the hash at the
address given as arg #3. The next problem however is that we've been
moving argv around so the third value is now in argv[0] not argv[3].
Confirmed on AM335x Beaglebone White.
This chip is compatible with the existing driver, except that it uses
BAR2 instead of BAR1 for the I/O memory region. Using this patch I can
use the PCIe ethernet interface on the CompuLab Trimslice to boot from
the network.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Patch: 276477
