A few platforms recently added in CONFIG_DFU_MMC under include/configs
rather than via the defconfig, update them.
mpc85xx config.mk: Add support for -msingle-pic-base
Print information about Aquantia system interface and firmware loaded
on the phy.
Signed-off-by: Valentin Catalin Neacsu <valentin-catalin.neacsu@nxp.com>
If System Interface protocol is USXGMII then enable USXGMII autoneg
No mainline board enables CONFIG_MCAST_TFTP and there have been
compilation issues with the code for some time. Additionally, it has a
potential buffer underrun issue (reported as a side note in
CVE-2018-18439).
Remove the multicast TFTP code but keep the driver API for the future
addition of IPv6.
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
ether_crc was added to the core net code in commit 53a5c424bf86
("multicast tftp: RFC2090") so that other drivers could use it. However
the only current user of it is tsec.c so move it there.
According to the datasheet to access the extended registers we have to:
1. Write Register 31 Data = 0x0XYZ (Page 0xXYZ)
2. Read/Write the target Register Data
3. Write Register 31 Data = 0x0000 or 0xa42 (switch back to IEEE
Standard Registers)
Hook the missing functions so that we can use the `mdio rx/wx` command to
easily access the extended registers.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Some architectures (MIPS) needs mapping to access IOMEM.
Fix that.
Fixes: f1dcc19b213d ("net: macb: Convert to driver model")
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
This patch add GPIO configuration support in mvneta driver.
Driver will handle PHY reset. GPIO pins should be set in device tree.
Ported from mvpp2x
[https://patchwork.ozlabs.org/patch/799654/]
Initial discussion to port the changes into mvneta
[https://patchwork.ozlabs.org/patch/1005765/]
Signed-off-by: Aditya Prayoga <aditya@kobol.io>
Tested-by: Dennis Gilmore <dgilmore@redhat.com>
Some existing device trees don't specify a phy-mode so fallback to GMII
when a phy-mode is not provided.
For KSZ9021, all skew register fields are 4-bit wide.
For KSZ9031, the clock skew register fields are 5-bit wide.
The common code in ksz90x1_of_config_group calculating the combined
register value checks if the requested value is above the maximum
and uses this maximum if so. The calculation of this maximum uses
the register width, but the check itself does not. It uses a hardcoded
value of 0xf, which is too low in case of the 5-bit clock (0x1f).
This detail was probably lost during driver unification.
Effect (only for KSZ9031 clock skews): For values greater 900 (== 0ps),
this silently results in 1860 (== +960ps) instead of the requested one.
Fix the check by using the bit width instead of hardcoded value(s).
Signed-off-by: Andreas Pretzsch <apr@cn-eng.de>
With CONFIG_REGEX enabled, ETHADDR_WILDCARD is set up for up to 10
interfaces (0..9) as the number can only have one digit.
On boards with more than 10 interfaces, this leads to the protection
and format checks being absent for eth10addr and above.
Fix this by changing ETHADDR_WILDCARD from "\\d?" to "\\d*" to allow
more than one digit.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
ETHADDR_WILDCARD is defined as the same value in both env_flags.h
and env_callback.h
As env_callback.h includes env_flags.h, remove the duplicate definition
from env_callback.h
When dealing with two ethernet ports and having "netretry" set
to "once", it could occur that the connection (e.g. an ARP
request) failed, hence the status of the netloop was
"NETLOOP_FAIL". Due to the setting of "netretry", the network
logic would then switch to the other network interface,
assigning "ret" with the return value of "net_start_again()".
If this call succeeded we would return 0 (i.e. success) to
the caller when in reality the network action failed.
Signed-off-by: Thomas RIENOESSL <thomas.rienoessl@bachmann.info>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Current code forces all ports on a given Ethernet device to use the same
mdio device. In practice different ports might be wired to separate mdio
devices. Move the mdio device from the container struct mvpp2 to the per
port struct mvpp2_port.
Cc: Ken Ma <make@marvell.com>
Cc: Stefan Chulski <stefanc@marvell.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Current mdio base lookup code relies on a 'reg' property at the upper CP
node. There is no 'reg' property there in current DT files of Armada
CP110. Use ofnode_get_addr() instead since it provides proper DT address
translation.
Short frames are padded to the minimum allowed size of 60 bytes.
However, the designware driver sends old data in these padding bytes.
It is common practice to zero out these padding bytes ro prevent
leaking memory contents to other hosts.
Fix the padding code to zero out the padded bytes at the end.
Tested on socfpga gen5.
The designware driver has a bug in setting the tx length into the dma
descriptor: it always or's the length into the descriptor without
zeroing out the length mask before.
This results in occasional packets being transmitted with a length
greater than they should be (trailer). Due to the nature of Ethernet
allowing such a trailer, most packets seem to be parsed fine by remote
hosts, which is probably why this hasn't been noticed.
Fix this by correctly clearing the size mask before setting the new
length.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The phy devices can be accessed via clause 22 or via clause 45.
This information can be deduced when we read phy id. if the phy id
is read without giving any MDIO Manageable Device Address (MMD), then
it conforms to clause 22. otherwise it conforms to clause 45.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
Xilinx changes for v2019.04
tools:
- Fix zynqmpimage generation
zynq:
- Some configs/Kconfig/DT updates
- Enable REMAKE_ELF and OF_SEPARATE
- Topic boards update
- i2c cleanups and conversion to DM_I2C
zynqmp:
- Board config cleanup
- Move arch folder to mach-zynqmp
versal:
- Enable DM_I2C, CMD_DM
zynq-gem:
- Fix driver cache handling
i2c:
- Live tree simple update
phy:
- Fixed phy cleanup
travis:
- Wire Versal SoC
Both boards have only controllers enabled that's why move to DM_I2C is
easy.
There is no i2c connected in base DT that's why disable I2C commands.
Also remove zynq_zybo which is not needed now.
With DM in place there is no need to have GEM addresses in headers. None
is using them.
is using them.
Most of the memory is being consumed by device binding code,
more space needed for other data structures.
Z-turn board has already hit the limit, others may follow soon.
Measuring only the memory consumed in device_bind_common, I've got
the following results (in decimal):
root_driver: 108
mod_exp_sw: 108
amba: 120
serial@e0000000 aka uart0: 112
serial@e0001000 aka uart1: 88
spi@e000d000 aka qspi: 120
sdhci@e0100000 aka mmc0: 455
sdhci@e0100000.blk: 208
slcr@f8000000: 96
clkc@100: 72
(total) 1487 = 0x5cf of 0x600
Signed-off-by: Anton Gerasimov <tossel@gmail.com>
The miamiplus can use GEM0 through MIO pins, which requires a 125 MHz TX
clock to be generated. With the IO PLL at 1200 MHz this isn't possible, so
change it to run at 1000 and adjust the divisors accordingly. Also set the
GEM0 clock source to MIO instead of EMIO.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
The miamiplus contains a speedgrade-2 device, which may run the CPU at 800MHz.
Change the PLL setting to 800MHz, and adapt the setpoints in the devicetree.
Update cadence i2c driver to support livetree
Similar changes were done by:
"net: zynq_gem: convert to use livetree"
(sha1: 26026e695afa794ac018a09e79a48120d322b60d)
It is useful to have this command enable to see which devices are
bind/probed.
Enable communication over i2c.
Similar changes was done for Zynq in past and this patch just follow
this pattern to separate cpu code from SoC code.
Move arch/arm/cpu/armv8/zynqmp/* -> arch/arm/mach-zynqmp/*
And also fix references to these files.
Based on
"ARM: zynq: move SoC sources to mach-zynq"
(sha1: 0107f2403669f764ab726d0d404e35bb9447bbcc)
Build warning was added by:
"fdt: Add warning about CONFIG_OF_EMBED"
(sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41)
Zynq mini configurations are not moved yet and it is questionable if
make sense to move them too.
This patch enables CONFIG_REMAKE_ELF for Zynq platform
so that it generates u-boot.elf from binary which works
for all Zynq boards with OF_SEPARATE option enabled.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
ZynqMP mini configurations are not moved yet and it is questionable if
Bootrom is not capable to work with non align bootloader partition
that's why it is necessary to align it before boot.bin creation.
The patch is creating new spl/u-boot-spl-align.bin which is used only
for boot.bin.
Bootrom is not capable to work with non aligned bootloader sizes.
SPL with OF_SEPARATE generates non-align images quite often that's
why this change is required before OF_SEPARATE enableding.
Test Xilinx Versal Virt platform running on the v3.1.0 Qemu.
All these boards have no SD enabled.
Enable fpga load secure feature for xilinx platforms.
Enable ISSI flash for platforms. Xilinx reference boards are also used
internally with different flash part to increase coverage that's why
enable also ISSI parts for all these boards even if that board is
released only with one part.
Enable GQSPI driver, SF command and SPL support for some platforms.
Select DM_SPI/DM_SPI_FLASH for the whole SoC.
Setup proper ETH/MMC dependency for the whole platform.
This patch enable net configs for zc1275 board.
When FPGA programming fails, it does so silently, unless debugging
code is enabled. This makes it hard to detect problems in production
environments.
Print the error message unconditionally so the error doesn't go
unnoticed.
Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net>
Trivial patch.
