Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
According to the README, CONFIG_SYS_HZ must be 1000 and most platforms
follow that. In preparation to remove CONFIG_SYS_HZ from all these
platforms, provide a common definition. The platforms which use a value
other than 1000 will get build warning now. These configs are:
include/configs/M5271EVB.h:#define CONFIG_SYS_HZ 1000000
include/configs/balloon3.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */
include/configs/idmr.h:#define CONFIG_SYS_HZ (50000000 / 64)
include/configs/mini2440.h:#define CONFIG_SYS_HZ 1562500
include/configs/mx1ads.h:#define CONFIG_SYS_HZ 3686400
include/configs/omap3_zoom2.h:#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
include/configs/omap730p2.h:#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
include/configs/palmld.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */
include/configs/palmtc.h:#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */
include/configs/rsk7203.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER)
include/configs/rsk7264.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER)
include/configs/rsk7269.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER)
include/configs/scb9328.h:#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */
include/configs/versatile.h:#define CONFIG_SYS_HZ (1000000 / 256)
include/configs/zipitz2.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Easy to resolve conflict on the GPIO change.
arch/blackfin/cpu/Makefile
folder.
The gpio register mappings are different among blackfin processors.
Signed-off-by: Steven Miao <realmz6@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
This commit fixes:
cpu.c:107: warning: ‘noreturn’ function does return
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
We have converted all makefiles needed to build $(LIBS).
Until this commit we used to grep switch so that U-Boot style
and Kbuild style makefiles coexist.
But we do not need any more.
Goint forward, use always Kbuild style Makefile when adding
a new Makefile
This commit also deletes post/rules.mk,
which in not necessary any more.
Cc: Stefan Roese <sr@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Macpaul Lin <macpaul@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Before this commit, arch/sparc/lib/Makefile used
both COBJS and COBJS-y.
And it missed to add COBJS-y into OBJS.
This means bootm.o was never compiled even if
CONFIG_CMD_BOOTM=y
This patch moves S5PC, EXYNOS specific directory entries
from the toplevel Makefile to arch/arm/cpu/armv7/Makefile
using Kbuild descending feature.
This patch moves OMAP specific directory entries
from the toplevel Makefile and spl/Makefile
to arch/arm/cpu/armv7/Makefile using Kbuild descending feature.
This patch moves Tegra specific directory entries
to arch/arm/cpu/*/Makefile using Kbuild descending feature.
Cc: Tom Warren <TWarren@nvidia.com>
This commit moves some subdirectories of fs
from the toplevel Makefile to fs/Makefile
This commit moves some drivers subdirectory entry
from the toplevel Makefile to drivers/Makefile
This patch tweaks scripts/Makefile.build to allow
the build system to descend into subdirectories like Kbuild.
To use this feature, use "obj-y += foo/" syntax.
Example:
obj-$(CONFIG_FOO) += foo/
Note:
arch/powerpc/cpu/mpc8260/Makefile is originally like follows:
---<snip>---
START = start.o kgdb.o
COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \
---<snip>---
COBJS-$(CONFIG_ETHER_ON_SCC) = ether_scc.o
---<snip>---
$(LIB): $(OBJS)
$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)
The link rule `$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)'
is weird.
kbdg.o is not included in $(OBJS) but linked into $(LIB)
and $(LIB) is not dependent on kgdb.o.
(Broken dependency tracking)
So,
shoud have been
START = start.o
SOBJS = kgdb.o
That is why this commit adds kgdb.o to obj-y, not to extra-y.
Multiple targets are included in arch/arm/imx-common/Makefile
In order to refactor it,
we need to tweak Makefile and spl/Makefile.
Note1:
In arch/arm/cpu/arm926ejs/spear/Makefile
START := start.o
was changed
extra-$(CONFIG_SPL_BUILD) := start.o
because spear/start.o is only used for SPL.
Note2:
START := start.o
was missing from arch/arm/cpu/arm926ejs/mxs/Makefile.
This commit simply adds
