This patch will create a configuration option for a minimum configuration for
the ns16550 serial driver at drivers/serial/ns16550.c and will apply this new
configuration option to the SIMPC8313.h config file in order to fix the NAND
bootstrap build error. This option will exclude all functions with exception of
NS16550_putc and NS16550_init. This will be used primarily to save space and
remove unused code from builds in which space is limited.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
swapping the include order suppresses warnings for board configs
that define their own CONFIG_MAX_MEM_MAPPED:
In file included from /home/r1aaha/git/u-boot/include/config.h:5,
from /home/r1aaha/git/u-boot/include/common.h:35,
from simpc8313.c:26:
/home/r1aaha/git/u-boot/include/configs/SIMPC8313.h:81:1: warning:
"CONFIG_MAX_MEM_MAPPED" redefined
In file included from /home/r1aaha/git/u-boot/include/config.h:4,
/home/r1aaha/git/u-boot/include/asm/config.h:28:1: warning: this is
the location of the previous definition
Fix for these build problems:
error: static declaration of 'flash_get_info' follows non-static declaration
This patch fixes a problem recently seen on some 4xx platforms. For
example on Kilauea PCIe slot #0.
This patch prepares the good old PMC405 board support for
upcoming PMC405V2 patches.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes coding style for PMC405 board support.
Also some unneeded features/code is removed.
1. Changes to the default environment:
- "bootcmd" defined as "run flash_self"
- "saveenv" command removed from "update"
- "uboot" changed to "u-boot" (also in "load")
- "addmtd" variable defined (and added to all boot commands)
2. CONFIG_CMD_JFFS2 defined to enable "mtdparts" command
3. MTDIDS_DEFAULT and MTDPARTS_DEFAULT defined
4. CONFIG_SYS_CBSIZE changed from 256 to 512. That solves the problem
with truncated "bootargs" environment variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Move the CONFIG_8xx mpc8xx_pcmcia.c protection out of the C file and
into the Makefile so we avoid pointless compiling of the file.
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to
avoid pointless compiles.
Because the functions have been defined using macros, grepping for
their definitions is not possible. This patch adds the real function
names in comments.
Signed-off-by: Petri Lehtinen <petri.lehtinen@inoi.fi>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
Default CONFIG_CMD_IMLS must be disabled when CONFIG_SYS_NO_FLASH is defined
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
- Extend ub_dev_read() and ub_dev_recv() so they return the length actually
read, which allows for better control and error handling (this introduces
additional error code API_ESYSC returned by the glue mid-layer).
- Clean up definitions naming and usage.
- Other minor cosmetics.
Note these changes do not touch the API proper, so the interface between
U-Boot and standalone applications remains unchanged.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
Acked-by: Rafal Jaworowski <raj@semihalf.com>
De-hardcode range in RAM we search for the API signature. Instead use the stack
pointer as a hint to narrow down the range in which the signature could reside
(it is malloc'ed on the U-Boot heap, and is hoped to remain in some proximity
from stack area). Adjust PowerPC code in API demo to the new scheme.
After introducing redundant environment the kernel images was
overlapping with environment.
Signed-off-by: Andy Fleming <afleming@freescale.com>
This uses the new MMC framework
Some contributions by Dave Liu <daveliu@freescale.com>
Here's a new framework (based roughly off the linux one) for managing
MMC controllers. It handles all of the standard SD/MMC transactions,
leaving the host drivers to implement only what is necessary to
deal with their specific hardware.
This also hooks the infrastructure into the PowerPC board code
(similar to how the ethernet infrastructure now hooks in)
Some of this code was contributed by Dave Liu <daveliu@freescale.com>
The current MMC infrastructure relies on the existence of an
arch-specific header file. This isn't necessary, and a couple
drivers were forced to implement dummy files to meet this requirement.
Instead, we move the stuff in those header files into a more appropriate
place, and eliminate the stubs and the #include of asm/arch/mmc.h
This is to get it out of the way of incoming MMC framework
MMC cards are not memory, so we stop treating them that way.
This errata fix is required for 32 bit DDR2 controller on 8572.
May also be required for P10XX20XX platforms
Signed-off-by: Poonam_Agarwal-b10812 <b10812@lc1106.zin33.ap.freescale.net>
The ecm variable in sdram.c was being declared for all 8548, but only
used by specific 8548 boards, so we make that variable require those
specific boards, too
The nand code was using an index "i" into a table, and then re-using "i"
to set addresses for each upm. However, then it relied on the old value
of i still being there to enable things. Changed the second "i" to "j"
This patch adds the workaround for erratum DDR20 according to MPC8548
Device Errata document, Rev. 1: "CKE signal may not function correctly
after assertion of HRESET". Furthermore, the bug DDR19 is fixed in
processor version 2.1 and the work-around must be removed.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This patch makes accesses to the system memory cachable by removing the
caching-inhibited and guarded flags from the relevant TLB entries for
the TQM8548_BE and TQM8548_AG modules. FYI, the Freescale MPC85* boards
are configured similarly.
This results in a big averall performace improvement. TFTP downloads,
NAND Flash accesses, kernel boots, etc. are much faster.
This patch add support for the 1 GiB DDR2-SDRAM on the TQM8548_AG
module.
Signed-off-by: Jens Gehrlein <sew_s@tqs.de>
According to new TQM8548 timing specification:
Refresh Recovery: 34 -> 53 clocks
CKE pulse width: 1 -> 3 cycles
Window for four activities: 13 -> 14 cycles
The TQM8548_AG is a variant of the TQM8548 module with 1 GiB memory,
CAN and without PCI/PCI-X and RTC. U-Boot can be built for this module
with "$ make TQM8548_AG_config".
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN
interface. With NAND support, the image is significantly larger and
TEXT_BASE is adjusted accordingly. U-Boot can be built for this
module with "$ make TQM8548_BE_config".
The TQM8548_AG module does not have the standard PCI/PCI-X interface
connected but just the PCI Express interface . So far it was not
possible to disable it without disabling the complete PCI interface
(CONFIG_PCI) including PCI Express.
As the reset vector is located at 0xfffffffc, all flash sectors from the
beginning of the U-Boot binary to 0xffffffff must be protected. On the
TQM8548-AG having small sectors at the end of the flash it happened that
the last two sector were not protected and an "erase all" left an
un-bootable system behind:
Bank # 2: CFI conformant FLASH (32 x 16) Size: 32 MB in 270 Sectors
AMD Standard command set, Manufacturer ID: 0xEC, Device ID: 0x257E
Erase timeout: 8192 ms, write timeout: 1 ms
FFFA0000 E RO FFFC0000 RO FFFE0000 RO FFFE4000 RO FFFE8000 RO
FFFEC000 RO FFFF0000 RO FFFF4000 RO FFFF8000 E FFFFC000
The same bug seems to be in drivers/mtd/cfi_flash.c:flash_init() and many
board BSPs as well.
- Update style of 86xx CPU information on boot to more closely
match 85xx boards
- Fix detection of 8641/8641D
- Use strmhz() to display frequencies
- Display L1 information
- Display L2 cache size
- Fixed CPU/SVR version output
== Before ==
Freescale PowerPC
CPU:
Core: E600 Core 0, Version: 0.2, (0x80040202)
System: Unknown, Version: 2.1, (0x80900121)
Clocks: CPU:1066 MHz, MPX: 533 MHz, DDR: 266 MHz, LBC: 133 MHz
L2: Enabled
Board: X-ES XPedite5170 3U VPX SBC
== After ==
CPU: 8641D, Version: 2.1, (0x80900121)
Core: E600 Core 0, Version: 2.2, (0x80040202)
Clock Configuration:
CPU:1066.667 MHz, MPX:533.333 MHz
DDR:266.667 MHz (533.333 MT/s data rate), LBC:133.333 MHz
L1: D-cache 32 KB enabled
I-cache 32 KB enabled
L2: 512 KB enabled
Update the 86xx reset sequence to try executing a board-specific reset
function. If the board-specific reset is not implemented or does not
succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard
reset procedure than the previous method and allows all board
peripherals to be reset if needed.
Previously if we >=4G of memory and !CONFIG_PHYS_64BIT we'd report
an error and hang. Instead of doing that since DDR is mapped in the
lowest priority LAWs we setup the DDR controller and the max amount
of memory we report back is what we can map (CONFIG_MAX_MEM_MAPPED)
Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
Added various p2020 processor specific details:
* SVR for p2020, p2020E
* immap updates for LAWs and DDR on p2020
* LAW defines related to p2020
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com>
Added some info that is printed out when we boot to distiquish if we
built MPC8572DS_config vs MPC8572DS_36BIT_config since they have
different address maps.
The device tree's PHY addresses need to be fixed up if we're using the
SGMII Riser Card.
The 8572, 8536, and 8544 DS boards were modified to call this function.
Code idea taken from Liu Yu <yu.liu@freescale.com>
This allows code to iterate through the ethernet devices
In the 36-bit physical config for MPC8572DS when need the start address
of memory and it size to be kept in phys_*_t instead of a ulong since
we support >4G of memory in the config and ulong cant represent that.
Otherwise we end up seeing the memory node in the device tree reporting
back we have memory starting @ 0 and of size 0.
When we introduced the 36-bit config of the MPC8572DS board we had the
wrong PCI MEM bus address map. Additionally, the change to the address
map exposes a small issue in our dummy read on the ULI bus. We need
to use the new mapping functions to handle that read properly in the
36-bit config.
Previously we only allowed power-of-two memory sizes and didnt
handle >2G of memory. Now we will map up to CONFIG_MAX_MEM_MAPPED
and should properly handle any size that we can make in the TLBs
we have available to us
If we only have one controller we can completely ignore how
memctl_intlv_ctl is set. Otherwise other levels of code get confused
and think we have twice as much memory.
