(tschaefer@giga-stream.de). Now inital stack in data cache can be used even if the chip select is in use.
add support for the MIP405T board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
* Fix alignment problems with flash driver for TRAB board
* Patch by Donald White, 21 May 2003:
fix calculation of base address in pci_hose_config_device()
* Fix bug in command line parsing: "cmd1;cmd2" is supposed to always
execute "cmd2", even if "cmd1" fails. Note that this is different
to "run var1 var2" where the contents of "var2" will NOT be
executed when a command in "var1" fails.
In preparation for an ixp port, rename cpu/xscale and arch-xscale
into cpu/pxa and arch-pxa.
- CPCI4052 added (PPC405GP based).
- CPCI405AB added (PPC405GP based).
- PCI405 added (PPC405GP based).
- PMC405 added (PPC405GP based).
- BUBINGA405EP added (PPC405EP based).
add support for the MIP405-3 board
- CONFIG_UART1_CONSOLE added (see README).
- "nand_init" (NAND FLASH) added.
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
allow to pass boot bitmap addresses in environment variables;
allow for zero boot delay
* Patch by Christian Geißinger, 19 May 2002:
On TRAB: wait until the dummy byte has been completely sent
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
allow the use of CFG_LOADS when CFG_NO_FLASH is set
(includes support for Intel 82365 and compatible PC Card controllers,
and Yenta-compatible PCI-to-CardBus controllers)
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
Update for R360MPI board
* Add new meaning to "autostart" environment variable:
If set to "no", a standalone image passed to the
"bootm" command will be copied to the load address
(and eventually uncompressed), but NOT be started.
This can be used to load and uncompress arbitrary
data.
* Set max brightness for MN11236 displays on TRAB board
OFFER-paket in the server option field #54 in the REQUEST-paket. This fixes a problem using a Windows 2000 DHCP server, where the DHCP-server is not the TFTP-server.
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
Add IDMA example code (tested on 8260 only)
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
