Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Tell 'find' to follow symbolic links, so that files under include/asm
and arch/$(ARCH)/include/asm/arch are added to the indexing file list.
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
Enable printout of i2c deblocking status if chips were in block
state or deblocking failed.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Heiko Schocher <hs@denx.de>
cc: Wolfgang Denk <wd@denx.de>
Moved eeprom config to specific part, to allow bigger eeprom write pages
for km_kirkwood designs. Write page only used for env eeprom in std use
cases. 24C128 has page size of 64bytes -> 8 time faster.
Now we use the standard u-boot make to build the Kirkwood binary.
The output file is u-boot.kwb. So use this name for the tftp
update function to avoid confusion, because this is the binary we
need on Kirkwood.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Be verbose if do_setboardid was called and print
correct names of variables in do_checkboardidhwk.
Previously reading or writing zero full sectors (reading the end of
one sector and the beginning of the next for example) was special
cased and involved stack allocating a second sector buffer. This
change uses the same code path for this case as well as when there
are a non-zero number of full sectors to access. The result is
easier to read and reduces the maximum stack used.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Andy Fleming <afleming@freescale.com>
Fix all checkpatch violations in the low level Ext2 block
device reading code. This is done in preparation for cleaning
up the partial sector access code.
see discussion also here:
http://patchwork.ozlabs.org/patch/75309/
cc: Holger Brunck <holger.brunck@keymile.com>
All the km boards uses CRAMFS images where the kernel is stored.
This isn't architecture specific because we use it on ARM and
POWERPC.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Common code should be valid for more than one architecture,
therefore the km82xx specific code was removed from common.c.
This code is unused and therefore dead code.
The file common.c grows in the past. So move the IVM specific
code into an ivm.c file.
This is unneeded here because we save the environment when
the board boots the first time. At this time we have set
the values already.
The ethaddr is stored inside the inventory eeprom. During
boottime this value was read out and the ethaddr variable was
set. Previously this was only done if it ethaddr == NULL but
this is wrong for our ARM boards. Because ethaddr is at this
stage never NULL for ARM due to the random calculation of a
MAC address in mvgbe.c.
These defines and the header keymile_hdlc_enet.h are obsolete
due to the removed hdlc code.
The debug environment which is stored in textfiles in the
scripts directory was reworked. Two usecase are now present
which can be executed simply from the default environment:
run develop: this configures the environment to setup the
rootfs via nfs
run ramfs: this configures the environment to setup the
rootfs in ram
Each architecture now has a "arch" variable which is used
to load the architecture specific debug scripts and to set
the rootpath for NFS.
The test SW is started when the test_bank variable is set.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
This is the second step to simplify and decrease the default
environment for the keymile boards. The release usecase formaly
used to set the production environment was removed and the default
configuration is now the production environment. So the formar
environment variable "release" which has done a lot of things
in the past, simply erase the current environment and do a reset
which forces u-boot to setup the default environment again.
Apple iPod nanos have sector sizes of 2 or 4 KiB, which crashes U-Boot when it
tries to read the MBR into 512-byte buffer situated on stack. Instead use the
variable length arrays to be safe with any large sector size.
change bd->bi_memsize to gd->ram_size, as this is defined
on all archs, so this post test can used on none powerpc
archs too.
cc: Wolfgang Denk <hs@denx.de>
cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Cc: Ben Warren <biggerbadderben@gmail.com>
Up to now only reading 'appreg' value was implemented in the
digsyMTC special 'mtc appreg' command. Extend the command to
support writing appreg value, too.
Signed-off-by: Werner Pfister <Pfister_Werner@intercontrol.de>
Add detection and initialisation for graphic extension board
and support splash screen when booting. Enable "bmp" command
in the board configuration and provide "disp" command to
be able to switch the display on/off.
gen10g_startup() had 2 bugs:
1) It had a boolean logic error in checking the MMD mask, and
always checked all of them.
2) It checked devices which don't actually report link state, which
meant that it would never believe the link was fully up.
Fix the boolean logic, and then mask the MMD mask so only link-reporting
devices are checked.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz>
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Command calls update_tftp() analogous to automatic update described
in doc/README.update.
Usage:
fitupd [addr]
- run update from FIT image at addr
or from tftp 'updatefile'
Signed-off-by: Andreas Pretzsch <apr@cn-eng.de>
Current update_tftp() flow:
1.) fetch "updatefile" from defined TFTP server
2.) check if FIT format
3.) flash contained images
Add an address parameter to update_tftp(). If this address is non-zero,
skip the TFTP transfer and use the image at this address.
Also extend update_tftp() to return success/fail.
The post.c code is missing braces around the pass case, and as a
result, the diagnostic function will post both fail and pass for
a failed test. The reason for this bug is probably the incorrect
indentation used, so when reading the code it seems like there
are proper braces.
Indent the code to the correct depth and put proper braces around
the "else" branch of the "if" statement.
Signed-off-by: James Kosin <jkosin@intcomgrp.com>
Now that the tools target requires the generated version header file, we
need to make sure that the directory it writes to exists. In a configured
tree, this is taken care of for us. But in an unconfigured one, the dir
does not yet exist causing a build error like so:
/bin/sh: line 5: ..../u-boot_build/include/version_autogenerated.h.tmp: No such file or directory
So create the dir for this file before we attempt to generate it.
Since panic() never returns, we should add an appropriate attribute to
let gcc improve optimization around it.
The targets/prerequisites are the same here; the rules only differ in
the recipes. So move the if logic protection to the recipe part so we
can keep the rest the same.
This adds a simple flash test to automatically verify erasing,
writing, and reading of sectors. The code is based on existing
Blackfin tests but generalized for everyone to use.
We've got a handy dandy macro already for calculating the number of
elements in an array, so use it.
Now that we have the generic GPIO layer, we can easily provide a common
implementation for the post_hotkeys_pressed() function based on it.
The current arch/driver specific UART posts basically boil down to setting
the UART to loop back mode, then reading and writing data. If we ignore
the loop back part, the rest can be built upon the existing common serial
API. So let's do just that.
First add a call back for serial drivers to implement loop back control.
Then write a post test that walks all of the serial drivers, puts them
into loop back mode, and verifies that reading/writing at all the diff
baud rates is OK.
If a serial driver doesn't support loop back mode (either it can't or
it hasn't done so yet), then skip it. This should allow for people to
easily migrate to the new post test with existing serial drivers.
I haven't touched the few already existing uart post tests as I don't
the hardware or knowledge of converting them over. So I've marked the
new test as weak which will allow the existing tests to override the
default until they are converted.
The multi serial support has a "ctlr" field which almost no one uses,
but everyone is forced to set to useless strings. So punt it.
Funny enough, the only code that actually reads this field (the mpc8xx
driver) has a typo where it meant to look for the SCC driver. Fix it
while converting the check to use the name field.
CC: Heiko Schocher <hs@denx.de>
CC: Anatolij Gustschin <agust@denx.de>
CC: Tom Rix <Tom.Rix@windriver.com>
CC: Minkyu Kang <mk7.kang@samsung.com>
CC: Craig Nauman <cnauman@diagraph.com>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Prafulla Wadaskar <prafulla@marvell.com>
CC: Mahavir Jain <mjain@marvell.com>
The serial_register function never fails (always return 0), so change it
to a void function to avoid wasting overhead on it.
Rather than sticking arch/board/driver specific logic in the common
serial code, push it all out to the respective drivers. The serial
drivers declare these funcs weak so that boards can still override
things with their own definition.
Tested-by: Minkyu Kang <mk7.kang@samsung.com>
Some toolchains enable security warning flags by default, but these don't
really make sense in the u-boot world. Such as forcing changes like:
-printf(foo);
+printf("%s", foo);
So disable the flags when the compiler supports them. Linux has already
merged a similar change in their build system.
The usage helper doesn't modify the command, so constify its input arg.
I can't see any obvious needs for the default environment to be writable,
so make it const.
For people who want to manually extract the embedded environment so that
it can be manually packed into the final u-boot image, add a config opt
to force building of the envcrc tool.
Newer SST flashes have dropped the Auto Address Increment (AAI) word
programming (WP) modes in favor of the standard page programming mode
that most flashes now support. So add a flags field to the different
flashes to support both modes with new and old styles.
Every spi flash uses the same write disable command, so unify this in
the common code.
Fixed commit message.
These defines are used in only one place, so just inline them.
Now that the common spi_flash structure tracks all the info that these
drivers need, kill off their local state indirection and use just what
the common code provides.
Once we add a new page_size field for write lengths, we can unify the
write methods for most of the spi flash drivers.
