This file should contain the bin_hdr generated by the original Marvell
U-Boot implementation. As this is currently not included in this
U-Boot version, we have added this placeholder, so that the U-Boot
image can be generated without errors.
If you have a known to be working bin_hdr for your board, then you
just need to replace this text file here with the binary header
and recompile U-Boot.
In a few weeks, mainline U-Boot will get support to generate the
bin_hdr with the DDR training code itself. By implementing this code
as SPL U-Boot. Then this file will not be needed any more and will
get removed.
Actually, unmap_sysmem() does nothing. Just in case.
- Do not insert a whitespace between a function name and
an open paranthesis
- Fix comment style
- Do not split an error message into multiple lines
even if it exceeds 80 columns
- Do not split "for" statement where it fits in 80 columns
- Do not use assignment in if condition
Since commit fe1378a961e5 (ARM: use r9 for gd), r9 register
is used on ARM to hold global_data.
Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
I finally had a look at the datasheet and spotted an additional
register address difference between regular E1000 and i210/i211 chips.
This patch fixes this and now successfully works on programmed
i210/i211 as well as unprogrammed i211.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Fix typo in defconfig file format description.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
CONFIG_TPL should not be enabled for boards that do not have TPL.
CONFIG_SUPPORT_TPL introduced by this commit should be "select"ed
by boards with TPL support and CONFIG_TPL should depend on it.
CONFIG_SPL should not be enabled for boards that do not have SPL.
CONFIG_SUPPORT_SPL introduced by this commit should be "select"ed
by boards with SPL support and CONFIG_SPL should depend on it.
Commit 951860634fdb557bbb58e0f99215391bc0c29779 may have changed
the logic unintentially from "if (!(swfw_sync & (fwmask | swmask)))"
to "if ((swfw_sync & swmask) && !(swfw_sync & fwmask))". This change
breaks some e1000 NIC with a message "ERROR: Unable to read EEPROM!".
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Marek Vasut <marex@denx.de>
CC: Tim Harvey <tharvey@gateworks.com>
Acked-by: Marcel Ziswiler <marcel@ziswiler.com>
CHUNK_TYPE_DONT_CARE should skip over the specified number of blocks, but
currently fails to increment the device block address. This results in
filesystem images getting written incorrectly. Add the missing block
address incrementing.
Cc: Steve Rae <srae@broadcom.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Steve Rae <srae@broadcom.com>
Enable EXT support in SPL for OMAP4 boards.
Build tested for duovero, omap4_sdp4430 and omap4_panda.
Run time tested on omap4_panda.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Tom Rini <trini@ti.com>
allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
Do not hang in spl_register_fat_device but return an error value.
It allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
If FAT load fails, then EXT load is tried.
Update documentation according to the EXT SPL support patch set.
Add EXT filesystem support to SPL.
[trini: Fix a warning and checkpatch problems]
Rename some defines containing FAT in their name to be filesystem generic:
MMCSD_MODE_FAT => MMCSD_MODE_FS
CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION
These types are problematic because they are typically declared in a
non-standard way in U-Boot. For example, U-Boot uses 'long long' for
int64_t even on a 64-bit machine whereas stdint.h uses 'long'.
Similarly, U-Boot always uses 'long' for intptr_t whereas stdint.h mostly
uses 'int'.
This simple test script runs a few toolchains on a few archs to check for
warnings.
Use the inttypes header file to provide this.
Use inttypes.h and uint64_t to correct the code so that it will not issue
warnings on 64-bit machines where 'uint64_t' is 'unsigned long'.
Use the correct type required by do_div().
Unfortunately 'unsigned long long' and 'uint64_t' are not necessarily
compatible on 64-bit machines. Use the correct typedef instead of
writing the supposed type out in full.
On 64-bit platforms (like sandbox) 64-bit integers may be 'long' rather
than 'long long'. Use the inttypes header to avoid compiler warnings.
inttypes.h defines format specifiers for printf which work with data types of
particular sizes. stdlib.h is currently just a passthrough to malloc.h which
has declarations of the various *alloc functions.
Add the required #define to common.h so that these printf format specifiers
will be made available.
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-by: Gabe Black <gabeblack@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
Reviewed-by: Bill Richardson <wfrichar@google.com>
(Replaced with a GPL version from glibc)
There's a definition in stdint.h (provided by gcc) which will be more correct
if available.
Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make'
commmand.
This adjusts the settings for x86 and sandbox, with both have 64-bit options.
Rewritten to be an option, since stdint.h is often available only in glibc.
Changed to preserve a clear boundary between stdint and non-stdint
Since i2c_init_all always sets the bus back to CONFIG_SYS_SPD_BUS_NUM
for compatibility reasons, it means that any eeprom not located on this
CONFIG_SYS_SPD_BUS_NUM is not accessible with the eeprom commands, even
if you change the bus number with an i2c dev command before.
Furthermore i2c_init_all should disappear and is currently only called
from the early board initialisation sequences, it is not suited for
other usage.
This reverts commit 01a0c64762e902971b34587a8a61b59e9ea51374.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Align the documentation with the include/linux/etherdevice.h ,
which is where this example comes from. The return value from
the check was inverted in the documentation.
Signed-off-by: Olaf Mandel <o.mandel@menlosystems.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
LaCie Wireless Space has no defined maintainer.
Set myself as maintainer, since I own one of these.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The run command treats each argument an an environment variable. It gets the
value of each variable and executes it as a command. If an environment
variable contains a newline and the hush cli is used, it is supposed to
execute each line one after the other.
Normally a newline signals to hush to exit - this is used in normal command
line entry - after a command is entered we want to return to allow the user
to enter the next one. But environment variables obviously need to execute
to completion.
Add a special case for the execution of environment variables which
continues when a newline is seen, and add a few tests to check this
behaviour.
Note: it's not impossible that this may cause regressions in other areas.
I can't think of a case but with any change of behaviour with limited test
coverage there is always a risk. From what I can tell this behaviour has
been around since at least U-Boot 2011.03, although this pre-dates sandbox
and I have not tested it on real hardware.
Reported-by: Wolfgang Denk <wd@denx.de>
This board is old and is using CONFIG_I2C_X, which is wrong.
This is the only used of CONFIG_SPI_X macro, just zap this.
Remove this board as this is the only one last user of eeprom_probe(),
which is pretty non-standard stuff.
This patch also removes all the PHP, SQL and CSS stuff from U-Boot,
which probably makes U-Boot a bit less IoT ;-)
This board uses eeprom accessors in an incorrect way. The board
is old and unsupported, just zap it.
This board is the only user of CONFIG_SYS_EEPROM_X40430 , remove
it so the EEPROM command code can be cleansed of the related code
as well.
The file board/Marvell/include/mv_gen_reg.h is incompatible with
the GPL (see for example the "MARVELL RESERVES THE RIGHT AT ITS SOLE
DISCRETION TO REQUEST THAT THIS CODE BE IMMEDIATELY RETURNED TO
MARVELL" clause). As this cannot be fixed, we remove the file and all
code that depends on it. Fortunately this only affects some very old
boards that have long reached EOL:
CPCI750
DB64360
DB64460
p3m750
p3m7448
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Roger Meier <r.meier@siemens.com>
The config targets described in README are not present
any more, update the info to currently used targets.
Also enable CONFIG_DISPLAY_BOARDINFO to get checkboard() called.
Commit d6b11fd1 (powerpc: remove MBX and MBX860T boards support)
removed mbxbar field in "struct sysconf512x" by mistake and broke
booting on mpc5121 boards. Fix it.
