This commit moves some flags which are used
under examples/ directory only.
Some flags are used for SPL (and TPL) build only.
This commit moves them from config.mk to spl/Makefile.
This commit merges commonly-used header include paths
to UBOOTINCLUDE and NOSTDINC_FLAGS variables, which are placed
at the top Makefile.
Before this commit, most of compiler flags were defined in config.mk.
But it is redundant because config.mk is included from all recursive make.
This commit moves many complier flags to the top Makefile
and export them.
And we use new vaiarables to store them:
KBUILD_CPPFLAGS, KBUILD_CFLAGS, KBUILD_AFLAGS.
This will allow us to switch more smoothly to Kbuild.
This commit adjusts some files to use Kbuild.include.
- Use cc-option defined in Kbuild.include
(Delete cc-option in config.mk)
- Use cc-version defined in
(Delete cc-version in config.mk)
- Move binutils-version and dtc-version to Kbuild.include
by analogy to cc-version
This commit also adds srctree (same as SRCTREE)
to use Kbuild scripts.
BFD_ROOT_DIR is used only in tools/gdb/Makefile
This commit moves some variable definitions from config.mk
to the top Makefile:
- HOSTCC, HOSTCFLAGS, HOSTLDFLAGS
- AS, LD, CC, CPP, etc.
- SHELL (renamed to CONFIG_SHELL)
I'd like to slim down config.mk file
because it is included from all recursive make.
It is redundant to re-define the variables
every time descending into sub directories.
We should rather define them at the top Makefile
and export them.
U-Boot makefiles has been used "SHELL" variable to store shell
chosen for the user, whereas Linux Kernel uses "CONFIG_SHELL".
We should never use "SHELL" variable because it is
a special variable for GNU Make.
Changing SHELL may cause unpredictable side effects
whose root cause is usually difficult to find.
We should use a generic variable name "CONFIG_SHELL".
We should not use the syntax as follows either:
rm -f $(obj)tools/env/{fw_printenv,fw_setenv}
This depends on "bash" although GNU Make generally
invokes "sh" to run the each rule.
This commit moves suffix rules from config.mk
to scripts/Makefile.build, which will allow us
to switch smoothly to real Kbuild.
Note1:
post/lib_powerpc/fpu/Makefile has
its own rule to compile C sources.
We need to tweak it to keep the same behavior.
Note2:
There are two file2 with the same name:
arch/arm/lib/crt0.S and eamples/api/crt0.S.
To keep the same build behavior,
examples/api/Makefile also has to be treaked.
Some Samsung boards have their own tools under board/samsung/<board>/tools/.
This commit refactor more makefiles with "hostprogs-y".
Before this commit, makefiles under tools/ directory
were implemented with their own way.
This commit refactors them by using "hostprogs-y" variable.
Several C sources have been added to wrap other C sources
to simplify Makefile.
For example, tools/crc32.c includes lib/crc32.c
This commit adds scripts/Makefile.host.tmp which will
be used in the next commit to convert makefiles
under tools/ directory to Kbuild style.
Notice this script, scripts/Makefile.host.tmp
is temporary.
When switching over to real Kbuild,
it will be replaced with scripts/Makefile.host of Linux Kernel.
Ignore generated files by Kbuild such as .*.cmd, *.order, etc.
Besides above,
- Ignore *.s files
We do not need to ignore with file name, asm-offsets.s
- Do not ignore *.rej (for quilt)
- Ignore backup files, \#*#
Commit 779bf42c moved timer functions from
arch/microblaze/lib/time.c to arch/microblaze/cpu/timer.c.
But the empty file, arch/microblaze/lib/time.c
has been remaining probably for a human mistake.
Cc: Michal Simek <michal.simek@xilinx.com>
Add the SATA boot support for OMAP5 and dra7xx.
Renamed the omap_sata_init to the common init_sata(int dev)
for commonality in with sata stack.
Added the ROM boot device ID for SATA.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Reviewed-by: Roger Quadros <rogerq@ti.com>
Add spl_sata to read a fat partition from a bootable SATA
drive.
The incorrect substitution made it rebuild every time.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Cc: Tom Rini <trini@ti.com>
Unlike other commands (for example, "fatwrite"), ext4write would
interpret the "sizebytes" as decimal number. This is not only
inconsistend and unexpected to most users, it also breaks usage
like this:
tftp ${addr} ${name}
ext4write mmc 0:2 ${addr} ${filename} ${filesize}
Change this to use the standard notation of base 16 input format.
See also commit b770e88
WARNING: this is a change to the user interface!!
Cc: Uma Shankar <uma.shankar@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
commit 626ee1e3 "phylib: update atheros ar803x phy"
leads in failing ethernet on the pxm2 board.
Calling genphy_config() instead of ar8021_config(),
which seems for ar8021 phys not ar803x phys, make
it working again.
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
This commit removes platform CONFIG_SYS_HZ definition for the
remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Cc: Rob Herring <rob.herring@calxeda.com>
Commit af5b9b1f removed mini2440 board support,
but missed to delete include/configs/mini2440.h.
Signed-off-by: Detlev Zundel <dzu@denx.de>
I recently re-wrote cmd_test() to add new features. Add a bunch of unit-
tests to make sure I didn't break anything.
Suggested-by: Simon Glass <sjg@chromium.org>
"env default -f" doesn't work any more; replace it with
"env default -f -a". This avoids the following when running the ut
command:
do_ut_cmd: Testing commands
env - environment handling commands
Usage:
env default [-f] -a - [forcibly] reset default environment
This hooks into the generic "file exists" support added in an earlier
patch, and provides an implementation for the FAT filesystem.
patch, and provides an implementation for the ext4 filesystem.
Since the generic ls command no longer segfaults sandbox, enable it.
patch, and provides an implementation for the sandbox test environment.
This is much like a regular shell's -e operator, except that it takes
multiple arguments to specify the device type and device/partition ID
in addition to the usual filename:
if test -e mmc 0:1 /boot/boot.scr; then echo yes; else echo no; fi
This emulates bash:
$ if test; then echo yes; else echo no; fi
no
Currently, the code sets expr = -1 in this case, which gets mapped to
0 (true) at the end of do_test() by the logical -> shell exit code
conversion.
Currently, ! can only be parsed as the first operator in an expression.
This prevents the following from working:
$ if test ! ! 1 -eq 1; then echo yes; else echo no; fi
yes
$ if test ! 1 -eq 2 -a ! 3 -eq 4; then echo yes; else echo no; fi
yes
Fix this by parsing ! like any other operator, and and handling it
similarly to -a and -o.
This better mirrors the behaviour of bash, for example:
$ if test -z = -z; then echo yes; else echo no; fi
yes
This is parsed as a string comparison of "-z" and "-z", since the check
for the binary "=" operator occurs first. Without this change, the
command would be parsed as a -z test of "-", followed by a syntax error;
a trailing -z without and operand.
This is a behavioural change, but I believe any commands affected were
previously invalid or bizarely formed.
do_test() currently uses strcmp() twice to determine which operator is
present; once to determine how many arguments the operator needs, then
a second time to actually decode the operator and implement it.
Rewrite the code so that a table lookup is used to translate the operator
string to an integer, and use a more efficient switch statement to decode
and execute the operator.
This approach also acts as enablement for the following patches.
This patch should introduce no behavioural change.
FAT and ext4 expect that the passed in block device descriptor not be
NULL. This causes problems on sandbox, where get_device_and_partition()
succeeds for the "host" device, yet passes back a NULL device descriptor.
Add special handling for this situation, so that the generic filesystem
commands operate as expected on sandbox.
This could be used in scripts such as:
load mmc 0:1 ${scriptaddr} /boot/boot.scr
source ${scriptaddr}
fi
rather than:
if load mmc 0:1 ${scriptaddr} /boot/boot.scr; then
fi
This prevents errors being printed by attempts to load non-existent
files, which can be important when checking for a large set of files,
such as /boot/boot.scr.uimg, /boot/boot.scr, /boot/extlinux.conf,
/boot.scr.uimg, /boot.scr, /extlinux.conf.
Fix a few issues with the generic "save" shell command, and fs_write()
function.
1) fstypes[].write wasn't filled in for some file-systems, and isn't
checked when used, which could cause crashes/... if executing save
on e.g. fat/ext filesystems.
2) fs_write() requires the length argument to be non-zero, since it needs
to know exactly how many bytes to write. Adjust the comments and code
according to this.
3) fs_write() wasn't prototyped in <fs.h> like other generic functions;
other code should be able to call this directly rather than invoking
the "save" shell command.
This enables generic filesystem commands such as load and ls, which
automatically work with multiple filesystem types, without having to
be told which is present, unlike e.g. ext2load, fatls.
Typo: The correct value is 1 not 2.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
KMSUGP1 is from a u-boot perspective (almost) identical to KMNUSA.
The only difference is that the PCIe reset is connected to Kirkwood pin
MPP7_PEX_RST_OUTn, we use a dedicated config flag KM_PCIE_RESET_MPP7.
Such pin should theoretically be handled by the PCIe subsystem
automatically, but this turned out not to be the case.
So simply configure this PIN as a GPIO and issue a pulse manually.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Cc: Karlheinz Jerg <karlheinz.jerg@keymile.com>
Cc: Valentin Longchamp <valenting.longchamp@keymile.com>
Cc: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Add set_fdthigh subcommand to "subbootcmds" (release) so to set "fdt_high"
This is necessary on Kirkwood so that the FDT does not get relocated
above the memory limit that the kernel cannot access
(that is the memory part reserved for the switch).
This was tested on NUSA1, where it is necessary, and on ETER1, where it
doesn't seem to hurt.
We want the scripts to also work with older versions of u-boot, where:
a) set_fdthigh is not defined (will be default env for newer u-boots)
b) the fdt will not be available
For this reason, we use "set_fdthigh" to tell whether we are running
a newer (FDT-aware) u-boot or not.
So if "set_fdthigh" runs successfully or arch != arm we try loading
the fdt; otherwise we proceed normally.
Notice how, contrary to release mode, set_fdthigh will _not_ be part of
subbootcmds for develop and ramfs, but will be executed as part of
"tftpfdt".
Since this is only needed for kirkwood cards, and it prevents the kernel
from booting on QorIQ (though it seemed to work on ETER1), we change
its definition in the default env for powerpc so that the value is only
set on ARM.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This consists of:
a) Defining the addresses, enabling fdtsupport [arm]
b) Defining "cramfsloadfdt" [arm,powerpc => common]
c) Adding the FDT address to bootm [arm,powerpc => common]
d) Defining "tftpfdt" in ramfs-,develop- [arm,powerpc >= common]
This should work with 3.10 kernels, whether loaded through TFTP
(with rootfs either through NFS or TFTP-ramfs) or from the NAND.
The machid was left unchanged, this should keep compatibility with both
older and newer kernels.
miiphy_read and miiphy_write are returning 0 on success.
This is needed for board specific additional environment variables.
E.g. the mgcoge3un has this additional "waitforne" variable.
