2007-01-24 | Merge with /home/tur/proj/idmr/u-boot | Wolfgang Denk | |
2007-01-23 | [iDMR] Add MTD and JFFS2 support, also add default partition definition. | Bartlomiej Sieka | |
2007-01-23 | [iDMR] Flash driver on initialisation write-protects some sectors, | Bartlomiej Sieka | |
currently sectors 0-3. Sector 3 does not need to be protected, though (U-boot occupies sectors 0-1 and the environment sector 2). This commit fixes this, i.e., only sectors 0-2 are protected. | |||
2007-01-23 | [iDMR] Using MII-related commands on iDRM board doesn't work now (e.g., | Bartlomiej Sieka | |
"mii device" results in "Unexpected exception"). Fixing this properly requires some clean-up in the FEC drivers infrastructure for ColdFire, so this commit disables MII commads for now. | |||
2007-01-23 | [ColdFire MCF5271 family] Add CPU detection based on the value of Chip | Bartlomiej Sieka | |
Identification Register (CIR). | |||
2007-01-19 | Minor code cleanup. | Wolfgang Denk | |
2007-01-19 | Merge with /home/hs/SC3/u-boot-dev | Wolfgang Denk | |
2007-01-19 | [PATCH] SC3 board: added CFG_CMD_AUTOSCRIPT. | Heiko Schocher | |
Signed-off-by: Heiko Schocher <hs@denx.de> | |||
2007-01-19 | [PATCH] CFI: define CFG_WRITE_SWAPPED_DATA for the CFI-Flash driver | Heiko Schocher | |
if you must swap the bytes between reading/writing. (Needed for the SC3 board) Signed-off-by: Heiko Schocher <hs@denx.de> | |||
2007-01-18 | [PATCH] Add support for Prodrive SCPU (PDNB3 variant) board | Stefan Roese | |
Signed-off-by: Stefan Roese <sr@denx.de> | |||
2007-01-18 | [PATCH] Update Prodrive P3Mx support | Stefan Roese | |
2007-01-18 | [PATCH] Add missing Taishan config file | Stefan Roese | |
2007-01-18 | [PATCH] Fix: Compilerwarnings for SC3 board. | Heiko Schocher | |
The EBC Configuration Register is now by CFG_EBC_CFG definable Added JFFS2 support for the SC3 board. Signed-off-by: Heiko Schocher <hs@denx.de> | |||
2007-01-18 | Merge with /home/stefan/git/u-boot/denx-merge-sr | Stefan Roese | |
2007-01-18 | [PATCH] Add support for AMCC Taishan PPC440GX eval board | Stefan Roese | |
2007-01-16 | Raname solidcard3 into sc3; add redundant env for sc3 | Wolfgang Denk | |
2007-01-16 | Update default environment for Solidcard3 | Wolfgang Denk | |
2007-01-15 | Merge with /home/hs/SC3/u-boot | Wolfgang Denk | |
Some code cleanup. | |||
2007-01-15 | Merge with /home/hs/MAN/u-boot-dev | Wolfgang Denk | |
2007-01-15 | Merge with /home/sr/git/u-boot/denx-merge-sr | Wolfgang Denk | |
2007-01-15 | [PATCH] Fix 440SPe rev B detection from previous patch | Stefan Roese | |
2007-01-14 | [FIX] correct I2C Writes for the LM81 Sensor. | Heiko Schocher | |
2007-01-13 | Merge with /home/sr/git/u-boot/denx-merge-sr | Wolfgang Denk | |
2007-01-13 | Merge with /home/git/u-boot | Wolfgang Denk | |
2007-01-13 | Undo commit 3033ebb2: reset command does not take any arguments | Wolfgang Denk | |
Haiying Wang's modification to the reset command was broken, undo it. Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2007-01-13 | Merge with git+ssh://sr@pollux.denx.org/home/sr/git/u-boot/denx-merge-sr | Stefan Roese | |
2007-01-13 | [PATCH] Update 440SP(e) cpu revisions | Stefan Roese | |
Also display enabled/disabled RAID 6 support for 440SP/440SPe PPC's. Signed-off-by: Stefan Roese <sr@denx.de> | |||
2007-01-13 | [PATCH] Update Yellowstone (440GR) to display board rev and PCI bus speed | Stefan Roese | |
Now the board revision and the current PCI bus speed are printed after the board message. Also the EBC initialising is now done via defines in the board config file. Signed-off-by: Stefan Roese <sr@denx.de> | |||
2007-01-13 | [PATCH] Update Yosemite (440EP) to display board rev and PCI bus speed | Stefan Roese | |
2007-01-13 | [PATCH] Update Sequoia (440EPx) to display board rev and PCI bus speed | Stefan Roese | |
Now the board revision and the current PCI bus speed are printed after the board message. Signed-off-by: Stefan Roese <sr@denx.de> | |||
2007-01-11 | Added support for the SOLIDCARD III board from Eurodesign | Heiko Schocher | |
2007-01-10 | Adjusted default environment for cam5200 board. | Reinhard Thies | |
2007-01-10 | Merge with /home/m8/git/u-boot/ | Detlev Zundel | |
2007-01-10 | Update CHANGELOG | Wolfgang Denk | |
2007-01-10 | Merge with /home/mk/11-cmb1920/u-boot#4upstream | Wolfgang Denk | |
2007-01-10 | Fix auto_update for MCC200 board. | Wolfgang Denk | |
The invocation of do_auto_update() is moved to the end of the misc_init_r() function, after the flash mappings have been initialized. Please find attached a patch that implements that change. Also correct the decoding of the keypad status. With this update, the key that will trigger the update is Column 2, Row 2. | |||
2007-01-10 | CAM5200 flash driver modifications: | Marian Balakowicz | |
- use CFI driver (replaces custom flash driver) for main 'cam5200' target - add second build target 'cam5200_niosflash' which still uses custom driver | |||
2007-01-09 | SPC1920: cleanup memory contoller setup | Markus Klotzbuecher | |
2007-01-09 | Fix the cpu speed setup to work with all boards. | Markus Klotzbuecher | |
2007-01-09 | SPC1920: add support for the FM18L08 Ramtron FRAM | Markus Klotzbuecher | |
2007-01-09 | SPC1920: update the HPI register addresses to work with the second | Markus Klotzbuecher | |
generation of hardware | |||
2007-01-09 | Miscellanious spc1920 related cleanups | Markus Klotzbuecher | |
2007-01-09 | SPC1920 GO/NOGO led should be set to color red in U-Boot | Markus Klotzbuecher | |
2007-01-09 | Add support for the DS3231 RTC | Markus Klotzbuecher | |
2007-01-09 | SMC1 uses external CLK4 instead of BRG on spc1920 | Markus Klotzbuecher | |
2007-01-09 | Update the SPC1920 CMB PLD driver | Markus Klotzbuecher | |
2007-01-09 | Add / enable I2C support on the spc1920 board | Markus Klotzbuecher | |
2007-01-09 | Add support for the tms320671x host port interface (HPI) | Markus Klotzbuecher | |
2007-01-07 | Prepare for release 1.2.0v1.2.0U-Boot-1_2_0 | Wolfgang Denk | |
