2011-03-05powerpc/85xx: Fix plat_mp_up() disabling of BPTR for CoreNet PlatformsEd Swarthout
Copying directly from ECM/PQ3 is not correct for how CoreNet based platforms handle boot page translation. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-05powerpc/corenet_ds: revise platform dependent parametersYork Sun
This patch revised clk_adjust and wrlvl_start timings for corenet_ds, based on testing on Virtium VL33B5163F-K9S and Kingston KVR1333D3Q8R9S/4G. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-05corenet_ds: pick the middle value for all tested timing parametersYork Sun
For DDR3 controller, the clk_adjust and wrlvl_start are platform-dependent. The best values should be picked up from the middle of all working combinations. This patch updates the table with confirmed values tested on Hynix dual-rank UDIMMs (HMT125U7BFR8C-H9) at 1300MT/s, 1200MT/s, 1000MT/s, 900MT/s, 800MT/s and Kingston quad-rank RDIMMs (KVR1333D3Q8R9S/4G) at 1300MT/s, 1200MT/s, 1000MT/s. Signed-off-by: York Sun <yorksun@freescale.com>
2011-03-05powerpc/mpc8xxx: Fix DDR3 timing_cfg_1 and sdram_mode registersYork Sun
The write recovery time of both registers should match. Since mode register doesn't support cycles of 9,11,13,15, we should use next higher number for both registers. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-22fsl_law: Fix LAW printing functionKumar Gala
We had an extra '0x' in the output of the LAWAR header that would cause output like: LAWBAR11: 0x00000000 LAWAR0x11: 0x80f0001d intead of: LAWBAR11: 0x00000000 LAWAR11: 0x80f0001d Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-21ARM: Update mach-typesSandeep Paulraj
This commit updates the mach-types based on the latest in linus's head Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-21arm1136 relocation: Fix calculation of board_init_rFabio Estevam
2011-02-21arm1136: Fix NAND bootFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2011-02-21arm: get_sp() should always be compiledPo-Yu Chuang
get_sp() was incorrectly excluded if none of CONFIG_SETUP_MEMORY_TAGS CONFIG_CMDLINE_TAG CONFIG_INITRD_TAG CONFIG_SERIAL_TAG CONFIG_REVISION_TAG were defined. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21mvmfp: add MFP configuration support for PANTHEONLei Wen
This patch adds the Multiple Function Pin configuration support for Marvell PANTHEON SoCs Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-21serial: add pantheon soc supportLei Wen
2011-02-21ARM: Add Support for Marvell Pantheon Familiy SoCsLei Wen
Pantheon Family processors are highly integrated SoCs based on Sheeva_88SV331x-v5 PJ1 cpu core. Ref: http://www.marvell.com/products/processors/communications/marvell_pantheon_910_920_pb.pdf SoC versions Supported: 1) PANTHEON920 (TD) 2) PANTHEON910 (TTC) Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-21mv: seperate kirkwood and armada from common settingLei Wen
Since there are lots of difference between kirkwood and armada series, it is better to seperate them but still keep the most common file shared by all marvell platform in the mv-common configure file. This patch move the kirkwood only driver definitoin in mv-common to the <soc_name>/config.h. This patch is tested with compilation for armada100 and guruplug. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-21ARM: fix write*() I/O accessorsWolfgang Denk
Commit 3c0659b "ARM: Avoid compiler optimization for readb, writeb and friends." introduced I/O accessors with memory barriers. Unfortunately the new write*() accessors introduced a bug: The problem is that the argument "v" gets evaluated twice. This breaks code like used here (from "drivers/net/dnet.c"): for (i = 0; i < wrsz; i++) writel(*bufp++, &dnet->regs->TX_DATA_FIFO); Use auxiliary variables to avoid such problems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Alexander Holler <holler@ahsoftware.de> Cc: Dirk Behme <dirk.behme@googlemail.com>
2011-02-21arm relocation: Fix calculation of board_init_rAlexander Stein
Signed-off-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
2011-02-21serial: Add Tegra2 serial port supportTom Warren
2011-02-21arm: Tegra2: Add basic NVIDIA Tegra2 SoC supportTom Warren
2011-02-21mx31pdk: Make the full boot log visibleFabio Estevam
Use board_early_init_f so that the full boot log output can be displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-02-21mx31pdk: Use the new relocation schemeFabio Estevam
2011-02-21EfikaMX: switch to MACH_TYPE_MX51_EFIKAMXLoïc Minier
Upstream linux moved from MACH_TYPE_MX51_LANGE51 to MACH_TYPE_MX51_EFIKAMX. Signed-off-by: Loïc Minier <loic.minier@linaro.org>
2011-02-19Fix compile warning in net/eth.cRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-02-19Fix build warnings in cmd_flash.cRemy Bohmer
These variables are only used in case CONFIG_SYS_NO_FLASH is NOT set: struct mtd_device *dev; struct part_info *part; u8 dev_type, dev_num, pnum; Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-02-19USB-RNDIS: Send RNDIS state on disconnectingVitaly Kuzmichev
Add waiting for receiving Ethernet gadget state on the Windows host side before dropping pullup, but keep it for debug. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB: Add USB RNDIS gadget protocolVitaly Kuzmichev
Port USB gadget RNDIS protocol support from linux-2.6.26 (.27 gadget stack actually has composite drivers). Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB-CDC: Move struct declaration before its useVitaly Kuzmichev
2011-02-19USB-CDC: Port struct net_device_statsVitaly Kuzmichev
Port struct net_device_stats and statistics collecting needed for RNDIS protocol. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB-CDC: handle interrupt after dropped pullupVitaly Kuzmichev
Disconnecting USB gadget with pending interrupt may cause its wrong handling in the next time when interface will be started again (especially actual for RNDIS). This interrupt may force the gadget to queue unexpected response before setup stage. Despite the fact that such interrupt handled after dropped pullup also may add pending response, this will not bring to any issues due to usb_ep_disable (which clears the queue) called on gadget unregistering. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19Add support for ASIX AX88772 USB 2.0 10/100Mbit Ethernet AdaptorSimon Glass
Driver originally written by NVIDIA Corporation, modified to handle odd-length packets. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Fix EHCI usb submit timeout and unify with OHCISimon Glass
Changed both to use a common timeout for URB submission, since they were using different values and EHCI's was too short. Also fixed EHCI to actually check if urb submission succeeded, rather than silently continuing into the weeds. Change-Id: I7f71499ffaa05187d8e5618db2419e1606007b82 Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-15add checking the CONFIG_ENV_IS_IN_SPI_FLASH in Enbedded envYoshihiro Shimoda
Fix the problem which cannot build the U-boot, if we only set the CONFIG_ENV_IS_IN_SPI_FLASH. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-15net: ne2000: Add spport RTL-8019ASNobuhiro Iwamatsu
Add infomation of RTL-8016AS to hw_info. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2011-02-15unzip: return uncompressed size in `filesize', and print it.Wolfgang Denk
The unzip command did not provide a way for the caller to get any information about the uncompressed size. To make it better usable in scripts, we now store the uncompressed size in the `filesize' variable, like we do when for example loading a file over the network or when reading it from a file system. Following that analogy, it is only consequent to also print the size. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-02-15itest: fix result of string comparesWolfgang Denk
The implementation of the string compare function of the "itest" command was weird, as only the length of the shortest argument was included in the compare, with the result that something like "itest.s abd == abddef" would return TRUE. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-02-15microblaze: Fix msr handling in interrupt_handlerMichal Simek
Fix ancient code which worked with MSR in a bad way. Use rtid instruction which enable IRQs and jump. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-02-15microblaze: Fix systems with MSR=0Michal Simek
u-boot BSP generates XILINX_USE_MSR_INSTR macro even for system with MSR=0. That's why explicitly check that MSR=1. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-02-12Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2011-02-12eNET: Move initial Global Data into CARGraeme Russ
2011-02-12sc520: Release CAR and enable cachingGraeme Russ
2011-02-12x86: Convert board_init_f to use an init_sequenceGraeme Russ
2011-02-12x86: Rearrange function calls in board_init_fGraeme Russ
2011-02-12x86: Split board_init_f() into init_fnc_t compatible functionsGraeme Russ
2011-02-12x86: Fix incorrect usage of relocation offsetGraeme Russ
x86 has always used relocation offset in the opposite sense to the ELF standard - Fix this
2011-02-12x86: Move console initialisation into board_init_fGraeme Russ
2011-02-12x86: Move test for cold boot into init functionsGraeme Russ
2011-02-12x86: Move call to dram_init_f into board_init_fGraeme Russ
2011-02-12x86: Defer setup of final stackGraeme Russ
