Add an option, CONFIG_BOOTSTAGE_FDT to pass boot timings to the kernel
in the device tree, if available. To use this, you must have
CONFIG_OF_LIBFDT defined.
Sometimes we want to add up the amount of time spent in a particular
activity when it is happening in a number of discrete chunks.
Add bootstage_start() to mark the start of an acitivity and
bootstage_accum() to accumulate the time since the last start. Calling
these function in pairs results in the accumulated time being collected.
This function is not static, but not exported either. Add a prototype
in the header file and move the required enum to the header also.
The AP1000 defines a 'get_device' function to determine what board
revision we are on. Inline that checking as it conflicts with the
get_device() in <part.h> and is only used once.
This file is required for all archs. Fixes a sandbox build break on ext4.
Commit cfda5aeab89d73779e26f0d34cf10f64caa67431
(cmd_fat: use common get_device_and_partition function)
introduced a warning:
cmd_fat.c: In function 'do_fat_fswrite':
cmd_fat.c:178:8: warning: unused variable 'ep' [-Wunused-variable]
Fix it.
Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Lei Wen <leiwen@marvell.com>
We often need the requirement that compressing those memory range start
from 0, but the default deflate code in zlib prevent us to do this.
Considering the special case of uboot, that it could access all memory
range, it is reasonable to be able to also take the address space from 0
into compression.
Add a new config CONFIG_GZIP_ENABLED, if enabled, the uboot bin would
include zlib's deflate method which could be used for compressing.
We set sata_curr_device to 0 right after returning from init_sata(), so there's
no point in setting it to the last scanned driver at this point.
Note: there are more duplicities with cmd_sata, but those might be required,
as the code seems to reset the entire controller on every scan, ignoring the
requested port number.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Commit 10a37fd "disk: get_device_and_partition() "auto" partition"
prevented the use of "-" on the command-line to request fallback to the
$bootdevice environment variable instead. This patch allows that, or an
empty string "" to be used.
Tested:
setenv bootfile /boot/zImage
setenv bootdevice 0:1
ext2load mmc 0:1
ext2load mmc -
ext2load mmc ""
Signed-off-by: Pavel Machek <pavel@denx.de>
First, remove the puts from the case where we don't have an mkimage
header as this is somewhat common and intentional for no-arg target
images. Second, rework the final switch statement in board_init_r to,
in the case of !CONFIG_SPL_OS_BOOT be only about doing debug prints
about if we know what the magic is or not (the CONFIG_SPL_OS_BOOT case
is unchanged). Then we call jump_to_image_no_args(). This gives us the
same behavior as before but with slightly smaller code.
By setting CONFIG_SYS_UBOOT_START boards can now use a different entry
point for their U-Boot image. So the U-Boot entry point is not fixed
to CONFIG_SYS_TEXT_BASE any more.
On some system (e.g. powerpc), the load-address and entry-point is
located at address 0. So the current approach to load the image
(payload) including the header to the address "load-address - 64"
can't work here.
This patch adds an flag to skip this copying including header to
the SPL framework. By setting SPL_COPY_PAYLOAD_ONLY, only the
playload will be copied. This will be used by the SPL NOR flash
driver on powerpc.
SPL NOR flash booting support is quite simple. Only copying of the
images is needed.
On MPC5xxx we need to make sure to only use the standard memcpy()
implementation and not the MPC5xxx specific one. As the MPC5xxx
version has some complexity which is not needed for this SPL
booting.
This file documents when to build for da850evm and when to build for
da850_am18xxevm. It also documents how to write the u-boot.ais file to
persistent storage (such as SPI), in some cases as well as how to write
a recovery image.
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Acked-by: Prabhakar Lad <prabhakar.lad@ti.com>
The common spl framework expects the u-boot payload size through
CONFIG_SYS_MONITOR_LEN. Define the macro with the u-boot's size. With
this change, CONFIG_SYS_NAND_U_BOOT_SIZE is no longer required. Delete
the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs.
- Remove duplicated code.
- Add spl_boot_device() that returns the statically chosen boot device.
Some DHCP servers (notably dnsmasq) always transmit DHCP Option 28,
Broadcast Address as specified in RFC 2132. Without this patch u-boot
displays the warning:
*** Unhandled DHCP Option in OFFER/ACK: 28
The patch suppresses the warning and ignores DHCP Option 28. There is
no environment variable to set the broadcast address into and if for
some reason u-boot needs the broadcast it can be calculated from
ipaddr and netmask.
Signed-off-by: Brian Rzycki <bmr@freescale.com>
Now DT support is becoming common for all new SoC's. Hence it is better
to have option for getting specific FDT from the remote server.
This patch adds support for new label i.e. 'fdt'. This will allow to
retrieve 'fdt blob' from the remote server. This patch take care for
the following scenarios.
The usage of fdt is optional.
The 'fdt blob' can be retrieved from tftp or can be available locally
or can be absent.
If 'fdt_addr_r' environment variable is set and 'fdt' label is defined
retrieve 'fdt blob' from tftp. 'fdt_addr_r' is then passed along bootm
command.
If 'fdt_addr' is set and 'fdt blob' is not retrieved from the tftp pass
'fdt_addr' to bootm command. In this case 'fdt blob' will be available
at 'fdt_addr'.
If 'fdt_addr' is not set and 'fdt blob' is not retrieve from tftp pass
NULL to boot command. In this case 'fdt blob' is not required and absent.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
Replace the magic contant 1 << 24 with properly defined bits.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
The mechanism waiting for transmission to finish in fec_send() now
relies on the E-bit being cleared in the TX buffer descriptor. In
case of data cache being on, this means invalidation of data cache
above this TX buffer descriptor on each test for the E-bit being
cleared.
Apparently, there is another way to check if the transmission did
complete. This is by checking the TDAR bit in the X_DES_ACTIVE
register. Reading a register does not need any data cache invalidation,
which is beneficial.
Rework the sequence that wait for completion of the transmission so that
the TDAR bit is tested first and afterwards check the E-bit being clear.
This cuts down the number of cache invalidation calls to one.
The FEC hardware sometimes errors out on data transfer and hangs in
the tightloop adjusted by this patch. So add timeout into the tightloop
to make such a hang recoverable.
Align the address that's to be invalidated/flushed properly.
Cc: Benoit Thebaudeau <benoit.thebaudeau@advans>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Do not pass unaligned RX buffer to the upper layers. The upper layer,
especially in the ARP case, recycles the buffer and passes it back into
the FEC, into it's TX path. With caches enabled, the FEC hangs on this
from time to time.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
-VSC8662 is Dual Port 10/100/1000Base-T Phy,
100Base-FX/1000/Base-X Gigabit Ethernt Transceiver Phy.
-Its register set and features are similar to
other Vitesse Phys
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
This patch add support for the configuration of an external switch from
the 88E6xxx series from Marvell trough an MDIO link using indirect
adressing. This can be used if we do not want to use an EEPROM for the
configuration.
This driver is not generic and was not tested on other switches than the
88e6352. This is proposed as a first implementation that is somewhat
limited but works and that can be used as a basis for further
developments for this switch family.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Joe Hershberger <joe.hershberger@gmail.com>
If dev->enetaddr was supposed to be set with dev->write_hwaddr() but the MAC
address was not valid, return an error.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
We move the spl_nand_load_image function to common/spl. This will allow
for easier integration of SPL-boots-Linux code on other arches.
If an u-boot image is not found, SPL thinks to load a bare
u-boot.bin image with a maximum size of 200KB.
Use CONFIG_SYS_MONITOR_LEN instead.
Signed-off-by: Stefan Roese <stefan.roese@gmail.com>
In SPL (CONFIG_SPL_FRAMEWORK) board_init_f must setup the stack pointer,
clear the BSS and call board_init_r. We mark this as weak as some
platforms may need to perform additional initalization at this point.
We provide a gd that we know will be in a usable location, once the BSS
has been cleared to help with this as well. Finally, we no longer call
relocate_code so remove that from the armv7 version.
Next, both board_init_f and jump_to_image_linux are going to be
inherently arch-specific, so move these versions to arch/arm/lib/spl.c
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
This is an OMAP/related-specific function, move calling it to
spl_board_init() and turn on CONFIG_SPL_BOARD_INIT on the boards that
enabled NAND and didn't enable this already.
- Remove includes we don't need
- Switch some printf statements to puts
- Convert some printf statements to debug, introduce new puts statements
- In most cases saying just "No mkimage signature, assuming
u-boot.bin" or similar is sufficient. This also means the non-DEBUG
case doesn't need printf, in the core of SPL.
- The other case here is that PLAIN_VERSION provided what we wanted
already, so just use it.
Move the default omap/related-centric board_mmc_init to
arch/arm/cpu/armv7/omap-common/boot-common.c and move the type defines
to <asm/spl.h>. Also use mmc->read_bl_len rather than MMCSD_SECTOR_SIZE
Move the SPL prototypes from <asm/omap_common.h> into <asm/spl.h> and
add <asm/arch/spl.h> for arch specific portions of CONFIG_SPL_FRAMEWORK.
We can only attempt to setup a malloc pool if
CONFIG_SYS_SPL_MALLOC_START is defined, and not all boards require it.
Make the call depend on the define.
This detection code doesn't (and can't) do anything currently, so
remove.
