Add new Kconfig option to let the user select the targets
endianess. Each target have to select SUPPORTS_BIG_ENDIAN
and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess
is supported.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Before this commit, the stack addresses for IRQ and FIQ modes,
IRQ_STACK_START and FIQ_STACK_START, were computed in interrupt_init but
they were not used.
This commit sets the stack pointers for IRQ and FIQ modes.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This commit relocates the exception vectors.
As ARM1176 and ARMv7 have the security extensions, it uses VBAR. For
the other ARM processors, it copies the relocated exception vectors to
the correct address: 0x00000000 or 0xFFFF0000.
Cc: Tom Warren <twarren@nvidia.com>
A regression was introduced in commit 41623c91. The consequence of that
is the non-relocation of the section .vectors symbols :
_undefined_instruction, _software_interrupt, _prefetch_abort,
_data_abort, _not_used, _irq and _fiq.
Before commit 41623c91, the exception vectors were in a .text section.
The .text section has the attributes allocatable and executable [1].
In commit 41623c91, a specific section is created, called .vectors, with
the attribute executable only.
What have changed between commit 41623c91^ and 41623c91 is the attribute
of the section which contains the exception vectors.
An allocatable section is "a section [that] occupies memory during
process execution" [1] which is the case of the section .vectors.
Adding the lacking attribute (SHF_ALLOC or "a") for the definition of
the section .vectors fixed the issue.
To summarize, the fix has to mark .vectors as allocatable because the
exception vectors reside in "memory during execution" and they need to
be relocated.
[1] http://man7.org/linux/man-pages/man5/elf.5.html
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
In preparation for the SoCFPGA support of the designware I2C driver,
convert this driver to the common CONFIG_SYS_I2C framework.
This patch converts all users of this driver, this is:
- ST spearxxx boards
- AXS101 (ARC700 platform)
I couldn't test this patch on those boards. Only compile tested for all
spear boards. And tested on SoCFPGA.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Tested-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vipin Kumar <vk.vipin@gmail.com>
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Add support for I2C bus 1 on the i.MX28.
This patch permeates the struct i2c_adapter throughout the driver,
so that it can be used to determine which adapter should be used.
Note that the driver still supports only one adapter. Note that
the patch does shuffle mxs_i2c_set_bus_speed() to the top of the
driver, but the function remains unchanged.
This patch just converts the function prototypes used throughout
this driver to match those of the i2c framework. There is so far
no functional change. This patch does not do the deeper integration
of the framework bits.
This patch prepares the MXS I2C driver for the conversion to the
new I2C driver framework by pulling out the hard-coded I2C0 address
from all the places.
The following bard configurations have been without active maintenance
for a long time, and the board maintainer agrees to have them removed:
MPC5200: TOP5200, MINI5200, EVAL5200
MPC860: TOP860
at91sam9xeXXX: top9000eval_xe, top9000su_xe
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
[trini: Add missing Kconfig removals]
The logic of the return statement in sata_port_status() calls for a
bitwise 'AND' operator, not logical 'AND'. Fix the typo.
Reported-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
This patch adds support for i211 as well as unprogrammed aka tools only
i210/i211 chip support.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Odroid is based on Exynos4412.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
There is no gaps in exynos gpio enum after rework, so the gpio
numbers should be adjusted to the new numbering.
The gpy0 don't need any additional register offset,
but the gpx0 does, so now it is fixed.
The gpf0 offset was bad and it's now fixed.
After fix gpio order in *pinctrl.dts , the gpy0 offset is not required now.
The pinctrl dts was imported from the kernel, but the order
of GPM and GPY is wrong. The gpio enum in: asm/arch/gpio.h
is proper.
This config is required by Odroid, and could be also useful for the other
boards.
The SD Card slot detection pin should be configured as input.
This adds custodian to the pmic subsystem.
Cc: Tom Rini <trini@ti.com>
Commit ae83d882f5fdf7aa7c5aec09cfafb593153c25d6 moved the fixed size mentioned
in the comment but missed the comment.
Some boards still use xstr(). Replace remaining occurrences
of xstr() by commonly used __stringify().
- switch to GENERIC_BOARD
- fix env support from eeprom
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch makes the following changes:
- Set kernel entry point correctly
- Append bootargs from image to global bootargs instead
of replacing them
- Return end address instead of size from android_image_get_end()
- Give correct parameter to genimg_get_format() in boot_get_ramdisk()
- Move ramdisk message printing from android_image_get_kernel() to
android_image_get_ramdisk()
Signed-off-by: Ahmad Draidi <ar2000jp@gmail.com>
This file should contain the bin_hdr generated by the original Marvell
U-Boot implementation. As this is currently not included in this
U-Boot version, we have added this placeholder, so that the U-Boot
image can be generated without errors.
If you have a known to be working bin_hdr for your board, then you
just need to replace this text file here with the binary header
and recompile U-Boot.
In a few weeks, mainline U-Boot will get support to generate the
bin_hdr with the DDR training code itself. By implementing this code
as SPL U-Boot. Then this file will not be needed any more and will
get removed.
Actually, unmap_sysmem() does nothing. Just in case.
- Do not insert a whitespace between a function name and
an open paranthesis
- Fix comment style
- Do not split an error message into multiple lines
even if it exceeds 80 columns
- Do not split "for" statement where it fits in 80 columns
- Do not use assignment in if condition
Since commit fe1378a961e5 (ARM: use r9 for gd), r9 register
is used on ARM to hold global_data.
Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
I finally had a look at the datasheet and spotted an additional
register address difference between regular E1000 and i210/i211 chips.
This patch fixes this and now successfully works on programmed
i210/i211 as well as unprogrammed i211.
Fix typo in defconfig file format description.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
CONFIG_TPL should not be enabled for boards that do not have TPL.
CONFIG_SUPPORT_TPL introduced by this commit should be "select"ed
by boards with TPL support and CONFIG_TPL should depend on it.
CONFIG_SPL should not be enabled for boards that do not have SPL.
CONFIG_SUPPORT_SPL introduced by this commit should be "select"ed
by boards with SPL support and CONFIG_SPL should depend on it.
Commit 951860634fdb557bbb58e0f99215391bc0c29779 may have changed
the logic unintentially from "if (!(swfw_sync & (fwmask | swmask)))"
to "if ((swfw_sync & swmask) && !(swfw_sync & fwmask))". This change
breaks some e1000 NIC with a message "ERROR: Unable to read EEPROM!".
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Marek Vasut <marex@denx.de>
CC: Tim Harvey <tharvey@gateworks.com>
Acked-by: Marcel Ziswiler <marcel@ziswiler.com>
CHUNK_TYPE_DONT_CARE should skip over the specified number of blocks, but
currently fails to increment the device block address. This results in
filesystem images getting written incorrectly. Add the missing block
address incrementing.
Cc: Steve Rae <srae@broadcom.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Steve Rae <srae@broadcom.com>
Enable EXT support in SPL for OMAP4 boards.
Build tested for duovero, omap4_sdp4430 and omap4_panda.
Run time tested on omap4_panda.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
Do not hang in spl_register_fat_device but return an error value.
It allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
If FAT load fails, then EXT load is tried.
Update documentation according to the EXT SPL support patch set.
Add EXT filesystem support to SPL.
[trini: Fix a warning and checkpatch problems]
Rename some defines containing FAT in their name to be filesystem generic:
MMCSD_MODE_FAT => MMCSD_MODE_FS
CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION
