The kernel does not know about rw,noatime. The string rw by itself
is valid, and to pass additional arguments rootflags=noatime can
be used. The kernel mounts ext3/ext4 file systems by default ro,
hence so far the kernel mounted the rootfs read-only. The init
manager systemd then remounts the rootfs after file system checking.
This makes sense and does not add measureable boot time. Let the
kernel explicitly mount ro on block device based rootfs.
The root mount flag noatime is only relevant when re-mounting
read-write, hence it needs to be present in /etc/fstab.
UBIFS used on raw NAND devices has no user space file checking,
hence there is no value to mount it in read-only first. Also mount
time for UBIFS is larger, and mounting first read-only and then
read-write has higher boot time (300ms, likely due to missing block
cache). Let the kernel explicitly mount rw on raw NAND based rootfs.
UBIFS has no atime support, hence no root mount flags needed.
This makes sure that all Colibri iMX7 modules work with the
same timing. The changes are:
- Disable ODT on read (JEDEC standard JESD79-3F says in chapter
5.2.3 ODT during Reads: "As the DDR3 SDRAM can not terminate
and drive at the same time, RTT must be disabled at least half
a clock cycle..." and also MX7D SABRESD is disabling it)
This alone fixed memory issues for two Colibri iMX7 1GB modules
which showed issues before
- Make sure tRFC(min) is at least 260ns
- Make sure tRC is >50.625ns
- tRP needs to be >13.125ns, we can lower from 18.75ns to 15ns
- tFAW is not relevant, leave at reset
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
When using ISO partitions with a DMA enabled block device driver
reading the ISO partition leads to unaligned DMA operations:
CACHE: Misaligned operation at range [bffb7da8, bffb85a8]
Align the buffer to make sure we pass a buffer which works for
DMA operations.
Setup all UARTs in DTE mode, so that when Linux does the pinmuxing
the data direction is already correct and no two outputs are working
against each other.
Make sure that with the switch also the UARTs' RI and DCD interrupts
are masked.
The resulting U-Boot boots at least from serial downloader mode.
On i.MX6ULL, according to the latest REFTOP_TRIM fuse define, we need
to set the REFTOP_VBGADJ bits in PMU_MISC0 register as below table:
'000" - set REFTOP_VBGADJ[2:0] to 3'b000
'001" - set REFTOP_VBGADJ[2:0] to 3'b001
'010" - set REFTOP_VBGADJ[2:0] to 3'b010
'011" - set REFTOP_VBGADJ[2:0] to 3'b011
'100" - set REFTOP_VBGADJ[2:0] to 3'b100
'101" - set REFTOP_VBGADJ[2:0] to 3'b101
'110" - set REFTOP_VBGADJ[2:0] to 3'b110
'111" - set REFTOP_VBGADJ[2:0] to 3'b111
Signed-off-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit b2690f5cf54390999acb2f1f7b788bfd18fa11be)
(cherry picked from commit 30ce7adebd443ef777e820c4a891cbb3b28ac671)
Per to design team, we need to set REFTOP_VBGADJ
in PMU MISC0 according to the REFTOP_TRIM[2:0] fuse. the
actually table is as below:
'000' - set REFTOP_VBGADJ[2:0] to 3b'110
'110' - set REFTOP_VBGADJ[2:0] to 3b'000
'001' - set REFTOP_VBGADJ[2:0] to 3b'001
'010' - set REFTOP_VBGADJ[2:0] to 3b'010
'011' - set REFTOP_VBGADJ[2:0] to 3b'011
'100' - set REFTOP_VBGADJ[2:0] to 3b'100
'101' - set REFTOP_VBGADJ[2:0] to 3b'101
'111' - set REFTOP_VBGADJ[2:0] to 3b'111
(cherry picked from commit 911fcf93bad8c0a595c350b92f107b626029559b)
arch/arm/cpu/armv7/mx6/soc.c
Not all of the following commit from the nxp vendor tree made
it into 2016.11.
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/?h=imx_v2016.03_4.1.15_2.0.0_ga&id=05922b0abf848949df778c19312cb1cf7fdfbe6a
commit 05922b0abf848949df778c19312cb1cf7fdfbe6a
Author: Peng Fan <peng.fan@nxp.com>
Date: Mon May 9 17:31:34 2016 +0800
MLK-12767 imx6ull: fix runtime checking for i.MX6ULL
Fix runtime checking for i.MX6ULL. Add is_cpu_type(MXC_CPU_MX6ULL)
to avoid using wrong code path.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The MIB RAM and FIFO receive start register does not exist on
i.MX6ULL. Accessing these register will cause enet not work well or
cause system report fault.
Reported-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit 5fb09cab9bb3cc4cef02239299d02cec666396ab)
drivers/net/fec_mxc.c
Add i.MX6UL support in setup_gpmi_io_clk and change
mx6ul_14x14_evk to use it.
(cherry picked from commit f39d809ef99c3727e17285c52df9cd01020bee65)
board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c
For Some USB mass storage devices, such as:
- Kingston DataTraveler 2.0 001D7D06CF09B04199C7B3EA
- Class: (from Interface) Mass Storage
- PacketSize: 64 Configurations: 1
- Vendor: 0x0930 Product 0x6545 Version 1.16
When `usb read 0x80000000 0 0x2000`, we met
"EHCI timed out on TD - token=0x80008d80".
The devices does not support scsi VPD page, we are not able
to get the maximum transfer length for READ(10)/WRITE(10).
So we limit this to 256 blocks as READ(6).
(cherry picked from commit df0052575b2bc9d66ae73584768e1a457ed5d914)
CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES is no longer used in code.
Remove it.
The nand torture command is a potentially destructive command used
for board bring up and qualification. Do not deploy it regularly.
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled
by default for '-O2':
BOOTP broadcast 1
data abort
pc : [<8ff8bb30>] lr : [<00004f1f>]
reloc pc : [<17832b30>] lr : [<878abf1f>]
sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4
r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594
r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e
r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Core reason is usage of structures for network headers without packed
attribute.
Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com>
(cherry picked from commit 704f3acfcf55343043bbed01c5fb0a0094a68e8a)
include/net.h
upstream changed magic numbers with define
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Use similar info message as on other modules.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
The current mechanism using SCR/GPR registers work well when
the serial downloader boot mode has been selected explicitly
(either via boot mode pins or using bmode command). However,
in case the system entered boot ROM due to unbootable primary
boot devices (e.g. empty eMMC), the SPL fails to detect that
it has been downloaded through serial loader and tries to
continue booting from eMMC:
Trying to boot from MMC1
mmc_load_image_raw_sector: mmc block read error
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
The only known way to reliably detect USB serial downloader
is by checking the USB PHY receiver block power state...
This macro allows to detect whether the boot ROM initialized USB
already (serial downloader). This is helpful to reliably detect
if the system has been recovered via USB serial downloader.
The i.MX 7 boot ROM provides a structure with boot information.
The reference manual (chapter 6.6.14 Boot Information for Software
in the RM) only lists 6 boot devices, but tests have shown that
the boot device type is consistently 0xf in case the SoC has been
booted through USB Serial Downloader. Create a new boot mode for
the USB Serial Download Protocol (SDP).
The function get_boot_device might be useful in board files,
add it to the sys_proto.h header file.
Allow optionally bringing up the Apalis type specific 4 lane PCIe port
as well as the PCIe switch as found on the Apalis Evaluation board. In
order to avoid violating the PCIe reset timing do this by overriding the
tegra_pcie_board_port_reset() function. Note however that both the
Apalis type specific 4 lane PCIe port as well as the regular Apalis PCIe
port are also left disabled in the device tree by default.
Fix PCIe port 2 on-module connected to the Intel i210 gigabit
Ethernet chip.
Add some more comments describing the various PCIe ports available.
Introduce a weak tegra_pcie_board_port_reset() function by default
calling the existing tegra_pcie_port_reset() function. Additionally add
a tegra_pcie_port_index_of_port() function to retrieve the specific PCIe
port index if required. This allows overriding the PCIe port reset
functionality from board specific code as e.g. required for Apalis T30
and Apalis TK1.
Fix as3722_ldo_enable() functions for LDOs with an index > 7. Turns out
there are actually two separate AS3722_LDO_CONTROL registers
AS3722_LDO_CONTROL0 and AS3722_LDO_CONTROL1. Actually make use of both.
As the AS3722 GPIO0 is also a not connected on our Apalis TK1 module
explicitly configure it to high-impedance as well.
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
If the Cortex-M4 is running we carve out 1MiB of memory for
rpmsg communication and/or the firmware running from DDR.
On the Colibri iMX7D this area is in the middle of its 512MiB
of memory. Linux seems not to handle the sparse memory area
well and shows only the first 254MiB of memory as available.
Enabling highmem seems to work around this issue. However,
enabling highmem is not ideal since memory from the highmem
area is more restricted then lowmem.
Aligning the carved out memory to ARM Linux' PMD (page middle
directory) size of 2MiB seem to allow allocating all available
memory as lowmem. Hence increase the carveout region to 2MiB.
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
Use a slower speed of 10 kbit/s for DDC to improve reliability.
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
Fix USB OTG power enable aka USBO1_EN which on Apalis T30 is connected
to the T30 ball GEN2_I2C_SCL.
Set vidargs default to VGA resolution
Make sure CMA memory is not greater than 50% of available physical
memory.
Allow user to change the CMA memory via 'cma-size' U-Boot environment
variable.
Trying to boot from an ext4 rootfs fails due to us defaulting to ext3.
While the downstream T20/T30 L4T kernel has issues with ext4 later TK1
L4T should work just fine with it. Hence enable ext4 for sdboot and
usbboot on TK1.
Using the SDP (Serial Download Protocol) in combination with some
USB hosts showed warnings such as:
EP0/out FAIL info=4018080 pg0=8df79500
ERROR: Unexpected report 4
at ../drivers/usb/gadget/f_sdp.c:327/sdp_rx_data_complete()
It seems that the descriptors are somehow not ready/overwritten
or similar. The exact cause and issue is not unterstood, but a
delay after handle_setup() seems to resolve the issue with three
different USB host machines which had previously shown the issue
regularly.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
If config block support is enabled, USB gadget modes unconditionally
use Toradex Product ID as USB PID. Some applications might prefer a
different and/or static USB PID. Add a Kconfig configuration option
to descide whether to use USB PID from config block or the fallback
config option CONFIG_G_DNL_PRODUCT_NUM.
The OCRAM_S alias for Cortex-M4's system bus is missing. Add
the alias so that firmwares which have code linked in that
area can be loaded successfully.
Use the same on-flash bad block table in U-Boot as we already
use/maintain in Linux.
Add config option which allows to enable on flash bad block table
support. This effectively has the same effect as when using the
device tree property "nand-on-flash-bbt" in Linux.
