Changes in lib/uuid.c to:
- uuid_str_to_bin()
- uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions
This change allows easy recognize which UUID type is or should be stored in given
string array. Binary data of UUID and GUID is always stored in big endian, only
string representations are different as follows.
String byte: 0 36
String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
string UUID: be be be be be
string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
This commit introduces cleanup for uuid library.
Changes:
- move uuid<->string conversion functions into lib/uuid.c so they can be
used by code outside part_efi.c.
- rename uuid_string() to uuid_bin_to_str() for consistency with existing
uuid_str_to_bin()
- add an error return code to uuid_str_to_bin()
- update existing code to the new library functions.
Cc: trini@ti.com
Commit 2faf5fb82ed6 introduced a regression that causes a data
abort when running scsi init followed by scsi reset.
There are 2 problems with the original commit
1) ALLOC_CACHE_ALIGN_BUFFER() allocates memory on the stack but is
assigned to ataid[port] and used by other functions.
2) The function ata_scsiop_inquiry() tries to free memory which was
never allocated on the heap.
Fix these problems by using tmpid as a temporary cache aligned buffer.
Allocate memory separately for ataid[port] and re-use it if required.
Fixes: 2faf5fb82ed6 (ahci: Fix cache align error messages)
Reported-by: Eli Nidam <elini@marvell.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
1. The Data timeout counter value in eSDHC_SYSCTL register is
not working as it should be, so add quirks to enable this
workaround to fix it to the max value 0xE.
2. Add CONFIG_SYS_FSL_ERRATUM_ESDHC111 to enable its workaround.
* Update of patch for change mmc interface by
Pantelis Antoniou <panto@antoniou-consulting.com>
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The controller reset is performed now if command error occurs.
This commit adds the reset for the case of data related errors too.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Calculation of the timeout value should be based on actual clock value,
written to controller registers. Since mmc->tran_speed is either the
maximum allowed speed, or the preliminary value, that is be not yet
set to registers, the actual timeout, taken by the controller, based
on its clock settings, may be much longer than expected, based on
mmc->tran_speed value. In particular it happens at early initialization
stage, when typical value of mmc->tran_speed is 20MHz or 26MHz, while
actual clock setting, configured in the controller, is 400kHz.
It's more correct to use mmc->clock value for timeout calculation instead.
Some eMMC chips may need the RST_n_FUNCTION bit set to a non-zero value
in order for warm reset of the system to work. Details on this being
required will be part of the eMMC datasheet. Also add using this
command to the dra7xx README.
* Whitespace fix by panto
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
BY commit "mmc: Split mmc struct, rework mmc initialization (v2)",
sh_mmcif has compile error. This fixes compile error.
CC: Pantelis Antoniou <panto@antoniou-consulting.com>
Prior to Kbuild, U-Boot could build under tools/ directory
withour configuring for a specific board.
That feature was lost when switching to Kbuild.
This patch revives it again by adding a make target "tools-only".
Usage:
$ make tools-only
Neither board configuration nor cross compiler are required to
build host tools.
Suggested-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Since Kbuild was introduced, warmboot_avp.o has been compiled
without -march=armv4t.
Makefile should be adjusted to pass a per-file option.
Cc: Tom Warren <twarren@nvidia.com>
Enable USB0 clock by resetting bit 20 of MSTPCR2. Leave other bits unchanged.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
All pins should be output.
In the recent mmc cleanup, the mmc_host_is_spi macro was broken and
bfin_sdh.c had mmc->bus_width turned into mmc_bus_width(mmc), both of
which were incorrect.
On the boards this target supports this option is either non possible
without hardware mods (Beaglebone White/Black) or not supported due to
board design. Drop this and regain some space.
If we build this function in cases where we would be discarding it
anyhow we still end up with maybe unused warnings. Rather than litter
the function with __maybe_unused, just spell out when to build it.
"make clean", "make clobber", "make mrproper" and "make distclean"
missed to clean-up some files when they were run with
O=<some_dir> option.
Reported-by: Wolfgang Denk <wd@denx.de>
Prior to Kbuild, the build system created a build directory,
when it did not exist, for out-of-tree build.
This feature was dropped when we switched to Kbuild
because many of lines in makefiles were copied from Linux Kernel.
(In Linux Kernel, we have to create a build directory by ourselves
before starting build.)
That feature seems worth reviving for less typing
even if our code and Linux Kernel diverge.
Suggested-by: Simon Glass <sjg@chromium.org>
We should move forward to remove the old board init code. Add a
prominent message to encourage maintainers to get started on this
work.
This allows to use exynos random number generator by enabling configs:
- CONFIG_EXYNOS_ACE_SHA
- CONFIG_LIB_HW_RAND
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
cc: Piotr Wilczek <p.wilczek@samsung.com>
cc: Minkyu Kang <mk7.kang@samsung.com>
This patch adds implementation of rand library based on hardware random
number generator of security subsystem in Exynos SOC.
This library includes:
- srand() - used for seed hardware block
- rand() - returns random number
- rand_r() - the same as above with given seed
which depends on CONFIG_EXYNOS_ACE_SHA and CONFIG_LIB_HW_RAND.
cc: Akshay Saraswat <akshay.s@samsung.com>
cc: ARUN MANKUZHI <arun.m@samsung.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
New configs:
- CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c
- CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand
Other changes:
- add CONFIG_LIB_RAND to boards configs which needs rand()
- put only one rand.o dependency in lib/Makefile
CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library
(declared in include/common.h):
- void srand(unsigned int seed)
- unsigned int rand(void)
- unsigned int rand_r(unsigned int *seedp)
When using CONFIG_SYS_I2C i2c needs to be initialized by
i2c_init_all(). This is done in some places but not in
eeprom_init().
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
CPU sets DMA buffer descriptors with data required for inetrnal DMA such as:
* Ownership of BD
* Buffer size
* Pointer to data buffer in memory
Then we need to make sure DMA engine of NAND controller gets proper data.
For this we flush buffer rescriptor.
Then we're ready for DMA transaction.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
It's important to have ability to flush/invalidate each DMA buffer descriptor
individually to prevent incoherency of adjacent BDs.
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Since TIZEN group has been used 450 X 140 bmp logo for lunchbox,
this patch tries to change the logo size from 500 X 150 to official size.
By reducing image size, we also save about 35KB.
To make row aligned 4 bytes, add 2 pixels to row. Therefore the real width
of image size is 452.
Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
Reviewed-by : Przemyslaw Marczak <p.marczak@samsung.com>
Fix the macros guarding the spl.h header for various platforms. Due to
a typo and a propagation of it, the macros went out-of-sync with their
ifdef check, so fix this.
U-Boot has supported two kinds of asm-offsets.h.
One is generic for all architectures and its source is located at
./lib/asm-offsets.c.
The other is SoC specific and its source is under SoC directory.
The problem here is that only boards with SoC directory can use
the asm-offsets infrastructure.
Putting asm-offsets.c right under CPU directory does not work.
Now a new demand is coming. PowerPC folks want to use asm-offsets.
But no PowerPC boards have SoC directory.
It seems inconsistent that some boards add asm-offsets.c to SoC
directoreis and some to CPU directories.
It looks more reasonable to put asm-offsets.c under arch/$(ARCH)/lib.
This commit merges asm-offsets.c under SoC directories into
arch/$(ARCH)/lib/asm-offsets.c.
By the way, I doubt the necessity of some entries in asm-offsets.c.
I am leaving refactoring to the board maintainers.
Please check "TODO" in the comment blocks in
arch/{arm,nds32}/lib/asm-offsets.c.
Cc: Yuantian Tang <Yuantian.Tang@freescale.com>
U-Boot uses the 'mkimage' tool to produce various image types,
not only uImage image type. Rename the invocation name from
UIMAGE to MKIMAGE.
The following command was used to do the replacement:
git grep 'quiet_cmd_mkimage.* = UIMAGE' | cut -d : -f 1 | \
xargs -i sed -i "s@\(quiet_cmd_mkimage\)\(.*\) = UIMAGE @\1\2 = MKIMAGE@" {}
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
For some time we have been using the run_command() with properly crafted
string. Such approach turned to be unreliable and error prone.
Switch to "native" mmc subsystem API would allow better type checking and
shall improve speed.
Also, it seems that this API is changing less often than u-boot commands.
The approach similar to env operations on the eMMC has been reused.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The way that struct mmc was implemented was a bit of a mess;
configuration and internal state all jumbled up in a single structure.
On top of that the way initialization is done with mmc_register leads
to a lot of duplicated code in drivers.
Typically the initialization got something like this in every driver.
struct mmc *mmc = malloc(sizeof(struct mmc));
memset(mmc, 0, sizeof(struct mmc);
/* fill in fields of mmc struct */
/* store private data pointer */
mmc_register(mmc);
By using the new mmc_create call one just passes an mmc config struct
and an optional private data pointer like this:
struct mmc = mmc_create(&cfg, priv);
All in tree drivers have been updated to the new form, and expect
mmc_register to go away before long.
Changes since v1:
* Use calloc instead of manually calling memset.
* Mark mmc_register as deprecated.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Using an array is pointless; even more pointless (and scary) is using
sprintf to fill it without a format string.
Remove the in-structure ops and put them in mmc_ops with
a constant pointer to it.
This makes the mmc structure smaller as well as conserving
code space (in theory).
All in-tree drivers are converted as well; this is done in a
single patch in order to not break git bisect.
Changes since V1:
Fix compilation b0rked issue on omap platforms where OMAP_GPIO was
not set.
as the siemens boards use dfu for updating a nand ubi partition
add DFU_MANIFEST_POLL_TIMEOUT to them, so dfu host waits after
complete transfer of the new image for DFU_MANIFEST_POLL_TIMEOUT
ms before sending again an usb request. So the board have enough
time to erase rest of the nand sectors.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
on nand flash using ubi, after the download of the new image into
the flash, the "rest" of the nand sectors get erased while flushing
the medium. With current u-boot version dfu-util may show:
Starting download: [##################################################] finished!
state(7) = dfuMANIFEST, status(0) = No error condition is present
unable to read DFU status
as get_status is not answered while erasing sectors, if erasing
needs some time.
So do the following changes to prevent this:
- introduce dfuManifest state
According to dfu specification
( http://www.usb.org/developers/devclass_docs/usbdfu10.pdf ) section 7:
"the device enters the dfuMANIFEST-SYNC state and awaits the solicitation
of the status report by the host. Upon receipt of the anticipated
DFU_GETSTATUS, the device enters the dfuMANIFEST state, where it
completes its reprogramming operations."
- when stepping into dfuManifest state, sending a PollTimeout
DFU_MANIFEST_POLL_TIMEOUT in ms, to the host, so the host
(dfu-util) waits the PollTimeout before sending a get_status again.
move the flushing code into an extra function dfu_flush(),
so it can be used from other code.
Add a new Patch-cc: tag which performs the service now provided by
the Cc: tag. The Cc: tag is interpreted by git send-email but
ignored by patman.
So now:
Cc: patman does nothing. (git send-email can cc patches)
Patch-cc: patman Cc's patch and removes this tag from the patch
As Simon Glass requested it, here's a patch that enables
CONFIG_CMD_LZMADEC in sandbox.
Signed-off-by: Patrice Bouchand <pbfwdlist@gmail.com>
I needed to be able to uncompress lzma files. I did this command
based on unzip command and propose it if it could help.
Changed to work with sandbox
Enable the Chrome OS EC emulation for sandbox along with LCD, sound
expanded GPIOs and a few other options to make this work correctly.
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
This function is needed when CONFIG_OF_SPI is defined.
When jumping from one sandbox U-Boot to another in sandbox, the RAM buffer
is preserved in the jump by using a temporary file. Add an option to tell
the receiving U-Boot to remove this file when it is no longer needed.
Similarly the old U-Boot image is left behind in this case. We cannot delete
it immediately since gdb cannot then find its debug symbols. Delete it just
before exiting.
Together these changes ensure that temporary files are removed both for
memory and U-Boot.
It is useful for Cltl-C to be handled by U-Boot as it is on other boards.
But it is also useful to be able to terminate U-Boot with Ctrl-C.
Add an option to enable signals while in raw mode, and make this the
default. Add an option to leave the terminal cooked, which is useful for
redirecting output.
