2012-11-25Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2012-11-24mx28: Fix typo in POWER_DCLIMITS_NEGLIMIT_OFFSETMarek Vasut
The POWER_DCLIMITS_NEGLIMIT_OFFSET bit in mx28 power supply block is not called POWER_DCLIMITS_NETLIMIT_OFFSET, but POWER_DCLIMITS_NEGLIMIT_OFFSET. Correct the name in the header file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-11-24mx28: Fix typo in POWER_MINPWR_VBG_OFFMarek Vasut
The POWER_MINPWR_VBG_OFF bit in mx28 power supply block is not called POWER_MINPWR_FBG_OFF, but POWER_MINPWR_VBG_OFF. Correct the name in the header file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-11-19tegra: use generic fs commands in BOOTCOMMANDStephen Warren
Modify tegra-common-post.h's BOOTCOMMAND definition to use the generic filesystem command load rather than separate fatload and ext2load. This removes the need to iterate over supported filesystem types in the boot command. This requires editing all board config headers to enable the new commands. The now-unused commands are left enabled to assue backwards compatibility with any user scripts. Boards (all from Avionic Design) which define custom BOOTCOMMAND values are not affected. Signed-off-by: Stephen Warren <swarren@nvidia.com> tegra generic fs cmds fixup Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: config: seaboard: Move tegra-common-post to correct placeSimon Glass
The NAND defines ended up before this include file, but should be after it, so it doesn't become a post-pre-NAND. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Remove unnecessary CONFIG_SYS_NAND_BASESimon Glass
Now that we are using the new CONFIG_SYS_NAND_SELF_INIT setup, we don't need CONFIG_SYS_NAND_BASE. Punt it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19ARM: tegra: enable 8-bit SD slots in board filesStephen Warren
Harmony contains an SD slot with all 8 bits routed. This allows plugging in an eMMC-chip-in-SD-form-factor. Seaboard/Springbank/Ventana/AC100 all have an eMMC chip with all 8 bits hooked up. Now that the U-Boot eMMC code fully supports 8-bit operation, initialize those ports as 8-bit instead of 4-bit to improve performance. Whistler was already registering its ports as 8-bit. TrimSlice doesn't have any 8-bit ports. I don't have any Avionic Design boards nor the Colibri board to test with. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19mmc: tegra: support 4-bit operation too on 8-bit slotsStephen Warren
If a board has all 8 data lines routed, the SD/MMC controller can still operate in 4-bit (or presumably even 1-bit) mode. Adjust Tegra's MMC driver to report the 4-bit capability even for 8-bit slots. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: add CONSOLE_MUX support to tegra-kbcAllen Martin
Add support for CONSOLE_MUX to tegra-kbc driver. This requires adding a flag to struct keyb to know the driver has already been initialized so if we try to initialize it again we can just return success. Also call into iomux_doenv() from drv_keyboard_init to re-evaluate the stdin string. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19ARM: tegra: TrimSlice: add support for USB1 portStephen Warren
TrimSlice's USB1 port has two purposes; it either acts as a device port hosting Tegra's USB recovery protocol, or acts as a host port connected to the internal USB->SATA bridge chip, which may in turn be connected to an SSD or HDD. Add the appropriate device tree and board configuration options to enable this port as a host port, and route the port to the SATA bridge using the VBUS GPIO. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Enable display/lcd support on SeaboardMayuresh Kulkarni
Enable the Seaboard's 16-bit LCD and use it as the console. Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19lcd: Add CONFIG_CONSOLE_SCROLL_LINES option to speed consoleSimon Glass
When the cursor position gets to the end of the LCD console we normally scroll by one line. This adds an option to increase that value. Console scrolling is often slow, and if a large amount of output is being sent, increasing this option to 10 or so will speed things up considerably. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add LCD definitions for SeaboardSimon Glass
The Seaboard has a 1366x768 16bpp LCD. The backlight is controlled by one of the PWMs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Support control of cache settings for LCDSimon Glass
Add support for selecting the required cache mode for the LCD: off, write-through or write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Align LCD frame buffer to section boundarySimon Glass
For tegra we want to enable the cache for the LCD. This is easier if we can avoid using L2 page tages, so align the LCD to a section boundary. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19lcd: Add support for flushing LCD fb from dcache after updateSimon Glass
This provides an option for the LCD to flush the dcache after each update (puts, scroll or clear). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19lcd: Add CONFIG_LCD_ALIGNMENT to select frame buffer alignmentSimon Glass
The normal alignment is PAGE_SIZE, but if this is defined, we can support other alignments. The motivation for this change is to make the display section-aligned on ARM so that we can easily turn off data caching for the frame buffer region without resorting to level 2 page tables. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19arm: Add control over cachability of memory regionsSimon Glass
Add support for adjusting the L1 cache behavior by updating the MMU configuration. The mmu_set_region_dcache_behaviour() function allows drivers to make these changes after the MMU is set up. It is implemented only for ARMv7 at present. This is needed for LCD support, where we want to make the LCD frame buffer write-through (or off) rather than write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD support to Nvidia boardsSimon Glass
Add calls to the LCD driver from Nvidia board code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD driverSimon Glass
This driver supports driving a single LCD and providing a U-Boot console on it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add SOC support for display/lcdWei Ni
Add support for the LCD peripheral at the Tegra2 SOC level. A separate LCD driver will use this functionality to configure the display. Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Mayuresh Kulkarni: - changes to remove bitfields and clean up for submission Signed-off-by: Simon Glass <sjg@chromium.org> Simon Glass: - simplify code, move clock control into here, clean-up Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add support for PWMSimon Glass
The pulse width/frequency modulation peripheral supports generating a repeating pulse. It is useful for controlling LCD brightness. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add LCD definitions for TegraSimon Glass
Add LCD definitions and also a proposed binding for LCD displays. The PWM is as per what will likely be committed to linux-next soon. The displaymode binding comes from a proposal here: http://lists.freedesktop.org/archives/dri-devel/2012-July/024875.html The panel binding is new, and fills a need to specify the panel timings and other tegra-specific information. Should a binding appear that allows the pwm to handle this automatically, we can revisit this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add pwm binding and nodeSimon Glass
This binding will apparently soon be in linux-next. Bring it in now since we need to do something, and may as well try to target what Linux will have. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add display support to funcmuxSimon Glass
Add support for a default pin mapping for display1. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Use const for pinmux_config_pingroup/table()Simon Glass
These two functions don't actually modify their arguments so add a const keyword. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19pxa: Disable dcache on palmld, palmtc, zipitz2Simon Glass
These platforms don't include dcache support. Define CONFIG_SYS_DCACHE_OFF so that functions don't try to call non-existent routines like flush_dcache_range(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19mx5: Mark lowlevel_init board-specific codeBenoît Thébaudeau
The mx5 lowlevel_init.S contains board-specific code based on the reference design. Let's keep it since it avoids creating new lowlevel_init files and it may be used by many boards. But add a config to make it optional in order not to cause issues on boards not following this part of the reference design. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Matt Sealey <matt@genesi-usa.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-19ehci-mxc: Fix host power mask bit for i.MX25Benoît Thébaudeau
The correct bit for H1_PM is 16, not 8, which is the DP pull-up impedance selection bit. This issue has been reported by Eric Bénard <eric@eukrea.com> and fixed by Christoph Fritz <chf.fritz@googlemail.com> on Linux, from which these #define-s had been copied. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-11-19mx35pdk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-19mx31pdk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19mx25pdk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19mx51evk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19mx6qsabre_common: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-11-19mx6qsabrelite: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19mx53loco: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19mx28evk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
2012-11-19ehci-mxc: Fix host power mask bit for i.MX35Benoît Thébaudeau
The correct bit for H1_PM is 16, not 8, which is the DP pull-up impedance selection bit. This issue has been reported by Michael Burkey <mdburkey@gmail.com> and fixed by Christoph Fritz <chf.fritz@googlemail.com> on Linux, from which these #define-s had been copied. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx6: clock: Only show CSPI clock if CSPI is enabledFabio Estevam
If a board does not enable CSPI, there is no need to show the CSPI clock frequency as part of the 'clock' command. Reported-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@gmail.com>
2012-11-19spi: mxc_spi: Fix spi clock glitch durant resetFabio Estevam
Measuring the spi clock line on a scope shows a 'glitch' during the reset of the spi. Fix this by toggling only the MXC_CSPICTRL_EN bit, so that the clock line becomes always stable. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-19spi: mxc_spi: Fix handling of chip selectFabio Estevam
In decode_cs() function the polarity of the chip select must be taken into account. Also, for the case of low active chip select, the CS was activated too early. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-19mx5: Print CSPI clock in 'clock' commandFabio Estevam
Print CSPI clock in 'clock' command. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2012-11-19mx5: Align SPI CS naming with i.MX53 reference manualFabio Estevam
Align SPI chip select naming with i.MX53 reference manual. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-16ehci-mx5/6: Make board_ehci_hcd_init() optionalBenoît Thébaudeau
A custom board_ehci_hcd_init() may be unneeded, so add a weak default implementation doing nothing. By the way, use simple __weak from linux/compiler.h for board_ehci_hcd_postinit() instead of weak alias with full attribute. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-11-16mx35pdk: Add support for OTGBenoît Thébaudeau
Add support for the OTG port on the mx35pdk Personality board. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Stefano Babic <sbabic@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-11-16ehci-mxc: Add support for i.MX35Benoît Thébaudeau
2012-11-16ehci-mxc: Define host offsetsBenoît Thébaudeau
Some MXC SoCs like the i.MX35 have hosts located at unusual offsets, so prepare to the introduction of i.MX35 support by defining the ehci-mxc hosts offsets at SoC level. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-11-16ehci-mxc: Make i.MX25 EHCI configurableBenoît Thébaudeau
Use EHCI MXC configuration options for i.MX25. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Matthias Weisser <weisserm@arcor.de>
2012-11-16ehci-mxc: Make EHCI power/oc polarities configurableBenoît Thébaudeau
Make EHCI power and overcurrent polarities configurable. If not set, these new configurartions keep the default register values so that existing board files do not have to be changed. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-11-16ehci-mx5: Add missing OC_DIS for i.MX53Benoît Thébaudeau
The i.MX53 has MXC_H*_UCTRL_H*_OC_DIS_BIT bits to disable the oc pin. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
