Cc: Detlev Zundel <dzu@denx.de>
This patch adds SPL code for the M28 board.
Cc: Andy Fleming <afleming@gmail.com>
This contains support for the following components:
- DUART
- MMC
- Both FEC interfaces
- NAND
- I2C (RTC, EEPROM)
- SPI (FLASH)
This tool can now generate proper image for "BootStream" files.
NOTE: This tool now works only for NAND.
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: Heiko Schocher<hs@denx.de>
Taken from Linux kernel with minor modifications:
commit bf985969e27b507f734435a99df8bf745a3dbb2b
Author: Shawn Guo <shawn.guo@freescale.com>
Date: Mon Dec 20 22:57:43 2010 +0800
ARM: mxs: Add iomux support
Cc: Ben Warren <biggerbadderben@gmail.com>
Acked-by: Andy Fleming <afleming@gmail.com>
This patch supports:
- Timers
- Debug UART
- Clock
Fix:
zmx25.c: In function 'board_late_init':
zmx25.c:131:25: warning: variable 'padctl' set but not used [-Wunused-but-set-variable]
add new configuration file da850_am18xxevm.h for AM18xx boards
which are based on da850 SOC. AM18xx has WINBOND spi flash which
is indicated in the config file. And make appropriate changes in
board.cfg for building.
Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This is needed to support the latest kernel versions.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
The devkit8000 ships with either a 128MB or 256MB NAND chip. In
order for SPL to work with 256MB NAND CONFIG_SYS_NAND_5_ADDR_CYCLE
needs to be set. After talking with Scott Wood this should be
safe to set even for smaller NAND chips.
Cc: Frederik Kriewitz <frederik@kriewitz.eu>
This enables Vpp and disables the flash protection on the
Integrator when starting U-Boot. The integrator/AP has double
protection mechanisms: this one and the EBI protection bit
(patch earlier), the Integrator/CP has only one line of
protection in these registers.
Break out the AP system controller and CP "CP controller"
registers into a header file, it gives better overview than
hardcoding its values and other disturbing practices.
This reconfigures the EBI (External Bus Interface) on the
integrator so that chip select 1, handling the flash memory, is
set to writeable. Without this it is not possible for U-Boot to
access flash memory and it crashes on startup since CFI won't
work properly.
Since this is the first time we use the EBI, we create a header
file for its registers.
Casting around to *(volatile ulong *) doesn't look good, so include
the <asm/io.h> macros and use good old readl() instead.
Do away with the config.mk file and move the text offset to the
config files to make things easier.
Alter the board.cfg to pass core module configuration flags
so we can make compile-time switches for different core
modules. These are already in use for some low-level code,
they just got lost in the conversion to the new build
system.
Signed-off-by: David Mueller <d.mueller@elsoft.ch>
This allows the SPL to avoid compiling in the CPU support code.
When booting from Flash, the Integrator remaps its flash memory
from 0x24000000 to 0x00000000, and starts executing it at
0x00000000. This ROM thus hides the RAM underneath and first
0x40000 bytes of the memory cannot be tested by get_ram_size().
So let's test from 0x40000 to the end of detected memory
instead.
timer.c used static data and are called before relocation.
Move all static variables into global_data structure. Also cleanup
timer.c from unused stubs and make it truly use 64 bit tick values.
Remove reset_timer_masked() get_timer_masked()
reference: arch/arm/cpu/arm926ejs/at91/timer.c
Based on Reinhard Meyer <u-boot@emk-elektronik.de>'s patches
5dca710a3d7703e41da0e9894f2d71f9e25bea6b
cfff263f41e32c7ba2ee9162a8cc6423eb5a8390
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Tested-by: Macpaul Lin <macpaul@gmail.com>
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
add a function in board file to pass board revision
info to kernel. Revision number 0 and 1 are passed in
case of DM6467 and DM6467T respectively.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
add new configuration file for dm6467T and appropraite changes
in boards.cfg. dm6467T is the new varaiant of dm6467 SOC which
supports 33 MHz reference clock where as dm6467 supports 27 MHz
reference clock.
da850_ddr_setup() expects the BOOTUNLOCK bit to be set in
If BOOTUNLOCK is not set in this define, several configuration
bits will not be writeable and the code will not work.
Since the BOOTUNLOCK and TIMUNLOCK bits are not configuration options
but access control bits, this patch changes the code to work
irrespective of the value of these bits in CONFIG_SYS_DA850_DDR2_SDBCR.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Paulraj Sandeep <s-paulraj@ti.com>
The LPSC functions defined in
arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c
are replaced by those already defined in
arch/arm/cpu/arm926ejs/davinci/psc.c.
Acked-by: Heiko Schocher <hs@denx.de>
Rename arch/arm/cpu/arm926ejs/davinci/am1808_lowlevel.c and
arch/arm/include/asm/arch-davinci/am1808_lowlevel.h to da850_lowlevel.c
and da850_lowlevel.h since they apply not only to the AM1808 SoC
but to all DA850 chips. The function names and #defines are changed
likewise.
This patch fixes following compile error for da8xx evm
da830evm.c: In function 'board_init':
da830evm.c:222: error: 'DAVINCI_SYSCFG_SUSPSRC_UART2' undeclared (first use in this function)
da830evm.c:222: error: (Each undeclared identifier is reported only once
da830evm.c:222: error: for each function it appears in.)
make[2]: *** [da830evm.o] Error 1
similarly for da850evm.
introduced through commit:
f9fc237f1f07d4e5ff7c9c2da39cabc8d3d7b339
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
* 'master' of git://git.denx.de/u-boot-mpc83xx:
powerpc/mpc83xx: Add 33.33MHz support for mpc8360emds
powerpc/mpc83xx: Add 512MB DDR support for mpc8360emds
mpc83xx: Rename CONFIG_SYS_DDR_CONFIG and cleanup DDR csbnds code
mpc83xx: Cleanup usage of LBC constants
mpc83xx: Cleanup usage of DDR constants
mpc83xx: Cleanup usage of BAT constants
mpc83xx: cosmetic: vme8349.h checkpatch compliance
mpc83xx: cosmetic: ve8313.h checkpatch compliance
mpc83xx: cosmetic: sbc8349.h checkpatch compliance
mpc83xx: cosmetic: mpc8308_p1m.h checkpatch compliance
mpc83xx: cosmetic: kmeter1.h checkpatch compliance
mpc83xx: cosmetic: TQM834x.h checkpatch compliance
mpc83xx: cosmetic: SIMPC8313.h checkpatch compliance
mpc83xx: cosmetic: MVBLM7.h checkpatch compliance
mpc83xx: cosmetic: MPC837XERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC837XEMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8360ERDK.h checkpatch compliance
mpc83xx: cosmetic: MPC8360EMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8349ITX.h checkpatch compliance
mpc83xx: cosmetic: MPC8349EMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC832XEMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8323ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8315ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8313ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8308RDB.h checkpatch compliance
mpc83xx: cosmetic: MERGERBOX.h checkpatch compliance
mpc83xx: Fix ipic structure definition
powerpc, mpc83xx: add DDR SDRAM Timing Configuration 3 definitions
cosmetic, powerpc, mpc83xx: checkpatch cleanup
powerpc/83xx: move km 83xx specific i2c code to km83xx_i2c
mpc83xx: fix global timer structure definition
The new MPC8360EMDS board changes the oscillator to 33.33MHz
in order to support QE 500MHz since 2008.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
* 'master' of git://git.denx.de/u-boot-arm:
Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board
arm: jadecpu: Readd MACH_TYPE_JADECPU
at91: defined mach-types for otc570 board in board config file
at91: defined mach-types for meesc board in board config file
mx31pdk: Enable D and I caches
ehci-mxc: remove incorrect comment
README: Fix supported i.MX SoC list for CONFIG_MXC_SPI
mx53: Turn off child clocks before reconfigure perclk_root
qong: enable support for compressed images
imx: imx31_phycore.h: fix checkpatch warnings
vision2: Remove unused get_board_rev function
mx53smd: Remove unused get_board_rev function
mx53ard: Remove unused get_board_rev function
mx53evk: Remove unused get_board_rev function
mx53evk: Add RTC support
mx53loco: Remove unused get_board_rev function
mx53evk: Remove unneeded '1' from mx53evk.h
OMAP3: mvblx: Initial support for mvBlueLYNX-X
ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE
omap3: mem: Move comments next to definitions
omap3: mem: Clean-up whitespaces
omap3: mem: Define and use common macros
Davinci: ea20: added PREBOOT to configuration
Davinci: ea20: added I2C support
Davinci: ea20: added video support
VIDEO: davinci: add framebuffer to da8xx
ARM: Davinci: added missing registers to hardware.h
Davinci: ea20: add gpios for LCD backlight control
Davinci: ea20: add gpio for keeping power on in board_late_init
Davinci: ea20: Add default U-Boot environment
Davinci: ea20: Add early init to get early output from console
Davinci: ea20: Add NAND support
Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console
Davinci: ea20: set console on UART0
arm, davinci: add cam_enc_4xx support
arm926ejs, davinci: add missing spi defines for dm365
arm926ejs, davinci: add cpuinfo for dm365
arm, davinci: add lowlevel function for dm365 soc
arm, davinci: add header files for dm365
spl, nand: add 4bit HW ecc oob first nand_read_page function
arm, davinci: add support for new spl framework
spl: add option for adding post memory test to the SPL framework
net, davinci_emac: make clock divider in MDIO control register configurable
arm, usb, davinci: make USBPHY_CTL register configurable
usb, davinci: add enable_vbus() weak function
omap3evm: fix errors caused by multiple definitions
omap3evm: Add (quick) configuration for NAND only
omap3evm: Add (quick) configuration for MMC/SD only
omap3evm: move common config options to new file
omap3evm: Prepare to split configuration
omap3evm: Reorder related config options
omap/spl: actually enable the console
davinci_emac: compilation fix, phy is array now
omap3evm: Set environment variable 'ethaddr'
arm, arm926: fix missing symbols in NAND_SPL mode
arm, davinci: Add function lpsc_syncreset()
arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD
arm/km: portl2 environment address update to P1B
arm/km: adapt bootcounter evaluation
arm/km: enable jffs2 cmds
arm/km: trigger reconfiguration for the Xilinx FPGA
arm/km: add boardid and hwkey to kernel command line
ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards
netspace_v2: enable I2C EEPROM support
netspace_v2: fix SDRAM configuration
armada100: define CONFIG_SYS_CACHELINE_SIZE
pantheon: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: drop empty asm-offsets.s file
arm/km/mgcoge3un: enhance "waitforne" feature
arm/km: add variable waitforne to mgcoge3un
gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared
ARM: dreamplug: fix compilation
ARM: DockStar: fix compilation
ARM: netspace_v2: fix warnings
am335x: Drop board_sysinfo struct
am335x: Temporarily add MACH_TYPE define
misc:pmic:samsung Enable PMIC driver at C210 Universal target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target
smdkv310: use macro for mmc data read function address
smdkv310: use spl framework for mmc spl
SMDKV310: use get_ram_size() to validate dram size
SMDKV310: Initialize board id using CONFIG_MACH_TYPE
ORIGEN : use absolute paths and fix tool naming
ORIGEN : enable device tree support
MX25: tx25: Fix building due to missing MACH_TYPE
mx31: Add board support for HALE TT-01
mx31: add ESD control registers
mx31: define pins and init for UART2 and CSPI3
MX35: add support for flea3 board
MX51: vision2: add MACH_TYPE in config file
vision2: Remove unused header file
mx51evk: Remove unused get_board_rev function
mx51evk: Remove unneeded '1' from mx51evk.h
I2C: Fix mxc_i2c.c problem on imx31_phycore
mx35pdk: Add RTC support
mx51evk: Use GPIO API for configuring the IOMUX
mx51evk: Add RTC support
rtc: Make mc13783-rtc driver generic
qong: remove unneeded IOMUX settings
qong: Use mx31_set_gpr to setup USBH2 pins
mx31: Introduce mx31_set_gpr function
mx31pdk: Add MC13783 PMIC support
qong: remove unneeded "1" from qong.h
misc: pmic: fix regression in pmic_fsl.c (SPI)
mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME
MX35: Drop unnecessary prototypes from imx-regs.h
I2C: added I2C-2 and I2C-3 to MX35
MX35: factorize common assembly code
MX35: add reset cause as provided by other i.MX
MX35: add pins definition for UART3
MX35: added ESDC structure to imx-regs
* 'master' of git://git.denx.de/u-boot-coldfire:
ColdFire: The EB+MCF-EV123 boards config update
ColdFire: Fix the compile issue for M52277
ColdFire:Moving the remaining coldfire boards to boards.cfg
* 'master' of git://git.denx.de/u-boot-i2c:
Powerpc/i2c: Use the same initialize codes
Fix:
scm.c: In function 'config_scoh_cs':
scm.c:400:16: warning: variable 'tmp' set but not used
Fix:
vovpn-gw.c: In function 'misc_init_r':
vovpn-gw.c:266:16: warning: variable 'temp' set but not used
Fix:
mpc8266ads.c: In function 'initdram':
mpc8266ads.c:278:9: warning: variable 'spd_size' set but not used
Make (mostly) checkpatch clean.
Cc: Rune Torgersen <runet@innovsys.com>
Fix:
sacsng.c: In function 'initdram':
sacsng.c:180:9: warning: variable 'spd_size' set but not used
Cc: Jerry Van Baren <gerald.vanbaren@smiths-aerospace.com>
Fix:
flash.c: In function 'flash_init':
flash.c:52:19: warning: variable 'size' set but not used
