commit 010a958b
(arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h)
breaks building keymile arm targets, when u-boot.kwb tries to
generate the binary with mkimage. A simple make <board> or MAKEALL
succeeded because it don't try to build the kirwood binary at the end.
Due this commit we use the CONFIG_SYS_KWD_CONFIG from the
arch-kirkwood/config.h and it was removed from the board config.
But it was forgotten to include the header. Now the header is included
in km_arm.h. Some other defines were obsolete due to this include,
these are also removed in this commit.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Heiko Schocher <hs@denx.de>
Some boards e.g. keymile arm boards have CONFIG_CMD_I2C switched on
but they use soft i2c on kirkwood. So don't switch CONFIG_I2C_MVTWSI
on in this case.
* Fix compiler error for cpu at91sam9, if lowlevel init is enabled
* use correct ATMEL_ name scheme to define ATMEL_BASE_SDRAMC
Signed-off-by: Jens Scharsig
This patch removes the board implemenatation for flash driver which can now
safely switched to the common cfi driver.
Compile tested for all atstk100x boards, runtime tested on atstk1002.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
The at91rm9200_usart driver could be fully replaced by atmel_usart driver.
Cc: Eric Bénard <eric@eukrea.com>
CC: Jens Scharsig <js_at_ng@scharsoft.de>
Acked-by: Jens Scharsig<js_at_ng@scharsoft.de>
Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
This is a copy of arm926ejs/at91 api for perpherial initialisation.
At the moment we just need the usart part of the api.
This patch enables the new clock features from arm920t/at91/clock.c. This
is an required step to get at91rm9200_usart replaced by atmel_usart driver.
Cc: Jens Scharsig <js_at_ng@scharsoft.de>
This patch adds an copy of arm926ejs/at91/clock.c to arm920t/at91. The
arm926ejs specialities are removed from arm920t version and vice versa.
This patch sets the ATMEL_PMX_AA_TXD2 to the correct value.
CC: eric@eukrea.com
Acked-by: Eric Bénard <eric@eukrea.com>
commit 0015de1a (MX5: Make the weim structure complete) fixed the name for
the WEIM registers in order to match with the MX51/MX53 manuals.
Fix the WEIM register for vision2 board so that it can build again.
Enable dcache and arch memset/memcpy for speed reasons
Remove of config.mk and some environment overwrites
Some generic cleanup
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Define CONFIG_SYS_SDRAM_BASE to physical SDRAM address
and CONFIG_SYS_INIT_SP_ADDR to physical SRAM address
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
As implemented now the timer used to implement __udelay counts
to 0xffffffff and then gets stuck there because the the programmed
reload value is 0xffffffff. This value is not only wrong but
illegal according to the reference manual.
One can reproduce the bug by leaving a board at the u-boot prompt
for sometime then issuing a sleep command. The sleep will hang
forever.
The timer is a count up timer that reloads as it rolls over
from 0xffffffff so the correct load value is 0.
Change TIMER_LOAD_VAL from 0xffffffff to 0 and introduce
a new constant called TIMER_OVERFLOW_VAL set to 0xffffffff.
Signed-off-by: John Rigby <john.rigby@linaro.org>
Tested-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Signed-off-by: David Müller <d.mueller@elsoft.ch>
adapt s5pc1xx to the new layered cache maintenance framework
Signed-off-by: Aneesh V <aneesh@ti.com>
adapt omap3 to the new layered cache maintenance framework
adapt omap4 to the new layered cache maintenance framework
PL310 is the L2$ controller from ARM used in many SoCs
including the Cortex-A9 based OMAP4430
Add support for some of the key PL310 operations
- Invalidate all
- Invalidate range
- Flush(clean & invalidate) all
- Flush range
1. make sure that page table setup is not done multiple times
2. flush_dcache_all() is more appropriate while disabling cache
than a range flush on the entire memory(flush_cache())
Provide a default implementation for flush_dcache_all()
for backward compatibility and to avoid build issues.
- Enable I-cache on bootup
- Enable MMU and D-cache immediately after relocation
- Do necessary initialization before enabling d-cache and MMU
- Changes to cleanup_before_linux()
- Make changes according to the new framework
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF
CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF
V2:
* Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE
V4:
* Changed all three flags to the final names suggested as above
and accordingly changed the commit message
- Add a framework for layered cache maintenance
- separate out SOC specific outer cache maintenance from
maintenance of caches known to CPU
- Add generic ARMv7 cache maintenance operations that affect all
caches known to ARMv7 CPUs. For instance in Cortex-A8 these
opertions will affect both L1 and L2 caches. In Cortex-A9
these will affect only L1 cache
- D-cache operations supported:
- Invalidate entire D-cache
- Invalidate D-cache range
- Flush(clean & invalidate) entire D-cache
- Flush D-cache range
- I-cache operations supported:
- Invalidate entire I-cache
- Add maintenance functions for TLB, branch predictor array etc.
- Enable -march=armv7-a so that armv7 assembly instructions can be
used
make default implementation of cache_flush() weakly linked so that
sub-architectures can override it
On MPC85xx based NAND_SPL builds we generate a u-boot-nand_spl.lds based
on output from preprocessor. We where never removed it.
This patch adds support for 16 bit NAND devices attached to the
NDFC on ppc4xx processors. Two config entries were added:
CONFIG_SYS_NDFC_16 - Setting this tells the NDFC that a
16 bit device is attached.
CONFIG_SYS_NDFC_EBC0_CFG - This is for the External Bus
Controller configuration register.
Also, a new ndfc_read_byte() function was added which does not
first convert the data to little endian.
The NAND SPL was also modified to do 16bit bad block testing
when a 16 bit chip is being used.
Signed-off-by: Alex Waterman <awaterman@dawning.com>
Add another nand write. variant, trimffs. This command will request of
nand_write_skip_bad() that all trailing all-0xff pages will be
dropped from eraseblocks when they are written to flash as-per the
reccommended behaviour of the UBI FAQ [1].
The function that implements this timming is the drop_ffs() function
by Artem Bityutskiy, ported from the mtd-utils tree.
[1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Artem Bityutskiy <dedekind1@gmail.com>
CC: Detlev Zundel <dzu@denx.de>
Acked-by: Scott Wood <scottwood@freescale.com>
Add a flag to nand_read_skip_bad() such that if true, any trailing
pages in an eraseblock whose contents are entirely 0xff will be
dropped.
The implementation is via a new drop_ffs() function which is
based on the function of the same name from the ubiformat
utility by Artem Bityutskiy.
This is as-per the reccomendations of the UBI FAQ [1]
Acked-by: Detlev Zundel <dzu@denx.de>
CC: Scott Wood <scottwood@freescale.com>
When specified in the flags argument of nand_write, WITH_YAFFS_OOB causes an
operation which is mutually exclusive with the 'usual' way of writing.
Add a check that client code does not specify WITH_YAFFS_OOB along with any
other flags and add a comment indicating that the WITH_YAFFS_OOB flag should
not be mixed with other flags.
In a future commit the behaviour of nand_write_skip_bad()
will be further extended.
Convert the only flag currently passed to the nand_write_
skip_bad() function to a bitfield of only one allocated
member. This should avoid an explosion of int's at the
end of the parameter list or the ambiguous calls like
nand_write_skip_bad(info, offset, len, buf, 0, 1, 1);
nand_write_skip_bad(info, offset, len, buf, 0, 1, 0);
Instead there will be:
nand_write_skip_bad(info, offset, len, buf, WITH_YAFFS_OOB |
WITH_OTHER);
Replace an incorrect 'read' with 'write' in a comment.
* 'next' of git://git.denx.de/u-boot-nios:
nios2: move generic config to boards.cfg
I can't build test this, but just looking at the config files written
and it seems OK ...
Tested-by: Thomas Chou <thomas@wytron.com.tw>
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
For newer STM parts where CFI >= 1.1, there is a byte in the extended
structure that declares the flash layout type (just like the AMD parts),
so key off of that to find out when we need to reverse the geometry.
This can be seen with M29W640 parts where U-Boot does:
Bank # 1: CFI conformant FLASH (16 x 16) Size: 8 MB in 135 Sectors
AMD Standard command set, Manufacturer ID: 0x20, Device ID: 0x22ED
Erase timeout: 8192 ms, write timeout: 1 ms
Buffer write timeout: 1 ms, buffer size: 16 bytes
Sector Start Addresses:
20000000 RO 20002000 RO 20004000 RO 20006000 RO 20008000 RO
2000A000 RO 2000C000 RO 2000E000 RO 20010000 RO 20020000 RO
But Linux does:
physmap platform flash device: 00800000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank.
Manufacturer ID 0x000020 Chip ID 0x0022ed
physmap-flash.0: Swapping erase regions for top-boot CFI table.
Looks like this was missed during the conversion to partial linking.
Convert the PCI base address into a virtual address.
Signed-off-by: Zhao Chenhui <b35336@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
When dealing with non-multipoint devices, if the software root hub code
accepted the message, then we still need to process it normally. So only
return quickly when the root hub skipped the message or is otherwise in
an error state.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
* 'master' of git://git.denx.de/u-boot-arm:
run arm_pci_init after relocation
IXP42x PCI rewrite
update/fix PDNB3 board
update/fix IXDP425 / IXDPG425 boards
add dvlhost (dLAN 200 AV Wireless G) board
IXP NPE: add support for fixed-speed MII ports
update/fix AcTux4 board
update/fix AcTux3 board
update/fix AcTux2 board
update/fix AcTux1 board
use -ffunction-sections / --gc-sections on IXP42x
support CONFIG_SYS_LDSCRIPT on ARM
fix "depend" target in npe directory
Fix IXP code to work after relocation was added
trigger hardware watchdog in IXP42x serial driver
add support for IXP42x Rev. B1 and newer
add XScale sub architecture (IXP/PXA) to maintainer list
arch/arm/lib/board.c
