2017-07-28clk: fix compilation errors for poplar platformPatrice Chotard
Move clk_release_all() prototype and definition inside OF_CONTROL flag to avoid following compilation error for poplar platform: aarch64: + poplar +drivers/usb/host/built-in.o: In function `ehci_usb_remove': +drivers/usb/host/ehci-generic.c:159: undefined reference to `clk_release_all' +drivers/usb/host/built-in.o: In function `ehci_usb_probe': +drivers/usb/host/ehci-generic.c:133: undefined reference to `clk_release_all' +make[1]: *** [u-boot] Error 139 +make: *** [sub-make] Error 2 Introduced by 4e542c4 clk: add clk_release_all() Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28usb: host: xhci-dxc3: fix compilation warningsPatrice Chotard
Fix following warnings encountered with platforms dra7xx_evm and dra7xx_hs_evm : arm: + dra7xx_evm + hccr = (struct xhci_hccr *)devfdt_get_addr(dev); + ^ + hcor = (struct xhci_hcor *)((phys_addr_t)hccr + + ^ w+drivers/usb/host/xhci-dwc3.c: In function 'xhci_dwc3_probe': w+drivers/usb/host/xhci-dwc3.c:124:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] w+drivers/usb/host/xhci-dwc3.c:125:30: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] w+drivers/usb/host/xhci-dwc3.c:125:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] arm: + dra7xx_hs_evm + hccr = (struct xhci_hccr *)devfdt_get_addr(dev); + ^ + hcor = (struct xhci_hcor *)((phys_addr_t)hccr + + ^ w+drivers/usb/host/xhci-dwc3.c: In function 'xhci_dwc3_probe': w+drivers/usb/host/xhci-dwc3.c:124:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] w+drivers/usb/host/xhci-dwc3.c:125:30: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] w+drivers/usb/host/xhci-dwc3.c:125:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] Introduced by 7e65e84 usb: host: xhci-dwc3: Convert driver to DM Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28phy: add a NO-OP phy driverJean-Jacques Hiblot
This driver is used to stub PHY operations in a driver (USB, SATA). This is useful when the 'client' driver (USB, SATA, ...) uses the PHY framework and there is no actual PHY harwdare to drive. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-28usb: host: ohci-generic: initialize PHY only when foundPatrice Chotard
Call generic_phy_init() only when a PHY was found. This will avoid a crash if no "phys" property is found in DT. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28usb: host: ehci-generic: initialize PHY only when foundPatrice Chotard
2017-07-28dm: usb: host: xhci-dwc3: add missing #ifdef CONFIG_DM_USBPatrice Chotard
Add CONFIG_DM_USB flag to avoid following compilation errors detected by buildman : +drivers/usb/host/built-in.o: In function `xhci_dwc3_remove': +drivers/usb/host/xhci-dwc3.c:168: undefined reference to `xhci_deregister' +drivers/usb/host/built-in.o: In function `xhci_dwc3_probe': +drivers/usb/host/xhci-dwc3.c:145: undefined reference to `usb_get_dr_mode' +drivers/usb/host/xhci-dwc3.c:152: undefined reference to `xhci_register' introduced by patch d5c3f014da3 "usb: host: xhci-dwc3: Convert driver to DM" Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Ran Wang <ran.wang_1@nxp.com>
2017-07-28dm: phy: add missing #ifdef CONFIG_PHYPatrice Chotard
To avoid compilation breakage on platform that doesn't support DM PHY but uses xhci-dwc3 driver, add the missing CONFIG_PHY flag. Introduced by patch : 84e53877 "usb: host: xhci-dwc3: Add generic PHY support" Cc: Ran Wang <ran.wang_1@nxp.com> Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Ran Wang <ran.wang_1@nxp.com>
2017-07-28dfu: add common function to initiate transactionPatrick Delaunay
- factorize code between read and write transaction - always use dfu_transaction_cleanup() to initialize the internal variable: easy maintenance - replace direct access by dfu_get_buf() and dfu_get_buf_size() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: factorize transaction cleanupPatrick Delaunay
rename cleanup function, as now called by read Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: remove limitation on partition sizePatrick Delaunay
Change long (32 bits on arm) to u64 (same type than offset) for size and read offset r_left So partition and device used for DFU can be greater than 4GB Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: allow dfu read on partition greater than 2GBPatrick Delaunay
solve issue on get_medium_size() function the detection of error is a simple test < 0 but for ARM platform, long is 32bits and 2GB = 0x80000000 is seen as error. I solve the issue by changing the prototype fo the function to separate size and result. This patch prepare the next patch with size change to u64. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28usb: gadget: f_thor: Free the allocated out request bufferSiva Durga Prasad Paladugu
Fix the memory leak by freeing the allocated out request buffer Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-07-28usb: xhci: Enable TT to support LS/FS devices behind a HS hubBin Meng
So far LS/FS devices directly attached to xHC root port can be successfully enumerated by xHCI driver, but if they are connected behind a hub, the enumeration process fails to address the device. It turns out xHCI driver still misses a part that in the device's input slot context, all Transaction Translator (TT) related fields are not programmed. The xHCI spec defines how to enable TT. Now LS/FS devices like USB keyboard/mouse can be enumerated behind a high speed hub. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Correct TT_SLOT and TT_PORT macrosBin Meng
These two macros really need a parameter to make them useful. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Implement update_hub_device() operationBin Meng
There is no way to know whether the attached device is a hub or not in advance before the device's descriptor is fetched. But once we know it's a high speed hub, per the xHCI spec, we need to tell xHC it's a hub device by initializing hub-related fields in the input slot context. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Call usb_update_hub_device() after hub descriptor is fetchedBin Meng
After fetching hub descriptor, we need to call USB uclass operation update_hub_device() to notify HCD to do some preparation work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28dm: usb: Add a new USB controller operation 'update_hub_device'Bin Meng
For USB host controllers like xHC, its internal representation of hub needs to be updated after the hub descriptor is fetched. This adds a new op that does this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Parse and save TT details from device descriptorBin Meng
A high speed hub has a special responsibility to handle full speed/ low speed devices connected on downstream ports. In this case, the hub must isolate the high speed signaling environment from the full speed/low speed signaling environment with the help of Transaction Translator (TT). TT details are provided by hub descriptors and we parse and save it to hub uclass_priv for later use. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Program 'route string' in the input slot contextBin Meng
xHCI spec says: the values of the 'route string' field shall be initialized by the first 'Address Device' command issued to a device slot, and shall not be modified by any other command. So far U-Boot does not program this field, and it does not prevent SS device directly attached to root port, or HS device behind an HS hub, from working, due to the fact that 'route string' is used by the xHC to target SS packets. But in order to enumerate devices behind an SS hub, this field must be programmed. With this commit and along with previous commits, now SS & HS devices attached to a USB 3.0 hub can be enumerated by U-Boot. As usual, this new feature is only available when DM is on. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Change xhci_setup_addressable_virt_dev() signatureBin Meng
For future extension, change xhci_setup_addressable_virt_dev() signature to accept a pointer to 'struct usb_device', instead of its members slot_id & speed, as the struct already contains these two plus some other useful information of the device. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Support 'set hub depth' request for USB 3.0 hubsBin Meng
USB 3.0 hub uses a hub depth value multiplied by four as an offset into the 'route string' to locate the bits it uses to determine the downstream port number. We shall set the hub depth value of a USB 3.0 hub after it is configured. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Translate USB 3.0 hub port status into old versionBin Meng
USB 3.0 hub port status field has different bit positions from 2.0 hubs. Since U-Boot only understands the old version, translate the new one into the old one. Since we are going to add USB 3.0 hub support, this feature is only available with driver model USB. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Add a new API to test if a hub device is root hubBin Meng
Sometimes we need know if a given hub device is root hub or not. Add a new API to test this. This removes the xHCI driver's own version is_root_hub() and change to use the new API. While we are here, remove the unused/commented out get_usb_device() in the xHCI driver too. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-28usb: hub: Remove hub_port_reset()Bin Meng
At present hub_port_reset() is defined in DM USB, but it is never called hence remove it (removing another ifdefs). While we are here, change legacy_hub_port_reset() name to usb_hub_port_reset() to better match other function names in the same hub module. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Use 'struct usb_hub_device' as hub device's uclass_privBin Meng
Use USB hub device's dev->uclass_priv to point to 'usb_hub_device' so that with driver model usb_hub_reset() and usb_hub_allocate() are no longer needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci-pci: Clean up the driver a little bitBin Meng
This cleans up the driver a little bit. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci-pci: Drop non-DM version of xhci-pci driverBin Meng
As there is no board that currently uses xhci-pci driver without DM USB, drop its support and leave only DM support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28x86: minnowmax: Enable USB xHCI supportBin Meng
BayTrail SoC supports both EHCI and xHCI controllers. However only one host controller (either EHCI or xHCI) can be used. To enable HSIC and SS ports, xHCI must be used. This turns on xHCI support on Intel MinnowMax board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28x86: minnowmax: Add a environment variable for USB power-on delayBin Meng
Occasionally it was observed that on Intel MinnowMax board, with a USB 2.0 device connected to the bottom port, when doing 'usb start' on the xHCI controller: scanning bus 0 for devices... cannot reset port 3!? But neither of the two USB ports is routed to xHCI root port 3. Adding some debug information shows that xHCI port 3 PORTSC register mysteriously reports both CCS = 1 and CSC = 1. This is not seen every time. After increasing the timeout to wait for power to become stable, the issue is gone. So this indicates current default USB power-on delay (20ms) might be at a critical region where power is stable/unstable. U-Boot provides a mechanism to have a environment variable to override the default one. Add one for MinnowMax. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Convert CONFIG_USB_XHCI_PCI to KconfigBin Meng
Add CONFIG_USB_XHCI_PCI as a Kconfig option. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: cmd: Print actual packet size for super speed devicesBin Meng
USB 3.0 defines bMaxPacketSize0 field in the device descriptor as the exponent of 2, so let's print the calculated actual size. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: ehci: Get rid of CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTSBin Meng
EHC reports supported maximum number of ports in the HCSPARAMS register, so it's unnecessary to use a hardcoded config option CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Get rid of CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTSBin Meng
xHC reports supported maximum number of ports in the HCSPARAMS1 register, so it's unnecessary to use a hardcoded config option CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Change MAX_HC_PORTS to 255Bin Meng
HCSPARAMS1:MaxPorts field specifies the maximum port number value, and its valid values are in the range of 1 to 255. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Add 3.0 hub port status mask of 2.0 hubBin Meng
USB 3.0 hub port status has different bit position regarding to port power, port speed, etc. But others are the same as 2.0 hubs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Change USB hub descriptor to match USB 3.0 hubsBin Meng
USB 3.0 hubs have a slightly different hub descriptor than USB 2.0 hubs, with a fixed (rather than variable length) size. Change the host controller drivers that access those last two fields (DeviceRemovable and PortPowerCtrlMask) to use the union. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Revise wLength for 'get port status' requestBin Meng
For accuracy, we should use 'sizeof(struct usb_port_status)' as the wLength for 'get port status' request, although it happens to be equal to 'sizeof(struct usb_hub_status)'. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Send correct wValue to get hub descriptor of a USB 3.0 hubBin Meng
Testing a USB 3.0 hub by connecting it to the xHCI port on Intel MinnowMax, when issuing 'get hub descriptor' to the hub, xHCI reports a transfer event TRB with a completion code 6 which means 'Stall Error'. In fact super speed USB hub descriptor type is 0x2a, not 0x29. Sending correct SETUP packet to the hub makes it not stall anymore. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Update handling connect status/change in usb_scan_port()Bin Meng
It was observed that on Intel MinnowMax board, when xHCI is enabled in the BayTrail SoC, with a USB 3.0 device connected to the bottom USB 3.0 port (mapped to xHCI root port #7), its PORTSC register is always 0x201203 (CCS = 1, CSC = 0). The root cause of such behavior is unknown yet. Connect status change bit is set on the same port with a USB 2.0 device (mapped to xHCI port #1, which is a different port on the root hub). With current logic in usb_scan_port(), the enumeration process will abort if it does not detect a connect status change on a hub port. However since a device connection status is correctly reported, the enumeration process can still continue. With this change, USB device connected to the bottom blue port on MinnowMax board can be enumerated under either SS or HS mode. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-28usb: xhci: Add input slot context in xhci_set_configuration()Bin Meng
A valid input slot context for a 'configure endpoint' command requires the 'Context Entries' field to be initialized to the index of the last valid endpoint context that is defined by the target configuration. We set up the 'Context Entries' field, but we forget to include the input slot context in the input control context 'Add Context flags' bitmap. So xHC will simply ignore input slot context and continue using its own which contains old information of the device. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Initialize scratchpad buffer array and scratchpad buffersBin Meng
The scratchpad buffer array is used to define the locations of statically allocated memory pages that are available for the private use of the xHC. The xHCI spec explicitly mentions that system software shall allocate the scratchpad buffers before placing the xHC in to Run mode (Run/Stop (R/S) = ‘1’), however U-Boot is missing this part. This causes xHC on Intel platform does not respond the very first 'enable slot' command that is given to xHC and the 'enable slot' command completion event TRB is never generated and xHC seems to hang forever. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Correct command TRB 4th dword initializationBin Meng
In xhci_queue_command(), when the command is not 'reset endpoint', 'stop endpoint' or 'set TR dequeue pointer', endpoint ID should not be encoded in the TRB. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: xhci: Remove incorrect comments for struct xhci_container_ctxBin Meng
There is no member called 'dma' in struct xhci_container_ctx. Remove the comments that mentions it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: host: ohci-generic: add generic PHY supportPatrice Chotard
Extend ohci-generic driver with generic PHY framework Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: host: ohci-generic: add RESET supportPatrice Chotard
use array to save deasserted resets reference in order to assert them in case of error during probe() or during driver removal. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: host: ohci-generic: add CLOCK supportPatrice Chotard
use array to save enabled clocks reference in order to disabled them in case of error during probe() or during driver removal. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: host: ehci-generic: add generic PHY supportPatrice Chotard
Extend ehci-generic driver with generic PHY framework Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: host: ehci-generic: add error path and .remove callbackPatrice Chotard
Use an array to save enabled clocks reference and deasserted resets in order to respectively disabled and asserted them in case of error during probe() or during driver removal. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
