2016-02-16tegra: video: Convert tegra20 LCD driver to driver modelSimon Glass
Move this driver over to use driver model. This involves rearranging the code somewhat. The effect is that everything is run from the probe() method. Boards which use this are fixed up, but only seaboard is tested. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Merge the two config structures togetherSimon Glass
We have a structure for the display panel and another for the controller. There is some overlap between them. Merge them to simplify the driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Move the check for CONFIG_OF_CONTROL to KconfigSimon Glass
We can check this in Kconfig now. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Merge the display driver into one fileSimon Glass
At present we have code in arch/arm and code in drivers/video. Move it all into drivers/video since it is a display driver and our current approach is to put all driver code in drivers/. Make a few functions static now that they are not used outside the file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: dts: Sync tegra20.dtsi with Linux v4.4Simon Glass
This file has changed quite a bit since it was set up. Sync it back with Linux v4.4. Adjust the users slightly to cope with the changes: - the host1x node is now called host1x@50000000 - we need a clocks node to provide the clk32k_in phandle - active usb nodes need status = "okay" - active i2c nodes need status = "okay" Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Rename CONFIG_VIDEO_TEGRA to CONFIG_VIDEO_TEGRA20Simon Glass
This option refers only to the tegra20 video driver, so name it as such to avoid confusion with tegra124. Also move this option to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: nyan-big: Move the LCD driver to driver modelSimon Glass
Adjust the driver to use driver model. The SOR becomes a bridge device. We use the normal simple_panel driver to handle the display itself. We also need to enable some options such as regulators, PWMs and DM_VIDEO itself. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: Allow CONFIG_DM_VIDEO to be used as well as CONFIG_LCDSimon Glass
While we transition to using driver model for video, we need to support both options. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: Allow driver model to be used for the PWMSimon Glass
We can skip this manual init when using driver model for the PWM. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: lcd: Merge tegra124-lcd.c into display.cSimon Glass
There isn't a lot of benefit of have two separate files. With driver model the code needs to be in the same driver, so it's better to have it in the same file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: pwm: Add a driver for the tegra PWMSimon Glass
This PWM supports four channels. The driver always uses the 32KHz clock, and adjusts the duty cycle accordingly. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: gpio: Show the GPIO value for outputsSimon Glass
The tegra GPIO controller has two ways of reading the value of a GPIO. It can supply the 'input' value (which is the value read from the pin) and the 'output' value (which is the value being driven from the pin. With a GPIO set to output mode, the 'input' value is always low which is not very useful. This has the unfortunate result that setting a GPIO high still leaves it showing as low in the 'gpio status' command. Adjust the driver to check which direction the GPIO is set to, then read the value from the appropriate register: 'input' for input GPIOs, 'output' for output GPIOs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: dts: Sync up nyan-big files with LinuxSimon Glass
Sync up these files with Linux v4.4. Some differences remain, principally that the addresses are still 32-bit in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: dts: Sync up the tegra124 device tree files with LinuxSimon Glass
Sync up these files with Linux v4.4. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: mmc: Fix comments in the MMC driver initSimon Glass
Fix the SoC names in two comments. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16dm: video: Flush the cache after a puts()Simon Glass
This helps keep the display consistent. puts() is used when printing the prompt, so is a useful way to make sure the current display contents is visible. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: keyboard: Fix the init orderSimon Glass
We need to add the base tables before adding the function tables. Fix the init order so the keyboard scans keys correctly. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-15Prepare v2016.03-rc2v2016.03-rc2Tom Rini
2016-02-15test/py: put "Starting U-Boot" into separate log sectionStephen Warren
The initial boot of U-Boot happens within the context of the first test that needs to access the U-Boot console when there is no existing connection. This keeps all activity nestled within test execution, which fits well into the pytest model. However, this mingles the U-Boot startup logs with the execution of some test(s), which hides find the boundary between the two. To solve this, wrap the "Starting U-Boot" logic into a separate log section. If the user wishes, they can simply collapse this log section when viewing the HTML log, to concentrate purely on the test's own interaction. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: handle exceptions in console creationStephen Warren
u_boot_console.exec_attach.get_spawn() performs two steps: 1) Spawn a process to communicate with the serial console. 2) Reset the board so that U-Boot starts running from scratch. Currently, if an exception happens in step (2), no cleanup is performed on the process created in step (1). That process stays running and may e.g. hold serial port locks, or simply continue to read data from the serial port, thus preventing it from reaching any other process that attempts to read from the same serial port later. While there is error cleanup code in u_boot_console_base.ensure_spawned(), this is not triggered since the exception prevents assignment to self.p there, and hence the exception handler has no object to operate upon in cleanup_spawn(). Solve this by enhancing u_boot_console.exec_attach.get_spawn() to clean up any objects it has created. In theory, u_boot_spawn.Spawn's constructor has a similar issue, so fix this too. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: print summary in test orderStephen Warren
Use lists rather than sets to record the status of tests. This causes the test summary in the HTML file to be generated in the same order as the tests are (or would have been) run. This makes it easier to locate the first failed test. The log for this test might have interesting first clues re: interaction with the environment (e.g. hardware flashing, serial console, ...) and may help tracking down external issues. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: fix CONFIG_SPL testStephen Warren
The Python ini file parser that's used to parse .config converts all keys to lower-case. Hence, all queries against the results must use lower-case. Fix u_boot_console.ensure_spawned() to test CONFIG_SPL correctly, or the connection will fail for boards that have SPL. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15Enable test/py for sandbox in Travis CIStephen Warren
This provides runtime test coverage in Travis, in addition to the existing build coverage. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: don't import pexpectStephen Warren
The code replaced pexpect with custom code long ago. Don't import the unused module so it doesn't need to be installed. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: add docs for gdbserver and pytest optionsStephen Warren
Add documentation describing the new --gdbserver feature, and some common pytest options. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15test/py: run all "ut" subtestsStephen Warren
Invoke each "ut"-based unit test as a separate pytest. Now that the DM unit test runs under test/py, remove the manual shell script that invokes it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> # v2, on sandbox
2016-02-15Makefile: generate symbol list from u-bootStephen Warren
This information may be useful for both debugging, and processes that want to perform simple forms of introspection on the U-Boot binary, such as determining the set of "ut" subtests that are compiled in. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15gpio: Correct handling of 'gpio status'Simon Glass
This is broken - we need to look at the first two characters to distinguish 'gpio status' from 'gpio set'. Fixes: 0ffe6ab5 (gpio: Allow 's' as an abbreviation for 'status') Reported-by: Soeren Moch <smoch@web.de> Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Soeren Moch <smoch@web.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2016-02-15tools: fix env_flags buildLubomir Rintel
$ make tools-all ... In file included from tools/env/env_flags.c:1:0: tools/env/../../common/env_flags.c: In function ‘env_flags_parse_varaccess_from_binflags’: tools/env/../../common/env_flags.c:156:18: warning: implicit declaration of function ‘ARRAY_SIZE’ [-Wimplicit-function-declaration] for (i = 0; i < ARRAY_SIZE(env_flags_varaccess_mask); i++) ^ Seems like the other utilities just add a copy of ARRAY_SIZE since there's nowhere to include it from (tools/imagetool.h, tools/mxsimage.h). Let's do the same here. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
2016-02-15ARM: rpi: set initrd_highLubomir Rintel
The kernel gets much too sad when the ramdisk is loaded too high into the 1GiB of memory on Raspberry Pi 2: ## Flattened Device Tree blob at 00000100 Booting using the fdt blob at 0x000100 Loading Ramdisk to 39c14000, end 3ab45067 ... OK Using Device Tree in place at 00000100, end 000045ea ... [ 0.599346] Unpacking initramfs... [ 0.602924] Unable to handle kernel paging request at virtual address f9c14000 Placement of the device tree was fixed in 89ca1000 (ARM: rpi: set fdt_high in the default environment). Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-02-15Makefile: remove BUILD_TAG from KBUILD_CFLAGSStephen Warren
If BUILD_TAG is part of KBUILD_CFLAGS, then any time the value changes, all files get rebuilt. In a continuous integration environment, the value will change every build. This wastes time, assuming that incremental builds would otherwise occur. To solve this, remove BUILD_TAG from KBUILD_CFLAGS and add it to CFLAGS for just the one file that uses it. This does have the disadvantage that if any other files want to use the flag, we'll need to duplicate this custom CFLAGS setup logic. However, it seems unlikely we'll need this. An alternative would be to add BUILD_TAG to the "local version" and remove the special case code from display_options.c. However, that would affect the format of the U-Boot signon message, which may negatively affect people looking for specific data there. The approach of using file-specific CFLAGS was suggested by Masahiro Yamada. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15OMAP3_logic: Add NAND args to boot UBIFSAdam Ford
With the recent addition of UBI support, this patch will add the preset parameters to allow for mouting an UBIFS from the 'fs' partition in NAND. -V2: ubi.mtd=fs instead of ubi.mtd=4 Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-15am43xx: qspi: Fix config to select SPI modeVignesh R
CONFIG_SF_DEFAULT_MODE is used to select default SPI mode when using sf commands. Therefore fix am43xx to use CONFIG_SF_DEFAULT_MODE instead of CONFIG_DEFAULT_SPI_MODE. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-15ARM : DRA7: Switch QSPI to use MODE-0 at 64MHzVignesh R
According to Data Manual(SPRS915P) of AM572x, TI QSPI controller on DRA74 EVM(rev 1.1+) can support up to 64MHz in MODE-0, whereas MODE-3 is limited to 48MHz. Hence, switch to MODE-0 for better throughput. Also, add IODelay parameters for the same. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-15arm: VCMA9: because of NOR flash space constrains, activate THUMB build modeDavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2016-02-15arm: build some file(s) as ARM mode onlyDavid Müller (ELSOFT AG)
2016-02-15arm: the ARM920T is THUMB capable, so select the appropriate ISADavid Müller (ELSOFT AG)
2016-02-15arm: make sure board_init_r() is being called using the right mode (ARM / THUMB)David Müller (ELSOFT AG)
2016-02-15Fix variable documented in README.distro for PXE address.Vagrant Cascadian
Fixes typo of pxe_addr_r with pxefile_addr_r. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
2016-02-15OMAP3LOGIC: Update maintainerAdam Ford
I will take this over from Peter Barada, since I work with it daily at Logic PD. Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Peter Barada <peter.barada@logicpd.com>
2016-02-15OMAP3: omap3_logic: Grow SPL to 64K from 54KAdam Ford
Based on the work done by Overo, this seems to help some compilers that have a hard time fitting all the code into the allocated space. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-15OMAP3: am3517_evm: SD/MMC boot with uEnv.txt, zImage, and FDTDerald D. Woods
Boot with the Linux zImage and am3517-evm.dtb pair, when SD/MMC media is present. This behavior can be overridden by creating a 'uEnv.txt' file with 'uenvcmd' defined. To boot an existing 'uImage', create the following 'uEnv.txt': [start]----------------------------------------------------------------- loaduimage=fatload mmc 0:1 ${loadaddr} ${bootfile} uenvcmd=run loaduimage; run mmcargs; bootm ${loadaddr} [end]------------------------------------------------------------------- Inspired by similar patches, for other OMAP3 boards, from EEWiki - https://github.com/eewiki/u-boot-patches/tree/master/v2016.01 Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-14Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-02-14ARM: uniphier: add support for PH1-Pro4 Ace and Sanji boardsMasahiro Yamada
Initial commit for PH1-Pro4 Ace and Sanji boards. Note: There are two variants for the Ace board in terms of the amount of DDR memory; 1GB or 2GB. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: dts: uniphier: enable I2C channel 2 of ProXstream2 Gentil boardMasahiro Yamada
This is used for on-board inter-connection. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: dts: uniphier: add EEPROM node for ProXstream2 Gentil boardMasahiro Yamada
This board has an EEPROM connected to the I2C channel 0 of the SoC. Its slave address is 0x54. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: drop unnecessary "bootm_low" environment defineMasahiro Yamada
This environment define has been here to work around the LMB allocation error introduced by commit 9c11135ce053 ("image: fix getenv_bootm_size() function"). It is no longer needed because the root cause was fixed by commit 0cb389dd1a38 ("image: fix getenv_bootm_size() function again"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: adjust DDR clock delay line for ProXstream2Masahiro Yamada
It turned out that DDR channel 2 was not working on ProXstream2 Vodka board. Add the missing ACBLDR0 register setting to adjust the delay between the clock lines and the address/command lines. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: move cmd_ddrmphy.c to fix build errorMasahiro Yamada
If CONFIG_CMD_DDRMPHY_DUMP is enabled, the build fails. Fixes: 93d92d46cd01 ("ARM: uniphier: add dump command for DDR Multi PHY registers") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: fix makefiles to build cmd_ddr(m)phy.cMasahiro Yamada
The U-Boot proper building needs to descend arch/arm/mach-uniphier/dram to build these commands. Fixes: 93d92d46cd01 ("ARM: uniphier: add dump command for DDR Multi PHY registers") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
