The PCI support for the Integrator AP has apparently never
been finished and I strongly suspect that it has never worked,
so let's fix it. This is a list of the more or less
un-splittable changes done in this driver rewrite:
- Replace the register definitions stashed into the config
file (!) with a copy if the register file from the Linux
kernels arch/arm/include/asm/hardware/pci_v3.h
- Delete the unreadable gigantic macros that perform the
config accesses and replace them with copyedited code from
Linux arch/arm/mach-integrator/pci_v3.c
- Rewrite the rest of the setup code to use the
v3_[read|write][lwb]() accessors.
- Enable PCI by default in the AP board configuration.
- Fix checkpatch warnings and make code more conformant.
Tested-by: Will Deacon <will.deacon@arm.com>
The U-Boot startup infrastructure already makes sure pci_init() is
called at a proper time, calling it again from within the board
setup code will not make things better.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Stefano Babic <sbabic@denx.de>
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Thomas Weber <weber@corscience.de>
Because the tricorder uses the CONFIG_OMAP_HSMMC the
initialization command is mmc rescan and not mmc init.
Cc: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Dirk Behme<dirk.behme@gmail.com>
* For cold silicon the DDR timings need to be relaxed in order for
the device to boot with DDR at 266MHz
* Fix proposed by James Doublesin
Signed-off-by: Chase Maupin <Chase.Maupin@ti.com>
add support to read mac address for AM18x EVM manufactured from
Spectrum digital which have mac address stored in I2C EEPROM manufactured
by WINBOND. This patch reads mac address from I2C EEPROM and sets the
environment variable if not set, If mac address is already present in
environment compare it with the mac address in EEPROM and warn on
mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where
to look for the mac address.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
add support to read mac address for da850/L138 evm manufactured by
Logic PD which store mac address in SPI flash manufactured by ST
Microelectronics. This patch adds support to read mac address from
SPI flash and set the mac address if it hasn't been set in environment,
If it has been set in the environment it compares the value one with
SPI flash and warns on mismatch. Introduced a config option
CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for.
this patch addresses the issue that there is no DVI output on beagleboard-xm in
u-boot; the TFP410 is not powered on, DVI_PUP needs to be set high
this is done differently on beagleboard-xm rev. B/C versus earlier boards:
beagleboard-xm B/C need to set GPIO2 of the TWL4030
earlier boards need to set GPIO170
note that the change occured somewhere inbetween beagleboard-xm rev. A2 and A3
note that beagleboard-xm rev. A and rev. B cannot be distinguished using
get_board_revision(), REVISION_XM_A/REVISION_XM_B is bogus
due to this glitch, the patch cannot work correctly on some beagleboard-xm
rev A/B boards
tested on beagleboard-xm rev. C (you should see orange color on a monitor)
note that the framebuffer is NOT yet set up, this could be done along the
lines below (for 800x480 resolution and RGB24) before calling omap3_dss_enable()
static void configure_frame_buffer() {
writel(0x80500000, (uint *) 0x48050480); // address
writel(0x80500000, (uint *) 0x48050484);
writel(0x01df031f, (uint *) 0x4805048c); // size
writel(0x00000091, (uint *) 0x480504a0); // RGB24
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
check for the return status for eth_getenv_enetaddr_by_index()
and eth_setenv_enetaddr() functions and print appropriate message
on failure.
The commit message of a28afca (Add uboot "fdt_high" enviroment variable)
states that fdt_high behaves similarly to the existing initrd_high.
But fdt_high actually has an outstanding difference from initrd_high.
The former specifies the start address, while the later specifies the
end address.
As fdt_high and initrd_high will likely be used together, it'd be nice
to have them behave same. The patch changes the behavior of fdt_high
to have it aligned with initrd_high.
The document of fdt_high in README is updated with an example to
demonstrate the usage of this environment variable.
MX35PDK board does not need to print CPU revision and reset cause in board file
because this is printed by common code when CONFIG_DISPLAY_CPUINFO is selected
get_reset_cause() function is only used inside print_cpuinfo(), so let it be
defined only when CONFIG_DISPLAY_CPUINFO is selected.
Use gpio_direction_input prior to gpio_get_value.
Cc: Jason Liu <r64343@freescale.com>
Acked-by: Jason Liu <r64343@freescale.com>
The default settings store the persistent environment on SD card
and not serial flash (SPI NOR).
To use SPI NOR to save the environment instead of SD card, edit
include/configs/mx6qsabrelite.h and
- undefine CONFIG_ENV_IS_IN_MMC
- define CONFIG_ENV_IS_IN_SPI_FLASH
The SPI driver can take as chip select the controller's chip selects
as well as an external GPIO. The LSB byte has the value of the internal
chip select, the highest (thought as 16-bit value) contains the GPIO
number.
The GPIO used on Sabre Lite is GP3:19 == 83.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Jason Liu <jason.hui@linaro.org>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU
Introduce two new macros to control conditional setup
MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x)
MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x)
The interface to the mxc_gpio driver uses integer (ordinal) values to
refer to all GPIOs on the i.MX processors. The registers themselves
and much of the i.MX documentation are banked in groups of 32, and these
macros allow the use of the port:index numbering for clarity.
GPIO_NUMBER() converts to ordinal value from port:index
GPIO_PORT() returns the port of an ordinal value
GPIO_INDEX() returns the index or offset of the ordinal.
Discussion on the mailing list at
http://lists.denx.de/pipermail/u-boot/2012-January/116927.html
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <festevam@gmail.com>
This patch fixes booting i.MX28 CPUs via USB download.
In this mode the CPU's bootrom implements a USB HID device that
accepts a bootstream.
When downloading the bootstream via USB, first the SPL code is
received and executed. Then the u-boot image is received and
called.
The USB bootmode is interrupt driven.
This patch fixes two things:
1) The ARM's fast interrupt mode is disabled when the SPL code
has been run. So save and restore the CPSR register.
2) Save and restore c1 control register: the exception vector
location needs to be set back to bootrom space to make the USB
interrupts work again. The SPL code needs to change this
option for the ram size probing.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
The DC power STS shouldn't be checked if booting off 5V supply.
Cc: Robert Deliën <robert@delien.nl>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
commit f31a911fe (arm, post: add missing post_time_ms for arm)
enables get_ticks and get_tbclk for all arm based boards,
MX5/MX6 have not yet implemented.
CC: Dirk Behme <dirk.behme@de.bosch.com>
CC: Jason Liu <jason.hui@linaro.org>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
This patch adds SPI support for the MX28EVK. Support for
an optionally installed SPI flash is also added. An example
configuration for redundant envrionment from SPI flash is also
added but disabled by default.
This patch has been tested on a MX28EVK Rev. D with an installed
SST25VF032B 32Mbit SPI flash.
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch enables USB host support on the MX28EVK board.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds support for the MX28 internal RTC
and enables u-boot's date command.
* 'master' of git://git.denx.de/u-boot-microblaze:
microblaze: Enable TFTP put command
microblaze: avoid interrupt race conditions
microblaze: fix build failure due to undefined reference to `get_ticks'
Signed-off-by: Stephan Linz <linz@li-pro.net>
The interrupt acknowledge action have to run after the
registered interrupt handler. So we have a chance to
bear out the corresponding interrupt request in the
corresponding controller hardware.
With this reordering, we optain a proper interrupt
handling for level triggered interrupt sources -- for
example the new axi_timer v1.02.a introduced in ISE 13.2.
Acked-by: Michal Simek <monstr@monstr.eu>
after commit "common: add possibility for readline_into_buffer
timeout" (sha1:9c34831) was applied. The Microblaze generic build
fails with error below:
common/libcommon.o: In function `cread_line':
/devel/u-boot/common/main.c:717: undefined reference to `get_ticks'
/devel/u-boot/common/main.c:717: undefined reference to `get_tbclk'
/devel/u-boot/common/main.c:720: undefined reference to `get_ticks'
This reverts commits 2faa76196af4b3e93bcb9e38ed9090cbd3b06db3 as
this has introduced some large problems on all other platforms and have
more changes in them than the commit message implies.
Cc: Patil, Rachna <rachna@ti.com>
This reverts commit 498cbdfe62a8330f6c89765bdd15e60328a26511 as we need
to revert the i2c changes that add the support for the platform.
* 'master' of git://git.denx.de/u-boot-mmc:
mmc: make mmc_send_status() more reliable
mmc: fix card busy polling
Tegra: mmc: Fixed handling of interrupts in timeouts.
omap_hsmmc: Wait for CMDI to be clear
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/8xxx:Add MPH controller support in USB device-tree fixup
powerpc/8xxx: Cleanup USB device-tree fixup
* 'trini@ti.com' of git://git.denx.de/u-boot-staging:
usb_ether: fix typo
cmd_eeprom: typo
doc: complete, typos
* 'master' of git://git.denx.de/u-boot-x86:
x86: Convert board_init_f_r to a processing loop
x86: Split init functions out of board.c
x86: Move relocation code out of board.c
x86: Move setup_pcat_compatibility() out of board.c
x86: Move do_go_exec() out of board.c
CHECKPATCH: arch/x86/lib/*
x86: Tweak IDT and GDT for alignment and readability
x86: Allow cache before copy to RAM
x86: Create weak init_cache() and default enable_caches() functions
x86: Set GD_FLG_RELOC after entering in-RAM copy of U-Boot
x86: Use fs for global data
x86: Rework relocation calculations
x86: Simplify Flash-to-RAM code execution transition
x86: Rework Global Descriptor Table loading
x86: Remove GDR related magic numbers
x86: Speed up copy-to-RAM and clear BSS operations
x86: Import glibc memcpy implementation
Align the card status polling with the Linux kernel and retry the
command at least five times. Also some cards apparently mishandle the
status bits, so make sure to check the card state too.
Signed-off-by: Jan Kloetzke <jan.kloetzke@dspg.com>
Cc: Andy Fleming <afleming@gmail.com>
A MMC/SD card may always go into the programming state (and hence be
busy) after a block write. Therefore always check the card state, even
after single block writes. On the other hand there is no need to check
the card status after a read.
Also make sure that errors during busy polling are propagated upwards.
We are seeing occasional timeouts in the Tegra mmc code when
we are reading from external MMC cards. These don't seem to be
detrimental if they are handled properly. This CL properly
clears the "normal interrupt status register" (norintsts) in
error conditions. If we don't do this, when we come back into
mmc_send_cmd() the register will still contain status from the
last transaction.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
