2011-09-05Correct call to eth_write_hwaddr()Simon Glass
This fixes "Warning: failed to set MAC address" on platforms which rely on an 'ethaddr' environment variable to set the MAC address. This bug was introduced by this commit: 7616e785 Add Ethernet hardware MAC address framework to usbnet Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Kumar Gala <galak@kernel.crashing.org> Tested-by: Michal Simek <monstr@monstr.eu> Tested-by: Heiko Schocher <hs@denx.de>
2011-09-05sf: winbond: Add support for the Winbond W25X40James Le Cuirot
The Winbond W25X40 is now being used in the IP02 (and possibly IP04). Tested and working on the actual device.
2011-09-05board/prodrive/alpr/fpga.c: Coding style cleanupWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-09-05PPC4xx: ALPR: constify FPGA codeWolfgang Denk
The ALPR custom FPGA code was missed by commit e6a857d "fpga: constify to fix build warning" resulting in such warnings: fpga.c:226: warning: initialization from incompatible pointer type Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-09-05FPGA: constify Lattice FPGA codeWolfgang Denk
The Lattice code was missed by commit e6a857d "fpga: constify to fix build warning" resulting in such warnings: fpga.c: In function 'fpga_load': fpga.c:238: warning: passing argument 2 of 'lattice_load' discards qualifiers from pointer target type fpga.c: In function 'fpga_dump': fpga.c:278: warning: passing argument 2 of 'lattice_dump' discards qualifiers from pointer target type Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Stefano Babic <sbabic@denx.de>
2011-09-05MPC8xx: fix build problem for ETX094 boardWolfgang Denk
Commit 58c583b "net: Check network device driver name" increased the code size and broke building for the ETX094 board. Adjust the linker script to make it build again. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-05linkstation: fix warning: "CONFIG_IDENT_STRING" redefinedWolfgang Denk
Commit 09c2e90 "unify version_string" defines a default value for CONFIG_IDENT_STRING in version.h, so any private settings musty be done before including this file. Move the include for version.h after the one for common.h to fix the build problem. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2011-09-05drivers/video/Makefile: include object files only onceWolfgang Denk
Use "$(sort $(COBJS-y))" to prevent multiple inclusion of the same object files. Also sort driver list. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-05video: Fix build error with global inclusion of videomodesKumar Gala
The following commit: commit de701d118380de12a48c8a4fb345e9f909329432 Author: Syed Mohammed Khasim <khasim@ti.com> Date: Tue Apr 19 14:00:34 2011 -0500 OMAP3: Add DSS driver for OMAP3 Added videomodes to the object list w/o any protection. This causes build issues like: videomodes.o:(.rodata.res_mode_init+0x0): multiple definition of `res_mode_init' videomodes.o:(.rodata.res_mode_init+0x0): first defined here videomodes.o: In function `video_get_params': /local/home/galak/git/u-boot/drivers/video/videomodes.c:160: multiple definition of `video_get_params' videomodes.o:/local/home/galak/git/u-boot/drivers/video/videomodes.c:160: first defined here videomodes.o: In function `video_get_video_mode': /local/home/galak/git/u-boot/drivers/video/videomodes.c:229: multiple definition of `video_get_video_mode' videomodes.o:/local/home/galak/git/u-boot/drivers/video/videomodes.c:229: first defined here videomodes.o:(.rodata.vesa_modes+0x0): multiple definition of `vesa_modes' videomodes.o:(.rodata.vesa_modes+0x0): first defined here make[1]: *** [libvideo.o] Error 1 Remove the unconditional inclusion and move to adding to CONFIG_VIDEO_OMAP3 case. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-04net: Check network device driver nameMichal Simek
If name is longer than allocated space NAMESIZE mac address is rewritten which show error message like: Error message: Warning: Xlltemac.87000000 MAC addresses don't match: Address in SROM is 30:00:00:00:00:00 Address in environment is 00:0a:35:00:6a:04 NAMESIZE contains Driver name + zero terminated character. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-09-04stdio: Fix a possible buffer overflowBradley Bolen
Signed-off-by: Bradley Bolen <bradleybolen at yahoo.com>
2011-09-04MAINTAINERS: fix integrator and versatileLinus Walleij
- Take maintainership of the integratorcp board - Remove the double entry for the versatile board it has two variants but only one board folder Cc: Philippe Robin <philippe.robin@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (145 commits) beagleboard: enable HUB power on all variants of the BeagleBoard dm3730: enable dpll5 ehci-hcd: Allow cleanups to happen gracefully on a timeout. OMAP3: Add DSS driver for OMAP3 led: Remove state-saving of led for toggle functionality and add toggle option to led command led: Fixed setting of STATUS_LED_BIT1 when led_name is 'all' led: correct off/on locations in structure led: added cmd_led to Makefile BeagleBoard: fix LED 0/1 in driver Corrected LED name match finding avoiding extraneous Usage printouts BeagleBoard: config: updated default configuration BeagleBoard: config: Enabled multibus support for I2C in configuration BeagleBoard: config: add optargs/buddy/camera BeagleBoard: config: increase command-line functionality BeagleBoard: config: make mtest run BeagleBoard: config: enable DSS BeagleBoard: config: enable asix driver and dhcp BeagleBoard: config: enable networking BeagleBoard: config: decrease bootdelay to 2 seconds BeagleBoard: config: use uImage.beagle for tftp BeagleBoard: config: hardcode MAC for onboard SMSC BeagleBoard: config: load kernel from MMC ext, not FAT BeagleBoard: Configure DVI/S-video BeagleBoard: Added userbutton command BeagleBoard: turn off clocks in ehci_stop USB: Remove __attribute__ ((packed)) for struct ehci_hccr and ehci_hcor beagleboard: add support for xM revision C beagle: pass expansionboard name in bootargs OMAP: Remove omapfb.debug=y from Beagle and Overo env settings OMAP3 Beagle Pin Mux initialization glitch fix da850: modifications for Logic PD Rev.3 AM18xx EVM da850: fix the channel number for EMAC teardown init da850: add support for Spectrum Digital AM18xx EVM da850: add support to wake up DSP during board init da850: modify the U-Boot prompt string da850: add NOR boot mode support da8xx: add support for multiple PLL controllers da850: indicate cache usage disable in config file dm365: modify boot prompt from dm365 to dm36x dm365: disable cache usage due to coherency issues dm6446: disable cache usage due to coherency issues OMAP3: Remove legacy mmc driver devkit8000: Use generic MMC driver TI OMAP3 SDP3430: Use generic MMC driver AM3517 CraneBoard: Use generic MMC driver OMAP3: pandora: Use generic MMC driver OMAP3: Zoom2: Use generic MMC driver OMAP3: Zoom1: Use generic MMC driver OMAP3: DIG297: Use generic MMC driver OMAP3: CM-T35: Use generic MMC driver am3517evm: Use generic MMC driver omap3evm: Use generic MMC driver omap3:clock: check cpu_family before enabling clks for IVA & CAM omap3:clock: configure GFX clock to 200MHz for AM/DM37x OMAP3/4: Increase console I/O buffer size PXA: vpac270: Remove re-defined CONFIG_SYS_TEXT_BASE PXA: Fix CSB226, fix monitor length PXA: Fix Lubbock, remove redundant parenthesis armv7: cache: remove flush on un-aligned invalidate armv7: stronger barrier for cache-maintenance operations omap: enable caches at system start-up arm: do not force d-cache enable on all boards ORIGEN: Add MMC SPL support ARMV7: Add support for Samsung ORIGEN board i2c:gpio:s5p: Enable I2C GPIO on the GONI target i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c) Tegra2: Use clock and pinmux functions to simplify code Tegra2: Add additional pin multiplexing features Tegra2: Add more clock support Tegra2: Add microsecond timer function ARM: remove broken "at91rm9200dk" board ARM: remove broken "m501sk" board ARM: remove broken "kb9202" board ARM: remove broken "csb637" board ARM: remove broken "cmc_pu2" board ARM: remove broken "at91cap9adk" board ARM: remove broken "voiceblue" board ARM: remove broken "smdk2400" board ARM: remove broken "sbc2410x" board ARM: remove broken "netstar" board ARM: remove broken "mx1fs2" board ARM: remove broken "lpd7a40x" boards ARM: remove broken "edb93xx" boards ARM: remove broken "B2" board ARM: remove broken "armadillo" board ARM: remove broken "assabet" board ARM: versatile: drop warnings IMX: scb9328: drop warnings MX31: imx31_litekit: make use of GPIO framework MX31: mx31ads: make use of GPIO framework MX5: mx51evk: make use of GPIO framework MX35: mx35pdk: make use of GPIO framework MX5: mx53loco: make use of GPIO framework MX5: mx53evk: make use of GPIO framework MX5: vision2: make use of GPIO framework MX5: mx53smd: make use of GPIO framework MX5: mx53ard: make use of GPIO framework MX25: zmx25: make use of GPIO framework MX5: efikamx: make use of GPIO framework MX31: QONG: make use of GPIO framework MX35: make use of GPIO framework for MX35 processor MX5: make use of GPIO framework for MX5 processor MX31: make use of GPIO framework for MX31 processor MX25: make use of GPIO framework for MX25 processor IMX: uniform GPIO interface using GPIO framework MX: MX35 / MX5: uniform clock command with powerpc MX35: MX35PDK: support additional RAM on CSD1 mx53: ddr3: Update DD3 initialization ARM: MX51: PLL errata workaround ARM: versatilepb : drop warnings due to double definitions omap4: increase SRAM budget to fix build error omap4: fix build warning due to signed unsigned comparison mkimage: Fix 'Unknown OMAP image type - 5' omap: fix gpio related build breaks gpio:samsung: s5p_ suffix add for GPIO functions (C210_universal) SMDKV310: MMC SPL: Remove unwanted dummy functions SMDKV310: Fix undefined reference error SMDKV310: Fix build error for smdkv310 board gpio:samsung s5p_ suffix add for GPIO functions mmc: S5P: Support DMA restarts at buffer boundaries SMDKV310: Fix host compilation of mkv310_image arm: fix bd pointer dereference prior initialization arm, lib/board.c: use gd->ram_size instead of bd->bi_memsize mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF MX31: removed warnings due to clock.h integrator: convert to new build system integratorcp: make the board compile integratorap: remove hardcoded 32MB memory cmdline ...
2011-09-04ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usageJason Jin
Remove the additional linker options for CONFIG_STANDALONE_LOAD_ADDR Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Add mb for 5253 dram initializationJason Jin
The dram initialization sequence should be in order. This patch add mb for the dram intialization code to make sure the compiler do not disorder the code. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Define the DM9000 byteswap for M5253 board.Jason Jin
The M5253DEMO board swapped the io pins which make the standard IO function did not work for dm9000. Define the byte swap to use raw io for dm9000. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Update the env settings for several boards.Jason Jin
Move the environment outside the u-boot for some boards and enlarge the u-boot size in some env settings. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:disable the NFS define for 52277 board.Jason Jin
There is no network device on ColdFire 52277EVB board.But the default cmd include NFS define which make the build error. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Update the timer_init since it was unified.Jason Jin
2011-09-04ColdFire: Cleanup for partial linking and --gc-sectionsJason Jin
Introduce the --gc-sections for ColdFire platform and clean up the corresponding lds file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire: Update compile flags for each CPUsJason Jin
Remove compiler version check for gcc 4.1 in config.mk. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Fix the configuration broken for some boards.Jason Jin
Some typoes in Makefile and boards.cfg make the M54455 board and M53017 board configuration broken. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04beagleboard: enable HUB power on all variants of the BeagleBoardChristian Spielberger
Changes made by Jason Kridner with inputs from Eric Benard to special case xM Rev A and xM Rev B Relevant discussions: http://www.mail-archive.com/u-boot@lists.denx.de/msg59361.html http://www.mail-archive.com/u-boot@lists.denx.de/msg59589.html Signed-off-by: Joel A Fernandes <joelagnel@ti.com> Cc: Eric Benard <eric@eukrea.com> Cc: Christian Spielberger <c.spielberger@bct-electronic.com> Cc: Jason Kridner <jdk@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04dm3730: enable dpll5Eric Benard
which is used to provide 120MHz to USB EHCI This allows EHCI to work on BeagleBoard XM Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04ehci-hcd: Allow cleanups to happen gracefully on a timeout.Joel Fernandes
With this, the EHCI seems to "recover" from a timeout. This is particularly observable if you were to ping the wrong IP Address and then ping the correct one or if there was a temporary failure during tftp sessions. All it takes is one timeout to disable it. If you have a noisy network (lot of traffic), even if the traffic is not for the board, the timeouts don't occur. Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3: Add DSS driver for OMAP3Syed Mohammed Khasim
* Supports dynamic panel configuration * Supports dynamic tv standard selection * Adds support for DSS register access through generic APIs * Incorporated DSS register access using structures. * DSS makefile update Previous discussions are here: http://www.mail-archive.com/u-boot@lists.denx.de/msg27150.html Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: Remove state-saving of led for toggle functionality and add toggle ↵Joel A Fernandes
option to led command * Read the led output state from GPIO instead saving state in memory when it is [re]set * Added a toggle option to the led command Previous discussion: http://lists.denx.de/pipermail/u-boot/2011-May/093068.html Changes since v1: Fixed checkpatch errors Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: Fixed setting of STATUS_LED_BIT1 when led_name is 'all'Joel A Fernandes
Fix for only one led getting set or reset when the led_name is 'all' Previous discussion: http://lists.denx.de/pipermail/u-boot/2011-May/093068.html Changes since v1: Fixed checkpatch if statement error noticed by Sergei. Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: correct off/on locations in structureJason Kridner
Although the initialization should probably be done with names, the existing implementation has these structures filled in the opposite order. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: added cmd_led to MakefileJason Kridner
Addition of cmd_led into the Makefile wasn't included in the patch applied to u-boot-ti. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: fix LED 0/1 in driverJason Kridner
Fixed USR0/USR1 to be LED 0/1 respectively Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04Corrected LED name match finding avoiding extraneous Usage printoutsJason Kridner
2011-09-04BeagleBoard: config: updated default configurationJason Kridner
* Improved boot env var setting * Made room for a 64MB ramdisk by moving from 0x81600000 to 0x81000000 * Added ramarg, ramroot and ramboot env variables Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: Enabled multibus support for I2C in configurationJason Kridner
2011-09-04BeagleBoard: config: add optargs/buddy/cameraJason Kridner
buddy and camera are used to configure peripherals in the kernel at boot time that cannot easily be detected by the kernel. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: increase command-line functionalityJason Kridner
Enable the expression evaluator. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: make mtest runJason Kridner
Utilize the alternate mtest and define a valid region. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: enable DSSKoen Kooi
2011-09-04BeagleBoard: config: enable asix driver and dhcpKoen Kooi
2011-09-04BeagleBoard: config: enable networkingKoen Kooi
2011-09-04BeagleBoard: config: decrease bootdelay to 2 secondsKoen Kooi
2011-09-04BeagleBoard: config: use uImage.beagle for tftpJoel A Fernandes
2011-09-04BeagleBoard: config: hardcode MAC for onboard SMSCJoel A Fernandes
2011-09-04BeagleBoard: config: load kernel from MMC ext, not FATKoen Kooi
2011-09-04BeagleBoard: Configure DVI/S-videoJason Kridner
Based on patches from Syed Mohammed Khasim (khasim@ti.com). Configures the output of the BeagleBoard DVI to be orange. Configures the output of the BeagleBoard S-Video to be a colorbar. Changed display_init to beagle_display_init as suggested by Igor Grinberg: http://www.mail-archive.com/u-boot@lists.denx.de/msg51446.html Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: Added userbutton commandJason Kridner
Based on commit f1099c7c43caf5bac3bf6a65aa266fade4747072 Author: Greg Turner <gregturner@ti.com> Date: Tue May 25 09:19:06 2010 -0500 New u-boot command for status of USER button on BeagleBoard-xM Modified bootcmd to check the staus at boot time and set filename of the boot script. * Moved to a BeagleBoard specific file. * Removed changes to default boot command from adding userbutton command. * Made to handle pre-xM boards. * Flipped polarity of the return value to avoid confusion. Success (0) is when the button is pressed. Failure (1) is when the button is NOT pressed. * Used latest revision getting function. * Used latest macros for board revision. * Added xM-C revision definition (optional, since it was default) * updated default configuration with UserButton functionality * Added a separate bootenv variable to load a user defined .txt file * Added an example, showing how a different environment file can be loaded with the user button pressed Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Cc: Greg Turner <gregturner@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: turn off clocks in ehci_stopKoen Kooi
This fixes display problems in linux Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04USB: Remove __attribute__ ((packed)) for struct ehci_hccr and ehci_hcorJason Kridner
Remove __attribute__ ((packed)) to prevent byte access to soc registers in some gcc versions. Having patches to enable ehci for the BeagleBoard lying around for several months, this one was the show-stopper. Switched to align(4), rather than remove the attribute, per suggestion from Alexander. Credits have to go to Laine Walker-Avina <lwalkera@ieee.org> for finding the problem. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Cc: Alexander Holler <holler@ahsoftware.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04beagleboard: add support for xM revision CKoen Kooi
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
