Fix problems with GCC 3.3.x which changed handling of global
variables explicitly initialized to zero (now in .bss instead of
.data as before).
* Patch by Leon Kukovec, 02 Mar 2004:
add strswab() to fix IDE LBA capacity, firmware and model numbers
on little endian machines
* Patch by Masami Komiya, 02 Mar 2004:
- Remove get_ticks() from NFS code
- Add verification of RPC transaction ID
* Patch by Pierre Aubert, 02 Mar 2004:
cleanup for IDE and USB drivers for MPC5200
Ocotea:
- Add IBM PPC440GX Ref Platform support (Ocotea)
Original code by Paul Reynolds <PaulReynolds@lhsolutions.com>
Adapted to U-Boot and 440GX port
440gx_enet.c:
- Add gracious handling of all Ethernet Pin Selections for 440GX
- Add RGMII selection for Cicada CIS8201 Gigabit PHY
ppc440.h:
- Add needed bit definitions
- Fix formatting
* Patch by Carl Riechers, 1 Mar 2004:
Add PPC440GX prbdv0 divider to fix memory clock calculation.
* Patch by Stephan Linz, 27 Feb 2004
- avoid problems for targets without NFS download support
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA)
- Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF)
- Added support for 64bit strtoul (CFG_64BIT_STRTOUL)
* Patch by Masami Komiya, 27 Feb 2004:
Fix rarpboot: add autoload by NFS
* Patch by Dan Eisenhut, 26 Feb 2004:
fix flash_write return value in saveenv
* Patch by Stephan Linz, 11 Dec 2003
expand config.mk to avoid trigraph warnings on NIOS
* Rename "BMS2003" board into "HMI10"
use redundand environment storage;
auto-set console on USB port (using preboot command)
add support for USB-based console
(enable with "setenv stdout usbtty; setenv stdin usbtty")
* Handle Auti-MDIX / connection status for INCA-IP
* Fix USB problems when attempting to read 0 bytes
Fix broken compile for XPEDITE1K target.
* Patch by Stephan Linz, 26 Feb 2004:
Bug fix for NFS code on NIOS targets
* Patch by Stephen Williams, 26 Feb 2004:
Break up SystemACE reads of large block counts
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
- Timeouts in FPGA code should be based on CFG_HZ
- Minor cleanup in code for Altera FPGA ACEX1K
* Patch by Steven Scholz, 25 Feb 2004:
Changed "Directory Hierarchy" section in README
* Patch by Masami Komiya, 25 Feb 2004:
Reduce copy count in nfs_read_reply() of NFS code
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
Fixes for for OMAP1610 board:
- shift some IRQ specific code to platform.S file
- remove duplicatewatchdog reset code from start.S
* Make Auto-MDIX Support configurable on INCA-IP board
* Fix license for mkimage tool
Update NetBootFileXferSize in NFS code
* Patch by Scott McNutt, 24 Feb 2004:
fix packet length in NFS code
Add support for NFS for file download
* Minor code cleanup
Add support for S3C44B0 processor and DAVE B2 board
* Patch by Steven Scholz, 20 Feb 2004:
- Add support for MII commands on AT91RM9200 boards
- some cleanup in AT91RM9200 ethernet code
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Fix buffer overflow in common/usb.c
* Patch by Tolunay Orkun, 10 Feb 2004:
Add support for Cogent CSB272 board
* Code cleanup
Add support for NET+50 CPU and ModNET50 board
* Patch by Sam Song, 10 Feb 2004:
Fix typos in cfi_flash.c
* Patch by Leon Kukovec, 10 Feb 2004
Fixed long dir entry slot id calculation in get_vfatname
* Patch by Robin Gilks, 10 Feb 2004:
add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==,
* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
o 440GX:
- Fix PCI Indirect access for type 1 config cycles with ppc440.
- Add phymode for 440 enet
- fix pci pre init
o XPedite1K:
- Change board_pre_init to board_early_init_f
- Add user flash to bus controller setup
- Fix pci pre init
- Fix is_pci_host to check GPIO for monarch bit
- Force xpedite1k to pci conventional mode (via #define option)
* Patch by Brad Kemp, 4 Feb 2004:
- handle the machine check that is generated during the PCI scans
on 82xx processors.
- define the registers used in the IMMR by the PCI subsystem.
* Patch by Pierre Aubert, 03 Feb 2004:
cpu/mpc5xxx/start.S: copy MBAR into SPR311
* Patch by Jeff Angielski, 03 Feb 2004:
Fix copy & paste error in cpu/mpc8260/pci.c
* Patch by Reinhard Meyer, 24 Jan 2004:
Fix typo in cpu/mpc5xxx/pci_mpc5200.c
Release version 1.0.2
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
modules at CPU clock frequencies above 66 MHz.
* Optimize flash programming speed for LWMON (by another 100% :-)
- Changed the incorrect FAT12BUFSIZE
- data_begin in fsdata can be negative. Changed it to be short.
* Code cleanup
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
Fix flash protection/locking handling for OMAP1610 innovator board.
* Patch by Rolf Peukert, 28 Jan 2004:
fix flash write problems on CSB226 board (write with 32 bit bus width)
* Patches by Mark Jonas, 16 Jan 2004:
- fix rounding error when calculating baudrates for MPC5200 PSCs
- make sure CFG_RAMBOOT and CFG_LOWBOOT are not enabled at the same
time which is not supported
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
Fix Intel 28F128J3 ID in include/flash.h
* Patch by Masami Komiya, 09 Jan 2004:
add support for TB0229 board (NEC VR4131 MIPS processor)
* Patch by Leon Kukovec, 12 Dec 2003:
changed extern __inline__ into static __inline__ in
include/linux/byteorder/swab.h
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
made CONFIG_SILENT_CONSOLE usable on all architectures
* Disable date command on TQM866M - there is no RTC on MPC866
clock frequency for INCA-IP; fix problem with board hanging when
switching from 150MHz to 100MHz
* Add PCMCIA CS support for BMS2003 board
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
pointing to a location in flash
* Fix INCA-IP clock calculation: 400/3 = 133.3 MHz, not 130.
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
fix problem with PARTNUM detection
version of the repository???]
* Patch by Reinhard Meyer, 09 Jan 2004:
- add RTC support for MPC5200 based boards (requires RTC_XTAL)
* Add support for IDE LED on BMS2003 board
(exclusive with status LED!)
* Add support for PS/2 keyboard (used with PS/2 multiplexor on
BMS2003 board)
* Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004:
Add common files for "emk" boards
Prepare for 1.0.1 release
add I2C support; add support for DS1337 RTC
* Add CompactFlash support for BMS2003 board
* Add support for status LED on BMS2003 board
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
add support for cramfs (uses JFFS2 command interface)
