Tegra's MMC driver does DMA, and hence needs cache-aligned buffers. In
some cases (e.g. user load commands) this cannot be guaranteed by callers
of the MMC APIs. To solve this, modify the Tegra MMC driver to use the
new bounce_buffer_*() APIs.
Note: Ideally, all U-Boot code will always provide address- and size-
aligned buffers, so a bounce buffer will only ever be needed for user-
supplied buffers (e.g. load commands). Ensuring this removes the need
for performance-sucking bounce buffer cache management and memcpy()s.
The one known exception at present is the SCR buffer in sd_change_freq(),
which is only 8 bytes long. Solving this requires enhancing struct
mmc_data to know the difference between buffer size and transferred data
size, or forcing all callers of mmc_send_cmd() to have allocated buffers
using ALLOC_CACHE_ALIGN_BUFFER(), which while true in this case, is not
enforced in any way at present, and so cannot be assumed by the core MMC
code.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The current bouncebuf API requires all parameters to be passed to both
bounce_buffer_start() and bounce_buffer_stop(). Modify the bouncebuf
start function to accept a state structure as a parameter, and only
require that state struct to be passed to the stop function. This
simplifies usage of the bounce buffer by clients.
Don't modify the data pointer, but rather store the temporary buffer in
this state struct. The bouncebuf code ensures that client code can
always use a single buffer pointer in the state structure, irrespective
of whether a bounce buffer actually had to be allocated.
Move cache management logic into the bounce buffer code, so that each
client doesn't have to duplicate this. I believe there's no need to
invalidate the buffer before a DMA operation, since flushing the cache
should prevent any write-backs.
Update the MXS MMC driver for this change.
If any driver ever needs to use the bounce buffer API, it always needs
to use it. As such, providing a dummy implementation of those APIs when
CONFIG_BOUNCE_BUFFER isn't defined does not make sense. Remove the dummy
implementation.
Commits 6dc71c8 "MMC: MXS: Toggle the generic bounce buffer on the
boards" and 49a627f "MMC: Remove the MMC bounce buffer" replaced
CONFIG_MMC_BOUNCE_BUFFER with CONFIG_BOUNCE_BUFFER, but missed
converting a few boards over to the new option. Fix this.
Bring in the code from Linux kernel.
Added to Linux kernel by:
commit e08c1694d9e2138204f2b79b73f0f159074ce2f5
Author: Andres Salomon <dilinger@queued.net>
Date: Fri Jul 4 10:00:03 2008 -0700
Some HW balks when writing both voltage setting and power up at the same
time to SDHCI_POWER_CONTROL register.
Signed-off-by: Rommel G Custodio <sessyargc@gmail.com>
CC: Andy Fleming <afleming@freescale.com>
v2: fix attribution and SOB
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
The interpretation of the data returned by the MMC_CMD_ALL_SEND_CID
command was incorrect with respect to the JEDEC Standard No. 84-A441.
This change makes the interpretation correct with respect to the
defined fields of the CID register.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Support DesignWare MMC Controller for Samsung Specific.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Rajeshawari Shinde <rajeshwari.s@samsung.com>
usbdescriptors.h conflicts with linux/usb/ch9.h
Remove it.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
This patch adds a NAND Flash torture feature, which is useful as a block stress
test to determine if a block is still good and reliable (or should be marked as
bad), e.g. after a write error.
This code is ported from mtd-utils' lib/libmtd.c.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Scott Wood <scottwood@freescale.com>
[scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings]
NAND Flash is erased by blocks, not by pages.
This patch cleans up nand_util.c:
- Fix tabs.
- Fix typos.
- Remove space character before opening parenthesis in function calls.
- Fix comments.
Use a flag instead of a hard-coded macro so that sub-page reads can be
enabled in other cases (such as on-die ecc).
This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux
IFC-1.1.0 uses 28nm techenology for SRAM. This tech has known limitaion for
SRAM i.e. "byte select" is not supported. Hence Read Modify Write is
implemented in IFC for any "system side write" into sram buffer. Reading an
uninitialized memory results in ECC Error from sram wrapper.
Hence we must initialize/prefill SRAM buffer by any data before writing
anything in SRAM from system side. To initialize SRAM user can use "READID"
NAND command with read bytes equal to SRAM size. It will be a one time
activity post boot
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
[scottwood@freescale.com: fix fsl_ifc_sram_init prototype]
Reference nand monitor commands in U-Boot README
Signed-off-by: Karl O. Pinc <kop@meme.com>
These controllers can only do hardware ECC on full page transfers.
This allows DDR configuration to be deferred to the final U-Boot image,
which is able to make use of SPD data. The SPL itself cannot use SPD due
to code size constraints. It previously used fixed register values for
DDR configuration, and those values did not work on the p2020rdb-pca
board I tested with. It's possible that different revisions of the board
require different settings. Using SPD eliminates that problem.
Cc: Andy Fleming <afleming@freescale.com>
- Sort by address, and fix column alignment
- Don't label things as localbus that aren't. Instead, put chipselect
info at the end of the description for localbus windows. Note that
NAND/NOR have their chipselects swapped when booting from NAND, and CS2
can be either PMC or VSC7385 depending on hwconfig.
- Shrink NAND to the 32K that's actually mapped in the localbus
- Assign an address and size to L2 SRAM. Remove the similarly named
but unintelligible "L2 SDRAM(REV.)".
- Remove the untrue comment about L1 stack being mapped with TLB0.
Document parameters used for specifying the NAND image to be loaded.
Also fix the definition of CONFIG_SPL_NAND_SIMPLE -- it's only
nand_spl_simple.c, not the entire nand directory. The word "simple" is
there for a reason. :-)
v2: updated for makefile changes earlier in patchset
Some small SPLs do not use nand_base.c, and a subset of those also
require a special driver. Some SPLs need software ECC but others can't
fit it.
All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these
symbols added to preserve existing behavior.
v2: use positive logic for including bits of NAND, rather than
a MINIMAL symbol that excludes things.
Introduces CONFIG_SPL_RELOC_TEXT_BASE and CONFIG_SPL_RELOC_STACK.
Update CONFIG_RAMBOOT and CONFIG_NAND_SPL references to accept CONFIG_SPL
and CONFIG_SPL_BUILD, respectively. CONFIG_NAND_SPL can be removed once
the last mpc85xx nand_spl target is gone.
CONFIG_RAMBOOT will need to remain for other use cases, but it doesn't
seem right to overload it for meaning SPL as well as nand_spl does. Even
if it's somewhat appropriate for the main u-boot, the SPL itself isn't
(necessarily) ramboot, and we don't have separate configs for SPL and
main u-boot. It was also inconsistent, as other platforms such as
mpc83xx didn't use CONFIG_RAMBOOT in this way.
cpu_init_nand.c is renamed to spl_minimal.c as it is not really NAND-specific.
v2: factor out START, and change cpu_init_nand.c to spl_minimal.c
A subsequent patch will conditionalize some of the files that are
currently unconditional.
There is nothing really NAND-specific about this file.
The toplevel makefile hardcodes this stuff, so spl/Makefile needs to as well.
It applies to non-Freescale 85xx boards as well as Freescale boards,
so it doesn't belong in board/freescale. Plus, it needs to come out
of nand_spl if it's to be used by the new SPL.
It's arch code and not a driver, so move it where it belongs. When it
originally went into drivers/misc there was no 8xxx CPU directory.
This will make new-SPL support a little easier since we can keep the CPU
stuff together and not need to pull stuff in from drivers/misc.
In the RAMBOOT/SPL case we were creating a TLB entry starting at
CONFIG_SYS_MONITOR_BASE, and just hoping that the base was properly
aligned for the TLB entry size. This turned out to not be the case
with NAND SPL because the main U-Boot starts at an offset into the image
in order to skip the SPL itself.
Fix the TLB entry to always start at a proper alignment. We still assume that
CONFIG_SYS_MONITOR_BASE doesn't start immediately before a large-page boundary
thus requiring multiple TLB entries.
Signed-off-by: Scott Wood <scottwood@frescale.com>
This was introduced by commit 244615197469dd6fe75ae082f38424b97c79aeaf, but it
fails in a minimal SPL build where the only thing in arch/powerpc/lib is
cache.c, which apparently doesn't generate any fixup records.
The problem is reported to occur with GCC 3.x, so insist on GCC 4.0 or newer.
Patterned after checkthumb as suggested by Tom Rini.
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Tom Rini <trini@ti.com>
v2: test gcc version instead of testing nothing
Currently the SPL target is specified in a CPU-specific makefile
fragment. While some targets may need something more complicated than a
simple target name, targets which don't need this shouldn't have to provide a makefile fragment just for this.
v2: Removed default target as it's been pointed out to me how existing platforms
cause the SPL to be built.
Samsung's S3C24XX SoCs need this in order to generate a binary image
with a padded SPL concatenated with U-Boot.
Signed-off-by: José Miguel Gonçalves <jose.goncalves@inov.pt>
[scottwood@freescale.com: fixed prereq of u-boot.ubl]
v2: Removed spl/ prefix from u-boot.ubl prerequisite.
Now outputs like this:
L2: 512 KB already enabled, moving to 0xf8f80000
rather than this:
L2: 512 KB already enabledmoving to 0xf8f80000
Cc: Andy Fleming <afleming@gmail.com>
Previously, in many if not all configs we were creating overlapping TLB entries
which is illegal. This caused a crash during boot when moving p2020rdb NAND SPL
into L2 SRAM.
Cc: Prabhakar Kushwaha <prabhakar@freescale.com>
Prabhakar, please test that debug still works.
TEMT is set when the transmitter is totally empty and all output has
finished.
This prevents output problems (including a loss of synchronization
observed on p2020 that persisted for quite a while) if SPL has output
still on its way out.
v2: fixed typo in subject, and explained what the bit does in the changelog
CONFIG_NS16550_MIN_FUNCTIONS is used by small SPLs to gain access to basic
ns16550 output code without pulling in things not needed by the SPL.
This previously only worked with non-MULTI configs. Recently MULTI was
made mandatory, and MIN_FUNCTIONS fails like this:
drivers/serial/libserial.o: In function `calc_divisor.clone.0':
serial_ns16550.c:(.text.calc_divisor.clone.0+0x24): undefined reference to `get_bus_freq'
drivers/serial/libserial.o: In function `_serial_getc':
(.text._serial_getc+0x30): undefined reference to `NS16550_getc'
drivers/serial/libserial.o: In function `_serial_tstc':
(.text._serial_tstc+0x30): undefined reference to `NS16550_tstc'
drivers/serial/libserial.o: In function `_serial_setbrg':
(.text._serial_setbrg+0x3c): undefined reference to `NS16550_reinit'
make[1]: *** [/tmp/u-boot/spl/u-boot-spl] Error 1
make: *** [/tmp/u-boot/spl/u-boot-spl.bin] Error 2
With MIN_FUNCTIONS we don't need anything from this file, so don't build
it. The conditional needs to be in the file itself rather than the
makefile, because the config symbols are only imported to the makefiles
once, not separately for the SPL phase of the build.
By commit c7e3b2b5, this was chanded to support multiple controllers.
But this has missing of parenthesis. This commit fix it.
r8a66597-hcd.c: In function ‘usb_lowlevel_init’:
r8a66597-hcd.c:911:52: error: expected declaration specifiers before ‘)’
token
r8a66597-hcd.c:935:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or‘__attribute__’ before ‘{’ token
r8a66597-hcd.c:939:1: error: expected ‘{’ at end of input
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Lucas Stach <dev@lynxeye.de>
Some variables are initialized with a value defined by macro.
This was changed to use the macro directly. And the variable not to
use deleted it.
Enable using of new MUSB framework on Beagle.
NOTE! This is not just a change of backend code: top-level behavior
is also changed, we now use USB device port for USB Ethernet instead
of serial.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Add initialization for new MUSB framework.
Backend driver for MUSB OTG controllers found on TI OMAP2/3/4
(tested only on OMAP3 Beagle).
Use new musb framework instead of the old one on AM3517_EVM.
AM35XX specific functions for integrated USB PHY/MUSB IP.
Add defines for MUSB IP block on AM35X SoCs.
Backend driver for MUSB OTG controllers found on TI AM35x.
It seems that on AM35X interrupt status registers can be updated
_before_ core registers. As we don't use true interrupts in U-Boot
and poll interrupt status registers instead this can result in
interrupt handler being called with non-updated core registers.
This confuses the code and result in hanged transfers.
Add a small delay in am35x_interrupt as a workaround.
