This board has been orphaned for more than 6 months.
It is the last board defining CONFIG_APM821XX.
The code inside #ifdef CONFIG_APM821XX should be removed too.
These boards have been orphaned for more than 6 months.
In some cases, the last lines of SPL or TPL are not output to a file.
The entries remaining in the "unmatched" variable must be flushed.
The definitions for div ratio supposed to be in hex and were added
in dec by mistake.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
At least on OMAP, init_sata() no longer performs scsi_scan()
so we must do it explicitly here.
Cc: Dan Murphy <dmurphy@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
scsi_scan() must be called as part of scsi_init() and not
as part of sata_init().
On OMAP platforms, SATA controller provides the SCSI subsystem
so implement scsi_init().
Get rid of the unnecessary sata_init() call from dra7xx-evm
and omap5-uevm board files.
The DMA/FIS buffers are set in ahci_port_start() which is called
after ahci_host_init(). So don't start the DMA engine here
(i.e. don't set FIS_RX)
This fixes the following error at kernel boot on OMAP platforms (e.g. DRA7x)
WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x260/0x358()
44000000.ocp:L3 Custom Error: MASTER SATA TARGET GPMC (Idle): Data Access in User mode during Functional access
Commit 12cc54376768461533b55ada1b0b6d4979f40579 'omap3: overo: Select
fdtfile for expansion board' wrongly missed the operator in the fdtfile
test. Update the test to only overwrite an empty fdtfile environment
variable.
Signed-off-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net>
Commit 294b91a5817147d4b7f47be2ac69bac2a1f26491 moved initr_malloc
earlier than initr_unlock_ram_in_cache. This causes issue on T4240.
It may be related to locked L1 d-cache and unlocked L2 cache. D-
cache could and should be unlock earlier for normal operation.
This patch moves initr_unlock_ram_in_cache before initr_malloc. It
has been verified on the following boards, in which only T4240QDS
suffered and has been since fixed: T4240QDS, T2080QDS, P5040DS,
P4080DS, MPC8572DS, MPC8536DS, MPC8641HPCN, B4860QDS.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
CC: Simon Glass <sjg@chromium.org>
On a couple of platforms I've tripped over long PXE append lines overflowing
this array, due to having CONFIG_SYS_CBSIZE == 256. When doing preseeded Debian
installs it's pretty trivial to exceed that.
Since the symptom can be a silent hang or a crash add a check. Of course the
affected boards would also need an increased CBSIZE to actually work.
Note that due to the printing of the final bootargs string CONFIG_SYS_PBSIZE
also needs to be sufficiently large.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
[trini: Use %zd not %d in printf for all args]
In order for the gmac nic to work reliable on the Bananapi, we need to set
bits 10-12 GTXDC "GMAC Transmit Clock Delay Chain" of the GMAC clk register
(0x01c20164) to 3.
Without this about 9 out of 10 ethernet packets get lost, with this setting
there is no packet loss.
So far setting these bits is only necessary on the Bananapi, so this commit
solves this with a bit of #ifdef CONFIG_BANANAPI code. If in the future we
need to do something similar for other boards, we can create a specific
CONFIG_FOO option for this then.
Reported-by: Karsten Merker <merker@debian.org>
Tested-by: Karsten Merker <merker@debian.org>
Tested-by: Zoltan HERPAI <wigyori@openwrt.org>
Tested-by: Tony Zhang <tony.zhang@lemaker.org>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Removed settings in unsupported register fields. They didn’t
do anything, and in most cases, were not documented in the
reference manual.
Changed register settings to comply with JEDEC required values.
Changed timing parameters because they included full clock
periods that were doing nothing.
Signed-off-by: Anthony Felice <tony.felice@timesys.com>
[rebased on v2014.10-rc2]
Signed-off-by: Stefan Agner <stefan@agner.ch>
Fix a trivial conflict in dw_mmc.c after talking with Marek.
drivers/mmc/dw_mmc.c
Without NULL termination, various commands will read past the
end of input. In particular, this was noticed with error()
calls in cb_getvar and simple_strtoul() in cb_download.
Since the download callback happens elsewhere, the 4k buffer
should always be sufficient to handle command arguments.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
This bit allows the MUSB controller to negotiate for high-speed mode when
the device is reset by the hub. If unset, Babble errors occur with
high-speed mass storage devices right after the first packet. This condition
is not caught by the interrupt handles in U-Boot, so no recovery is done,
and the USB communication is stuck.
To fix this, set the bit unconditionally, not only for
CONFIG_USB_GADGET_DUALSPEED but also for host-only modes.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Enable and use the CONFIG_CMD_FS_GENERIC to avoid hard-coding the
filesystem type into the environment.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Cc: Pavel Machek <pavel@denx.de>
Acked-by: Pavel Machek <pavel@denx.de>
Split the SoCFPGA configuration into SoC-specific part which is
common for all boards (socfpga_cyclone5_common.h) and a board
specific part. There is currently only one board, which is the
generic SoCFPGA board (socfpga_cyclone5.h), but there are more
to come.
This is necessary due to various features of the boards, which
unfortunatelly cannot be autodetected.
Reorganize and cleanup the configuration file for SoCFPGA. There
is no functional change after this cleanup. This was necessary,
since the file was a wild mess and it was impossible to make sense
of it's content, let alone change something without breaking some
other thing. This patch puts the contents on par with regular U-Boot
standards.
Also remove unused preprocessor symbols CONFIG_SINGLE_BOOTOADER
and CONFIG_USE_IRQ, which is undefined by default. Finally, do
logical reordering of the defines in the file so it's much more
readable. The reordering was also necessary for the splitting
as the initial one was messy.
Add command to enable and disable the bridges between HPS and FPGA.
This patch does have a checkpatch issue with the assembler portion,
checkpatch correctly complains that there should be no whitespace
before quoted newline. I do not agree that fixing this specific
checkpatch issue will improve the readability, thus this one is not
addressed.
Move icache_enable() and dcache_enable() function calls from
board code into the CPU code and into the enable_caches()
function. This is how the cache enabling code was designed
to work.
Enable the SDMMC boot as default boot for SOCFPGA U-Boot dev kit.
Enable the bootz command as zImage is used instead uImage.
Signed-off-by: Chin Liang See <clsee@altera.com>
Enable the DesignWare MMC controller driver support
for SOCFPGA Cyclone5 dev kit
Add code which configures the AMBA NIC-301 and the SCU on the SoCFPGA .
The code sets the access permissions for the CPU to the AMBA slaves such
that the CPU can access them in both secure and non-secure mode.
Configure the PL310 address filter to make sure DRAM is mapped to 0x0.
This code also configures the "remap" register of NIC-301 and sets the
required 'mpuzero' bit.
Add register definition for the NIC-301 used on SoCFPGA.
Add the Snoop Control Unit register definition file.
Enable the PL310 L2 cache controller support for the SoCFPGA.
With the cache related issues resolved, this is safe to be done.
The code is now fixed to the point where we can safely enable
the L1 data cache. Enable the D-Cache and set it as write-alloc.
The Cortex-A9 has 32-byte long L1 cachelines. Define this value.
Add missing system manager bits from Altera U-Boot to make the code
comparable. These are the bits which depend on the FPGA manager.
Add function to enable and disable FPGA bridges. This code is used
by the FPGA manager to disable the bridges before programming the
FPGA and will later be also used by the initialization code for the
chip to put the chip into well defined state during startup.
Add code necessary to program the FPGA part of SoCFPGA from U-Boot
with an RBF blob. This patch also integrates the code into the
FPGA driver framework in U-Boot so it can be used via the 'fpga'
command.
Signed-off-by: Pavel Machek <pavel@denx.de>
V2: Move the not-CPU specific stuff into drivers/fpga/ and base
this on the cleaned up altera FPGA support.
Cosmetic change to the checkboard() function output. Align the
output with the rest of initial output produced by U-Boot.
The bi_boot_params must point to offset 0x100 in DRAM. Make it so.
Cosmetic change to the print_cpuinfo() function output. Align the
Add CPU function to register and initialize the dw_mmc SD controller.
This allows us to use the HPS SDMMC block.
Add function to initialize the EMAC blocks upon board startup.
The preprocessor guards against building on SoCFPGA-VT and against
SPL build are not needed as those are handled implicitly via both
SPL framework and the socfpga_cyclone5.h config file, which will
not define CONFIG_DESIGNWARE_ETH if building for SoCFPGA-VT.
We cannot handle two EMAC ethernet blocks yet, therefore the ifdefs.
Once there is hardware using both EMAC blocks, this ifdef will have
to go.
Add functions to reset the EMAC ethernet blocks. We cannot handle
two EMAC ethernet blocks yet, therefore the ifdefs. Once there is
hardware using both EMAC blocks, this ifdef will have to go.
The timer reload value is a property of the timer hardware and there
is no reason for this to be configurable. Place this into the timer
driver just like on the other hardware.
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Make the SoCFPGA MMC stub pick clock via the clock manager
frequency accessors instead of hard-coding the frequency.
Also fix calloc() misuse.
Add the missing pieces from the reference clock code from Altera. This
puts the code on par with the Altera U-Boot fork for all but the SDRAM
self-refresh bits, which are not part of this patch.
Clean up the clock code definitions so they are aligned with mainline
standards. There are no functional changes in this patch.
Pull out functions to read frequency of Main clock VCO and
PLL clock VCO as the code is duplicated multiple times.
Add the entire bulk of code to read out clock configuration from the SoCFPGA
CPU registers. This is important for MMC, QSPI and UART drivers as otherwise
they cannot determine the frequency of their upstream clock.
V2: Fixed the L4 MP clock divider and synced the clock code with latest
rocketboards codebase (thanks Dinh for pointing this out)
