Fix data size.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
SH did not support do_bdinfo fuction.
This code based avr32 stuff.
Fix data size.
Fix data size.
Fix data size.
Fix data size.
Fix data size.
Fix data size.
Update data address size and fix typo of register.
This patch updates the mach-types.h based on the latest linux kernel
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
I have "ported" U-boot to a in house made board with Numonyx Axcell P33/P30
256-Mbit 65nm flash chips.
After some time :( searching for bugs in our board or soft, we have
discovered that those chips have a small but annoying bug, documented in
"Numonyx Axcell P33/P30 256-Mbit Specification Update"
It states :
When customer uses [...] block unlock, the block lock status might be
altered inadvertently. Lock status might be set to either 01h or 03h
unexpectedly (00h as expected data), which leads to program/erase failure
on certain blocks.
A working workaround is given, which I have applied and tested with success :
Workaround: If the interval between 60h and its subsequent command
can be guaranteed within 20us, Option I is recommended,
otherwise Option II (involves hardware) should be selected.
Option I: The table below lists the detail command sequences:
Command
Data bus Address bus Remarks
Sequence
1 90h Block Address
Read Lock Status
2 Read Block Address + 02h
(2)(3) (1)
3 60h Block Address
(2)(3) (1) Lock/Unlock/RCR Configuration
4 D0h/01h/03h Block Address
Notes:
(1) Block Address refers to RCR configuration data only when the 60h
command sequence is used to set RCR register combined with 03h
subsequent command.
(2) For the third and fourth command sequences, the Block Address must
be the same.
(3) The interval between 60h command and its subsequent D0h/01h/2Fh/03h
commands should be less than 20us.
And here is a log comparison of a simple (destructive) flash test without
and with the workaround.
diff without-numonyx-workaround.log with-numonyx-workaround.log
-U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:07:47)
+U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:25:19)
CPU: Freescale MCF5484
CPU CLK 200 MHz BUS CLK 100 MHz
Board: Macq Electronique ME2060
I2C: ready
DRAM: 64 MiB
FLASH: 32 MiB
In: serial
Out: serial
Err: serial
Net: FEC0, FEC1
-> flinfo
Bank # 1: CFI conformant FLASH (16 x 16) Size: 32 MB in 259 Sectors
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x8922
Erase timeout: 4096 ms, write timeout: 1 ms
Buffer write timeout: 5 ms, buffer size: 1024 bytes
Sector Start Addresses:
FE000000 RO FE008000 RO FE010000 RO FE018000 RO FE020000 RO
FE040000 RO FE060000 RO FE080000 RO FE0A0000 RO FE0C0000 RO
FFF80000 RO FFFA0000 RO FFFC0000 RO FFFE0000 RO
-> protect off all
Un-Protect Flash Bank # 1
................... done
-> erase all
Erase Flash Bank # 1
-> cp.b 1000000 fe000000 2000000
-Copy to Flash... Flash not Erased
+Copy to Flash... done
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
This patch does the following:
- Extract code to detect if sector is erased into function
sector_erased().
- Because of this, we don't have variable declarations inside the
sector loop in flash_print_info()
- Change "return" to "break" in the "if (ctrlc()) statement:
This fixes a problem with the resulting output. Before this
patch the output was:
FC000000 FC020000 FC040000 =>
With this patch it is now:
Cc: Kim Phillips <kim.phillips@freescale.com>
Fix reading and printing of CFI flashes 16-bit devices identifiers
Nowadays CFI flashes have a 16-bit device identifier. U-boot still
print them and read them as if they were only 8-bit wide. Fix that.
Before:
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x1B
After:
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x881B
flashes getting larger, users more impatient.
Currently, if there is an error probing the NAND chip and the env is based
in NAND, the readenv() function will use a NULL function pointer and thus
jump to address 0.
Here I just check for a non-zero value of blocksize as that shouldn't be
zero when a valid device is found, but perhaps there is a better way for
someone familiar with the NAND internals to suggest.
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
The "usb help" doesn't format the output correctly:
=> help usb
usb - USB sub-system
Usage:
usb reset - reset (rescan) USB controller
usb stop [f] - stop USB [f]=force stop
usb tree - show USB device tree
usb info [dev] - show available USB devices
usb storage - show details of USB storage devices
usb dev [dev] - show or set current USB storage device
usb part [dev] - print partition table of one or all USB storage devices
usb read addr blk# cnt - read `cnt' blocks starting at block `blk#'
to memory address `addr'usb write addr blk# cnt - write `cnt'
blocks starting at block `blk#' from memory address `addr'
With fix below applied, the output is correct:
=> help usb
Usage:
usb write addr blk# cnt - write `cnt' blocks starting at block `blk#'
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Enabling USB HOST in defconfig.
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
AM35x supports only 32bit read operations so we need to have
workaround for 8bit and 16bit read operations.
Tested MSC Host on AM3517EVM.
Adding general register structure of system control module (SCM)
of AM35x. This would be required to access devconf2 and ip_sw_reset
register in musb module.
The bi_cpu field of the board data is already set to the relevant cpu
string, so there is no need for us to use the define directly.
Recent features enabled by default require a larger monitor size for the
cm-bf548 port, so bump it up a bit.
In case there is no frame buffer driver present in Linux to hand over the
PPI LCD DMA upon boot, the DMA initiated by u-boot to display the splash
screen runs unattended. Therefore always stop the video driver in u-boot
before starting Linux. If people don't want this behavior, then they can
simply stub out the video_stop() function in their board video driver.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Before:
Marvell>> usb storage
Device 0: Vendor: StoreJet Rev: Prod: Transcend
Type: Hard Disk
Capacity: 28759.9 MB = 28.0 GB (488397168 x 512)
After:
Type: Hard Disk
Capacity: 238475.1 MB = 232.8 GB (488397168 x 512)
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Turn all ORION5X_DEF{ADR,SZ}_xxx macros into ORION5X_{ADR,SZ}_xxx
and allow defining them from board code to override defaults. This
is particularly useful for defining board-specific FLASH address
and size in board header file rather than having to tweak orion5x
code.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
get_timer_masked() should return current timestamp,
not current ticks from hardware register.
Tested on one custom board with NAND flash.
Without this patch, NAND write always TIMEOUT
because get_timer(0) return a big value.
This patch applies for u-boot-2010.06
Signed-off-by: Li Haibo <hbli@sinocastel.com>
Remove warning for missing " at the end of line 136
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls
to take a (const char *) parameter instead of (char *), but in some cases
the modified functions call other functions taking (char *). The end result
is warnings about discarding the const qualifier.
This patch fixes these other function signatures.
For code that uses miiphy_{read,write}, every call invokes a full look up
of the mii list. There is already a "current_mii" cache that is used by
some code, but have the miiphy_{read,write} function use it as well. This
does increase the code size slightly, but I think it's worth it.
Rather than have every func re-implement the list walking code, do it one
local function. This shrinks the resulting object code a little while
making the source much more manageable.
The driver name does not need to be writable, so constify it.
continuation of commit 2ecc2262d66a286e3aac79005bcb5f461312dea8
"net ppc: fix ethernet device names with spaces" (currently in
u-boot-net.git) for QE based parts.
Acked-by: Dave Liu <daveliu@freescale.com>
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names
with spaces drop a
Warning: eth device name has a space!
message. This patch fix it for:
- "FEC ETHERNET" devices found on
mpc512x, mpc5xxx, mpc8xx and mpc8220 boards.
renamed to "FEC".
- "SCC ETHERNET" devices found on
mpc8xx, mpc82xx based boards. Renamed to "SCC".
- "HDLC ETHERNET" devices found on mpc8xx boards
Renamed to "HDLC"
- "FCC ETHERNET" devices found on mpc8260 and mpc85xx based
boards. Renamed to "FCC"
Tested on the kup4k board.
After discussion on the ML it is suggested to drop unrequired
and not useful characters from the device name.
This patch changes the name for the fec_mxc driver from
"FEC_MXC" to "FEC".
This patch has the following fixes/changes:
- Set 'kernel_addr' and 'ramdisk_addr' to correct values and add
'fdt_addr' environment variable
- Remove 'kozio' environment variable
- Remove environmant variables to boot ancient arch/ppc Linux kernels
- Remove CONFIG_SYS_BOOTMAPSZ definition. It's already defined to
the same value in amcc-common.h
Update image size after addition of new environment handling.
Update image size and default environment
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
None of the AMCC boards uses an embedded environment, so there is no
need to run "saveenv" after updating U-Boot. Drop the redundant
commands from the default environment.
