- update clock settings for higher perfomance
- change standard baud rate to 115200
- fix flash base address
- remove unused defines
- add I2C support
- switch form board dependent flash to cfi
- remove board dependent flash code
- use sdram bank 0 instead of bank 1 on boot
- enable on board frame buffer instead external
- remove fake mac address form config
- add watchdog support
- add status led support
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
[agust: fixed small style issues and build warning]
PMIC framework
Move pmic_init() function call from board_init() to power_init_board()
to work with new PMIC/POWER framework.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Rename CONFIG_DIALOG_PMIC to CONFIG_DIALOG_POWER
Rename all CONFIG_PMIC* defines to CONFIG_POWER*
Rename pmic/power related files at ./drivers/power directory
Two extra commands:
"pmic name bat state" and "pmic name bat charge" has been added to
pmic framework. Those provides state display and charge capabilities
to named batteries.
The pmic_core.c file has been refactored to more consistent name scheme.
The battery connected to Samsung's Trats development board is now
charged when voltage drops below threshold.
When charging battery is necessary, the development board needs to
be turned into low power mode for better efficiency.
Support for MAX8997 built-in charger.
Support for TRATS battery has been added. It is treated as a "normal"
power related device and thereof controlled by pmic/power subsystem.
FG IC built into the MAX8997 device (compliant to MAX17042) is enabled
at TRATS.
MUIC IC built into the MAX8997 device is enabled at TRATS.
Default PMIC (MAX8997) initialization for Samsung's TRATS development board.
Function for calculating LDO internal register value from passed micro
Volt.
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997
power management device.
Special file - fg_battery_cell_params.h with cells characteristics
added.
The FG device will work with redesigned PMIC framework.
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997
The MUIC device will work with redesigned PMIC framework.
Trats battery is now treated in the same way as other power related
devices. This approach allows for more unified handling of all devices
responsible for power management.
Now it is possible to provide specific function per PMIC/power
device instance.
The PMIC framework has been moved to its more natural place
./drivers/power from ./drivers/misc directory.
New power_chrg.h file has been added to "bind" together common
information about charging battery available in the system.
Enable support for power_board_init() method at TRATS board.
It is necessary to introduce a new system wide function- power_init_board()
It turns out, that power initialization must be done as early as possible.
In the case of PMIC framework redesign, which aims to support multiple
instances of PMIC devices the initialization shall be performed just
after malloc configuration.
The power_init_board function is a weak function with default implementation.
The PMIC framework has been extended to support multiple instances of
the variety of devices responsible for power management.
This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB
Interface Circuit).
Power related includes have been moved to ./include/power directory.
This is a first of a series of patches - in the future "pmic" will be
replaced with "power".
Two important issues:
1. The PMIC needs to be initialized just after malloc is configured
2. It uses list to hold information about available PMIC devices
PMIC MAX8997 is now ready to work with single and multibus soft I2C
implementation.
Since the pmic_reg_read is the u32 value, the order in which bytes
are placed to form u32 value is important.
Support for big and little sensor endianess is added.
Moreover calls to [leXX|beXX]_to_cpu have been added to support
little and big endian SoCs.
This patch adds support for proper handling of a PMIC I2C transmission
comprising of two bytes.
Commit 97b24d3d51a92cb8c0c1e1a74abf22fe1a1807a3 "common: Add symbol
handling for generic lists into Makefile" introduced build errors in many
nand_spl targets, complaining of a missing u-boot.lst. When not doing an
out-of-tree build, $(obj) expands to nothing, so GCC ended up being given
-I with no argument (or rather, -ansi was the argument). The failure
didn't show up during a -j1 build because it was picking up the non-SPL
version of u-boot.lst.
Often a particular patch may change only for some versions of a series.
For versions where there is no change, issue a change log indicating
that (for example 'Changes in v4: None').
For such lines, don't add a blank line afterwards, to conserve space.
Use list.insert() instead of list = [item] + list.
Tested-by: Stefan Roese <sr@denx.de>
When using SUBLEVEL for the -rc? tag, this results in an ugly version
string like "2013.01.-rc1" - let's use EXTRAVERSION instead to get the
simple "2013.01-rc1"
The BRANCH= tag can be used to indicate the destination branch for a
commit. Ignore this tag.
Also ignore the gerrit 'Commit-Ready:' tag.
The gadget ethernet driver needs to keep copies of the MAC address (at
both endpoints) as strings so it needs a custom function for validation
of the MAC. It was not however performing a totally correct check and
also was emitting a warning about a set but unused variable. The
solution to both is that after checking the string contents we use the
standard test for a valid MAC.
nand_ecc.c:82:5: warning: symbol 'nand_calculate_ecc' was not declared. Should it be static?
nand_ecc.c:155:5: warning: symbol 'nand_correct_data' was not declared. Should it be static?
nand_base.c:2854:1: error: directive in argument list
nand_base.c:2856:1: error: directive in argument list
Acked-by: Scott Wood <scottwood@freescale.com>
cfi_flash.c:756:43: warning: Using plain integer as NULL pointer
cfi_flash.c:1150:52: warning: cast to non-scalar
cfi_flash.c:1433:46: warning: cast truncates bits from constant value (890089 becomes 89)
cfi_flash.c:1490:61: warning: cast truncates bits from constant value (1f001f becomes 1f)
cfi_flash.c:1508:61: warning: cast truncates bits from constant value (10001 becomes 1)
cfi_flash.c:1738:63: warning: cast truncates bits from constant value (10001 becomes 1)
cfi_flash.c:1857:6: warning: symbol '__flash_cmd_reset' was not declared. Should it be static?
fsl_esdhc.c:71:6: warning: symbol 'esdhc_xfertyp' was not declared. Should it be static?
fsl_esdhc.c:413:6: warning: symbol 'set_sysctl' was not declared. Should it be st
mmc.c:137:5: warning: symbol 'mmc_send_cmd' was not declared. Should it be static?
mmc.c:203:5: warning: symbol 'mmc_send_status' was not declared. Should it be static?
mmc.c:247:5: warning: symbol 'mmc_set_blocklen' was not declared. Should it be static?
mmc.c:440:5: warning: symbol 'mmc_read_blocks' was not declared. Should it be static?
mmc.c:510:5: warning: symbol 'mmc_go_idle' was not declared. Should it be static?
mmc.c:532:1: warning: symbol 'sd_send_op_cond' was not declared. Should it be static?
mmc.c:597:5: warning: symbol 'mmc_send_op_cond' was not declared. Should it be static?
mmc.c:661:5: warning: symbol 'mmc_send_ext_csd' was not declared. Should it be static?
mmc.c:683:5: warning: symbol 'mmc_switch' was not declared. Should it be static?
mmc.c:705:5: warning: symbol 'mmc_change_freq' was not declared. Should it be static?
mmc.c:775:5: warning: symbol 'sd_switch' was not declared. Should it be static?
mmc.c:796:5: warning: symbol 'sd_change_freq' was not declared. Should it be static?
mmc.c:935:6: warning: symbol 'mmc_set_ios' was not declared. Should it be static?
mmc.c:953:6: warning: symbol 'mmc_set_bus_width' was not declared. Should it be static?
mmc.c:1108:26: warning: dubious: !x & y
mmc.c:960:5: warning: symbol 'mmc_startup' was not declared. Should it be static?
mmc.c:1243:5: warning: symbol 'mmc_send_if_cond' was not declared. Should it be s
input.c:97:5: warning: symbol 'input_queue_ascii' was not declared. Should it be
mpc83xx_gpio.c:166:26: warning: non-ANSI function declaration of function 'mpc83xx_gpio_init_f'
mpc83xx_gpio.c:190:26: warning: non-ANSI function declaration of function 'mpc83xx_gpio_init_r'
sata_sil.c:371:7: warning: symbol 'sil_sata_rw_lba28' was not declared. Should it be static?
sata_sil.c:399:7: warning: symbol 'sil_sata_rw_lba48' was not declared. Should it be static?
sata_sil.c:429:6: warning: symbol 'sil_sata_cmd_flush_cache' was not declared. Should it be static?
sata_sil.c:441:6: warning: symbol 'sil_sata_cmd_flush_cache_ext' was not declared. Should it be static?
sata_sil.c:489:7: warning: symbol 'sata_read' was not declared. Should it be static?
sata_sil.c:505:7: warning: symbol 'sata_write' was not declared. Should it be static?
sata_sil.c:526:5: warning: symbol 'init_sata' was not declared. Should it be static?
sata_sil.c:588:5: warning: symbol 'scan_sata' was not declared. Should it be static?
fsl_sata.c:59:6: warning: symbol 'dprint_buffer' was not declared. Should it be static?
fsl_sata.c:187:42: warning: incorrect type in assignment (different base types)
fsl_sata.c:187:42: expected unsigned int [unsigned] [usertype] cda
fsl_sata.c:187:42: got restricted __le32 [usertype] <noident>
fsl_sata.c:291:6: warning: symbol 'fsl_sata_hardware_reset' was not declared. Should it be static?
fsl_sata.c:418:27: warning: incorrect type in assignment (different base types)
fsl_sata.c:418:27: expected unsigned int [unsigned] [usertype] dba
fsl_sata.c:418:27: got restricted __le32 [usertype] <noident>
fsl_sata.c:424:41: warning: incorrect type in assignment (different base types)
fsl_sata.c:424:41: expected unsigned int [unsigned] [usertype] ext_c_ddc
fsl_sata.c:424:41: got restricted __le32 [usertype] <noident>
fsl_sata.c:431:41: warning: incorrect type in assignment (different base types)
fsl_sata.c:431:41: expected unsigned int [unsigned] [usertype] ext_c_ddc
fsl_sata.c:431:41: got restricted __le32 [usertype] <noident>
fsl_sata.c:442:22: warning: incorrect type in assignment (different base types)
fsl_sata.c:442:22: expected unsigned int [unsigned] [usertype] cda
fsl_sata.c:442:22: got restricted __le32 [usertype] <noident>
fsl_sata.c:446:31: warning: incorrect type in assignment (different base types)
fsl_sata.c:446:31: expected unsigned int [unsigned] [usertype] prde_fis_len
fsl_sata.c:446:31: got restricted __le32 [usertype] <noident>
fsl_sata.c:448:22: warning: incorrect type in assignment (different base types)
fsl_sata.c:448:22: expected unsigned int [unsigned] [usertype] ttl
fsl_sata.c:448:22: got restricted __le32 [usertype] <noident>
fsl_sata.c:460:28: warning: incorrect type in assignment (different base types)
fsl_sata.c:460:28: expected unsigned int [unsigned] [usertype] attribute
fsl_sata.c:460:28: got restricted __le32 [usertype] <noident>
fsl_sata.c:623:6: warning: symbol 'fsl_sata_flush_cache' was not declared. Should it be static?
fsl_sata.c:667:5: warning: symbol 'fsl_sata_rw_ncq_cmd' was not declared. Should it be static?
fsl_sata.c:710:6: warning: symbol 'fsl_sata_flush_cache_ext' was not declared. Should it be static?
fsl_sata.c:725:6: warning: symbol 'fsl_sata_software_reset' was not declared. Should it be static?
fsl_sata.c:760:5: warning: symbol 'ata_low_level_rw_lba48' was not declared. Should it be static?
fsl_sata.c:795:5: warning: symbol 'ata_low_level_rw_lba28' was not declared. Should it be static?
the following compiler warnings show up after fixing the above, so
remove those three functions:
fsl_sata.c:59:13: warning: 'dprint_buffer' defined but not used [-Wunused-function]
fsl_sata.c:291:13: warning: 'fsl_sata_hardware_reset' defined but not used [-Wunused-function]
fsl_sata.c:726:13: warning: 'fsl_sata_software_reset' defined but not used [-Wunused-function]
Other than that, the following are fixed by __iomem annotation:
fsl_sata.c:84:39: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:84:39: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:84:39: got unsigned int volatile *addr
fsl_sata.c:172:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:172:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:172:26: got unsigned int *<noident>
fsl_sata.c:175:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:175:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:175:19: got unsigned int *<noident>
fsl_sata.c:181:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:181:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:181:19: got unsigned int *<noident>
fsl_sata.c:184:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:184:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:184:26: got unsigned int *<noident>
fsl_sata.c:186:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:186:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:186:19: got unsigned int *<noident>
fsl_sata.c:189:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:189:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:189:26: got unsigned int *<noident>
fsl_sata.c:191:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:191:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:191:19: got unsigned int *<noident>
fsl_sata.c:194:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:194:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:194:26: got unsigned int *<noident>
fsl_sata.c:195:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:195:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:195:19: got unsigned int *<noident>
fsl_sata.c:198:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:198:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:198:19: got unsigned int *<noident>
fsl_sata.c:201:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:201:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:201:19: got unsigned int *<noident>
fsl_sata.c:204:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:204:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:204:26: got unsigned int *<noident>
fsl_sata.c:205:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:205:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:205:19: got unsigned int *<noident>
fsl_sata.c:208:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:208:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:208:26: got unsigned int *<noident>
fsl_sata.c:209:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:209:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:209:19: got unsigned int *<noident>
fsl_sata.c:212:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:212:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:212:26: got unsigned int *<noident>
fsl_sata.c:213:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:213:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:213:19: got unsigned int *<noident>
fsl_sata.c:216:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:216:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:216:19: got unsigned int *<noident>
fsl_sata.c:219:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:219:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:219:19: got unsigned int *<noident>
fsl_sata.c:222:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:222:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:222:19: got unsigned int *<noident>
fsl_sata.c:225:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:225:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:225:26: got unsigned int *<noident>
fsl_sata.c:227:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:227:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:227:19: got unsigned int *<noident>
fsl_sata.c:242:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:242:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:242:26: got unsigned int *<noident>
fsl_sata.c:256:32: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:256:32: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:256:32: got unsigned int *<noident>
fsl_sata.c:262:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:262:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:262:26: got unsigned int *<noident>
fsl_sata.c:274:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:274:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:274:53: got unsigned int *<noident>
fsl_sata.c:275:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:275:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:275:53: got unsigned int *<noident>
fsl_sata.c:276:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:276:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:276:53: got unsigned int *<noident>
fsl_sata.c:277:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:277:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:277:53: got unsigned int *<noident>
fsl_sata.c:278:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:278:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:278:53: got unsigned int *<noident>
fsl_sata.c:279:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:279:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:279:53: got unsigned int *<noident>
fsl_sata.c:280:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:280:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:280:53: got unsigned int *<noident>
fsl_sata.c:281:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:281:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:281:53: got unsigned int *<noident>
fsl_sata.c:282:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:282:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:282:53: got unsigned int *<noident>
fsl_sata.c:283:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:283:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:283:53: got unsigned int *<noident>
fsl_sata.c:284:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:284:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:284:53: got unsigned int *<noident>
fsl_sata.c:285:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:285:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:285:53: got unsigned int *<noident>
fsl_sata.c:286:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:286:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:286:53: got unsigned int *<noident>
fsl_sata.c:287:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:287:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:287:53: got unsigned int *<noident>
fsl_sata.c:288:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:288:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:288:53: got unsigned int *<noident>
fsl_sata.c:289:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:289:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:289:53: got unsigned int *<noident>
fsl_sata.c:290:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:290:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:290:53: got unsigned int *<noident>
fsl_sata.c:291:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:291:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:291:53: got unsigned int *<noident>
fsl_sata.c:292:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:292:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:292:53: got unsigned int *<noident>
fsl_sata.c:293:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:293:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:293:53: got unsigned int *<noident>
fsl_sata.c:294:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:294:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:294:53: got unsigned int *<noident>
fsl_sata.c:295:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:295:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:295:53: got unsigned int *<noident>
fsl_sata.c:296:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:296:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:296:53: got unsigned int *<noident>
fsl_sata.c:297:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:297:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:297:53: got unsigned int *<noident>
fsl_sata.c:298:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:298:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:298:53: got unsigned int *<noident>
fdt.c:91:78: warning: Using plain integer as NULL pointer
fdt.c:103:78: warning: Using plain integer as NULL pointer
speed.c:55:11: warning: symbol 'corecnf_tab' was not declared. Should it be static?
speed.c:519:5: warning: symbol 'do_clocks' was not declared. Should it be static?
mpc8313erdb.c:73:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:74:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:75:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:76:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:79:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:80:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:81:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:82:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:85:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:86:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:87:17: warning: obsolete struct initializer, use C99 syntax
mpc8313erdb.c:88:17: warning: obsolete struct initializer, use C99 syntax
fsl_corenet_serdes.c:485:6: warning: symbol '__soc_serdes_init' was not declared. Should it be static?
cpu_init.c:185:6: warning: symbol 'invalidate_cpc' was not declared. Should it be static?
bcsr.c:28:27: warning: non-ANSI function declaration of function 'enable_8568mds_duart'
bcsr.c:39:33: warning: non-ANSI function declaration of function 'enable_8568mds_flash_write'
bcsr.c:46:34: warning: non-ANSI function declaration of function 'disable_8568mds_flash_write'
bcsr.c:53:29: warning: non-ANSI function declaration of function 'enable_8568mds_qe_mdio'
bcsr.c:28:33: warning: non-ANSI function declaration of function 'enable_8569mds_flash_write'
bcsr.c:33:34: warning: non-ANSI function declaration of function 'disable_8569mds_flash_write'
bcsr.c:38:28: warning: non-ANSI function declaration of function 'enable_8569mds_qe_uec'
bcsr.c:63:47: warning: non-ANSI function declaration of function 'disable_8569mds_brd_eeprom_write_protect'
ngpixis.c:245:1: error: directive in argument list
ngpixis.c:247:1: error: directive in argument list
ctrl_regs.c:31:5: warning: symbol 'fsl_ddr_get_version' was not declared. Should it be static?
cpu.c:135:14: warning: non-ANSI function declaration of function 'cpu_mask'
cpu.c:154:18: warning: non-ANSI function declaration of function 'cpu_numcores'
cpu.c:37:17: warning: symbol 'cpu_type_list' was not declared. Should it be static?
cpu.c:117:17: warning: symbol 'cpu_type_unknown' was not declared. Should it be static?
fsl_lbc.c:14:6: warning: symbol '__lbc_sdram_init' was not declared. Should it be static?
and:
lc_common_dimm_params.c:15:1: warning: symbol 'compute_cas_latency_ddr3' was not declared. Should it be static?
making it static produces the following compiler warning:
lc_common_dimm_params.c:15:1: warning: 'compute_cas_latency_ddr3' defined but not used [-Wunused-function]
so we protect it with the preprocessor.
vsprintf.c:31:12: warning: symbol 'hex_asc' was not declared. Should it be static?
vsprintf.c:398:18: warning: Using plain integer as NULL pointer
define Z_NULL to (void *)0 include/u-boot/zlib.h to get rid of most of
the NULL pointer warnings.
inflate.c:942:1: warning: non-ANSI definition of function 'inflateEnd'
inflate.c:9:1: warning: non-ANSI definition of function 'inflateReset'
inflate.c:12:17: warning: Using plain integer as NULL pointer
inflate.c:12:42: warning: Using plain integer as NULL pointer
inflate.c:15:17: warning: Using plain integer as NULL pointer
inflate.c:21:19: warning: Using plain integer as NULL pointer
inflate.c:35:1: warning: non-ANSI definition of function 'inflateInit2_'
inflate.c:38:20: warning: Using plain integer as NULL pointer
inflate.c:41:17: warning: Using plain integer as NULL pointer
inflate.c:42:17: warning: Using plain integer as NULL pointer
inflate.c:50:18: warning: Using plain integer as NULL pointer
inflate.c:65:23: warning: Using plain integer as NULL pointer
inflate.c:69:21: warning: Using plain integer as NULL pointer
inflate.c:78:1: warning: non-ANSI definition of function 'inflateInit_'
inflate.c:86:1: warning: non-ANSI definition of function 'fixedtables'
inflate.c:108:26: warning: Using plain integer as NULL pointer
inflate.c:109:1: warning: non-ANSI definition of function 'updatewindow'
inflate.c:112:30: warning: Using plain integer as NULL pointer
inflate.c:339:1: warning: non-ANSI definition of function 'inflate'
inflate.c:349:17: warning: Using plain integer as NULL pointer
inflate.c:349:42: warning: Using plain integer as NULL pointer
inflate.c:350:27: warning: Using plain integer as NULL pointer
inflate.c:369:42: warning: Using plain integer as NULL pointer
inflate.c:376:32: warning: Using plain integer as NULL pointer
inflate.c:401:54: warning: Using plain integer as NULL pointer
inflate.c:419:32: warning: Using plain integer as NULL pointer
inflate.c:426:32: warning: Using plain integer as NULL pointer
inflate.c:433:32: warning: Using plain integer as NULL pointer
inflate.c:444:36: warning: Using plain integer as NULL pointer
inflate.c:449:37: warning: Using plain integer as NULL pointer
inflate.c:450:38: warning: Using plain integer as NULL pointer
inflate.c:457:40: warning: Using plain integer as NULL pointer
inflate.c:458:47: warning: Using plain integer as NULL pointer
inflate.c:480:40: warning: Using plain integer as NULL pointer
inflate.c:481:50: warning: Using plain integer as NULL pointer
inflate.c:491:37: warning: Using plain integer as NULL pointer
inflate.c:492:37: warning: Using plain integer as NULL pointer
inflate.c:501:40: warning: Using plain integer as NULL pointer
inflate.c:502:53: warning: Using plain integer as NULL pointer
inflate.c:512:37: warning: Using plain integer as NULL pointer
inflate.c:513:40: warning: Using plain integer as NULL pointer
inflate.c:525:32: warning: Using plain integer as NULL pointer
inflate.c:529:52: warning: Using plain integer as NULL pointer
inflate.c:543:54: warning: Using plain integer as NULL pointer
inflate.c:932:17: warning: Using plain integer as NULL pointer
inflate.c:932:42: warning: Using plain integer as NULL pointer
inflate.c:935:26: warning: Using plain integer as NULL pointer
inflate.c:940:19: warning: Using plain integer as NULL pointer
adler32.c:58:5: warning: non-ANSI definition of function 'adler32'
adler32.c:81:16: warning: Using plain integer as NULL pointer
zutil.c:53:9: warning: non-ANSI definition of function 'zcalloc'
zutil.c:64:9: warning: non-ANSI definition of function 'zcfree'
inffast.c:70:1: warning: non-ANSI definition of function 'inflate_fast'
inftrees.c:33:1: warning: non-ANSI definition of function 'inflate_table'
