2007-07-10 | board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols. | Jon Loeliger | |
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too. Those always evaluated TRUE, and thus were always compiled even when IDE really wasn't defined/wanted. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-10 | cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols. | Jon Loeliger | |
2007-07-10 | include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h used to be included but CONFIG_BOOTP_MASK was not defined. Remove lingering references to CFG_CMD_* symbols. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-10 | include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
2007-07-10 | include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
2007-07-10 | include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
2007-07-10 | include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
2007-07-10 | include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*. | Jon Loeliger | |
2007-07-09 | Finally retire cmd_confdefs.h and CONFIG_BOOTP_MASK! | Jon Loeliger | |
All of the choices for CONFIG_BOOTP_ are now documented in the README file. You must now individually select exactly the set that you want using a series of #define CONFIG_BOOTP_<x> statements in the board port config files now. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-09 | include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
CONFIG_BOOTP_MASK. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-09 | include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
2007-07-09 | include/configs/[T-Z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
2007-07-09 | include/configs/[P-S]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
2007-07-09 | include/configs/[H-N]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
2007-07-09 | include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵ | Jon Loeliger | |
2007-07-09 | Retire CONFIG_COMMANDS finally. | Jon Loeliger | |
Strip old CFG_CMD_* symbols out. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-09 | Update README.* to reference new CONFIG_CMD_* names now. | Jon Loeliger | |
2007-07-09 | cpu/m*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | cpu/[7a-ln-z]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | board/[q-z]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | board/[m-p]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | board/[f-l]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | board/[d-e]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | rtc/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵ | Jon Loeliger | |
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-09 | lib_{m68k,microblaze,mips,ppc}/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | fs/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | tools/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | net/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | drivers/[n-z]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | drivers/[a-m]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | disk/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-09 | include/: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-08 | common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
2007-07-08 | common/cmd_[p-x]*: Remove obsolete references to CONFIG_COMMANDS. | Jon Loeliger | |
2007-07-08 | common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS. | Jon Loeliger | |
2007-07-08 | common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS. | Jon Loeliger | |
2007-07-08 | Clear up confusion over the CMD_POST and POST_DIAG mess. | Jon Loeliger | |
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-08 | Remove references to the old cmd_confdefs.h include file. | Jon Loeliger | |
2007-07-08 | include/configs: Catch some CONFIG_CMD_* conversion stragglers. | Jon Loeliger | |
Use new CONFIG_CMD_* in lwmon5.h board config file. Fix CONFIG_CMD_* typo braindamage in omap1510inn.h Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various [TUVWZYZ]* named board ↵ | Jon Loeliger | |
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various S* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various R* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various Q* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various P* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various [NO]* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various M* named board config files. | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various [IJKL]* named board config ↵ | Jon Loeliger | |
2007-07-08 | include/configs: Use new CONFIG_CMD_* in various H* named board config files. | Jon Loeliger | |
